Can you install more RAM than your motherboard supports? Let's test!
p.kaczmarek2 11058 58
  • ASUS N73SV laptop proved capable of running far above its listed 12GB limit with three 8GB modules.
  • The upgrade strategy swapped RAM sticks step by step across two bottom-flap slots and the keyboard-mounted third slot.
  • The system reached 16GB, 20GB, and finally 24GB; Windows memory diagnostics passed without errors.
  • A heavy workload then used 22.6GB RAM stably with no bluescreens, though the author warns this is a risky, unofficial modification.
  • #31 21023794
    acctr
    Help: 389
    Rate: 2021
    tronics wrote:
    And since there is no RAM slot... why? Not necessary in ARM versions
    To increase the RAM? because, for example, I want to build a few Dockers.
  • Cheap NAS models omit RAM slots to cut cost
    #33 21024067
    tronics
    Help: 358
    Rate: 840
    >>21023794
    If you want a model with memory expansion, choose a model with memory expansion. After all, they are. E.g. TS-364-4G.
    You would be right if there was a trend of limiting the expansion possibilities of devices that so far had this possibility. But cheap NAS never did. Home routers didn`t have it, tablets and smartphones don`t have it either. The cheapest nettops and laptops. For 2 reasons: 1. to make them as cheap as possible, 2. because the market for these devices does not require them. So if you can give up some functionality to lower the price, then... you give it up to lower the price. The question is, on what basis did my colleague put forward the thesis that the new equipment will be "devoid of frills such as RAM slots" ...
  • Motherboard northbridge limits can cap usable RAM
    #34 21024082
    kotbury
    Gantry automation specialist
    Help: 2096
    Rate: 3619
    I once had an HP WorkStation - a PC designed like a server and had 8 memory slots.
    It could work in Dual Channel and Quad Channel mode - the condition was cooled memory and the appropriate type, which was described in the manual. The BIOS update allowed for the use of more memory as the Xeon was upgraded to a higher model.
    Win7 64-bit handled it, Win10 Prof too.
    In the end it was probably 2xXeon and 64GB RAM (only 8x8GB due to the cost of RAM which exceeded the entire cost of the computer).
    As a courtesy, I sold an HP Z800 to a friend - and it had 12 Quad Channel memory banks - in my configuration, all banks were filled with DDR3 4GB memory (48 GB in total) - and both Win7 64 and Win 10 read the whole thing without any problems. And you could install 8GB sticks (and then you would have 96GB RAM)...
    And on the other side of the age barricade - I still "use" Toshiba Satellite A105, which has 2 RAM slots accepting 4 GB each, but despite both slots being filled with good memory, the system (currently Win7 64) only sees 2.99 GB. And as I read - it is the fault of the motherboard design, or more precisely, the northbridge configuration, and no BIOS updates will change it. Well...
  • #35 21024154
    sq3evp
    Help: 219
    Rate: 878
    Well, the fact that having an OS supporting a large amount of memory will not do anything if the board does not address the entire available amount of RAM.
  • Intel chipset limits ended with integrated memory controllers
    #36 21024166
    tronics
    Help: 358
    Rate: 840
    @kotbury because this satellite was still on Core 2 - the memory controller was still in the motherboard chipset. From Nehalem (Intel) and the first K8 (AMD) it is in the processor and the chipset in fact has nothing to say here (the design of the board itself is another matter), another thing is that even here it was sometimes artificially limited (rather Intel) - e.g. recently I dug out an old Dell with what seems to be the 3rd generation of core and 2C/4T processor. It seems that the processor only supported 4GB max (2 SO-DIMM slots, one with a "dummy module"), but the 4-core processor from the same family did not have such a limit. That Intel wanted to specifically block the supported RAM in a smaller system... But Intel is famous for such tricks, its budget designs usually had neutered sets of additional instructions.
  • #37 21024233
    Zwierzak_PAH
    Help: 127
    Rate: 262
    Well, it wasn`t necessarily castration to obtain a weaker product.
