ESP32-CAM: Compilation error A fatal error occurred: Failed to connect - image transmission
mikolaj17 1026 1
  • ESP32-CAM upload failing with no serial data received
    #1 20212567
    mikolaj17
    Hi, I have a problem with making an esp32cam server with image transmission. When I upload the code that is in the arduino.ide examples such an error I get as below in the screengrab. I changed the voltage from 3.3v to 5v and the baud rate from 115200 to 9600 unfortunately with no change the same error is displayed.
    ESP32-CAM: Compilation error A fatal error occurred: Failed to connect - image transmission .
    The terminal displays this error:
    Sketch uses 1431465 bytes (45%) of program storage space. Maximum is 3145728 bytes.
    Global variables use 65360 bytes (19%) of dynamic memory, leaving 262320 bytes for local variables. Maximum is 327680 bytes.
    esptool.py v3.3
    Serial port COM7
    Connecting......................................
    A fatal error
    Code: C / C++
    : Failed to connect to ESP32: No serial data received.
    For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
    The selected serial port For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
    does not exist or your board is not connected
  • #2 20212934
    bubu1769
    Help: 1177
    Rate: 2374
    Which tile do you have selected in the menu?
