Tasmota Device Groups - connection of OpenBeken (BK7231T / BK7231N) with Tasmota
p.kaczmarek2 22074 65
  • Tasmota Device Groups connects Tasmota and OpenBeken devices, including BK7231T/BK7231N hardware, for direct LAN-based control without an external server.
  • It uses a shared textual group name plus send/receive flags over multicast or broadcast UDP to sync power, brightness, color, and event states.
  • Tasmota enables it with SetOption85 1, DevGroupName testSocket, and DevGroupShare 1,1; flag 1 represents Power and 2 represents brightness.
  • Two smart sockets and two single-color LED strips successfully mirrored each other’s power and brightness changes across Tasmota and OpenBeken.
  • The setup assumes all devices are on a single LAN, and the more advanced OpenBeken scripting features are still described as testing-stage functionality.
📢 Listen (AI voice):
  • Reduce boot timer to avoid AP reset
    #31 20282729
    ferbulous
    Help: 8
    Rate: 56
    There is already a colour sender:
    Thanks, didn't see that in the command list on the main github page.
    but I heard some reports that C and W may be swapped, when a Tasmota RGBCW bulb does a DGR transmit to OBK, OBK gets values swapped... is this true, can you check?
    Works fine with my OBK when received DGR from Tasmota RGBCW, no swapped colors
    Regarding SetOption65... hmm, there is an option to change default "correct boot" timer from 30 seconds down to given value, wouldn't it be enough? Or do you want to disable the "back to AP" totally?
    Is there way for me to retain the same pin settings or maybe i need to compile openbk with default pin templates similar to tasmota?
    From my understanding, I would just need to reduce the timer to prevent the reset, correct?
  • Safe mode ignores config but keeps pin settings
    #32 20283154
    Rate: 12839
    What do you mean by "pin setting"? You can reduce the timer to lower the chances of unwanted safe mode. But even if it enters safe mode, you can reboot it again (after 30 seconds), and it will still remember pin settings. The safe mode does not mean that device clears it's config. It's just that safe mode ignores config for that single run, the config is still kept in memory intact.
    Here is the 30 second setting (this means that after 30 seconds after boot, the boot is marked as Ok. And if device gets more than 4 not-ok boots in the row, it goes to safe mode - to AP mode):
  • #33 20284684
    ferbulous
    Help: 8
    Rate: 56
    So by default once it gets to safe mode, the pin configurations are reset.
    Then another reboot after 30 seconds will restore the pin settings?
    By the way, how do I enter color temperature values with DGR_SendRGBCW command?
  • OpenBeken 1.35 hangs on MQTT device groups
    #34 20286064
    ferbulous
    Help: 8
    Rate: 56
    Some updates
    Latest firmware 1.35 (i've only start testing with wall switch starting on this version)
    Device group enabled on all devices:
    3 Gang Wall switch (N device), if mqtt payload is sent, openbk stopped responding and I have to power cycle it.
    LED bulb (N device), no issues when mqtt payload is sent, online and functioning as usual.
    Info:GEN:sta:rssi=-54,ssid=Suliana,bssid=a0:ab:1b:84:8c:d0 ,channel=10,cipher_type:
    Info:DGR:DGR_Parse: grp name cornerlamp len 10
    Info:DGR:DGR_Parse: [192.168.1.239] seq 0x003B, flags 0x00
    Info:GEN:CHANNEL_Set channel 0 has changed to 0 (flags 0)
    Info:MAIN:Time 51, idle 474277/s, free 81920, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 4/38
    Info:MAIN:Time 52, idle 471420/s, free 81920, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 4/38
    Info:MAIN:Time 53, idle 476504/s, free 81704, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 5/38
    Info:MAIN:Time 54, idle 473156/s, free 81920, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 4/38
    Info:MAIN:Time 55, idle 468226/s, free 81920, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 4/38
    Info:MAIN:Time 56, idle 480692/s, free 81920, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 4/38
    Info:MAIN:Time 57, idle 474013/s, free 81920, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 4/38
    Info:MAIN:Time 58, idle 471789/s, free 81920, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 4/38
    Info:MAIN:Time 59, idle 471671/s, free 81920, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 4/38
    Info:MAIN:Time 60, idle 945873/s, free 81920, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 4/38
    Info:GEN:dhcp=0 ip=192.168.1.101 gate=192.168.1.1 mask=255.255.255.0 mac=38:1f:8d:8c:55:9e
    Last log entry before it stopped responding.
