Trouble reading analog signals on BK7231N via P26/ADC1, P24/ADC2, P28/ADC4, P22/ADC5, and P21/ADC6
cuemaxx 1404 5
  • #1 20644311
    cuemaxx
    I have a BK7231N and have successfully configured the battery monitoring via P23/ADC3 readout so far. However, I would like to read another analog signal. Per datasheet, the BK7231N has additional ADCs: P26/ADC1, P24/ADC2, P28/ADC4, P22/ADC5 and P21/ADC6. However, when I set those pins to "ADC" via webconfig and assign a channel, the channel on the web UI reads '-1.00'. Reading out P23/ADC3 works completely fine.
    Could that be due to hal_adc_bk7231.c:18 having the wrong GPIOs for the remaining ADCs or did I miss something else?
    Thanks for your help and this nice project! :)
    - cuemaxx
  • #2 20645380
    Help: 656
    Rate: 12712
    Hello, thank you for reporting the issue. I will try to look into it and come back to you within the following days.
    Or maybe.... I can just apply changes now and push them to the branch:
    https://github.com/openshwprojects/OpenBK7231T_App/pull/871
    I am not able to test right now. I just entered the GPIO indices you've listed. Can you download the automatic build from Github and check if they are working as you want?
  • #3 20645522
    cuemaxx
    Thanks for your reply and for the commit! However, the changes are not yet in main... How long will it take or what would need to be done for that?
  • #4 20645844
    Help: 656
    Rate: 12712
    They are merged into main releases for now. I decided I can try doing that because I don't think we can break anything more by committing those changes.
  • #5 20646106
    cuemaxx
    Thanks for pushing the commit - it seems like we found the culprit: indeed works now :)
  • #6 20646130
    Help: 656
    Rate: 12712
    Can you also check on BK7231T?
