Flashing OpenBKN Firmware on Elivco LSPA9 Smart Plugs via OTA with ESPhome Interface
mikez0r 3504 3
  • Asking whether OpenBKN can be OTA flashed from esphome
    #1 20786182
    mikez0r
    Hi All,
    I'm in possession of a few of these plugs:
    https://zry.io/smart-home/elivco-lspa9-smart-plug/
    I have flashed ESPhome on them using Tuya Cloudcutter, and this is successful.
    I can flash new firmware to them using the OTA option in the web interface or through esphome itself.
    I would like to go to OpenBKN because of the MQTT implementation that ESPhome does not have.
    Would it be possible to compile firmware of OpenBKN and flash it to my ESPhome plugs using the OTA option in the web interface?
    Thanks in advance.
  • ESPhome uses a nonstandard BK binary format
    #2 20786193
    Rate: 12805
    The esphome guys are using some kind of strange, non-BKstandard format for BK binary, totally different from Tuya. This is very strange, because it makes migration way harder, but it's still possible to migrate. Suprisingly enough, migrating the other way is easy. Hmmm, strange.
    I think that @ferbulous may know something more about it, we had a thread about it.
    You can look here: https://www.elektroda.com/rtvforum/topic3958492.html
    Check this out and let me know if the conversion worked for you.
  • #3 20786214
    mikez0r
    Thanks for this information, that's very valuable :)
    I read through the topics that you put in your post, and found this repo:
    https://github.com/BenJamesAndo/OpenBeken_uf2_firmware
    This person converted the OpenBekend firmware to a compatible uf2 format.
    I have flashed it remotely (shouldn't have done that), but it told me "flash successful!" but now I have to go home first to check if it is broadcasting the Open Wifi network to configure it haha.
    Thanks, I will keep you posted about the result.
  • #4 20786785
    Rate: 12805
    Whoa, what a nice find! Well, it seems that we can now assume it's solved. I will remember that link!