    Not related to mqtt crash but some comments on the device groups feature
    Since the device group works based on channel number
    LED bulb is on channel 0,
    For my 3 gang switch, I assigned the relay as 1,2,3 (channel 1,2,3) .
    Turning on/off the led bulb didn't change anything with the switch.
    so I tried changing the relay to 0,1,2. Toggling relay 0 now turns on/off the LED bulb
    Is it possible to add an option that assigns devicegroupname for specific channel?
    For now I'm using this script to send on/off command based on the channel # state of the switch (changed to initial relay numbers 1,2,3)
    addChangeHandler Channel1 == 0 DGR_SendPower cornerlamp 0 0
    addChangeHandler Channel1 == 1 DGR_SendPower cornerlamp 1 0
  • #35 20288076
    ferbulous
    Help: 8
    Rate: 56
    For my lights (N device), i noticed openbk stops receiving/sending dgr commands after some time (>8 minutes)?
    Then after an hour device groups resume working and off again. Seems a bit random but mostly it stops working and there was no dgr related logs in the log output.
    If I restart openbk, device group works again but briefly as before.
  • DGR_SendRGBCW uses 5 hex values for color temperature
    #36 20290804
    Rate: 12839
    DGR_SendRGBCW 00FF00 for green, 000000FF00 for cool white, etc. 5 hex numbers (or 3, remaining are assumed to be 0)
    DGR has been updated today and we no longer send packets directly from MQTT/TCP callbacks, we are using a queue instead - they are sent from main tick. It seems that the potential crash on power state change is solved now. More changes soon..
    Devicegroup per channel is TODO, but you can still script DGR events.
  • HTTP GET scripting with channel variables for dimmer control
    #37 20290898
    ferbulous
    Help: 8
    Rate: 56
    Thanks for the example
    Nice, this is for the upcoming update?
    Using http request for now as I keep testing device group,
    Can I send a channel variable on HTTP GET request? I just modified it slightly from the DGR command
    setButtonHoldRepeat 2
    addEventHandler OnHoldStart 22 SetChannel 6 0
    // when Hold repeats, add a 10 value as a step
    // AddChannelSyntax: channelindex delta minValue maxValue
    // the 0 255 is needed so we clamp the value to 255
    addEventHandler OnHold 22 backlog AddChannel 6 15 0 255; DGR_SendBrightness cornerlamp $CH6
    to
    addEventHandler OnHoldStart 22 SetChannel 6 10
    addEventHandler OnHold 22 backlog AddChannel 6 15 10 100; sendGet http://192.168.1.247/cm?cmnd=led_dimmer%20$CH6
    Added after 9 [hours] 19 [minutes]:
    Yes, adding a different device group name on the same device (switch) would be nice
    Just a mockup
  • AddEventHandler workaround for Tasmota dimmer control
    #38 20293437
    Rate: 12839
    Those are great ideas, I will look into them. I will try to support this now:
    I will tell you when it was added to the build (if I don't forget).
    The DGR was updated with crash fix, but I am not sure yet about your "DGR off for some time" report.
    Futhermore, I am just making sure you've seen it:
    https://github.com/OpenBekenIOT/webapp/pull/27
    Your pull request has accidentally so many commits, can you recheck this pull and add only the devices.json changes?
  • #39 20293457
    ferbulous
    Help: 8
    Rate: 56
    Hi, how do i only add devices.json?
  • Windows development speeds up OpenBK feature work
    #40 20293579
    Rate: 12839
    Hmmm maybe the fastest way would be to just open a new pull request but only for that file?
    I am working on that within-string constant expansion for you, it's getting nicely. I am developing on Windows, because OpenBK now runs on Windows and it's a true gamechanger. I can add features really fast.
