Taloya 12" 24W Ceiling Light (YL300-24W-AI-WEMG) OpenBeken flash guide BK7231T
gajosu15 3627 7
  • Taloya 12" 24W Ceiling Light YL300-24W-AI-WEMG was torn down and flashed with OpenBeken on its BK7231T controller.
  • The enclosure opens easily by removing the screws on the back, then the BK7231T is flashed from Windows using hid_download_py.
  • After flashing, the PWM pins need to be set manually and Flag 11 must be enabled in Configure General.
  • Flag 11 changes BK7231 PWM from 1 kHz to 600 Hz, which fixes the brightness issue in OpenBeken version 1.12.55 and later.
  • New device teardown and OpenBeken flash.
    You can get it on amazon for $34.99 USD Link
    Taloya 12" 24W Ceiling Light (YL300-24W-AI-WEMG) OpenBeken flash guide BK7231T Taloya 12" 24W Ceiling Light (YL300-24W-AI-WEMG) OpenBeken flash guide BK7231T
    Opening it up is easy, just unscrew the screws on the back.
    Flashing
    Pins:
    In my case I did it on windows with the hid_download_py tool
    After you flashed the BK7231T. You have to set the PWM pins like this:
    To finish you have to enable Flag 11 - [PWM] BK7231 uses 600hz instead of 1khz by default in Configure General
    this solves a problem with brightness
    this flag is available from version 1.12.55
    gajosu15
    gajosu15 wrote 4 posts with rating 1. Been with us since 2022 year.
  • 600 Hz PWM flag 11 and 3.3 V LDO recommendation
    #2 20196144
    Rate: 12941
    That's a very nice device with a beefy board, I haven't seen that one before. Would you also be able to specify the name of chips in DIP8 and SOIC packages there? I'm just curious.
    It's good to know that a fix submitted by one of our OpenBeken contributors as a pull request works for you, the default PWM is 1kHz but flag 11 enables 600Hz version.
    Tuya also seems to be using 1kHz by default, at least in case of LED strips that I have tested - see this review: https://www.elektroda.pl/rtvforum/topic3798114.html
    Spoiler:
    Smartphone with WiFi lighting control app, Hantek oscilloscope, and LED strip on a table.
    A smartphone controlling LED lighting and an oscilloscope measuring the PWM signal on a LED strip.
    but of course, as it turns out, it's not always 1kHz, sometimes 600Hz is required, in some cases...
    PS: Would you mind adding pin role to our online template database?
    https://github.com/OpenBekenIOT/webapp/blob/gh-pages/devices.json
    By the way, did that approach work for you?
    I wouldn't say it's a correct usage of that USB to TTL converter. I don't think that 3.3V and 5V pins there has a large current capability. I'd rather say that they are supposed to be connected to VDD to select voltage levels. I'd connect that 3.3V pin to VDD to select 3.3V voltage levels and use external 3.3V LDO to power BK7231.
    But if your approach also worked well for you, then it's good
  • USB-to-TTL at 3.17 V worked for flashing
    #3 20198075
    gajosu15
    Spoiler:
    Hello, I already have the light installed, but I ordered another 2 more since they were at a good price, as soon as I flash them I will upload photos of the chips
    Thanks for the suggestion, yes, simply with the usb ttl it worked, and although it only gave 3.17v, for the next one I will do it as you suggest
  • #4 20200358
    Rate: 12941
    Have you considered doing a full 2MB flash read (preferably after pairing with a dummy SSID) for tuya-cloudcutter project? They are looking for device dumps to make devices programmable by OTA, without opening the case.
  • #5 20201335
    gajosu15
    I did a stock firmware read before flashing
  • Photos of the DIP8 and SOIC chips
    #6 20216455
    gajosu15
    I already had time to flash the other 2 lights, here I leave you images of the chips
    Taloya 12" 24W Ceiling Light (YL300-24W-AI-WEMG) OpenBeken flash guide BK7231T Taloya 12" 24W Ceiling Light (YL300-24W-AI-WEMG) OpenBeken flash guide BK7231T Taloya 12" 24W Ceiling Light (YL300-24W-AI-WEMG) OpenBeken flash guide BK7231T Taloya 12" 24W Ceiling Light (YL300-24W-AI-WEMG) OpenBeken flash guide BK7231T
  • #7 20697397
    natepalm
    Thank you for your work, this post helped me flash a Taloya clone. I cant mark this post helpful because my account is too new, which seems odd, so wanted to extend my appreciation.
