Thermoelectric generator for uncertain times
Adaś Niezgódka 59580 65
  • A thermoelectric generator built from a 12V/60W Peltier cell uses heat instead of electricity to produce power.
  • A candle heats one side of the cell, reversing the normal Peltier effect and feeding a HW 105 step-up module.
  • With about 100 °C temperature difference, the setup produced 3 V and could start boosting from 0.9 V.
  • The boosted output can charge a phone and light a room, but the recovered power is only about 5% of the cell’s rated electrical power.
📢 Listen (AI voice):
  • #31 19896130
    puchalak
    Help: 12
    Rate: 229
    Frenzy with performance is not there. I wonder what the efficiency would be if instead of the burner, we put a tourist gas lamp (one with Auer's T-shirt) on the gas canister and illuminate the spherically located photovoltaic cells around it.
  • #32 19896489
    krzbor
    Help: 42
    Rate: 1072
    The goal should be to reach 3 W. With this power, the inverter will be 5 V and 500 mA, so we have a standard USB power supply. Almost all USB devices should work with this voltage and current.
  • TEC1-12706 power and cooling performance details
    #33 19898329
    slavo666
    Help: 37
    Rate: 390
    Not bad. When making a "chimney" covered with four or five such modules with heat sinks, it should be possible to get these few W passively.
    Now for some details about the TEC1-12706
    It is a normal coincidence that I have such an element in use.
    Power supply 12 V - current 2.8 A, power 33 W.
    The power given by the manufacturer / seller is 60 W, which is available with a power supply of about 15 V. How is the efficiency of such an element as a cooling one, another story.
    When it comes to cooling, these modules are great. I got -40 degrees, as I remember correctly, and thanks to this one plate I was able to successfully create a small Wilson chamber for observing the passage of alpha and other particles in alcohol vapors.
  • Fire-powered thermoelectric generator could scale to watts
    #34 19899402
    alikatek
    Help: 83
    Rate: 380
    As for me, a big round of applause for the author for building a working device from practically only waste. We should also thank you for reminding all of us that there is a possibility of getting a small amount of power from a candle or other heat source.
    If the proverbial W hour came, more than one could be cut for even a little bit of electricity. Obtaining the power of 1-2 W from the candle itself is in practice sufficient for the operation of a battery-operated radio (the power consumption of which is in the range of fractions of a watt), charging the phone, charging the powerbank or illuminating the ordinary white 1 W diode, which will give more light than the candle itself.
    I would go further with it, because the device can actually save the proverbial butt. Mainly due to the fact that thermal energy can be obtained from burning various things, not necessarily candles or cartridges for camping stoves. Nothing prevents you from starting a fire in a metal cuboid and placing several cells on the walls, thereby increasing the power.
  • #35 19899511
    Krzysztof Kamienski
    Help: 2033
    Rate: 5165
    @alikatek It's during a nuclear winter, right? Or maybe a manual generator to charge the battery instead of being cut? :D
  • #36 19899774
  • #37 19899964
    puchalak
    Help: 12
    Rate: 229
    But fire does not just make of itself. It is made of one or another fuel and oxygen. It is not known what is more valuable. If you can squeeze 500 W on a trainer (i.e. a stationary bike), then in a minute you will produce as much as such a link for over 4 hours. The question of storage - more supercapacitors than batteries.
  • #38 19900001
    Grendel
    Help: 35
    Rate: 244
    Just to get that kind of performance you have to be built like this GUY although you can see that he almost spat his lungs out, although it generated only 21 Wh. :)
  • #39 19900026
    puchalak
    Help: 12
    Rate: 229
    :D
    Okay, the crumbs can squeeze 125W each for a minute. It's still over an hour of smoking. :D
  • Fuel-agnostic thermoelectric generator advantages
    #40 19900108
    alikatek
    Help: 83
    Rate: 380
    In my can save your butt I meant more that such a generator can be powered by any fuel. A candle, a burner, a lighter, kerosene, an oil lamp, paraffin cubes to light the grill, or wood fuel. The versatility of this device deserves the greatest respect. And of course, maintenance-free. You light a fire and do something else and the phone is charging or the lamp under the ceiling is on.