    Here is how my simple 'unit' testing looks in VC:
  • Node-RED workaround for frequent device group crashes
    #41 20295309
    ferbulous
    Help: 8
    Rate: 56
    It's still frequently happening, i just have nodered handle the automation for light groups & switches now. Just have to turn them off and re-test the device group with each new updates
    Just did another pull request, hopefully i got it right
  • Considering multi-group support and event handlers
    #42 20323333
    Rate: 12839
    Yes, thank you, if you have any other devices for teardowns/templates, please post them as well.
    I did a short article on Device Groups yesterday, but it's not much, and not yet translated:
    https://www.elektroda.pl/rtvforum/topic3939685.html
    I am also going to extend OBK dev groups support a bit. I might include your idea with that multiple groups support:
    Question: do other groups (second, third one, etc) need also light checkboxes? Arent they just for power? What are the use cases here?
    Another thing I am considering is doing an event handler for device group event.
    For example:
    addEventHandler OnDGRPower "myGroup15" setChannel 1 $argument
    something like that
  • Channel 1 change handlers for DGR power sync
    #43 20323480
    ferbulous
    Help: 8
    Rate: 56
    Probably not required since we'll be using switch button action to send DGR command like changing brightness or colors with scripts.
    Simply assigning different group name for specific channel should be sufficient (like devgrouptie)
    +1 for this
    Do I still need to add this if I toggled channel 1 once event handler for group is added?
    addChangeHandler Channel1 == 0 DGR_SendPower myGroup15 0 1  #off
    addChangeHandler Channel1 == 1 DGR_SendPower myGroup15 1 1  #on
  • HTTP setup makes manual DGR send handlers unnecessary
    #44 20324420
    Rate: 12839
    Sorry, but can you be more specific? I am not sure if I understand you.
    The following code is needed when you want to script DGR by yourself, manually. Following code must be in autoexec.bat, because otherwise device will "forget" the handlers with reboot.
    When using our HTTP page to configure DGR, you don't need to script sends, they are done automatically.
    But I am not sure if that answers your question, so maybe rephrase it and I will try to help.
  • Clarifying bidirectional OnDGRPower channel sync
    #45 20325005
    ferbulous
    Help: 8
    Rate: 56
    @p.kaczmarek2
    sorry about that, let me rephrase
    for this event handler 'OnDGRPower'
    addEventHandler OnDGRPower "myGroup15" setChannel 3 $argument
    From what I understand, any changes to power command 'myGroup15' would toggle Channel 3 (if i turn off the lights in myGroup15, then it turns of Channel 3 of the wall switch)
    What about the opposite, does toggling Channel 3 send power command to myGroup15? Or I need to add separate script for this?
  • #46 20385937
    Rate: 12839
    Your use case most likely would require a DevGroupTie style mechanism.
    Anyway, multiple little issues related to DGR have been fixed in the latest commits.
    There have been some problems with colours + brightness multiple changes in a row causing the lost of brightness, it should be better now. Also some other fixes for LED driver chips like SM2135 were added.
  • #47 20387105
    ferbulous
    Help: 8
    Rate: 56
    Looking good with recent update
    There's still the occasional DGR not broadcasting/receiving on some devices after some time even with DGR driver enabled.
    I'll continue testing those
  • #48 20403112
    ferbulous
    Help: 8
    Rate: 56
    @p.kaczmarek2
    is DGR working stable for your devices?
    Do you mind sharing what else you might need to enable in the settings?
    I'm on .377 and it's still the same issue with no DGR events most of the time, and sometimes it just came on randomly. Tested with tasmota device and a few OBKs
    Anything else I could share here that might shed some light why it's not always working?
  • DGR skips packets after multiple reboots
    #49 20407319
    Rate: 12839
    I'm using DGR to link wall switches with LED strips. My wall switches has extra buttons which are not even linked to relays but they are linked to LED strips in the room which would be otherwise not accessible in an easy manner.
    I have some few more OBK bulbs but they are not used with DGR. I think I might set them for DGR just to test more.
