S1 Kontakt funktioniert nicht nach Flashen des Switches – Parameter und Konfiguration prüfen
flakerazor 552 3
  • Clarifying switch model and OpenBeken firmware version
    #1 21790212
    flakerazor
    Hallo, ich hab wie in diesem Thread den Switch geflasht
    es funktioniert leider der S1 Kontakt nicht.
    https://www.elektroda.com/rtvforum/topic4099102.html#21393164
       "rl1_lv":"1",
       "on_off_cnt":"10",
       "onoff_rst_m":"1",
       "onoff_clear_t":"10",
       "rand_dpid":"42",
       "net_trig":"4",
       "onoff_n":"5",
       "netled1_lv":"1",
       "jv":"102",
       "onoff_rst_type":"2",
       "total_bt_pin":"24",
       "nety_led":"0",
       "over_cur":"20000",
       "total_stat":"2",
       "reset_t":"3",
       "netled1_pin":"9",
       "chip_type":"3",
       "lose_vol":"40",
       "remote_add_dp":"49",
       "remote_list_dp":"50",
       "net_type":"0",
       "over_vol":"300",
       "inch_dp":"44",
       "module":"CBU",
       "ch_cddpid1":"9",
       "onoff1":"26",
       "clean_t":"6",
       "init_conf":"38",
       "zero_select":"0",
       "onoff_type":"0",
       "series_ctrl":"2",
       "total_bt_lv":"0",
       "cyc_dpid":"43",
       "remote_select":"0",
       "ch_num":"1",
       "rl1_pin":"20",
       "ele_rx":"10",
       "netn_led":"0",
       "vol_def":"0",
       "ch_dpid1":"1",
       "ele_tx":"11",
       "crc":"118"
    Grüße
    AI: Um welchen Switch (Hersteller und genaue Modellbezeichnung) handelt es sich genau?
    Girier 1 Gang mit CBU Chip
    AI: Welche Firmware (inkl. Versionsnummer) hast du genau geflasht?
    OpenBeken 1.18.226
  • Suggested BK7231N pin mapping and GPIO test steps
    #2 21790272
    Rate: 12945
    Hi! According to your Tuya JSON data, the device configuration is as follows:
    Device seems to be using CBU module, which is BK7231N chip.
    - Relay (channel 1) on P20
    - WiFi LED on P9
    - TglChannelToggle (channel 1) on P26
    - Pair/Toggle All Pin on P24
    - BL0942 (?) RX on P10
    - BL0942 (?) TX on P11
    Do you have set TglChannelToggle role with channel 1 on P26?
    If not sure, you can use GPIO Doctor and set this pin to digital input there, and observe if it changes when you close the switch.
    How did you flash your device? Is it possible that you have a cold solder joint? Did you desolder board with CBU? Can you show photos?
  • #3 21791082
    flakerazor
    Ich habe 3 von diesen switchen und bei keinem geht es.
    Ich habe es so konfiguriert, wie du es aufgeschrieben hast.
    GPIO Doktor weiß ich nicht, ob ich ihn richtig bediene.
    Habe alle Pins auf Set input P-up gestellt und geschaut, ob was passiert.
    CBU wurde nicht ausgebaut, Kabel direkt an CBU angelötet.
    Grüße
  • Requesting USB-powered test and wiring photos
    #4 21793422
    Rate: 12945
    I think we may need to debug more. Disconnect device from mains. Operate only on safe voltage. Power it from USB 5V (connect to LDO input, so wiFi module gets 3.3V). Then try connecting P26 to GND or 3.3V to see if it reacts in firmware.
    I think it may be a hardware issue, but first we need to know that firmware works ok for you.
    Can you show a photo of your device, which model is that? How did you try to wire it?