    This is what management of waste that does not meet the requirements of a high-end product looks like.
    There was a moment when guides appeared every now and then on how to unlock the number of cores or something else. I even remember that at one point the best albums for mixing were made by ABIT.
  • AMD binning affects cores and cache, not RAM support
    #38 21024258
    tronics
    Help: 358
    Rate: 840
    Yes, but do you believe that Intel made a mistake where exactly 1 and the same address line did not work and only in 2-core processors? AMD had this waste management - the chip came out super duper ok, so you had a 4-core phenom, some core didn`t work, you had a 2-3 core phenom. The L3 cache didn`t work, so you had an Athlon II X4. L3 and some core didn`t work, so you had Athlon II X2-X3. I don`t know of AMD cutting supported instructions or limiting the supported RAM of lower models in the same series.
  • #39 21024278
    Zwierzak_PAH
    Help: 127
    Rate: 262
    I perceive both companies in a specific way.
    Intel - pay, pay, pay!
    AMD - we will do something cool! Will you buy it?
    Maybe it`s because I built the first board on the Am486 DX2-80, where the Intel one cost twice as much.
  • Declining RAM demand favors soldered memory designs
    #40 21024296
    acctr
    Help: 389
    Rate: 2021
    These are the facts. The rate of demand for increasing RAM is getting slower. Which more or less means that if someone bought a device with 16GB of RAM 10 years ago, it is quite possible that they have not felt the need to add RAM so far, but the device is already in disarray and they decide to buy a new one.
    In addition, the unification of memory chips used in smartphones and laptops, e.g. LPDDR5.
    Not everyone needs efficient hardware - some choose mobility and convenience (ultraslim) because they connect to the cloud through something like Citrix.
  • Expansion slots still make computers highly upgradeable
    #41 21024342
    tronics
    Help: 358
    Rate: 840
    But this is nothing new, because such ultra-thin laptops with permanently built-in memory have already existed. And this is not a trend that is taking its toll now. Smartphones, or electronics in general (including portable consoles, tablets, cameras, media players) have always been built this way. However, when it comes to computers, the share of those with expansion slots is neither decreasing nor their number. A friend once had 5-6 PCI slots, 2 ISA, one AMR, 2 IDE and one AGP. And maybe 2x USB 1.1 in bursts
    Now, sometimes a desktop has 2x PCIe 16x and 4x PCIe 1x, plus 2x M.2, 6 SATA and a total of 10 USB ports (including usually no less than 4 USB3.x), and currently the standard is at least 1 USB-C 20Gbps which again opens up a number of possibilities when it comes to accessories connected to it. And yet the 40Gbps standard has already been implemented. So I`m sorry, but I don`t see this "expansion limitation" somehow. From my perspective of several decades in computers, it`s just the opposite, because you can expand them more and more smartly and more conveniently.
    The main question is - why should it increase dramatically? Nowadays, even in games, more than 16GB RAM is practically unused, but... more than 16GB VRAM - oh, it looks completely different here. And in typical use, the most resource-intensive application (next to any antivirus) is... the web browser. But even here it`s hard to beat 16GB. There are more requirements for non-standard applications (photo or video processing, CAD applications) and for such applications equipment is purchased that is generally available.
    What a unification, after all, these (low power) memories are for specific applications - for mobile devices. Ultra-efficient laptops can and should use such memory. But this does not mean that they have to be soldered permanently - see what Dell offers under the name CAMM...
  • Artificial RAM demand driven by bloated software and SSD swap use
    #42 21024347
    Zwierzak_PAH
    Help: 127
    Rate: 262
    And do you know why?
    Because the amount of demand for frames in previous years was artificially driven.
    Instead of optimizing the OS, applications and games, behemoths were created (they still are) that consumed RAM in alarming amounts.
    Two examples are very simple.
    Game - Diablo 3 - the error has not been fixed yet, during intense gameplay the demand can jump by 100% and even after stopping the game (standing in the city) it does not drop until the game is turned off.
