Teardown & Flashing Guide: BK7231N LSC 200 LED Multicolor Smart Light GP-SWXXXDCXXXX(EU)-1C Plug
gi7mo1 2919 9
How do I configure a GP-SWXXXDCXXXX(EU)-1C smart LED light that uses a BK7231N chip, and does it need a custom driver?
It appears to need a BK7231N/Beken configuration and a custom driver rather than a standard ESP/Tasmota template [#20281251][#20281759] The strip does not look like a WS2812 device; it has only two connector pins and is likely controlled as a non-addressable LED load with a single selected color/function [#20281251] The thread also notes a broader migration from ESP-based Tuya modules to Beken MCUs, which explains why older ESP templates may no longer work [#20281759]
  • BK7231N flashing via UART with CEN pull-down
    #1 20280294
    gi7mo1
    Teardown of GP-SWXXXDCXXXX(EU)-1C plug
    Internally it has a vertically mounted wifi board with tuya and a BK7231N
    You can push the cover (where the led strip is connected to) pretty easily up to open the electronic compartment
    Pull out the pcb by grabbing it with a plier
    Was able to flash the chip with
    python uartprogram OPENBK...bin -d comX -w -u -s 0x0
    sometimes I had to pull down CEN to get a bus
    when you are getting "WriteSector 1 failed" try another usbttl converter
    with my first one I constantly got the errors
    module configuration is currently unknown, help is appreciated
  • #2 20281116
    Rate: 12880
    Hello, I will try to help you, can you please provide some more information what kind of IC is used for this device? Your teardown lacks this crucial information currently. Is it some kind of WS2812b device?
    Is device able to display multiple colors at the same time (on multiple LEDs, of course)?
  • BK7231N board with two-pin 6 V strip output
    #3 20281251
    gi7mo1
    hey, thanks for your reply
    the ic is the BK7231N or what do you need?
    i made a picture of the wifi/control board during flash
    on the back are no more components, just some breakout solder points
    as far as i understood this light strip with only one single color (but that you can choose) for all
    but, as i never tried, i can't really tell
    i don't think it's a ws2812* device as communication is only via 6v and/or -6v
    there are only two connector pins to the strip
  • #4 20281285
    leoshusar
    Level 4  
    I found this, it is ESP version, but the rest might be the same
  • #5 20281291
    gi7mo1
    yes, that was the reason why I brought it
    but I was unable to flash Tasmota, so I dig deeper
    and that was the result here :-D
  • #6 20281293
    Rate: 12880
    This is indeed a useful information. I will look into that tomorrow in detail.
    Are you saying that this device used to be based on ESP8266 (85?), and now is using Beken?
  • #7 20281500
    leoshusar
    Level 4  
    It looks like. But it would be nothing new, there are many templates for Tasmota which say "this device is now being shipped with Beken MCU".
  • Custom driver needed for BK7231N migration
    #8 20281759
    Rate: 12880
    So you think it's fair to say that there is a trend of migration from ESP to BK?
    Well, don't worry, I got it covered. From what I've seen, it indeed requires a custom driver. I will try to port that one soon. Please wait, let's hope, a day or so... but I am not sure right now how hard can it be.
    By the way, here are further device specs:
    ModelGP-SWXXXDCXXXX(EU)-1C,IP20 SERIES,GP-SWXXXDCXXXX-IP44(EU)-1C,IP44 SERIES
    Physical dimensionL x W x H : 113.5mmx 42mmx42 mm
    Input voltage100-240V~
    Input frequency50-60Hz
    Output voltage3-42VDC
    Output current20-1200mA
    Output Power6W Max
    Special functionOCP,SCP
    HIPOT Testing3000Vac/5mA/Min
    AC pin typeEU
    Mean time between failures50,000 HOURS AT FULL LOAD AND 25°C AMBIENT
    Application LED Driver
    Safety certificationEN 61347-2-13:2014+A1:2017;EN 61347-2-11:2001;EN 61347-1:2015;EN 62493:2015
    Safety regulations and Electromagnetic interference standardsEN 55015:2013+A1:2015;EN 61547:2009;EN 61000-3-2:2014;EN 61000-3-3:2013
    Energy efficiency standardsVI
    Protection indexIP20-IP44(Indoor/Outdoor use)
    Burn-in100% Full Load Burn in
    Operating temperature-20~40℃
    8 functions1.COMB 2.IN WAVES 3.SEQUENTIAL 4.SLO-GLO 5.CHASING/FLASH 6.SLOW FADE 7.TWINKLE/FLASH 8.STEADY ON
    TimingPerform free setting for 0-24 hours
    DimmingFour Dimmer:100%、75%、50% 、25%
  • #9 20281853
    gi7mo1
    thanks for helping me out with that
    if you need some help with testing, just give me a ping
  • #10 20281882
    leoshusar
    Level 4  
    I would say so. Copy and paste this to Google:
    "New Tuya devices have replaced their Wi-Fi module with one incompatible with Tasmota" site:templates.blakadder.com
    and it will show around 1020 results (there might be some duplicates).
The discussion revolves around the teardown and flashing of the BK7231N-based GP-SWXXXDCXXXX(EU)-1C LED multicolor smart light plug. The user successfully opened the device, revealing a vertically mounted Wi-Fi board with Tuya integration. They managed to flash the chip using a specific command but encountered issues with USB TTL converters, suggesting that different converters may yield varying results. The conversation highlights a trend of migrating from ESP-based devices to those using Beken MCUs, with users sharing insights on device specifications, flashing challenges, and the need for custom drivers for compatibility with Tasmota firmware. Additional technical details about the device's electrical specifications and safety certifications were also provided.
