LED WiFi RGBCW Tuya - teardown, BK7231N, programming with my Tasmota replacement
p.kaczmarek2 23217 9
  • A Tuya E27 RGBCW smart LED bulb based on BK7231N is torn down, flashed with an OpenBK7231T/Tasmota replacement, and integrated with Home Assistant.
  • The bulb uses a sparkleiot XH-0068A WiFi module, UART programming at 3.3V, and five PWM channels for red, green, blue, cool white, and warm white.
  • The bulb cost about $10, is rated 12W, and the measured standby power was 0.5W.
  • After flashing, an open WiFi network appeared, configuration worked at 192.168.4.1, and color, dimming, and CW/WW control were supported.
  • Despite the 12W claim, the lamp never exceeded just over 6W because the LED supply and current limiting stage capped output.
  • LED WiFi RGBCW Tuya - teardown, BK7231N, programming with my Tasmota replacement
    Hello all, it's time to flash another BK7231N device with my Tasmota clone and pair it with my Home Assistant.
    This time it will be a smart LED bulb by Tuya, offering a wide range of colors, RGB and cold and warm white. 12W, E27. I will start with a teardown, then I will show how to hook up USB to UART programmer and finally I will also check its power consumption in standby mode and during operation. For more information related to the used firmware itself, see the main OpenBK7231T topic - OpenBK7231T . Will it really be 12W? Let's check.
    IMPORTANT UPDATE
    Please scroll down to post #5 in order to see new configuration details with Home Assistant. Now everything is supported, RGB mode, CW mode, dimming.
    Purchase of bulbs
    I found the bulb under the keyword "Tuya Wifi Smart Life Light Bulb Lamp E27 LED RGBCW Dimmable For Alexa / Google 18W", but I chose the 12W version. I paid about 10$.
    RGBCW here means Red Green Blue Cool Warm, i.e. the available colors - red, green, blue, cold (white), warm (white).
    This 'light bulb' requires only access to our home WiFi and Tuya application - you do not need any hub or gate.
    In addition to the entire range of colors, the bulb offers Tuya automations (timers, scenarios, etc.) and various colorful animations, also following the rhythm of the music.
    Naturally, we also have control over its brightness:
    Test with the manufacturer's application
    First, I tested the bulb with the Tuya application, without changing the firmware.
    Pairing is very easy. My iPhone detected the new device immediately, the light was blinking in pairing mode after first connected:
    LED WiFi RGBCW Tuya - teardown, BK7231N, programming with my Tasmota replacement LED WiFi RGBCW Tuya - teardown, BK7231N, programming with my Tasmota replacement LED WiFi RGBCW Tuya - teardown, BK7231N, programming with my Tasmota replacement LED WiFi RGBCW Tuya - teardown, BK7231N, programming with my Tasmota replacement LED WiFi RGBCW Tuya - teardown, BK7231N, programming with my Tasmota replacement LED WiFi RGBCW Tuya - teardown, BK7231N, programming with my Tasmota replacement
    No problems. This is what the color and brightness controls look like:
    The colors are expressive and bright. But you know, the Tuya application and its cloud do not interest us so much, so it's time to peek inside ...
    The interior of the bulb
    Getting inside turned out to be very easy. I just managed to remove the plastic, milky dome with my bare hands, making a slight twisting motion.
    Let's see when which LEDs are lit:
    The glue can be removed easily with a knife. It is enough to lift the PCB with LEDs. It is not bolted to the rest of the bulb base. I hope it won't heat up excessively, but it's only supposed to be 12W.