    Windows 10 / 11 - I observed many times when downloading large amounts of patches (fresh installation, etc.), the demand jumped to 16Mb and when the computer had 32Gb, it increased to 24Gb.
    The second reason is the popularity of SSD drives.
    In the case of HD drives, the SWAP recording problem was very visible or audible. Well, sometimes something hit you when you listened to the whining of WD or the scratching of Samsung.
    The speed of SSD means that almost no one pays attention to SWAP.
    Well, there are almost no questions anymore about how much to set, on which disk, etc. And the questions about it were from people who had 16Gb.
  • Trend toward non-upgradable laptop RAM explained
    #43 21024500
    acctr
    Help: 389
    Rate: 2021
    tronics wrote:
    this is not at all a trend that is taking its toll now
    I`m afraid there is. A few years ago, from what I remember, the first one was Surface, but now probably every laptop brand offers thin laptops with non-removable RAM. Therefore, when shopping, you have to be careful not to accidentally find a model without memory slots, unless it doesn`t bother someone because they change their equipment every year.
    But nowadays it is no longer obvious that you can expand the RAM, because this has become a feature of the equipment of the past years.
    This results from many things, but generally from Moore`s law, which, according to many, has ceased to apply in recent years.
    Just compare the offers of new laptops from particular years.
    15 years ago, the difference in RAM in an average laptop over 3 years was from 1GB to 2GB. Currently, in 2024, a glance at the store and the most offers are 16 GB. If the old trend continued, it would be 64 GB.
    And if 16 GB was enough for the average customer for several years, why install slots if he won`t expand the RAM anyway?
  • Universal RAM configurations are more economical to sell
    #44 21024590
    Zwierzak_PAH
    Help: 127
    Rate: 262
    And this is what it looks like in a store with a large selection:
    List of various RAM options in an online store with the number of available products for each option.
    So there are practically as many of those above and below as 16Gb.
    And it`s not about the possibility of expansion, but it is more economical to do it universally and, depending on the demand, we sell the same equipment with a different number of frames. By adding or subtracting.
  • Moore’s law and RAM capacity plateau argument
    #45 21024625
    tronics
    Help: 358
    Rate: 840
    No, it doesn`t. Same as non-volatile memory capacity. Consumer computers have processors with up to 16 cores and 32 threads. That`s all you CAN have. What does typical home equipment look like? 6C12T? 8C16T? Exactly. Because you don`t have to. Baaah, usually these additional 8 cores won`t change much. Just like 64GB RAM, which can be purchased relatively cheaply, won`t change much. Relative to the current national average, it is cheaper than the 512MB RAM when XP was introduced, and it does not provide even a fraction of the improvement that 512MB RAM gave in XP. So why go through with it? Because you can? Because Moore? Oh no!
    The specification is available and must be. Nobody "accidentally" buys a bad laptop. He must be careless and must make a mistake. Another thing is that for about a decade, 16GB RAM has been a reasonable amount and usually sufficient for trouble-free use of a computer. In the case of ultra-thin laptops that are neither super efficient in terms of CPU nor GPU, I don`t think that an OS and applications will suddenly appear that will make it more necessary. Especially in the era of web applications such as Google Docs, where server performance and connection parameters are the most important.
    If, instead of RAM, you check the disk capacity over these 15 years, you will also notice that it has stopped around 1TB. Only it used to be 1TB HDD 2.5``, and now it is 100x faster* NVMe on M.2 PCIE4.0 giving a completely different comfort of use. And data is... uploaded to the cloud, movies are watched via vodka, music is listened to via Spotify. You don`t have to have huge local warehouses like before. And that`s why there is some flattening here too. And it is also completely justified. And this is not a conspiracy to prevent you from expanding your computer.
  • RAM needs depend more on workload than platform limits
    #46 21024657
    kotbury
    Help: 2096
    Rate: 3619
    Gentlemen, I have been using the Intel I7-3790K with DDR3 1600 RAM from Geil for I don`t know how long - only 8 GB - and with Cyberpunk and the last Tomba (the one with the 4K resolution) - all in ultra settings - I have not noticed any major slowdowns -
    except that the card is a 16GB Radeon RX6800.
