Create Tuya Wi-Fi switch backup - information about connection
flakerazor 1188 4
This content has been translated flag-de » flag-en View the original version here
  • #1 21615309
    flakerazor
    I would like to back up a Tuya Wi-Fi switch, what is the best way to do this?
    Does the bin file show where what is connected?
    Greetings
    AI: Which exact model or version of the Tuya Wi-Fi switch are you talking about?
    Tuya Wi-Fi Smart Circuit Breaker MCB 1P + N 16A with metering
  • Requesting Wi-Fi module details and internal photos
    #2 21616823
    Rate: 12972
    Hello, which Wi-Fi module? Something from the BK7231?
    Have you seen the repository of our flasher?
    The procedure for connecting the UART and ripping and uploading the firmware is also shown on our English language YT: https://www.youtube.com/@elektrodacom
    Please show some pictures from the inside of this device, or at least give some information about what Wi-Fi module you have there. It is difficult to advise more in the dark.
  • OpenBeken backup works, but power sensing missing
    #3 21619413
    flakerazor
    Wi-Fi module is CBU.
    Interior view of a plastic device housing with Wi-Fi CBU module and components on PCB Person holding a green PCB marked FL28101 with visible SMD components
    Added after 7 [hours] 21 [minutes]:
    Hello, I created a backup today with the Bk7231GUI FlashTool and then flashed it with the latest OpenBeken.
    Reading out which pin does what also worked.
    The only thing I'm missing now is the information on how voltage and current are read out, it didn't read that out.
    Screenshot of BK7231N device GPIO setup in JSON format from Bk7231GUI FlashTool
    Screenshot showing CBU module configuration using Bk7231GUI FlashTool
    Can anyone help me?
  • BK7231 pinout and flashing links for CB2S/CBU
    #4 21619905
    Rate: 12972
    Download our flasher, also check out the tutorial (CB2S is similar to CBU).
    Pins:
    Technical drawing of CBU module with pin numbers and detailed dimensions .
    Pin number . Symbol I/O type Function
    1 1 P14 I/O Common GPIO, which can be reused as SPI_SCK (Correspond to Pin 11 of the IC)
    . 2 P16 I/O Common GPIO, which can be reused as SPI_MOSI (Correspond to Pin 12 of the IC)
    3 P20 I/O Common GPIO (Correspond to Pin 20 of the IC)
    4 P22 I/O Common GPIO (Correspond to Pin 18 of the IC)
    5 5 ADC I/O ADC, which corresponds to P23 on the internal IC (Correspond to Pin 17 of the IC)
    6 RX2 I/O UART_RX2, which corresponds to P1 on the internal IC. (Correspond to Pin 28 of the IC)
    7 TX2 I/O UART_TX2, which is used for outputting logs and corresponds to P0 of the internal IC (Correspond to Pin 29 of the IC)
    8
    8 P8 I/O Support hardware PWM (Correspond to Pin 24 of the IC)
    9 P7 I/O Support hardware PWM (Correspond to Pin 23 of the IC)
    10 P6 I/O Support hardware PWM (Correspond to Pin 22 of the IC)
    11 P26 I/O Support hardware PWM (Correspond to Pin 15 of the IC)
    12 P24 I/O Support hardware PWM (Correspond to Pin 16 of the IC)
    13 GND P Power supply reference ground
    P 3V3 P Power supply 3V3
    15 TX1 I/O UART_TX1, which is used for transmitting user data and corresponds to Pin 27 of the IC. For the MCU solution, please refer to CBx Module.
    . 16 RX1 I/O UART_RX1, which is used for receiving user data and corresponds to Pin 26 of the IC. For the MCU solution, please refer to CBx Module.
    17 . P28 I/O Common GPIO (Correspond to Pin 10 of the IC)
    18 CEN I/O Reset pin, low active (internally pulled high), compatible with other modules (Correspond to Pin 21 of the IC)
    19 P9 I/O Common GPIO (Correspond to Pin 25 of the IC)
    20 P17 I/O Common GPIO, which can be reused as SPI_MISO (Correspond to Pin 14 of the IC)
    . 21 P15 I/O Common GPIO, which can be reused as SPI_CS (Correspond to Pin 13 of the IC)
    Test point point CSN I/O Mode selection pin. If it is connected to the ground before being powered on, enter the firmware test mode. If it is not connected or connected to VCC before being powered on, enter the firmware application mode. Correspond to Pin 19 on the internal IC.
