[Solved] Connecting the SH1106 OLED display to the ESP32 30-pin with WiFi antenna
Użytkownik_Elektrody 4122 10
Can I connect an SH1106 1.3" 128x64 I2C OLED display to a 30-pin ESP32 board with built-in Wi‑Fi antenna using the shown wiring?
Yes, the shown wiring is correct for this display and it should work with the ESP32. The display is an I2C module, and the fact that one pin is labeled SCK instead of SCL is likely just a Chinese labeling mistake [#20086998][#20087630][#20087634] If your program supports I2C, it should be compatible [#20087656] The original poster later confirmed that the scheme worked [#20119645]
  • #1 20086898
    Rate: 22
    Good morning.
    I have a question if it is possible to plug in this following display from Allegro: /oferta/wyswietlacz-oled-1-3-128x64-i2c-sh1106-bialy-11840272724
    To the ESP32 of this 30 pin version with built-in WiFi antenna. I found such a schematic, but nowhere could I find confirmation of this schematic:
    Connecting the SH1106 OLED display to the ESP32 30-pin with WiFi antenna .
  • #4 20087007
    Rate: 22
    If the display from the Chinese one arrives we'll find out, I just wanted to make sure nothing burns when connected :)
  • #5 20087479
    Rate: 22
    I have one more question why this display has different pins than other displays instead of SCL it has the SCK pin ?
  • #7 20087624
    Rate: 22
    khoam wrote:
    why this display has different pins than other displays instead of SCL it has SCK pin ?
    Then maybe post a picture of this display and it will clarify if it has an I2C or SPI interface.
    Here is the link to the auction : https://allegro.pl/oferta/wyswietlacz-oled-1-..._unit_id=510bfe04-ad20-4579-ac41-0ab45106709d
    Added after 41 [seconds]:
    there are also auctions of this display 7 pins
    inot
    Help: 441
    Rate: 803
    This is a display with an I2C interface. SPI requires more connections.
    If you’re using an OLED display with SPI communication protocol, use the following GPIOs.
    GPIO 18: CLK
    GPIO 19: MISO
    GPIO 23: MOSI
    GPIO 5: CS
  • #10 20087656
    Rate: 22
    The program I want to use supports I2C, so it should work, namely caradio32
  • #11 20119645
    Rate: 22
    The scheme worked, so the topic is closed
✨ The discussion centers around connecting an SH1106 OLED display to an ESP32 30-pin version with a built-in WiFi antenna. The user inquires about the compatibility of the display, referencing a schematic they found. Responses confirm that the schematic is correct and that the display operates via an I2C interface, despite some confusion regarding pin labeling (SCL vs. SCK). The user expresses concern about potential damage during connection and later confirms successful implementation of the schematic.