    So you don`t need Intel 12xxx or 32 GB RAM for everything to work properly.
    But budget laptops (e.g. those for teachers or schools) with Intel I5 M even with 16 GB RAM and SSD - on Win11 and fancy websites on Chrome, they already start to slow down and the system startup takes longer than the SSD law stipulates...
    PS. Previously, we wrote about professional equipment such as HP stations. But this equipment was (and is) niche. 12 or 18 physical cores of two processors (with hyperthreading 24 or 36 threads) and over 48 GB of RAM would not bring anything in the most demanding games - especially since the reasonably priced devices are old and have quite poor overall clock speeds. But when you run 3DStudio MAX with multithreading support, you can see the work.
    Eeetam. In fact, they didn`t have movies indefinitely, but the cloud won`t solve everything - if you don`t care, and the owner (if there is no EPM impulse) will at least have the books. Some 4 TB stored on separate 2-4 disk drives will never hurt.
  • #47 21025775
    forest1600
    Help: 10
    Rate: 172
    If you play in 1080p you don`t need it, turn it on in 4k and you will be surprised.
  • 68000 address space limited to 16 MB without MMU
    #48 21025787
  • 68000 addresses 16-bit words, not bytes
    #49 21025823
    tronics
    Help: 358
    Rate: 840
    @ledo99 - no, it is not derived and yes, it addresses 2^23 16-bit words, UDS/LDS only serves to select the interesting piece on the data bus. When operating on words and long words, these signals will always be both active. However, 16-bit memory cells are always addressed.
    As for FC, these are outputs that, in theory, would allow the memory areas to be divided into 16MB of user code, 16MB of user data, 16MB of supervisor code and 16MB of supervisor data, but strangely enough, practically no computer has implemented it this way. MMU is not intended to bypass restrictions, but to increase memory control (i.e. add restrictions...)
  • Memory-freeing utility prevented XP-era RAM exhaustion
    #50 21026428
    zgierzman
    Help: 108
    Rate: 1571
    A long time ago, about 20 years ago, in the times of XP, I had an application that was supposed to work 24/7 (RFID access control in a large company), but it was poorly written and over time it took up more and more RAM. She attributed it to herself, but didn`t slow down and took another piece. After some time, the computer crashed due to lack of memory.
    Then I found some program that ran in the background and freed up unused memory. It worked great and I never had to restart my computer due to lack of RAM. But unfortunately I don`t remember what this miracle was called. You could display statistics, and I often saw amounts of free RAM that were absurd for those times. Thick tens of GB.
    And what modern application can take up 20+ GB?
  • #51 21026467
    tronics
    Help: 358
    Rate: 840
    CATIA opening a complex model... Like most CAD. Adobe Lightroom can also jerk. But I wrote about it earlier and these are specific applications and not what is usually run on a home computer.
  • #52 21026615
    forest1600
    Help: 10
    Rate: 172
    Usually some programs for editing videos, etc.
  • #53 21026889
    dktr
    Help: 45
    Rate: 729
    Internet browser.
  • Windows 10 compatibility depends on chipset drivers
    #54 21027374
    Dale65
    Help: 9
    Rate: 27
    speedy9 wrote:
    Dale65 wrote:
    Nforce4, AM2 platform without plus and Athlon 64 x2 5600 processor. There are four slots, the manual states a maximum of 4GB, this is currently installed. I want to install Windows 10 on it
    Are you kidding? Here, RAM is not the problem, but component compatibility. Windows 10 the oldest that supports FXy. The latest drivers for nForce2 are for Windows 7.
    nForce4. I`m completely serious. There are even 64-bit versions on the driver CD, so why not. The processor supports CX16, LAHF/SAHF, PrefetchW. And if 10 can`t handle it even in the 32-bit version, 7 will land here and it will also be git.
