Teardown of a Smart Life Curtain (Shutter) switch, Flashing, Configuring and setting up with HA
richardsg307 11490 32
  • Teardown and conversion of a Smart Life DS-151 N+L WiFi+BLE curtain switch and skylight opener, replacing Tuya firmware with OpenBeken for Home Assistant control.
  • A WB3S module with BK7231T was flashed after cutting the TXD1/RXD1 tracks, because BK_Writer failed and the hid_download_py Python method succeeded.
  • The controller uses 3 buttons, 3 LEDs, and 2 relays, and the skylight run time was increased from 10 seconds to 15 seconds.
  • An autoexec.bat script emulates the original Tuya behavior, and Home Assistant MQTT buttons trigger Open, Stop, and Close commands successfully.
  • Default GUI buttons were hidden to avoid energizing both relays at once, since the actuator’s behavior in that case was uncertain.
  • #31 21752581
    Rate: 12914
    Can you also copy paste a JSON for us - either from Tuya config (Tuya json) or OBK template?
    Added after 13 [seconds]:
    We need it for this page: https://openbekeniot.github.io/webapp/devicesList.html
  • Physical LED button color cannot be changed in autoexec.bat
    #32 21752890
    Romanusss
    >>21752581
    Sure, please find the JSON,
    Added after 17 [minutes]:
    >>21752890
    Hi again,
    The only thing I can't change is the color of the physical LED button, it stay blue and change to red in action.
    I've tried to do in autoexec.bat but it seems to only handle logical button into OpenBeken and not the physical ones.
    Do you have any idea?
  • Request for native Home Assistant cover integration
    #33 21758553
    Acefx
    heyyy long time since we discussed.
    @p.kaczmarek2 any news about a proper driver in C for the covers ?
    I'm now migrating on home Assistant, and the 3 relays discovery isn't the best integration.
    Do you know how we could have a native integration with Homeassistant discovery ?
    Real cover entitie
    Wifi and uptime information
    Led Off/ON preference ?
    I have 23 cover in here to migrate... quite a pain with a yaml trick to transform it ;-)
    All the best
Discussion about reverse-engineering and flashing a Smart Life / Tuya curtain and roller-shutter switch based on WB3S/CB3S modules with BK7231T/BK7231N chips, then configuring it in OpenBeken for Home Assistant use. The thread covers wiring of a skylight/roller shutter motor, firmware dumping, OTA flashing, pin mapping, and the need for an autoexec.bat script to implement shutter logic such as open/close/stop, relay interlocking, timing-based travel calibration, and percentage position control. Several users report successful operation after importing Tuya configuration, while others ask for improvements such as native MQTT/HA cover entities, proper stop handling, and a dedicated C driver compatible with Tasmota-style commands.
TL;DR: This FAQ covers 15 practical DS-151/OpenBeken shutter lessons; “NEVER power the two direction in the same time” is the core safety rule. It helps Home Assistant users flash BK7231T/BK7231N curtain switches, map pins, script safe relays, and avoid MQTT hazards. [#20640181] Why it matters: A wrong shutter configuration can energize Open and Close together, risking motor, relay, or switch damage.
Approach Chip or platform Strength Limitation
OpenBeken script BK7231T/BK7231N, WB3S/CB3S Works locally with autoexec.bat and MQTT commands No native cover driver in the thread
Original Tuya firmware Tuya Smart Life Operates 3 buttons and 2 relays out of the box Cloud-based unless kept in Tuya ecosystem
Tasmota-style shutter logic Referenced as target behavior Uses travel times and position calculation Not yet implemented as OpenBeken C driver in the thread
Key insight: Treat the DS-151 as a two-direction motor controller, not as two independent switches. Safe control requires scripts or a future driver that interlocks relays before Home Assistant or MQTT can operate it.
  • The DS-151 example uses a WB3S module with a BK7231T processor, 3 touch buttons, 3 LEDs, and 2 relay outputs. [#20547099]
  • UART flashing used TXD1, RXD1, GND, and VCC pads with a USB/UART adapter set to 3.3 V. [#20547099]
  • The skylight actuator wiring was 4-wire mains: Earth, Neutral, Live Open, and Live Close. [#20547099]
  • The successful flash command used 115200 baud and wrote OpenBK7231T_UA_1.15.700.bin through com3. [#20547099]
  • The working script used channel 60 as a movement timer, changed from 10 s to 15 s, then used 20 s for safer closing. [#20555187]
How do I flash OpenBeken onto a Smart Life DS-151 WiFi+BLE curtain switch with a WB3S BK7231T module?
Flash it by UART after exposing the WB3S pads and using the BK7231T OpenBeken binary.
  1. Solder TXD1, RXD1, GND, and VCC.
  2. Use a 3.3 V USB/UART adapter and cut interfering tracks if flashing fails.
  3. Run python uartprogram ...OpenBK7231T_UA_1.15.700.bin -d com3 -w -b 115200. After flashing, repair the cut tracks with solder or fine wire. [#20547099]
Why does BK_Writer fail when flashing a DS-151 curtain switch, and how do the TXD1 and RXD1 circuit tracks interfere with UART flashing?
BK_Writer can fail because DS-151 circuitry also uses TXD1 and RXD1 for normal hardware functions. TX is used as a button input, and RX is used as an LED output. That extra circuitry interferes with UART signalling during flashing. Cutting the tracks from those pins allowed progress, but BK_Writer still failed at default settings. The Python UART method succeeded at 115200 baud. [#20547099]
What is OpenBeken, and how is it different from Tasmota for BK7231T and BK7231N smart switch modules?