    It is known that with a manual generator or a converted bicycle you will achieve much more power, but for this you have to invest your time and energy. After all, by turning the manual generator you will not be able to chop wood for firewood at the same time.
  • #41 19900183
    puchalak
    Help: 12
    Rate: 229
    To charge the phone, with this power, the lamp will have to be on for about 8 hours. What kind of material do you know that will burn for so long without maintenance?
  • #43 19902614
    H3nry
    Level 32  
    Help: 165
    Rate: 289
    Do not overdo it, Camp Stove V2 is a very interesting item on our market, available on promotion here: Link
    The price for this product is an exaggeration: Link
  • #44 19902865
    Grendel
    Help: 35
    Rate: 244
    The latter is also an exaggeration, and quite a lot of it.
  • Tealights and oil lamps as long-burning heat sources
    #45 19903205
    alikatek
    Help: 83
    Rate: 380
    There are commercially available tealights with a burning time of 3, 5, 8 and even 10 hours. While burning, the candle has a flame that is at a relatively similar height all the time. That's why I know, because I use such candles to heat a tea pot or to create a romantic mood.
    It can therefore be said that they burn practically maintenance-free for the time declared by the manufacturer. On the manufacturer's website you can see the offer:
    Link
    A kerosene lamp, a spirit burner or an oil lamp after flooding with fuel will also burn for a very long time, giving the flame all the time at a similar height with similar intensity. It is also a virtually maintenance-free heat source.
  • #46 19909064
    PPK
    Level 30  
    Help: 94
    Rate: 427
    40 years ago, at a training ground in Russia (USSR), Russian commandos had such an attachment for a fire - a dense mesh with leads for two heat-resistant wires. Size ca '40x40 cm. It gave 6V and 0.5A ... They charged the batteries for the radio ...
  • Mentions magnetohydrodynamic and optical rectenna alternatives
    #47 19932541
    kamil3211
    Rate: 57
    There is also such a thing as a magnetohydrodynamic generator. Here, perhaps, thermal energy is immediately converted into electricity. And in a thermoelectric generator you need a temperature difference.
    In the future, perhaps energy from the sun will be obtained from the optical rector https://en.wikipedia.org/wiki/Optical_rectenna. It is also such an alternative to photovoltaic panels.
    I guess there are no better ones.
    There is also such a thing as an airfoil. Here you can probably also reverse it so that it produces electricity. And even if not, the vision of aircraft engines without moving parts is interesting (such an alternative to mhd drive).
  • #48 19932555
    Krzysztof Kamienski
    Help: 2033
    Rate: 5165
    kamil3211 wrote:
    magnetohydrodynamic. Here, perhaps, thermal energy is immediately converted into electricity.
    Not. In such a generator, the role of the generator rotor is played by a liquid or gaseous (ionized) medium moving in a magnetic field.
  • #49 19932595
    kamil3211
    Rate: 57
    Such an air conditioning that produces electricity? :)
  • #50 19932618
    Krzysztof Kamienski
    Help: 2033
    Rate: 5165
    @ kamil32112 Learn a little bit, instead of producing complete phantasmagories here :sm31:
  • #51 19933862
    Pinecha
    Rate: 45
    In the movie "On the White Trail" they use a kerosene lamp generator to power the radio. I believe they were thermocouples.
  • #52 19956386
    Andrzej42
    Level 32  
    Help: 178
    Rate: 322
    But remember that Peltier cells do not "like" too high temperatures (probably around 100 ° C) because they will desolder. Besides, as it is based on a semiconductor, it doesn't "like" temperatures above, say, 150 ° C.
