Adding Timestamps to Logs in OpenBK WebApp Like Tasmota
jkwim 726 2
  • Request for timestamps in WebApp logs
    #1 20972902
    jkwim
    Rate: 25
    Wonder whether it is possible to add timestamps like in Tasmota in Logs tab of WebApp
    12:23:25.416 Script: performs "HSBColor 8,100,100"
    12:23:25.426 MQT: stat/tasmota/RESULT = {"POWER4":"ON","Dimmer":100,"Color":"FF2300","HSBColor":"8,100,100","Channel":[100,14,0]}
  • #2 20974555
    Rate: 12954
    It could be done once NTP is running. Fist messages (before time sync) do not have a way to get timestamps
  • Timestamps depend on NTP sync first
    #3 20975878
    jkwim
    Rate: 25
    Even Tasmota does not. It just shows 00:00:00 until it gets synced with NTP. I think if there was no NTP at all, it just increments seconds. Need to check.
    Anyway the idea is it is very easy to reconcile interactions between multiple devices over the network when you have timestamps.
    Also to identify and processing deadlocks/delays.