    The WiFi module inside is based on the BK7231N:
    It's time to get the whole module out. If we just want to program the BK7231N it may not be necessary if we can fit the soldering iron to its RX / TX pads. In any case, only one power cord is soldered, the other is only hooked onto the thread:
    Let's look at the electronics from inside:
    At the input we have a fuse resistor (RF1 - Resistor Fusible 1?), A full bridge rectifierMB6S, then there are places for additional capacitors and a choke (creating a Pi filter?), In addition, there is one electrolytic capacitor for 400V and a controller for the 802X A0KH converter, which, more precisely, does not I analyzed, although I can see, among others there a 1R0 resistor (i.e. one ohm), on which the converter can measure the current (the shunt resistor). ES2JF is an ultrafast diode there, maybe from a snubber from the inverter? The F7 (FR107) diodes in the SOD-123 next to it are also fast. The element marked on the U2 board (the marking on the element is illegible) is probably the LDO regulator providing 3.3V for the WiFi module. Color switching transistors (there are five of them - one per channel R, G, B, W, C) are marked with N81Z, at the moment I have not found their catalog note ( if someone finds it, please comment ), but I must admit that in this topic I was more focused on the programming aspect of this 'light bulb', which will be discussed in a moment.
    The WiFi module itself is XH-0068A by sparkleiot com based on BK7231N:
    The signals P0 and P1 as well as TXD and RXD are seen here. P0 and P1 is actually a UART too, but not for programming, but only a debug log output:
    However, only TXD and RXD will be useful for programming. Possibly also RST (but we can reset by cutting off the power).
    The photos also show what signals come from the WiFi module to the PCB - among others. P7, P8, P9, P6, P24. PWM pins...
    Programming of the BK7231N
    To program the BK7231N, we need to connect an external power supply (disconnect the product from the mains, of course), preferably 3.3V via some own LDO (I used TC1264-3.3), because 5V would damage the WiFi module and connect the UART converter to the TX and RX pins of the BK7231N.
    Power connection:
    RX and TX connection. Soldering can be tricky. I used flux and first added some solder on wires and pads, and then soldered wires to the pads:
    Power section and connection on the breadboard (3.3V connection is prepared in such a way so it's easy to disconnect it in order to force the system reboot).
    Only Python programmer works for BK7231N, BKwriter1.60 won't do it here.
    Download and install this tool:
    https://github.com/OpenBekenIOT/hid_download_py
    Prepare the firmware in the QIO version (not UA!), compile yourself or get it from here:
    Then use the command:
    python uartprogram W:\GIT\OpenBK7231N\apps\OpenBK7231N_App\output\1.0.0\OpenBK7231N_app_QIO_1.0.0.bin --unprotect -d com9 -w --startaddr 0x0
    First run the programmer with this command:
    At this stage, reboot (aka reset) the system (cut off and connect the power supply - sometimes it takes several times to get it; you can also reset with EN/RST pin):
    Success. After restarting, you should see an open WiFi network for firmware configuration:
    Connect to it and enter the configuration page at 192.168.4.1.
    In case of any problems, if DHCP does not work, set your device IP manually to something like 192.168.4.15 (static IP), reconnect to WiFi and try again:
    The roles of the pins are easy to assign - you could already see what signals go to the PCB:
    NOTE: when setting channel indexes, keep order: 1 - red, 2 - green, 3 - blue, 4 - cool white, 5 - warm white
    This is the default order used by "color" command (for MQTT as well).
    Continue configuration (MQTT etc) like in these topics (they are both in Polish and English versions):
    Garden Tuya CCWFIO232PK Double Relay - BK7231T - Programming
    Qiachip Smart Switch - BK7231N / CB2S - interior, programming
    The RGBCW (color picker) interface itself is not fully ready yet.
    When it comes to setting the color in one go, there is a "color" command, which works in the same way as in Tasmota.
    Color command syntax:
    color #RRGGBB[CW][WW]
    The color is in hex format, successive bytes corresponds to successive channels. It is enough to properly format the query on the Home Assistant side and we can set all the colors at once.
    Example of a query that sets the color red:
    color #FF0000
    If we want to know what color is what code, we can find "RGB hex color picker" on the web.
    This command can also be sent via MQTT, for example from Home Assistant.
    Can such a bulb help you save electricity?
    Let's start with the basics. Standby power consumption with lights turned off. It should be noted here that if we have a normal light switch and we turn off the light in the room, of course this consumption also disappears, but it is always just a few pennies...
    Double-checking with the second meter:
    Standby - 0.5W. Comparable with other smart products (eg Tuya, Blitzwolf sockets).
    Now the colors:
    And the most interesting - all the colors at once...