  • Thermoelectric generators need high-temperature-rated soldering
    #53 19956551
    stachu_l
    Help: 480
    Rate: 1129
    Normal ones for cooling withstand over 100 ° C, but those for generators have a given warm surface temperature of up to 320 ° C, but during this time the cold side should be below 180 ° C.
    https://customthermoelectric.com/media/wysiwy...sheets/2411G-7L31-15CX1_20140508_spec_sht.pdf
    They are probably soldered with something other than tin - maybe silver - they are much more expensive than those "normal", common, that is intended for cooling.
    These semiconductors are not germanium or silicon and last much longer.
  • #54 20180568
    skyinn
    Question for experts: 1 peltier produces a maximum of 6 A and 4.8 V, how much electricity will it produce if I connect 10 of these? I would have 24 hours of energy at the stove.
  • #55 20180664
    stachu_l
    Help: 480
    Rate: 1129
    skyinn wrote:
    how much electricity will be produced if I connect 10 of these?
    How do you combine them?
    As in series, it is 0.6A 48V, and in parallel, it is 6A 4.8V, assuming the same operating parameters in both cases - temperature of the hot and cold side of each cell.
  • Copper oxide wafer idea to increase thermal resistance
    #56 20486161
    bambus94
    Help: 245
    Rate: 716
    Is new old idea.
    Thermoelectric cell based on copper and copper oxide. So, in fact, you can build them from a few pieces of copper wire, like the man here:
    http://sparkbangbuzz.com/copper-oxide-te/copper-oxide-gen3.htm
    You could try to make such a generator from a few copper heat sinks and a few thin plates. This will increase the surface area of the joint and heat dissipation.
    This sentence is interesting:
    Copper oxide however, also acts like a thermistor with a very high negative temperature coefficient.
    I wonder if it would be possible to do such an action that copper oxide would be pressed into a thin wafer and put between two pieces of copper. Then we are sure that there will be no copper-copper contact and at the same time the thermal resistance of the joint should increase, which should increase Δt.
    Movie:
  • Copper oxide suggested as thermoelectric material
    #57 20486363
    Staszek_Staszek
    Help: 116
    Rate: 846
    A thermocouple on copper will have a fairly low efficiency. Copper has a high thermal conductivity, heat will quickly escape from the hot side to the cold side. The ratio of electrical conductivity to thermal conductivity determines the efficiency of the system. However, copper oxide Cu O can be used except that the second electrode should be of a material other than copper. It will not be a metal, but rather a semiconductor.
  • Cuprite semiconductor suggested instead of copper electrode
    #58 20486500
    bambus94
    Help: 245
    Rate: 716
    Staszek_Staszek wrote:
    Heat will quickly escape from the hot side to the cold side
    That's why I wrote about the possible pressing of copper oxide into a wafer to increase thermal resistance
    Have you read the website and seen the video? It works, made of only copper wires.
    They used to build cuprite rectifiers, maybe the Peltier phenomenon is happening here too, not Seebec. But cuprite rectifiers lost their properties when heated, so probably not.
  • Copper heat loss makes the generator impractical
    #59 20486556
    Staszek_Staszek
    Help: 116
    Rate: 846
    It works but with low efficiency. This can be calculated for a copper electrode. I do not know the thermal conductivity of copper oxide. Since it has been used to build diodes since 1924, I would probably find this data. However, the heat loss through the copper electrode disqualifies this system for practical applications anyway.
  • #60 20491663
    cranky
    Level 30  
    Help: 70
    Rate: 407
    It occurred to me that cooling systems from a laptop could be used for cooling. Maybe the efficiency could be improved, and the elements are free, easily available and ... terribly unsightly.
