Unitra Diora "Beskid" DMP-411 - interior, photo gallery, diagram
p.kaczmarek2 4629 12
  • The Unitra Diora Beskid DMP-411 is a 1970s-80s mono radio receiver with longwave, mediumwave, shortwave, and UKF OIRT reception plus a DIN input.
  • Inside, it uses a ferrite antenna, incandescent backlight, 50 Hz mains transformer, a single TONSIL GD10-16/5/2 speaker, and a single-sided through-hole PCB.
  • It covers 165-285 kHz, 525-1605 kHz, 5.96-9.8 MHz, and 65.5-73.5 MHz, and consumes about 10 W from 220 V/50 Hz mains.
  • The receiver is built around UL1211 and UL1402 integrated circuits, and the posted schematic also matches related DMP-401 and DMP-413 models.
  • Unitra Diora "Beskid" DMP-411 - interior, photo gallery, diagram .
    I would like to invite you to a short photo gallery and documentation of another radio receiver from my collection - a mono Beskid from the Unitra Diora stable, also known as DMP-411. This receiver was produced in the 1970s-80s and allows to receive radio waves in the long (165-285 kHz), medium (525-1605 kHz), short (5.96-9.8) MHz and UKF OIRT (65.5-73.5 MHz) ranges. It also allows connection of a DIN input (e.g. from a tape recorder). It is powered from the mains, still 220V/50Hz, power consumption approximately 10W.
    Unitra Diora Beskid from outside .
    The front panel is made of black plastic, the case is made of plywood:
    Unitra Diora "Beskid" DMP-411 - interior, photo gallery, diagram Unitra Diora "Beskid" DMP-411 - interior, photo gallery, diagram .
    On the front panel, we see the main switch and four isostat switches for changing the ranges (U, D, S, K). There is also a 'hidden' function there - pressing U and D simultaneously activates the DIN (tape) input. In addition to this, there are two sliders (in my case without 'heads') for adjusting the strength and timbre of the sound.
    Unitra Diora "Beskid" DMP-411 - interior, photo gallery, diagram Unitra Diora "Beskid" DMP-411 - interior, photo gallery, diagram Unitra Diora "Beskid" DMP-411 - interior, photo gallery, diagram Unitra Diora "Beskid" DMP-411 - interior, photo gallery, diagram Unitra Diora "Beskid" DMP-411 - interior, photo gallery, diagram Unitra Diora "Beskid" DMP-411 - interior, photo gallery, diagram .
    The fibreboard is removable at the back.
    On the rear panel there is an aerial output and a DIN-type turntable/magnetophone output. This output is activated by pressing the D and S range selector keys simultaneously.
    The radio is a box just under 14cm high, 18cm deep and 52cm wide.
    Unitra Diora Beskid inside .
    The back plate is removed by loosening three screws:
    Inside you'll notice a ferrite antenna, an incandescent light bulb (backlighting), a 50Hz mains transformer (it's not those days that switching power supplies were popular) and a single TONSIL GD10-16/5/2 5W 4Ohm speaker.
    To get further, loosen the screws holding the catches in the housing groove:
    PCB freed from its hooks, which need to be loosened from the underside of the case:
    Extending the front end from the PCB, you can see the adjustable capacitor used for tuning by changing the capacitance:
    In the photos I have tried to capture the characteristic components of the time well, here for example you can see the isostat switches, filters, coils (also those with an air core) and even the BF195 and BF194 transistors in those characteristic housings of theirs. You can also see the tuning mechanics with the string.
    There's quite a bit of dirt around the front, but I shouldn't complain anyway, it's the best preserved electro-junk receiver I've come across so far.
    Volume and tone potentiometers:
    Unitra Zatra TS 6/10 mains transformer:
    Finally the integrated circuits - the radio is realised on UL1211 and UL1402.
    What is the UL1211? Below you have it in Polish:
    And about the UL1402:
    Whole PCB:
    From the underside I did not take a photo, but it is rather clear that it is single-sided and the assembly is through-hole (THT).
    Finally, the schematic. The schematic has already appeared on our forum several times, but for the sake of convenience I will post it here anyway:
    According to the information I found the schematic fits related receivers: Silesian DMP-401, Beskid DMP-411 and Giewont DMP-413.
    Summary .
    This radio is older than I am and in my childhood I was not likely to encounter such wonders any more, but I still liked it very much, especially as it is one of the better preserved copies that came into my hands.
    Some time ago I posted a similar topic on the forum about UNITRA Snowball R-207 and if another similar receiver falls into my hands, I will be happy to document it too.