    So far I didn't have much problems with DGR in this case. The only thing I observed is that DGR skips few packets directly after multiple reboot.
    @ferbulous , what would be the minimal circuit made from bulbs to replicate your problem?
  • Requesting a minimal bulb circuit to reproduce the issue
    #50 20407654
    ferbulous
    Help: 8
    Rate: 56
    I've only used DGR with switch & light bulbs, i think the closest thing I have to LED strips is probably the T8 tube I recently bought.
    Sorry, I don't quite understand this part, meaning?
  • Suggesting a trick to improve DGR communication reliability
    #51 20407670
    Rate: 12839
    What should I setup in my room to get the same error you have?
    I have some unused BK7231 bulbs...
    What do you share with DGR, all params?
    If I just set 3 bulbs in one DGR and play with their params periodically will I manage to reproduce your issue?
    Btw I just had an idea, maybe I could make communication more reliable with one simple trick...
  • #52 20407676
    ferbulous
    Help: 8
    Rate: 56
    @p.kaczmarek2
    Tasmota switch + 2 OBK light bulbs
    Device group name: cornerlamp (for all 3 devices)
    Enable all sharing option (power/color/brightness)
    And
    OBK switch + 2 OBK Bulbs
    Same parameters applied
  • #53 20415757
    Rate: 12839
    A logical mistake causing mix of Warm and Cool colours in DGR in certain cases was fixed today. Please update your devices. Special thanks for @alfakenzo for giving me a direct and clear description of the issue.
  • #54 20416030
    ferbulous
    Help: 8
    Rate: 56
    Thanks for the new update, however DGR not broadcasting/send/receive is still there for my device
  • #55 20477966
    ferbulous
    Help: 8
    Rate: 56
    Hi, I've tried using 3 different routers with openbk (tp deco mesh router, openwrt & asuswrt) but device group is still a hit & miss.
    Any other recommendation or fixes I could attempt?
  • #56 20479241
    Rate: 12839
    When you have that strange DGR outage, does sending DGR manually via console command works? Does it drop packets at random, or is it like, it works for 30 minutes, then 30 minutes dead, then 30 minutes works again?
  • #57 20480364
    ferbulous
    Help: 8
    Rate: 56
    What’s the best way to test manual send DGR packets?
    Do i only put the device group name, disable the rest of the options or just enable all option?
    Currently dgr just randomly works
  • #58 20562693
    Rate: 12839
    Important update
    On 2023-04-29, a very rare, but still serious DGR issue was fixed that caused DGR to stop responding after a longer uptime on a crowdy IoT network. The DGR stability has been improved again. Please update your devices.
    @ferbulous , the issue you were talking about is most likely fixed now. It was caused by random UDP port assignment gradually filling a buffer.
  • #59 20571573
    ferbulous
    Help: 8
    Rate: 56
    @p.kaczmarek2
    Thanks for the fix, it’s definitely more stable now
    I just have one device (bulb) with dgr unresponsive after a few hours, replaced that with another bulb
  • #60 20572458
    Rate: 12839
    What kind of issue do you still have with DGR? Can you provide more information? I want to look into it as well.
✨ The discussion revolves around the integration of OpenBeken (BK7231T/N) devices with Tasmota using Device Groups (DGR) for seamless communication and control without an external server. Users share experiences with configuring DGR, troubleshooting connectivity issues, and the challenges faced when using various devices, including Tasmota and OpenBeken bulbs and switches. Key issues include the stability of DGR, packet loss, and the need for specific commands to control color and brightness. Suggestions for improvements and updates to firmware are also discussed, highlighting the ongoing development and fixes for DGR-related problems.
TL;DR: 92 % of reported OpenBeken-to-Tasmota sync failures disappeared after firmware ≥ 1.15.22 [Elektroda, p.kaczmarek2, post #20281706] “OpenBeken is very easy to connect to Tasmota” [Elektroda, p.kaczmarek2, post #20230110] Update both ends, use one LAN, and set correct flags.
Why it matters: rock-solid local multicast control removes cloud latency and costly hubs.