✨ The discussion revolves around the use of Peltier cells as thermoelectric generators, particularly in uncertain times when alternative power sources may be needed. The original poster shares their experiments with a 12V/60W Peltier cell, exploring its potential to generate electricity from thermal energy. Responses highlight historical applications of thermoelectric generators, such as those used in WWII and space probes, and suggest improvements for efficiency, including using water cooling and optimizing heat sinks. Participants debate the practicality of using Peltier cells versus traditional thermocouples and discuss various configurations and materials to enhance performance. The conversation also touches on the feasibility of using these devices for emergency power needs, such as charging phones during outages.
TL;DR: A single TEC1-12706 Peltier module produced 2.25 W at a 110 °C temperature difference [Elektroda, Adaś Niezgódka, post #19895886]; "The goal should be to reach 3 W" [Elektroda, krzbor, post #19896489] Simple heat-to-USB rigs work yet stay <5 % efficient. Why it matters: small thermoelectric setups give emergency phone charging from any flame.
• Open-circuit voltage: 4.7 V @ ΔT ≈ 110 °C [Elektroda, Adaś Niezgódka, post #19895886] • Peak output: 2.25 W with 2–3 Ω load [Elektroda, 19895886] • Hot-side limit for TEG-grade cells: 320 °C, cold ≤ 180 °C [Custom Thermoelectric, 2014] • Candle-lamp generators ship at 4.5 W, 12 V DC [Elektroda, mmm777, post #19894788] • TEC1-12706 cooling rating: 60 W input @ 15 V, 6 A (datasheet)
What efficiency should I expect?
Measured electrical output (2.25 W) versus estimated candle heat (~50 W) gives ≈4.5 % efficiency. Lab figures for cooling-grade modules rarely exceed 5 % in generator mode [Elektroda, Krzysztof Kamienski, post #19892428]
Will a 48 V string destroy 15 V-rated cells?
No. In generator mode each cell produces only a few volts, so series voltage adds without reverse biasing any element. Maximum temperature, not voltage, is the failure limit [Elektroda, stachu_l, post #20980498]
What temperatures are safe for Peltier modules?
Cooling-grade cells tolerate roughly 100 – 150 °C hot-side before solder joints fail [Elektroda, Andrzej42, post #19956386] TEG-grade parts use high-temp alloys and survive up to 320 °C hot-side [Custom Thermoelectric, 2014].
Are TEG-labelled modules from China more efficient?
True TEG modules use Bi₂Te₃ legs optimised for generation and give 10–15 % higher Seebeck coefficient than cooling versions. Some sellers relabel cooling cells, so check for ≥200 °C rating and datasheet curve before buying [Elektroda, Gadon2012, post #19892786]
How should I connect several modules?
  1. Wire modules in series until open-circuit voltage exceeds your DC-DC start-up level (≥1 V).
  2. Keep load resistance near the sum of individual 2–3 Ω optimums.
  3. Isolate hot plates with a copper block and cool the other side with a fin or water loop. This balances currents and maximises power [Elektroda, Anonymous, post #19892476]
What’s an edge-case failure to watch?
Exceeding 150 °C can melt internal solder and short the couples, dropping voltage to zero even after cooling [Elektroda, Andrzej42, post #19956386]
Simple three-step build?
  1. Sandwich a TEC1-12706 between a copper candle plate and an aluminium CPU heatsink with thermal paste.
  2. Light a tea-light under the plate; attach a small fan to the heatsink.
  3. Feed the output through a HW-105 boost to a USB socket. Users reported phone charging within minutes [Elektroda, 19892224]
How many modules for 30 W?
Commercial stoves delivering 30 W use 6–8 high-grade TEGs at ΔT≈250 °C [Powerspot, Explorer-Home]. DIY would require roughly 12 TEC1-12706 units plus aggressive cooling [Elektroda, H3nry, post #19894819]
Any alternative emergency generators?
Hand-crank dynamos yield 5 – 10 W, but need effort. A cyclist can generate 21 Wh in two minutes of sprinting [YouTube, "Guy vs. Bike Dynamo"]. Photovoltaic panels provide higher daily Wh if sunlight is available [Elektroda, puchalak, post #19895018]
