Error esp 32 cam: 'Detected camera not supported' after uploading Camera Web Server, CP2102
arduina 1758 4
  • Wrong serial wiring likely causing camera probe failure
    #1 19994082
    arduina
    after uploading the camera web server program on the serial port, I get an error:
    [E] [camera.c:1113] camera_probe(): Detected camera not supported
    [E] [camera.c:1379} esp_camera_init(): Camera probe failed with error 0x20004
    i'm using cp2102 programmer this is how i connected pins:
    gnd->gnd
    3v3->3v3
    TXD->UOR
    RXD->UOT
    i don't know what to do. is it necessary to replace the programmer with an ftdi? please answer quickly because it is important.
  • #2 19994130
    czareqpl
    Help: 196
    Rate: 580
    The message clearly indicates that the camera is not recognised. So why do you want to change the programmer?
  • #3 19994202
    arduina
    I have seen some tutorials on the subject, unfortunately none of them were sufficiently explanatory and on many of them I saw that it could be a power supply problem and that it was solved by using a different programmer
  • #4 19994484
  • #5 19994530
    arduina
    I tried powering from 5v by changing the power connection to:
    5v->5v
    gnd->gnd (this gnd under 5v)
    the same error pops up and I can't upload the program at this voltage
