[Solved] [BL2028N and PAI-053] Dreo Pilot Max S DR-HTF004S High End Fan
ouaibe 1215 2
  • BL2028N fan uses UART protocol and hidden OTA page
    #1 21163609
    ouaibe
    Hello all,
    Recently went through reversing a high end Dreo fan to cloudcut it and create an ESPHome device and posted the process on Github https://github.com/ouaibe/dreo-cloudcutter
    Thanks to the hard work from this community, it wouldn't have been possible without all the specsheets and details posted here.
    TL;DR;
    - Uses BL2028N (0000... coeffs worked although the real ones are different, OTA Key/IV are still 0123456789ABCDEF).
    - Talks UART with a 8051 MCU to control the fan (speed/oscillation/etc.).
    - I was able to extract/re-flash the stock firmware using Bk7231 Flasher.
    - Found a local webserver that allows OTA via a hidden webpage.
    - Was not able to use OpenBeken because I needed to re-implement the UART protocol to control the fan (so had to use ESPHome instead), and a custom checksum algorithm.
    • readResult_BK7231M_QIO_Dreo_orig_wifi_2024-14-7-08-15-30.bin (2 MB) You must be logged in to download this attachment.
  • #2 21166358
    Help: 451
    Rate: 921
    That's some article! Good going. I'll re-read and try some bits myself on those Matter devices, see if there's another avenue to get Openbeken going on them.