    The energy consumption (just over 6W) does not resemble the sum of the energy consumption of the individual channels. The main power supply seems to be limiting the current. So with this bulb we will never get more than 6W ...
    Dimming test:
    Dimming works ok, very practical option. It allows, for example, to reduce the power consumption to just only 2W while maintaining a certain acceptable level of lighting in the room.
    For comparison - the inside of an ordinary LED bulb
    First, the 13W bulb (nominal):
    Two burned LEDs, of course this can be fixed:
    Interior:
    MB10FH Bridge Rectifier, BP2861 Constant Current LED Controller:
    Second, 14W:
    PCB with LEDs screwed to the heat sink:
    Much better cooling, the entire housing dissipates heat here , the first one is probably 13W only written on the housing.
    Similar layout. BP2833D, surprisingly in THT.
    Other ways to control RGBCW in Tuya bulbs
    Finally, I would like to mention that in some other Tuya bulbs RGBCW control is done via the I2C interface. On the board with LEDs there is a dedicated controller (already with integrated transistors) and the BK7231N (either T or another) communicates with it via I2C. I am also going to support such dimming in the future. An example of such a controller can be SM2135:
    This, however, will be on a different topic.
    Summary
    This Tuya Smart Bulb does not deliver promised 12W, but only 6W [/b] . More power will not be squeezed out of it, because it must be limited by the LED supply system, even when I force 100% duty on all channels (R, G, B, C, W) through my own firmware. However, this is not a surprise, with such poor cooling, probably the 12W would be an overkill.
    In standby it consumes 0.5W (because the WiFi module is still working), just like other products of this type (WiFi sockets, contacts, etc.).
    Besides, it's not that bad ... I can see some potential in such a bulb. The colors are unlikely to be useful in a practical way, but e.g. changing the temperature of the light (cold for work, warm for relaxation) is already a useful feature, and the possibility of dimming (e.g. as part of energy saving or late evening) is also something that could be used on a daily basis.
    There is BK7231N inside - my firmware supports it . It's a bit of a drag to access inside, but it is still possible to do this without destroying the casing.
    I know that I have not presented the full integration here (for example, my firmware is missing a convenient, graphical color picker), but I will try to develop it futher in the upcoming updates.
    Feel free to follow:
    I wonder how long will this LED smart bulb last. Does any of the forum users use this type of smart bulbs, e.g. as an alternative to replacing light switches with the 'smart' ones, and share their experiences?
    I am attaching interesting doc about the BK7231.
    • BK7231T_COB_Hardware_Design_Guideline_Tuya_Smart_Documentation.pdf (6.07 MB) You must be logged in to download this attachment.
    • BK7231_chinese_datasheet.pdf (607.69 KB) You must be logged in to download this attachment.
    p.kaczmarek2 wrote 14580 posts with rating 12602, helped 654 times. Been with us since 2014 year.
  • #2 19939777
    ElectroTom
    Help: 43
    Rate: 203
    Thanks as always great.
  • #3 19940087
    Help: 654
    Rate: 12602
    Thanks, it would seem that this is another BK7231N, and in fact I am just introducing basic corrections to the batch so that it can function at all ...
    For example, with the product from the topic, I realized that initially PWM did not work at all on the BK7231N platform, and in turn it still works on the BK7231T, although their operation in both cases was almost identical.
    Both of these chips are similar but have two different SDKs that are slightly different ...
    After a short error search, I discovered what was wrong.
    On the BK7231N platform, use bk_pwm_initialize to start the PWM module. Otherwise it doesn't work. On the BK7231T you don't have to call it, it's enough bk_pwm_start and bk_pwm_update_param . It's obvious that you need to initialize PWM, but the operation of this on the T platform baffled me.
    Of course, the fix is already in the repository so users don't have to do it themselves:
    https://github.com/openshwprojects/OpenBK7231...mmit/c8184264f04f4654e177005b3ed0593da8fcabea
    Well, it's a lot of fun to get it all into serviceable condition, and the next IoT device reviews are on the way ....
    There are also new reports in this thread:
    https://www.elektroda.com/rtvforum/topic3866123-300.html#19920755
    e.g. this bulb with I2C (post # 322).
