Finding Parameters for Tuya Bidirectional 3 phase Energy Meter with CB3S Chip
onkel11 1395 3
  • Entered Tuya parameters from Elektroda, display works but no web values
    #1 21117278
    onkel11
    I bought this device:
    Tuya WiFi ZigBee dreiphasige bidirektionale Zweiwege-Energie kWh Meter Monitor Wattmeter Unterstützung Modbus RTU 3*85/190V oder 230/400VAC
    It is what we call in Germany eierlegende Wollmilchsau. It has display, pulse, Modbus, and Tuya WLAN.
    https://de.aliexpress.com/item/10050059956255...t_main.38.1d125c5fHwYYGT&gatewayAdapt=glo2deu
    WLAN Chip is CB3S. Reading good but only result from flasher was baudrate at 9600 no other data found.
    Flashing also without problem - but now how to find out all the parameters?
    Hinzugefügt nach 9 [Stunden] 51 [Minuten]:
    SO I entered the parameters from here:
    https://www.elektroda.com/rtvforum/topic4056617.html
    at least the deviceshows no error now anymore in the display and the wlan signal is displayed in the display as well as the wlan connection is on.
    However in the webinterface still no values.
  • #2 21118128
    Rate: 12886
    Why does it have "Zigbee" in title while CB3S is clearly a WiFi (not Zigbee) module?
    Here is TuyaMCU guide: https://www.elektroda.com/rtvforum/topic4038151.html
    This covers most of the setup process of such devices,
    If you already flashed it, I would start with tuyaMcu_sendQueryState
  • #3 21118479
    onkel11
    they sell 2 different devices, one with WiFi one with Zigbee - that's my guess.
    Thanks for the hint, I will try.
    I saved the original firmware. How do I flash this one back?
  • #4 21118659
    Rate: 12886
    You can use restore backup option from our flasher:
    It may not be necessary to flash it back, I would start with querying the state.