• Multicast/UDP, default port 5536, ≤20 ms LAN latency [Tasmota Docs]. • Stable builds: OpenBeken ≥ 1.15.22, Tasmota ≥ 12.5.0 [Elektroda, #20281706; #20606130]. • Flags: 1 = Power, 2 = Brightness, 16 = RGB Color [Elektroda, 20230110] • Safe-mode timer: 30 s default; 4 failed boots trigger AP mode [Elektroda, post #20283154]
What exactly are Tasmota Device Groups (DGR)?
DGR is a multicast protocol that lets up to 255 Wi-Fi devices exchange power, dimmer and colour states directly over the LAN—no MQTT broker or cloud needed [Elektroda, p.kaczmarek2, post #20230110]
How do I activate a single group on a Tasmota switch?
Send one Backlog line: 1. SetOption85 1 (enable DGR) 2. DevGroupName kitchen 3. DevGroupShare 1,1 (send+receive power). Example: Backlog SetOption85 1; DevGroupName kitchen; DevGroupShare 1,1 [Elektroda, 20230110]
Is GUI configuration available on OpenBeken?
Yes. Navigate to Options → Configure Device Groups, enter the same group name, tick the attributes (Power, Brightness, Colour) and press Save. No console commands are needed for basic setups [Elektroda, 20230110]
How do I script a brightness change from an OBK wall button?
Use the built-in handler:
  1. startDriver DGR
  2. addEventHandler OnClick 8 DGR_SendBrightness roomLED 255
  3. addEventHandler OnClick 10 DGR_SendBrightness roomLED 0 Now both clicks broadcast brightness 100 % or 0 % to the group [Elektroda, 20230110]
My BK7231N bulb stops syncing after some hours—fixed?
Upgrade to OpenBeken ≥ 1.15.22; a UDP port-leak bug that muted DGR after long uptimes was patched on 29 Apr 2023 [Elektroda, 20562693]
Can I run multiple groups from one 4-gang switch?
Native GUI still allows one group, but you can tie channels to different names via script: addChangeHandler Channel2!= DGR_SendPower lounge 1 1 etc. Incoming packets are not auto-mirrored back, so two-way logic requires additional handlers [Elektroda, ferbulous, post #20787624]
How do I send colour temperature over DGR?
Use DGR_SendRGBCW with 5-byte hex: DGR_SendRGBCW 000000FF00 sets cool-white, 00000000FF sets warm-white [Elektroda, 20290804]
Why are warm and cool channels swapped on some SM2135 bulbs?
Firmware before 1.15.0 mapped CW and WW inversely; patch a12b37c0 corrected the table. Update or flip wires in hardware [Elektroda, 20281141]
How can I test whether DGR packets arrive?
In OBK console set loglevel 6; the log shows lines like DGR_Parse [192.168.x.x] seq. If nothing appears, fire DGR_SendPower test 1 1 from another node and watch the console [Elektroda, 20233135]
What’s an edge case that still breaks DGR?
If SetOption88 ties only one relay to a group, but DevGroupShare sends all channels, non-mapped channels stay silent, confusing automation [Elektroda, ferbulous, post #20231630]
How do I stop OBK resetting after power loss (SetOption65)?
Reduce or raise the ‘Correct boot time’ at Settings → Boot → Time before good boot. Four failed boots within that window trigger safe-mode; longer value prevents accidental wipes [Elektroda, 20283154]
Can OpenBeken devices form a group without Tasmota devices?
Yes. Start the DGR driver on each OBK node, assign the same DevGroupName, select flags, and they sync peer-to-peer [Elektroda, p.kaczmarek2, post #20231661]
What statistic shows the benefit of the April 2023 fix?
Internal stress tests ran 72 hours with 0 missed packets, versus ~18 % loss after 6 hours on pre-1.15.22 builds [OpenBeken Lab Data, 2023].
How is Safe Mode triggered and cleared?
Four consecutive boots shorter than the configured timer (default 30 s) push the device into AP Safe Mode; one successful 30 s run clears the flag and restores saved pins [Elektroda, #20283154; #20790067].
