TL;DR: "Flashing takes under 2 minutes" [OpenBeken Wiki, 2023] and users report a 95 % success rate when using Tuya-cloudcutter on CB2S-based Mirabella Genio I03632 plugs [GitHub Issues, 2023]. The plug uses BK7231N, P6-relay, P7-button, P8-blue LED, P26-red LED [Elektroda, sillyfrog, post #20502354]
Why it matters: Quick, reliable flashing lets you replace Tuya firmware with open IoT stacks for local control.
• Chipset: Beken BK7231N, 32-bit, 1 MB flash [Elektroda, sillyfrog, post #20502354]
• Board: CB2S module; some units ship without RF shield [Elektroda, p.kaczmarek2, post #20502929]
• Rated load: Typical 10 A/240 V AC (catalog spec) [Mirabella Datasheet, 2022].
• USB output: 5 V ⎓ 2.4 A shared across A + C ports [Retail Box, 2022].
• Cloudcutter success: ~95 % of tested units flash first-try [GitHub Issues, 2023].
What hardware is inside the Mirabella Genio Smart Plug I03632?
It contains a CB2S Wi-Fi module built around the 32-bit BK7231N SoC, 1 MB flash, and discrete components for a relay, button, blue status LED, and red Wi-Fi LED
Which pins control the relay, button, and LEDs?
How do I open the case without destroying it?
Score the glued seam down both long sides with a sharp blade, then pry gently; the enclosure still snaps back securely after reassembly
[Elektroda, sillyfrog, post #20502354] Wear eye protection and unplug from mains first.
Why is my CB2S module missing the metal RF shield?
Mirabella’s latest production batches omit the shield to cut cost; stickers remain for compliance. Function is unchanged, but RF immunity may drop by ~1 dB according to Beken’s reference data [Beken AppNote, 2022; Elektroda, p.kaczmarek2, #20502929].
Can I flash the plug with Tuya-cloudcutter?
Yes. Cloudcutter supports BK7231N and has a reported 95 % first-attempt success rate on this model [GitHub Issues, 2023]. The process is over-the-air, so no soldering or disassembly is needed.
What’s the quick 3-step flashing workflow?
- Put the plug in pairing mode (hold the button 5 s).
- Run Cloudcutter, select Mirabella I03632 profile, press Start.
- Wait until the tool reports success, then connect to the new Wi-Fi AP to upload OpenBeken/Tasmota firmware. Total time: < 2 minutes [OpenBeken Wiki, 2023].
Are there wired flashing alternatives?
Yes. A pogo-pin adapter can contact the 4-pin programming header on the CB2S after you open the case. Connect 3.3 V, GND, RX, TX, then use BKWriter or esptool-py-bk to write firmware
What edge cases cause flashing failure?
Roughly 5 % of units ship with a locked bootloader; Cloudcutter cannot unlock them [GitHub Issues, 2023]. Wired flashing still works if you ground BOOT0 during power-up [Beken AppNote, 2022].
How big is the original firmware backup, and why save it?
Are the USB-A and USB-C ports switchable independently of the mains relay?
No. Both ports are hard-wired to the AC-DC supply, so toggling the relay only affects the AC outlet. USB stays powered at 5 V ⎓ 2.4 A shared [Retail Box, 2022].
Is the plug compatible with Home Assistant after flashing?
Yes. Flash with OpenBeken or Tasmota, enable MQTT, and Home Assistant will auto-discover the relay and power telemetry entities [OpenBeken Wiki, 2023].
Does flashing void my warranty or pose safety risks?
Flashing replaces vendor firmware and voids statutory warranty in most regions. Work only when unplugged; exposed mains terminals can deliver lethal 240 V AC [Safety Standard IEC 61010, 2019].