  • #55 21031100
    SochaczewskiWsparcie
    Level 4  
    >>21021236
    I can compare this processor with the laptop version of the T7800, which had 8GB. That`s why I think you can go ahead and add additional memory.
  • 68000 has 32-bit addressing with 24 address lines
    #56 21033118
  • BIOS bottom I/O setting affects usable RAM
    #57 21056356
    Dale65
    Help: 9
    Rate: 27
    Who said that 10 will not work on this hardware? Everything works fine, I regret that I did not install the 64-bit right away, because all drivers for nForce4 are available for both 32 and 64. Drivers from XP 32-bit swallowed like a pelican, only for the graphics card (Geforce 7300GT) I had to install from Windows Vista/7/8, because the old version under XP admittedly installed but did not work.
    Let it not be that unrelated to the topic, why 10 32-bit also sees only 3.25GB of RAM? Installed four dice of 1GB each. The bios certainly doesn't reserve anything because there is no integrated graphics card, only the sound card. The only thing that actually affects the size of memory seen by the system (both XP and 10) is the "Auto Optimize Bottom I/O" option in the BIOS. It takes a hexadecimal value from 00 to FF, defaults to C0 and there is only 3GB of RAM in the system. If I enter D0 it sees 3.25GB, but I don't play around further because I once did experiments and ended up resetting the Bios with a jumper :) Screenshot of system settings in Windows 10 on a computer. Screenshot of system settings in Windows 10 on a computer. .
  • #58 21056428
    sq3evp
    Help: 219
    Rate: 878
    Sometimes new softwares and OS's run on old hardware, the question is whether the CPU and OS has all the functions implemented to run at full steam?
    How long ago did MMX start and then other functions built into the CPU could be emulated programmatically, but at the expense of performance and resource consumption.
  • Athlon 64 X2 runs Windows 10 with driver limits
    #59 21057259
    Dale65
    Help: 9
    Rate: 27
    The Athlon 64 X2 on the Windsor kernel (an older one, later there was a version on Brisbane) theoretically supports all those features that 10 requires. Of course, the computer muddles just like on XP, but at least the new programs work. Oh, the only thing that doesn't work is the transparency of windows and the bottom bar, but that's probably a graphics driver issue for an aged card for which no driver has been released for 10.
✨ The discussion revolves around the possibility of installing more RAM than a motherboard officially supports, using an ASUS N73SV laptop as a case study. Users share experiences where they successfully exceeded the specified RAM limits, citing examples from various devices, including QNAP servers and older motherboards. Key factors influencing RAM compatibility include chipset capabilities, BIOS updates, and the memory controller's specifications. Some users emphasize that while it may be possible to install more RAM, it could lead to issues such as excessive load on the RAM power section or compatibility problems with the operating system. The conversation also touches on the evolution of hardware limitations and the trend towards devices with non-removable memory.
TL;DR: 24GB worked in an ASUS N73SV even though most listings said 12GB, and one poster’s result was simple: "Success, 24GB RAM!" This FAQ is for upgraders testing undocumented RAM limits safely on older laptops and motherboards, with practical checks for BIOS, controller, SPD, Windows limits, and stability. [#21021089]
Why it matters: Older systems often have conservative memory limits on paper, so a careful test can extend useful life without replacing the whole machine.
Configuration Reported result Notes
3×4GB 12GB Original ASUS N73SV setup
4GB + 8GB + 8GB 20GB Booted and worked
3×8GB 24GB Stable, passed memory test
Windows 10 32-bit on 4×1GB 3.25GB visible OS/address-space limit
Key insight: The real RAM limit is set by the whole platform, not one spec sheet. CPU controller, chipset, BIOS support, module organization, and operating system limits can all change the final result.
