Setup outdoor relay (openbeken) with different pins for on and off state.
daviddevries 1290 3
  • Need separate on and off pins for relay control
    #1 20758153
    daviddevries
    I'm having trouble configuring my lsc relay (https://github.com/tuya-cloudcutter/tuya-cloudcutter.github.io/blob/4934b68d31df1b00eb7e73ab4811919f50d5de20/devices/lsc-3004200-wifi-outdoor-dual-socket.json)
    The challenging part is that it appears you need two pins for one socket. P14 needs to be on and P25off to turn the relay on mirrored to turn it off.
    I had it set up like this with esphome:
    esphome:
    bk72xx:
      board: generic-bk7231t-qfn32-tuya
      framework:
        version: dev
        loglevel: verbose
    logger:
    web_server:
    captive_portal:
    mdns:
    api:
      password: ""
    ota:
      password: ""
    wifi:
      ssid: !secret wifi_ssid
      password: !secret wifi_password
      ap:
    button:
      - platform: restart
    debug:
      update_interval: 30s
    text_sensor:
      - platform: debug
        reset_reason:
      - platform: libretiny
        version:
    sensor:
      - platform: uptime
    binary_sensor:
      - platform: gpio
        pin:
          number: P7
          inverted: true
          mode: INPUT_PULLUP
    switch:
      - platform: template
        optimistic: true
        assumed_state: true
        turn_on_action:
          - switch.template.publish:
              state: ON
          - switch.turn_off: switch_1_off
          - switch.turn_on: switch_1_on
          - logger.log: "Switch 1 Turned On!"
          #- light.turn_on: stat_led
        turn_off_action:
              state: ON
          - switch.turn_off: switch_1_on
          - switch.turn_on: switch_1_off
          - logger.log: "Switch 1 Turned Off!"
          #- light.turn_off: stat_led
        optimistic: true
        assumed_state: true
        turn_on_action:
          - switch.turn_off: switch_2_off
          - switch.turn_on: switch_2_on
          - logger.log: "Switch 2 Turned On!"
      #    - light.turn_on: stat_led
        turn_off_action:
          - switch.turn_off: switch_2_on
          - switch.turn_on: switch_2_off
          - logger.log: "Switch 2 Turned Off!"
       #   - light.turn_off: stat_led
      - platform: gpio
        pin: P14
      - platform: gpio
        pin: P9
      - platform: gpio
        pin: P26
      - platform: gpio
        pin: P8
    #  - platform: gpio
    #    id: switch_all
    #    name: Relay 1&2
    #    pin: P7
    #    on_turn_on:
    #    - switch.turn_off: switch_1_off
    #    - switch.turn_on: switch_1_on
    #    - switch.turn_off: switch_2_off
    #    - switch.turn_on: switch_2_on
    #    - logger.log: "Switch Turned On!"
    #    on_turn_off:
    #    - switch.turn_on: switch_1_off
    #    - switch.turn_off: switch_1_on
    #    - switch.turn_on: switch_2_off
    #    - switch.turn_off: switch_2_on
    #    - logger.log: "Switch Turned Off!"
    light:
      - platform: status_led
        pin:
          number: P1
          inverted: true
    #status_led:
    #  pin:
    #    number: P1
    #    inverted: true
    It 'worked' however the outdoor relay crashes/reboots non stop. With OpenBeken it is stable. I just do not know how to set something like this up. Any help appreciated.
  • #2 20758155
    Rate: 12954
    Rate: 12954
    Well, then you can always just set two pins to one channel, one as Relay, and second as Relay_n