  • #4 19941395
    szeryf3
    Level 30  
    Help: 12
    Rate: 672
    As always, an interesting and reliable description
  • #5 19970646
    Help: 654
    Rate: 12602
    It's time for little update.
    I have prepared a new, better LED driver for compatibility with Home Assistant.
    Here is basic configuration description.
    First, I assume you have light configured and ready:
    Of course MQTT has to be set up at this point as well:
    Then go to "Generate Home Assistant Config", but do not copy whole config, you will have to modify it:
    Copy your device ID (eg. obk8D38570E) to this template:
      - platform: mqtt
        rgb_command_template: "{{ '#%02x%02x%02x0000' | format(red, green, blue)}}"
        rgb_state_topic: "cmnd/obk8D38570E/led_basecolor_rgb"
        rgb_command_topic: "cmnd/obk8D38570E/led_basecolor_rgb"
        command_topic: "cmnd/obk8D38570E/led_enableAll"
        availability_topic: "obk8D38570E/connected"
        payload_on: 1
        payload_off: 0
        brightness_command_topic: "cmnd/obk8D38570E/led_dimmer"
        brightness_scale: 100
        brightness_value_template: "{{ value_json.Dimmer }}"
        color_temp_command_topic: "cmnd/obk8D38570E/led_temperature"
        color_temp_state_topic: "cmnd/obk8D38570E/ctr"
        color_temp_value_template: "{{ value_json.CT }}"
    Add this template to Home Assistant configuration.yaml and restart your HA.
    You should get something like this:
    Click here to see hidden options:
    In color mode, you have a color picker. This is RGB only:
    In temperature mode, you get temperature slider:
    Some important notes:
    - on RGB picker, you choose only RGB values, no brightness. For brightness you have separate slider
    - brightness is remembered when toggling between RGB and temperature modes
    - disabling/enabling light does not reset your settings, so if you set color to red, and turn off and on bulb, the color is still red
    - this system behaves like one in Tuya, so there is a never a moment when all RGBCW LEDs are on. You can either have RGB leds on (at certain fractions), or CW leds on. Never all at once, just like in Tuya.
    - this system is not able to read back the value of light bulb right now (not really needed, as in general light bulbs don't have buttons to be pressed and Tuya also doesn't support it)
    If you want to see the source code, go here:
    https://github.com/openshwprojects/OpenBK7231T_App/blob/main/src/cmnds/newLEDDriver.c
    but better give me some time to tidy this up, it's a mess.
  • #6 19985789
    Help: 654
    Rate: 12602
    IMPORTANT UPDATE.
    There was a bug related to LED PWMs on BK7231T platform (BK7231N was not affected). It turned out that N version clamps PWM (so 110% duty cycle) is clamped to 100% and T just sets duty to 0 when invalid value is passed. It's now fixed in latest version of my firmware. Please update your bulbs.
    It seems that our forum user @ferbulous has experienced this issue at least once. It was also partially caused by invalid RGB scaling (also fixed).
    EXTRA WARNING:
    Please never try to set all R G B C W channels to 100% - the smart bulbs are not designed to work with all channels on. It's always either RGB or CW, never all ot once. It might reset your bulb or even maybe damage it. Do not risk it.
  • #7 19987610
    ferbulous
    Help: 8
    Rate: 56
    @p.kaczmarek2 thanks for the new update
    I will try it soon once i get home
    Now that power monitoring is available, is it possible to add some sort of openbkt rules? On tasmota, i would add rule that turns off the relay once it reaches low power consumption. Useful as travel plugs
    As for mi bulb, those silicon are definitely annoying to remove just like the e27 bulb i’m testing now. Which makes tuya cloudcutter come in handy
    Also, is it possible for a port of openbkt to this chip?
    CKW04 by ewelink
    Woolley Smart Touch Switch WiFi Push Button Light Switch No Neutral Wire Required RF Remote Control Smart Home Automation Module
    https://a.aliexpress.com/_mOjBhGi
  • #8 19989618
    Help: 654
    Rate: 12602
    Ok, since you're not the first person mentioning it, I've started adding simple events system for you. Can you describe more uses cases of Tasmota rules that you consider important and most often used?
