How to correctly download a new version of NodeMCU for ESP32 ?
TvWidget 675 2
  • #1 19589020
    TvWidget
    Help: 472
    Rate: 697
    A new version of NodeMCU has been released https://nodemcu.readthedocs.io/en/dev-esp32-idf4/build/.
    I tried to download it by following the description on the page provided. However, this physically found on the disk is an older version for IDF3 and should be https://github.com/nodemcu/nodemcu-firmware/tree/dev-esp32-idf4
    I don't know what is causing this.
  • #2 19589586
    mpier
    Help: 153
    Rate: 141
    maybe the cause is downloading dev-esp32 instead of dev-esp32-idf4? Do clone dev-esp32-idf4 or in the downloaded sources directory "git checkout dev-esp32-idf4".
    Greetings.
  • #3 19589602
    TvWidget
    Help: 472
    Rate: 697
    I also thought of this idea and it solved the problem.
