[BK7231T] OXT 1ch WiFi Tuya dimmer - OpenBeken dimming / MCU problem
koloksk1 3078 10
Why does the dimming control not work in OpenBeken on this OXT 1-channel Tuya dimmer, and how should it be configured or wired to control the MCU correctly?
The dimming control likely fails because this board is not behaving like a normal TuyaMCU device, and the assumed P7/dInput setup conflicts with the dimmer channel [#20418157][#20419726] First, remove all dInput roles, reboot, and test only the basic TuyaMCU mapping with `setChannelType 1 toggle`, `setChannelType 2 dimmer`, `tuyaMcu_setDimmerRange 0 1000`, and the two `linkTuyaMCUOutputToChannel` commands, then watch the logs at level 7 [#20418577][#20418651] The logs showed TuyaMCU debug messages but no real MCU traffic, changing the baud to 115200 did not help, and the RX path may not even be physically connected on this module [#20418651][#20419726] A later hardware check suggested P7 (PWM1) is connected to nothing, and the BK7231T may communicate with the HK32F030MF4P6 only through TX and SCK, so the interface may not be standard UART/TuyaMCU at all [#20425864][#20425887] If you want to keep testing, try a logic analyser and, as a fallback, send manual UART packets at 9600 baud with `startDriver TuyaMCU` and `uartSendHex`, since another similar dimmer responded to direct brightness frames rather than normal channel mapping [#20425887][#20507842]
  • Suspected MCU communication issue blocking dimming control
    #1 20417634
    koloksk1
    After uploading the OpenBeken software to the dimmer module, configuring the ports, the dimming control does not work. The LED, the button on the board and the external one work normally. I think there might be a communication problem, with the MCU (HK HK32F030MF4P6 MCU model). I was able to get the MOSFET on by setting the P7 port to dInput channel 2 (doesn't always work). Maybe someone knows how to solve this problem?
    I am using the script:
    startDriver TuyaMCU
    linkTuyaMCUOutputToChannel 2 2 2
    Pictures of the module:
    [BK7231T] OXT 1ch WiFi Tuya dimmer - OpenBeken dimming / MCU problem.
    Photo source: https://github.com/arendst/Tasmota/discussions/14506
    List of ports:
    P6(PWM0) - external switch (S1)
    P7(PWM1) - ?
    P8(PWM2) - LED diode on board
    P9(PWM3) - button on board
    List of Tuya DPID:
    1 - switch
    2 - dimmer
  • Avoiding dInput and dimmer on channel 2
    #2 20418157
    Rate: 12806
    Hello, you have an interesting device, I haven't seen it before and haven't analysed it, but I'll try to help "in the dark" somehow.
    koloksk1 wrote:
    Mosfet I've managed to switch on by setting port P7 to dInput channel 2 (doesn't always work).
    dInput copies the High/Low value from a given pin to the channel, using this you cut off the ability to control over the network. I guess you rather want to use TglChannelOnToggle, then changing the state on the switch switches the channel to the opposite state, so control over WiFi also works.
    koloksk1 wrote:
    I use the script:
    startDriver TuyaMCU
    Wait, so you are using channel 2 as a dimmer (dimmer) and as a dInput value at the same time? After all, dInput will set this channel to a value of 0 or 1 for you, and it will still overwrite the dimmer value from this channel. You can't store two things in one variable.
    You must either give your dInput channel to something other than channel 2 (e.g. free 3), or give the dimmer channel (dimmer) to a different slot than the 2.
    Recall the syntax of linkTuyaMCUOutputToChannel :
    linkTuyaMCUOutputToChannel	[dpId][varType][channelID]
    [BK7231T] OXT 1ch WiFi Tuya dimmer - OpenBeken dimming / MCU problem .
  • dInput on channel 2 overwrites dimmer value
    #3 20418567
    koloksk1
    You either have to give your dInput channel to something other than channel 2 (e.g. free 3), or give the channel with the dimmer (dimmer) to a different slot than the 2.
    Buttons(toggle, dimmer) connected to the tuyamcu are not responsive from the beginning, i.e. before setting dinput to P7. Therefore I was looking for another way to switch on the mosfet and by chance I noticed that after setting dinput the mosfet sometimes switches on.
    I also add that I have no communication logs from tuyamcu, only the message about the driver switching on is displayed.
  • Reset dInput roles and test TuyaMCU control script
    #4 20418577
    Rate: 12806
    It's become too much of a chaos, you can get lost.
    One by one.... logs.
    I would start with this.
    Then.... I would unset all dInput settings, i.e. set all pins to no role.... so they don't mix...
    Then reboot, but with this script:
    Kod: [rozwiń] [zaznacz wszystko][Kopiuj do schowka]
    startDriver TuyaMCU
    And then I'd check if anything at all reacts to the controls from the web panel, i.e. the toggle control (here channel 1) and the slider control (here channel 2).
    It's also possible to try looking in a completely different place.... for example, is the communication with the MCU alive at all? Or maybe a different baud needs to be set? Have you performed any tests with the uart sniffer? Rather not?
    tuyaMcu_setBaudRate 115200
    And do you have MQTT connected?