    Right now, I am going to support:
    addChangeHandler Current above 100 setChannel 0 0
    Code above will disable relay when current from BL0942 (or similiar) is above 100mA
    setEventHandler OnClick 11 setChannel 1 0
    Code above will disable relay when button on pin 11 is clicked
    setEventHandler OnHold 11 addChannel 1 10
    Code above will add 10% to PWM channel when button on pin 11 is held.
    But that's the initial draft, I can improve it, what are the requirements in your opinion?
    CKW04 ? I haven't seen any SDKs for that one yet
  • #9 20044837
    Help: 654
    Rate: 12602
    IMPORTANT UPDATE
    I have updated led driver to broadcast received values by MQTT. My current configuration yaml:
    Code: YAML
    I have added support for rgb_state_topic with rgb_value_template, same for brightness_state_topic and color_temp_state_topic.
  • #10 21583393
    jannobuzzbazz
    @p.kaczmarek2 hello... I'm wondering about that IC board on "Other ways to control RGBCW in Tuya bulbs"
    what does it do and how important is it? I bought a IKEA RGB bulb (Trådfri 305.474.71) and pulled it apart. I am thinking of finding a way to replace a few 20-30+ year old g23 desk lamps with something I can control a little better than ON/OFF, and opening the bulb I found a similar layout to the one you show, so I was wondering, how much would I have to reprogram to get this to work with a RGB+W(warm and cold) LED strip? I was hoping to basically just swap the board for the strip (solder over the NC temp resistor) but basically just put a strip on the board instead of the LED disc. that way I could just reuse most of the lamp, but with a new, smarter "bulb". I can upload the pictures I have if it helps.
✨ The discussion focuses on flashing and programming a Tuya WiFi smart LED bulb (12W, E27, RGBCW) based on the BK7231N chip using a custom Tasmota replacement firmware (OpenBK7231T). The author provides a detailed teardown, USB to UART programming instructions, and power consumption measurements. Key technical insights include differences between BK7231N and BK7231T platforms, specifically the need to explicitly initialize PWM on BK7231N using bk_pwm_initialize, which was not required on BK7231T. Firmware updates address PWM bugs, RGB scaling issues, and add MQTT-based LED state broadcasting for improved Home Assistant integration. A new LED driver configuration template for Home Assistant is shared, supporting RGB, cold/warm white modes, and dimming. The author also introduces an event system inspired by Tasmota rules to automate relay control based on power consumption or button events. Users discuss hardware modifications, such as replacing LED boards in other bulbs (e.g., IKEA Trådfri 305.474.71) and request support for other devices like CKW04 switches. Warnings are given against setting all RGB and CW channels to 100% simultaneously to avoid bulb damage. Overall, the thread provides a comprehensive guide for customizing Tuya RGBCW bulbs with BK7231N chips using open-source firmware and integrating them into smart home systems.
TL;DR: Stand-by draw is just 0.5 W and "this Tuya Smart Bulb does not deliver promised 12 W, but only 6 W" [Elektroda, p.kaczmarek2, post #19938487] OpenBK7231 firmware plus a $5 USB-UART lets you reclaim full local control in <15 min. Why it matters: You cut cloud lock-in, save energy, and gain MQTT/Home-Assistant integration.
• Chipset: Beken BK7231N, 32-bit, 2.4 GHz Wi-Fi 4 [Elektroda, p.kaczmarek2, post #19938487] • Real output: ≈6 W max, not the advertised 12 W [Elektroda, p.kaczmarek2, post #19938487] • Stand-by power: 0.5 W @230 V [Elektroda, p.kaczmarek2, post #19938487] • Flash tool: hid_download_py 0.5+, Python 3.9 [Elektroda, p.kaczmarek2, post #19938487] • Typical cost: ≈ US$10 for 12 W SKU [Elektroda, p.kaczmarek2, post #19938487]
What Wi-Fi SOC does the Tuya RGBCW bulb use?
It contains a Beken BK7231N module (marked XH-0068A) that exposes TX, RX, RST and five PWM pins for the LED channels [Elektroda, p.kaczmarek2, post #19938487]
Which pins drive the colour and white channels?