OpenBeken is firmware for Beken-based smart devices that replaced the cloud firmware in this DS-151 case. "OpenBeken is an alternative IoT firmware that runs on BK7231T and BK7231N modules, providing local configuration, scripting, web control, and MQTT integration without relying on the original Tuya cloud." Tasmota was mentioned as familiar ESP8266 firmware and as a model for future shutter commands. [#20547099]
How should the pins be configured in OpenBeken for the Smart Life DS-151 curtain switch with Open, Stop, Close buttons, LEDs, and two relays?
Configure the BK7231T DS-151 with relays on pins 6 and 9, buttons on 8, 10, and 24, and inverted LEDs on 11, 14, and 26. The working mapping used Rel;1 on pin 6, Rel;3 on pin 9, Btn;3 on pin 8, Btn;2 on pin 10, and Btn;1 on pin 24. It used LED_n for the three button lights. [#20547099]
How do I write an autoexec.bat script in OpenBeken to safely control a skylight or roller shutter without powering both relays at once?
Write aliases that stop all movement before energizing Open or Close. The shared script used Set_Stop to set channels 1, 2, and 3 to 0, then Set_Open or Set_Close. It added stopAllScripts before each new motion. Channel 60 stored the movement time, set to 15 s in the example. The script hid default GUI channels because they could switch both relays on together. [#20547099]
What is autoexec.bat in OpenBeken, and where do I place it on a Teekar or DS-151 shutter switch?
autoexec.bat is the OpenBeken startup script file used to define aliases, buttons, event handlers, and relay logic. "autoexec.bat is a device-side startup script that runs OpenBeken commands automatically, letting the switch create safe Open, Stop, and Close behavior after boot." The thread points Teekar and DS-151 users to the OpenBeken autoexec tutorial for placement and upload details. [#21213675]
How do I connect an OpenBeken curtain switch to Home Assistant using MQTT and create Open, Stop, and Close dashboard buttons?
Configure MQTT in OpenBeken with broker IP, port, user, password, and client topic such as skylight. Copy the generated YAML into Home Assistant configuration.yaml. Then create dashboard buttons that call mqtt.publish. The working card published to cmnd/skylight/Start_Opening, cmnd/skylight/Stop_All, and cmnd/skylight/Start_Closing. That approach calls script aliases instead of raw relay states. [#20547099]
Why is it dangerous to control OpenBeken shutter relays directly through MQTT, and how can MQTT commands trigger Start_Opening, Stop_All, and Start_Closing instead?
Direct MQTT relay control is dangerous because it can turn both direction relays on at once. That can damage the motor or switch. Users reported raw channel MQTT only exposed relay behavior, not the scripted logic. Use command topics that call the aliases instead: Start_Opening, Stop_All, and Start_Closing. In the working Home Assistant card, each button published to a cmnd/skylight/... topic. [#20664100]
How can a roller shutter or skylight controller estimate opening percentage from relay run time, and what causes position drift over time?
It can estimate position by timing relay run duration against calibrated full-travel times. For example, a 17 s actuator travel time makes 8.5 s approximately 50%. The thread warns this can drift because the script only knows how long the relay was on, not the true position. A stop halfway, manual movement, or limit cut-out can desynchronize the estimate. Resetting at 0% can reduce drift. [#20555187]
What safety checks are needed before using a time-based OpenBeken shutter script with skylights, blinds, or roller shutters?
Verify end-stop or stall protection before relying on timed relay control. The skylight actuator stopped gracefully at limits or when the motor stalled. The author warned users to ensure blinds have similar cut-outs. Also confirm the script never powers Open and Close together. Use an initial short time, such as 10 s or 15 s, before extending closing to 20 s. [#20555187]
How do I troubleshoot a DS-151 switch where Open or Close stays on and the Stop button does not respond after flashing OpenBeken?
Add the required autoexec.bat script before testing shutter behavior. A user reported Open or Close staying on and Stop not responding with the listed DS-151 pin settings. The fix was not a new pin map. Another participant identified the missing autoexec.bat entries as the cause. After adding the script, the user confirmed it worked perfectly. [#20871172]
How do I use Tuya config extraction in OpenBeken to fix pin mappings on a DS-151 with a CB3S or BK7231N chipset?
Use Tuya config extraction first when a CB3S or BK7231N DS-151 behaves differently from the WB3S template. The thread shows a CB3S unit improved after importing the extracted Tuya configuration. The extracted JSON included module: CB3S, bt1_pin: 24, bt2_pin: 20, bt3_pin: 7, rl1_pin: 6, and rl3_pin: 8. [#21752890]
What does the OpenBeken log message “Button_OnLongPressHold” on pin 8 mean on a DS-151 BK7231N curtain switch?
It means OpenBeken sees pin 8 as a button held continuously. The maintainer explained that a permanent short to ground would produce that log when the pin is configured as a button. On the reported BK7231N DS-151, close and stop did not respond. The suggested next step was Tuya config extraction, then PCB tracing or multimeter checks if needed. [#21752395]
How can the physical button LED colors on a DS-151 or CB3S curtain switch be changed in OpenBeken when setButtonColor only affects logical web buttons?
The thread does not provide a confirmed method for changing physical LED colors. A CB3S user reported that physical LEDs stayed blue and changed to red during action. They tried setButtonColor in autoexec.bat, but it affected only logical OpenBeken web buttons. No later post in the supplied thread gives a working physical LED color command or driver setting. [#21752890]
What would a proper OpenBeken C shutter or cover driver need to support for Home Assistant discovery, cover entities, position control, WiFi status, uptime, and LED preferences?
A proper driver would need interlocked Open and Close relays, Stop handling, travel timers, percentage position, and Home Assistant cover discovery. Users requested 3 physical buttons, 3 LEDs, WiFi status, uptime, LED on/off preference, and native cover entities instead of 3 relay entities. One user also listed a 2-minute default movement countdown and a 15 ms delay when reversing direction. [#20640181]