    And what radios do you guys have in your collections? The first 5 posts by different users with a photo with a card with an Elektroda nickname and Unitra equipment in the background will get 200 Elektroda points from me.
    p.kaczmarek2 wrote 14767 posts with rating 12906, helped 659 times. Been with us since 2014 year.
  • #2 20236934
    Grzegorz740
    Level 37  
    Help: 313
    Rate: 553
    My Taraban radio 3.
  • #3 20236991
    ArturAVS
    Moderator
    Help: 2303
    Rate: 7832
    Grzegorz740 wrote:
    My Taraban 3.
    radio.
    Such a piece of equipment "rammed" into me over a quarter of a century ago, acquired (new from a shop for MM) and after about a month was converted to stereo working with the also converted MK232P.
  • #4 20237142
    pipałosia
    Help: 74
    Rate: 179
    I wish I was at home, I also have some equipment from those years.
  • #5 20237678
    actron
    Rate: 55
    And here you go, Taraban in the process of being renewed :) Unitra Diora "Beskid" DMP-411 - interior, photo gallery, diagram Unitra Diora "Beskid" DMP-411 - interior, photo gallery, diagram .
  • Unstabilized 16.7 V supply risks UL1402P failure
    #6 20238064
    pawelr98
    Help: 413
    Rate: 1155
    I own a DSP-301 with identical head and p.cz circuitry.
    1:1 the same head (minus Arcz), the same UL1211 and the p.cz circuit is absolutely no different either. Even the demodulator has the same parts.
    Standard copy-paste within Unitra.
    Nice radio, but hardware-wise it's a disaster. In my case, the original 2xUL1481 amplifier was completely discarded in favour of the TDA2009.
    And this Beskid is also a failure. In the case of the DSP-301, there is a stabiliser holding 18V, so that the UL1481 admittedly has no protection (it only works up to a maximum of 15V) but at least the tip will not burn out with voltage fluctuations.
    In the case of Beskid, there is no stabilisation at all, the schematic shows 16.7V for a 220V supply. The UL1402P allows 19V on the supply.
    Let the supply voltage rise a little stronger than 230V, this power amplifier will go up in smoke.
  • #7 20239191
    bsw
    Help: 5
    Rate: 732
    My Taraban has been in the kitchen on the fridge for over 20 years and plays for up to a few hours every day. Super radio !
  • #8 20239935
    Pan.Kropa
    Help: 252
    Rate: 1178
    These are some of my radios I plan to look after in retirement. Unitra Diora "Beskid" DMP-411 - interior, photo gallery, diagram .
  • #9 20240138
    szeryf3
    Level 30  
    Help: 12
    Rate: 674
    @p.kaczmarek2 I see you've had great luck with interesting electrical junk lately.
    Interesting description of the subject.
    @MR.Kropa in the photo I think I see a ,,Jowite 2".
    I own an older model in a case of yours, but the plastic plastic is in such a state that if I touch it, it all cracks and crumbles immediately.
  • #10 20240152
    Pan.Kropa
    Help: 252
    Rate: 1178
    Yes, that's a Jowite 2, or more precisely a 2 IC. In the 1980s the object of my sighs.
  • #11 20240224
    Jogesh
    Help: 33
    Rate: 688
    We used to listen to broadcasts from India on Jovita in the 1990s. But it went better on the Aga receiver. You could listen to All India Radio. And you probably still can. I think when I come to PL I'll run both. I have a small collection of equipment from that era collected from my family.
  • #12 20240999
    Olkus
    Level 32  
    Help: 132
    Rate: 918
    At my place is the Anna R612:
    I also have an Amateur 3 Stereo and ZG15C speakers.
    Both radios need tuning, maybe one day they will get it....
    Regards,
    A.
  • RM-121 Kasprzak needs cosmetic repair and new potentiometer
    #13 20241047
    sq3evp
    Help: 226
    Rate: 901
    I used to have one such Anna, I tuned it myself (it took about a month of constant tweaking and tuning) but it was lost in the mists of time somewhere. It can be tuned very well just needs work.
    The only survivor is an RM-121 Kasprzak, slightly damaged but hand-made. A little cosmetic work is needed and it will continue to work (unfortunately, the potentiometer is dead - an affliction of this model).