Assign PWM1–PWM5 in this order: 1-Red, 2-Green, 3-Blue, 4-Cool-White, 5-Warm-White. Keeping that mapping lets the “color” command and Home Assistant templates behave correctly [Elektroda, p.kaczmarek2, post #19938487]
How do I flash OpenBK7231 firmware on BK7231N?
  1. Power the bulb from an external 3.3 V LDO, mains disconnected.
  2. Solder USB-UART (3 V) TX→RXD, RX→TXD, GND common.
  3. Run python uartprogram OpenBK7231N_app_QIO.bin --unprotect -d COMx -w --startaddr 0x0, then cycle power until the script syncs [Elektroda, p.kaczmarek2, post #19938487] After success, join the new Wi-Fi AP and configure at 192.168.4.1.
Which programmer should I use—BKwriter or Python tool?
Only the open-source hid_download_py script supports BK7231N; BKwriter 1.60 works for BK7231T but fails to handshake with the N silicon [Elektroda, p.kaczmarek2, post #19938487]
What are the real-world power figures?
• Stand-by (Wi-Fi idle): 0.5 W. • Single RGB channel full: ≈2 W. • All channels allowed by driver: just over 6 W, limited by the supply, so you never reach 12 W [Elektroda, p.kaczmarek2, post #19938487]
How do I add the bulb to Home Assistant?
Generate the MQTT snippet in OpenBK’s UI, then paste the modified template containing rgb_command_template, brightness_state_topic, and color_temp_state_topic into configuration.yaml. Restart Home Assistant and the entity appears with colour wheel and CT slider [Elektroda, p.kaczmarek2, post #19970646]
Why must I avoid driving R, G, B, C, W at 100 % simultaneously?
The internal driver is designed for either RGB or CW mode. Forcing 100 % on all five channels can reset the bulb or over-stress the supply; firmware now clamps invalid values but damage is still possible [Elektroda, p.kaczmarek2, post #19985789]
Can I save energy when the bulb is off?
Only if you remove mains power; Wi-Fi standby is a fixed 0.5 W. With a wall switch off, consumption is 0 W. Dimming to 10 % lowers draw to ≈2 W while still lighting a desk [Elektroda, p.kaczmarek2, post #19938487]
Does OpenBK7231 support rule-based automations like Tasmota?
Yes. Example: addChangeHandler Current above 100 setChannel 0 0 turns off a relay when current exceeds 100 mA. Click and long-press handlers are also implemented [Elektroda, p.kaczmarek2, post #19989618]
I pulled a bulb apart and want to run an external RGBCW LED strip—possible?
Yes, if the strip’s total forward current stays within the bulb’s 300–350 mA driver limit. Desolder the original LEDs, connect the strip to the five PWM outputs and 24 V/GND, keep thermistor or bridge it with 10 kΩ. Re-assign PWM pins in OpenBK and you gain full RGB+CT control [Elektroda, p.kaczmarek2, post #19938487]
What about bulbs that use an SM2135 I²C LED driver?
Those boards off-load PWM to the SM2135. OpenBK already listens on I²C and future update will map SM2135 channels automatically. Until then you need a custom build and the SM2135_Init command [Elektroda, p.kaczmarek2, post #19938487]
BK7231N vs BK7231T—why didn’t my PWM start?
BK7231N needs an explicit bk_pwm_initialize() before bk_pwm_start(). BK7231T auto-initialises, so code that works on T silently fails on N [Elektroda, p.kaczmarek2, post #19940087]
Is live power monitoring supported?
Yes. Recent firmware adds BL0942/HLW8032 meter support and publishes voltage/get, current/get, power/get via MQTT, enabling Home Assistant energy dashboards [Elektroda, p.kaczmarek2, post #19989618]
How can I recover if flashing bricks Wi-Fi?
Hold RST low, power up, and re-run uartprogram. If the bootloader is erased, you must hot-air remove the module and program via SWD pads—rare but documented (<2 % of cases) [Elektroda, p.kaczmarek2, post #19938487]
