Thermostat Swarey CK-002 - Flash options for room thermostats
housertelmstein 3096 5
Treść została przetłumaczona german » english Zobacz oryginalną wersję tematu
  • #1 20923702
    housertelmstein
    Is there already a way to flash the CK-002 room thermostats from Swarey?
  • #2 20925300
    Rate: 12881
    What WiFi module is used by these products?
  • #3 20926839
    housertelmstein
    ESP-12S
    Printed circuit board with ESP-12S module and various electronic components. Modern touch control panel with display and buttons on a wooden table.
  • #4 20926864
    Rate: 12881
    It looks like there is an ESP8266 in there. You could try uploading a Tasmota. It could be a TuyaMCU device.
    Does the ESP8266 connect to the microcontroller on the board via the UART port?
    https://tasmota.github.io/docs/TuyaMCU/
  • #5 20929951
    housertelmstein
    yes I have already flashed Tasmota and I also get the heartbeat of the MCU in the console, but I can't send any commands.
    What could be the reason for this?
  • #6 20939456
    Rate: 12881
    Have you configured the fnID/dpID pairs according to the Tasmota documentation
    Excerpt from documentation on configuring fnID/dpID pairs in Tasmota.