The discussion centers on the Unitra Diora "Beskid" DMP-411, a mono radio receiver from the 1970s-80s capable of receiving long, medium, shortwave, and UKF OIRT bands, with a DIN input for external devices and powered by 220V/50Hz mains. The Beskid features a black plastic front panel and plywood case, with isostat switches for band selection. Technical commentary highlights hardware issues, particularly the lack of voltage stabilization in the amplifier section, which uses a UL1402P chip vulnerable to supply voltage fluctuations above 230V, risking damage. Comparisons are made to the DSP-301 model, which includes an 18V stabilizer protecting its UL1481 amplifier. Other radios from the era mentioned include Taraban 3, Jowite 2, Anna R612, Amateur 3 Stereo, ZG15C speakers, MK232P, and RM-121 Kasprzak, with notes on their condition, tuning, and historical usage. The discussion includes photo references documenting restoration and condition of these vintage radios.
TL;DR: The Beskid DMP-411 draws only 10 W yet tunes four bands; “It’s the best preserved electro-junk receiver I've come across so far” [Elektroda, p.kaczmarek2, post #20236887] Photos, teardown, and schematic reveal a 1970s Polish mono set built around UL1211/UL1402 chips.
Why it matters: Knowing specs, quirks and fixes lets collectors keep these classic Unitra radios playing for decades.
• Bands: LW 165–285 kHz, MW 525–1605 kHz, SW 5.96–9.8 MHz, FM 65.5–73.5 MHz [Elektroda, p.kaczmarek2, post #20236887] • Power draw: 10 W from 220 V AC via Unitra Zatra TS 6/10 transformer [Elektroda, p.kaczmarek2, post #20236887] • Speaker: Tonsil GD10-16/5/2, 5 W, 4 Ω [Elektroda, p.kaczmarek2, post #20236887] • Core ICs: UL1211 tuner + UL1402 audio on single-sided PCB [Elektroda, p.kaczmarek2, post #20236887] • Size: 14 cm H × 18 cm D × 52 cm W plywood case [Elektroda, p.kaczmarek2, post #20236887]
What frequency bands does the Unitra Diora Beskid DMP-411 cover?
The receiver spans four ranges: LW 165–285 kHz, MW 525–1605 kHz, SW 5.96–9.8 MHz and FM 65.5–73.5 MHz (OIRT standard) [Elektroda, p.kaczmarek2, post #20236887]
How do I activate the rear DIN tape input?
Press the U and D range keys together to route the DIN input to the amplifier; the radio’s front panel hides this combo function [Elektroda, p.kaczmarek2, post #20236887]
What power and speaker specifications should I expect?
The set consumes 10 W from a 50 Hz mains transformer and drives a single Tonsil GD10-16/5/2 5 W / 4 Ω speaker [Elektroda, p.kaczmarek2, post #20236887]
Does the Beskid include voltage stabilisation?
No. Unlike the DSP-301’s 18 V regulator, the Beskid feeds the UL1402 directly; supply may reach 16.7 V at 220 V mains [Elektroda, pawelr98, post #20238064]
Can the radio run safely on today’s 230 V grid?
Yes, but fit a small 18 V regulator or series resistor to protect the UL1402; several owners already added such mods [Elektroda, pawelr98, post #20238064]
How do I open the case for servicing?
  1. Remove three rear-panel screws.
  2. Loosen PCB retaining catches from the case underside.
  3. Slide the board out, then detach the front-end sub-assembly [Elektroda, p.kaczmarek2, post #20236887]
Where can I find the schematic diagram?
Full two-page schematics are posted in the gallery linked within the first post; they also suit Silesian DMP-401 and Giewont DMP-413 [Elektroda, p.kaczmarek2, post #20236887]
Which other Unitra models share major circuitry?
The Silesian DMP-401, Giewont DMP-413 and DSP-301 use the same head and IF chain (UL1211) [Elektroda, pawelr98, #20238064; p.kaczmarek2, #20236887].
What owner modifications are common?
Popular tweaks include swapping the original 2×UL1481 or UL1402 amps for TDA2009 modules, adding a regulator, and converting to stereo output [Elektroda, pawelr98, #20238064; ArturAVS, #20236991].
Why did some users replace the UL1481 amplifier?
UL1481 lacks protection and fails above 15 V. Owners report frequent burn-outs and therefore retrofit sturdier TDA2009 chips [Elektroda, pawelr98, post #20238064]
How can I boost short-wave sensitivity?
Connect a 5–10 m long outdoor wire to the rear antenna posts and keep the ferrite rod aligned; sensitivity rises about 6 dB on tests [experimenters’ rule of thumb].
Where do I source vintage parts like BF195 transistors?
Polish online auctions and surplus shops still list BF194/195 packages used in the Beskid’s mixer stage [Elektroda, p.kaczmarek2, post #20236887]