  • Clear config and test TuyaMCU channel mapping
    #5 20418651
    koloksk1
    There's too much chaos, you can get lost.
    Then ... I would unset all dInput settings, i.e. set all pins to no role.... so they don't mix...
    Code: [expand] [select all][Copy to clipboard]
    startDriver TuyaMCU
    linkTuyaMCUOutputToChannel 1 1 1
    I would then check if anything responds at all to the controls from the web panel, ie. on the toggle control (here channel 1) and the slider control (here channel 2).
    To be sure, I cleared the entire configuration.
    After changing the loglevel to 7 it started to show the messages:
    ExtraDebug:TuyaMCU:TuyaMCU heartbeat_valid = 0, product_information_valid=0, self_processing_mode = 1, wifi_state_valid = 0, wifi_state_timer=0
    and when changing the dimmer:
    Debug:TuyaMCU:TuyaMCU_OnChannelChanged: mapped value 100 (OpenBK7321T_App range) to 1000 (TuyaMCU range)
    You can also try to look quite elsewhere.... For example, is the communication with the MCU alive at all? Or maybe you need to set a different baud?
    Changing the baud to 115200 didn't do anything.
    Have you done any tests with the uart sniffer? Not likely?
    I haven't.
    Not currently.
  • TuyaMCU RX appears unconnected on this board
    #6 20419726
    Rate: 12806
    It does not appear from these logs that any communication with the MCU is occurring.
    Are you the author of these photos and posts from the linked Tasmota topic?
    Moment....
    From this photo (and from the LMA35 leads in the photo earlier), it appears that U1_RX, needed for the TuyaMCU is not connected at all! There is no physical connection between the RX port of the TuyaMCU and the TuyaMCU IC.
    Does this device use the TuyaMCU at all? Where did the dpIDs come from, how were they specified?
    Added after 1 [hour] 33 [minutes]:
    koloksk1 wrote:
    Mosfet I was able to enable by setting the P7 port to dInput channel 2 (doesn't always work)
    and if I would disable TuyaMCU completely, delete all autoexec.bat, reboot and set P11 (TX1) to Relay and try switching with it?
  • TuyaMCU presence and dpID derivation questioned
    #7 20420468
    koloksk1
    I am not the author that's why I gave the source. My module is identical and the same chip ZH-Z06-A rev.A is in it .
    I am uploading some of my photos.
    [BK7231T] OXT 1ch WiFi Tuya dimmer - OpenBeken dimming / MCU problem [BK7231T] OXT 1ch WiFi Tuya dimmer - OpenBeken dimming / MCU problem [BK7231T] OXT 1ch WiFi Tuya dimmer - OpenBeken dimming / MCU problem
    Does this device use TuyaMCU at all? Where did the dpID come from, how was it determined?
    dpID I deduced according to this guide
    https://www.zigbee2mqtt.io/advanced/support-n...ya_data_points.html#_4-create-a-cloud-project
    Data from dump of default tuya soft (storage.json):
    	"gw_bi": {
    		"uuid": "8a3ee6ed8ec6c49c",
    		"psk_key": "xxx",
    		"auth_key": "xxx",
    		"ap_ssid": "SmartLife",
    		"ap_passwd": null,
    		"country_code": null,
    		"bt_mac": null,
    		"bt_hid": null,
    		"prod_test": false,
    		"fac_pin": "wpzhrpz3k0sxl6ew"
    	"gw_di": {
    		"abi": 0,
    		"id": "bf558876b13a40702dh8xx",
    		"swv": "1.0.2",
    		"bv": "40.00",
    		"pv": "2.2",
    		"lpv": "3.3",
    		"pk": "wpzhrpz3k0sxl6ew",
    		"firmk": null,
    		"cadv": "1.0.3",
    		"cdv": "1.0.0",
    		"dev_swv": "1.0.2",
    		"s_id": "0000037fs2",
    		"dtp": 0,
    		"sync": 0,
    		"attr_num": 0,
    		"mst_tp_0": 0,
    		"mst_ver_0": null,
    		"mst_tp_1": 0,
    		"mst_ver_1": null,
    		"mst_tp_2": 0,
    		"mst_ver_2": null,
    		"mst_tp_3": 0,
    		"mst_ver_3": null
    	"tls_ca_cnt": 0,
    	"gw_wsm": {
    		"nc_tp": 1,
    		"ssid": null,
    		"passwd": null,
    		"md": 0,
    		"random": 0,
    		"wfb64": 1,
    		"stat": 1,
    		"token": null,
    		"region": null,
    		"reg_key": null,
    		"dns_prio": 0
    	"is_stride": 0,
    	"gw_ai": {
    		"key": "xxx",
    		"lckey": "xxx",
    		"h_url": "http://a.tuyaeu.com/d.json",
    		"h_ip": "52.58.178.100",
    		"hs_url": null,
    		"hs_ip": null,
    		"hs_psk": "https://a3.tuyaeu.com/d.json",
    		"hs_psk_ip": "3.121.131.36",
    		"mqs_url": null,
    		"mqs_ip": null,
    		"mq_url": "m2.tuyaeu.com:1883",
    		"mq_ip": "18.192.43.219",
    		"ai_sp": null,
    		"ai_sp_ip": null,
    		"mq_psk": "m2.tuyaeu.com:8886",
    		"mq_psk_ip": "3.64.85.28",
    		"time_z": "+01:00",
    		"s_time_z": "[[1679792400,1698541200],[1711846800,1729990800]]",
    		"wx_app_id": null,
    		"wx_uuid": null,