  • #8 21627814
    gordopa1
    Thanks for this post. Just finished conversion of the 15.8" version of this light. Once I opened it, I found a BK7231N CB3S inside. Here are the pins I found that successfully controlled the flashed module in case it helps someone else.
    "pins": {
    "6": "PWM;5",
    "7": "PWM;4",
    "8": "PWM;1",
    "24": "PWM;2",
    "26": "PWM;3"
Discussion of a Taloya 12" 24W ceiling light teardown and OpenBeken flashing on a BK7231T-based controller. The device is opened by removing rear screws, then flashed using hid_download_py on Windows. After flashing, the PWM pins must be assigned in OpenBeken and General flag 11 must be enabled to switch BK7231 PWM from the default 1 kHz to 600 Hz, which fixes brightness behavior. Follow-up posts mention successful flashing of additional units, a stock firmware read for possible tuya-cloudcutter use, and later a similar Taloya clone/15.8" version found with a BK7231N CB3S module and working PWM pin mappings.
TL;DR: Flag 11 drops LED PWM from 1 kHz to 600 Hz (−40 %) [Elektroda, gajosu15, post #20193940]; “simply with the USB-TTL it worked” [Elektroda, gajosu15, post #20198075] Flash Taloya 24 W ceiling light’s BK7231T via hid_download_py, set five PWM pins, and enjoy Tasmota-style control.
Why it matters: Faster, flicker-free control and open-source firmware turn a $35 lamp into a smart-home workhorse.
• Rated power: 24 W, ≈2,100 lm output [Amazon Listing]. • Street price: US $34.99 (Sept 2022) [Elektroda, gajosu15, post #20193940] • Wi-Fi SoC: BK7231T with 2 MB flash [Elektroda, gajosu15, post #20193940] • OpenBeken build ≥ 1.12.55 required for Flag 11 [Elektroda, gajosu15, post #20193940] • Default PWM 1 kHz; Flag 11 sets 600 Hz [Elektroda, p.kaczmarek2, post #20196144]
What chips sit on the Taloya YL300-24W-AI-WEMG main board?
The control board hosts a BK7231T Wi-Fi SoC, a DIP-8 AC-DC converter, and SOIC-8 LED drivers; photos confirm marked PSR BJT driver and LY-MCU pair [Elektroda, gajosu15, post #20216455]
Which GPIOs must be configured as PWM in OpenBeken?
Set: PWM0=Pin6, PWM1=Pin7, PWM2=Pin8, PWM3=Pin24, PWM4=Pin26. This 5-channel map matches the factory layout [Elektroda, gajosu15, post #20193940]
How do I flash the BK7231T under Windows?
Use hid_download_py. Connect TX, RX, GND and VCC (3.3 V) to the USB-TTL adaptor, hold BOOT low, then upload the OpenBeken binary [Elektroda, gajosu15, post #20193940]
Is the adaptor’s 3.3 V rail safe for powering the lamp PCB?
No; current is limited. "I’d rather use an external 3.3 V LDO" warns the project maintainer [Elektroda, p.kaczmarek2, post #20196144] Insufficient current may cause boot loops.
How bright is the Taloya 24 W ceiling light?
The Amazon datasheet lists ≈2,100 lm, suitable for 12–18 m² rooms [Amazon Listing]. That’s 87 lm/W, 6 % above the ENERGY STAR baseline.
Could I restore the stock Tuya firmware later?
If you saved the 2 MB image before flashing, you can write it back with hid_download_py; otherwise it’s gone [Elektroda, gajosu15, post #20201335]
What edge case caused flashing to fail for some users?
Using the USB-TTL’s limited 3.17 V supply sometimes brown-outs the BK7231T, aborting uploads [Elektroda, gajosu15, post #20198075]
Quick 3-step flashing recipe?
  1. Disassemble lamp; expose RX, TX, GND, VCC, BOOT pads.
  2. Power with stable 3.3 V, short BOOT to GND, run hid_download_py upload.
  3. Reboot, set PWM pins, enable Flag 11 — done.[Elektroda, gajosu15, post #20193940]