  • The ASUS N73SV thread documents a live upgrade from 12GB to 24GB, using three 8GB modules in place of three 4GB modules. [#21021089]
  • The upgrader reports the memory purchase cost at about PLN 120 for 3 modules, which was cheaper than replacing the laptop. [#21021089]
  • A practical load test reached 22.6GB RAM in use without bluescreens, after Windows Memory Diagnostic reported no errors. [#21021089]
  • One nForce4/AM2 case with 4×1GB installed showed only 3GB to 3.25GB in Windows 10 32-bit, depending on a BIOS I/O setting. [#21056356]
  • Another workstation example shows how platform class matters: an HP Z800 ran 48GB total as 12×4GB DDR3, and could be expanded to 96GB with 8GB modules. [#21024082]
How did the ASUS N73SV end up working stably with 24GB of RAM when most specifications list a maximum of 12GB and the CPU spec mentions 16GB?
It worked because the published limit was not the platform’s real limit. The laptop started at 12GB, accepted 16GB after one swap, then 20GB, and finally 24GB with 3×8GB installed. It also passed Windows memory diagnostics and handled a real workload at 22.6GB in use. That combination shows the limiting document was conservative, outdated, or based on older module availability rather than the true hardware ceiling. [#21021089]
What step-by-step method should I use to test unsupported RAM sizes safely in a laptop like the ASUS N73SV, including tools like HWiNFO and Windows mdsched?
Use a staged upgrade, not a full swap at once. 1. Record the baseline in HWiNFO and note slot count, module size, and current total, such as 3×4GB = 12GB. 2. Replace one module at a time, boot after each change, and confirm detected memory in BIOS, Windows, and HWiNFO. 3. Run mdsched, then stress the target application until memory usage climbs well past the old limit, such as 16GB or 22.6GB. Stop if the machine fails to boot, resets, or throws errors. [#21021089]
Why does HWiNFO sometimes show RAM modules as "Unknown" after a memory upgrade even when the laptop boots and passes memory tests?
It usually means the system reads the memory enough to run, but not enough to identify every module detail cleanly. In the ASUS N73SV test, HWiNFO showed the new modules as “Unknown,” yet the laptop booted with 24GB, passed mdsched, and stayed stable under load. That points to imperfect module identification, not automatic failure. The thread also distinguishes normal SPD data from true firmware stored on special modules. [#21021089]
What is mdsched in Windows, and how reliable is it for checking whether a new RAM configuration is stable?
mdsched is Windows Memory Diagnostic, a built-in test that checks RAM for basic errors during reboot. In the ASUS N73SV case, it completed without errors after the 24GB upgrade, and the machine then handled a memory-heavy workload stably. That makes it a useful first filter, not a final proof. If mdsched passes and the target application also runs without crashes or bluescreens, confidence rises sharply. [#21021089]
How much do the CPU memory controller, chipset, BIOS, and motherboard layout each matter when figuring out the real maximum RAM a computer can use?
All four matter, but the dominant part depends on platform age. One poster states the memory controller has long been inside the processor, while another explains older Core 2-era machines still used a chipset controller. The thread also shows BIOS updates can raise supported RAM, and board layout still matters because slot count and wiring cap practical capacity. A 2-slot board and a 12-slot workstation do not face the same ceiling, even with similar-era software. [#21024166]
Why would a laptop or motherboard manual list a lower RAM limit than users actually achieve in practice with newer memory modules?
Manuals can reflect what existed and was validated at launch, not every module that appeared later. The thread suggests vendors may have calculated limits from then-common module sizes, such as 3 slots × 4GB = 12GB, or separated models for pricing reasons. Later BIOS revisions can also expand support. That explains why users report systems officially rated for 8GB, 12GB, or 16GB later running 16GB, 24GB, or even 32GB. [#21021342]
What is SPD on a RAM module, and how is it different from the idea that memory sticks have their own firmware?
“SPD” is a small data storage area on a RAM module that stores identification and timing parameters, and the system reads it to recognize the memory and set operating values. In the thread, one poster corrects the claim that ordinary DIMMs have their own firmware. He says standard modules usually expose SPD data only, while true onboard firmware applies to specific advanced modules, not typical consumer RAM sticks. [#21022701]
What is PAE, and why could some 32-bit Windows systems still be limited to about 4GB even though the hardware could address more physical memory?