    		"dy_tls_m": 2,
    		"cloud_cap": 1025,
    		"psk21_key": null
    	"0000037fs2": [
    			"type": "obj",
    			"mode": "rw",
    			"property": {
    				"type": "bool"
    			"id": 1
    			"type": "obj",
    			"mode": "rw",
    			"property": {
    				"min": 10,
    				"max": 1000,
    				"scale": 0,
    				"step": 1,
    				"type": "value"
    			"id": 2
    			"type": "obj",
    			"mode": "rw",
    			"property": {
    				"min": 10,
    				"max": 1000,
    				"scale": 0,
    				"step": 1,
    				"type": "value"
    			"id": 3
    			"type": "obj",
    			"mode": "rw",
    			"property": {
    				"min": 0,
    				"max": 86400,
    				"scale": 0,
    				"step": 1,
    				"type": "value"
    			"id": 6
    			"type": "obj",
    			"mode": "rw",
    			"property": {
    				"range": [
    					"off",
    					"on",
    					"memory"
    				"type": "enum"
    			"id": 14
    	"em_sys_env": "bk7231t",
    	"wf_start_md": 3,
    	"timer_arr": {
    		"lastFetchTime": 0,
    		"cnt": 0
    I have the entire fw tuya dump from before the openbeken installation, if needed for analysis I can upload it.
    And if I would disable TuyaMCU completely, delete all autoexec.bat, reboot and set P11 (TX1) to Relay and try switching with it?
    I checked, still zero response.
  • P7 appears unconnected in simplified wiring diagram
    #8 20425864
    koloksk1
    After a preliminary analysis of the paths, I came to the conclusion that pin P7 (PWN1) is not connected to anything. And it looks like the BK7231T communicates with the HK32F030MF4P6 chip using only the tx and sck pins. I made a simplified wiring diagram:
    Some additional pictures:
    [BK7231T] OXT 1ch WiFi Tuya dimmer - OpenBeken dimming / MCU problem [BK7231T] OXT 1ch WiFi Tuya dimmer - OpenBeken dimming / MCU problem [BK7231T] OXT 1ch WiFi Tuya dimmer - OpenBeken dimming / MCU problem [BK7231T] OXT 1ch WiFi Tuya dimmer - OpenBeken dimming / MCU problem [BK7231T] OXT 1ch WiFi Tuya dimmer - OpenBeken dimming / MCU problem
  • Suggesting logic-analyzer tracing of the dimmer interface
    #9 20425887
    Rate: 12806
    As I wrote - in my opinion it is not TuyaMCU.
    It's rather impossible to transfer the UART from certain pins to BK, always the same pins are UART1 and UART2.
    It would be best to check it with some logic analyser, possibly for principle you can still check if it's not something like one signal 1 or 0 to switch on the dimmer and the other is e.g. PWM to set the brightness.... but I don't think so.
    Maybe it's something like I2C, but that's not clear from the pins either, is it? On the table I see some I2C but not where we want it...
    Tough situation. This is the first time I have encountered this. You were exceptionally unlucky to come across a device with something not as common as the TuyaMCU, which could be easily grasped and is already supported.
    Is it possible to buy this dimmer somewhere, but with this particular interior, to analyse it quietly on the factory insert?
  • Manual TuyaMCU packets control brightness at 9600 baud
    #11 20507842
    Rate: 12806
    Hello, after testing another dimmer that only communicated via TX with the MCU, I suggest you try to do manually:
    startDriver TuyaMCU
    And then try to send these packets, they should change the brightness level:
    This works (very bright): uartSendHex 0AFF5502FFF100000A
    It works (very dark): uartSendHex 0AFF5502003F00000A
    It works (disabled ): uartSendHex 0AFF5502000F00000A
    It works (ultra dark): uartSendHex 0AFF55020F1F00000A
    It works (ultra dark): uartSendHex 0AFF5502001F00000A
    It works (semi dark): uartSendHex 0AFF5502005F00000A
    It works (light?): uartSendHex 0AFF5502009F00000A
    Summary:
    The package is like this: uartSendHex 0A FF 55 02 00 9F 00 00 0A
    A I guess 9F is the brightness value...
    This at baud 9600.
✨ The discussion revolves around issues with the OXT 1ch WiFi Tuya dimmer after uploading OpenBeken software. The user reports that while the LED and buttons function correctly, the dimming control fails, possibly due to a communication problem with the HK32F030MF4P6 MCU. Various troubleshooting steps are suggested, including adjusting channel settings, checking physical connections, and analyzing communication logs. It is noted that the P7 pin may not be connected, and the device might not utilize TuyaMCU as expected. Suggestions include using a logic analyzer for further diagnostics and testing with different baud rates. The user also shares links to images of the module and configuration details.
