Amysen BL602/BL6037 (and Others!) Smart Plug: Power Measurement and OTA Function Status
davidcpurdy 555 2
  • Status of power measurement and OTA on BL602 plugs
    #1 21527468
    davidcpurdy
    Hi @p.kaczmarek2,
    I worked/contributed a bit with some Amysen/BL602 smart plugs [ https://www.elektroda.com/rtvforum/topic4025259.html ] and a few others...... IIRC they have the BL602/BL6037 combination that should allow power measurement (kWh)...
    I've got two questions (and I've tried to sift through the threads but I may have missed the details/answers - I'm on chemotherapy now and sometimes my concentration is not as sharp as it would normally be...):
    1. What is the status of the Power Measurement/Utilization function on these units? Is it now working as expected?
    2. Is the OTA function now fully working? It looked like there had been a problem that required the WDT to be enabled...
    Thanks in advance for your thoughts and insight,
    Dave
  • #2 21528253
    miegapele
    Help: 15
    Rate: 29
    Yes, BL0937 is supported. You need to trace SEL,CF,CF1 pins to the chip and then calibrate.
    OTA also is working fine.
  • #3 21528406
    davidcpurdy
    Thank you!  I'll give it a try later this month or two and post back w/ details.  ... it will be a while though...
    Again, thanks!