“PAE” is an addressing extension that lets a 32-bit processor and operating system map more physical RAM, while each normal 32-bit process still remains limited to a much smaller address space. The thread says 32-bit NT could address up to 64GB with PAE, but consumer Windows editions often still exposed only about 4GB and used PAE mainly for NX-bit support. So the hardware capability and the visible RAM limit were not the same thing. [#21022387]
How does single-sided vs double-sided RAM organization affect whether an older motherboard will recognize higher-capacity memory sticks?
It can decide whether the board sees the full module, part of it, or nothing at all. One reply says hidden limits may come from memory-bank organization, including single-sided versus double-sided layouts. On older boards, the controller may expect a specific chip arrangement per rank or bank. If the module’s organization falls outside that expectation, the machine may refuse to boot or report less than the sticker capacity. [#21021342]
What should I check in a BIOS update if I want to unlock support for more RAM or newer processors on an older motherboard or server?
Check whether the BIOS revision explicitly expands memory support, CPU support, or module compatibility. The thread gives two clear examples: one server gained higher RAM support after a BIOS update, and one workstation used more memory after upgrading the Xeon to a higher model alongside a BIOS update. Also verify that the update matches your exact board revision. A bad flash or wrong image can leave the system unbootable. [#21022766]
DDR2 vs DDR3 on older Intel chipsets like GM45: which one affects the practical RAM limit more, and why?
The memory type can affect the practical limit more than the chipset headline number. A poster gives a GM45 example where Intel lists 8GB maximum, yet a specific laptop configuration is officially limited to 4GB and realistically reaches 6GB. He points to the platform’s DDR2 versus DDR3 support combination as the key reason. On these older systems, the chipset number alone does not guarantee the same limit across every board and memory standard. [#21021510]
Why do some old systems boot with extra RAM installed but the operating system only shows 3GB to 3.25GB, like on Windows XP or Windows 10 32-bit?
They boot because the hardware can initialize the modules, but a 32-bit OS cannot map all installed RAM into usable address space. The thread gives a live example: Windows 10 32-bit on an nForce4 system with 4×1GB installed showed only 3GB to 3.25GB, depending on a BIOS option called “Auto Optimize Bottom I/O.” Hardware reservations and address-space overlap squeeze visible memory below the physical total. [#21056356]
What risks should I consider for the RAM power section or overall system stability when installing more memory than the motherboard documentation officially supports?
The main risks are boot failure, partial detection, instability under load, and platform-specific electrical or firmware mismatches. One poster explicitly asks whether the RAM power section could be overloaded, while others report some older boards simply would not start after too much memory was installed. The ASUS case succeeded only after staged testing, mdsched, and a real workload check. Treat unsupported RAM as an experiment, not a guaranteed upgrade path. [#21021323]
Which kinds of software actually benefit from more than 16GB of RAM on older hardware, such as CAD, video editing, Lightroom, browsers, or Docker workloads?
Memory-heavy professional and multitasking workloads benefit most. The thread names CAD, CATIA with complex models, Adobe Lightroom, video editing, browser-heavy use, and Docker-style container workloads on NAS devices. In the ASUS N73SV test, the target application pushed usage above 16GB and later to 22.6GB without errors. Games and ordinary desktop use were described as much less likely to justify more than 16GB on older machines. [#21026467]
When upgrading an old platform like nForce4, AM2, or a Core 2-era laptop, how do I decide whether buying more RAM still makes sense versus replacing the whole machine?
Buy RAM only if the machine already does the job except for memory pressure. The clearest success case cost about PLN 120 for three modules and avoided replacing a 24/7 work laptop. Do not upgrade if drivers, OS support, or chipset limits are the real bottleneck. The thread warns that on very old platforms, compatibility and practical performance can matter more than RAM, especially with Windows 10 and old nForce-era hardware. [#21021089]
