OBK Docker Local Build: Reducing SDK Copy Time and Improving Build Speed
DeDaMrAz 405 14
  • #1 21830409
    DeDaMrAz
    OBK local build via Docker.
    I was in need to build N platform builds locally for testing things and gave Docker build a try. What I found out is that SDK files will be copied every time into docker and then build will be serialized and that all takes approximately 20 minutes because for some reason all the SDK's are being copied every time (not cached).
    I gave my Container 16 cores to play with and I am in a process of creating a local build script that may reduce that time to ~105 seconds on clean build (first copy of selected SDK - time depends on SDK size) but subsequent builds are just 15 seconds!?!
    Has anybody been playing with this ever??
    I am in testing phase right now but damn this time reduction seems unreal 😁
    Script is not yet ready but I'll share once finalized, just curious to see if somebody played around with this at all.
  • #2 21830930
    DeDaMrAz
    Is anybody else willing to test this out?
    Added after 4 [hours] 6 [minutes]:
    Script will now honor all available platforms and respected drivers but I need somebody else to test it on their machines.
    Requirements are:
    - Docker desktop installed and running
    - Python 3.xx installed and added to PATH
    - Git installed and added to PATH
    - about 25Gb of free space (all cached files volumes + build container without ESP-IDF!!!)
    - about 30-45 minutes of time for initial volume and container builds
    I think this is a significant build time update but again more testing is needed not just by me. For example, clean build is less than 30 seconds, driver change updates and subsequent builds are below 15 second (PC spec dependent!!)
    Thanks.
    Added after 6 [hours] 30 [minutes]:
    ESP32C6 test build time...
    Wrote 0x8e340 bytes to file output/3DRIVERS/OpenESP32C6_3DRIVERS.factory.bin, ready to flash to offset 0x0
    cp ./platforms/ESP-IDF/build-c6/OpenBeken.bin output/3DRIVERS/OpenESP32C6_3DRIVERS.img
    Build artifacts copied to output folder.
    Build task finished in 23.20 seconds.
    PS C:\Users\DeDaMrAz\Desktop\Docker tests>
    BK7231N build time test....
    rm sdk/OpenBK7231N/platforms/bk7231n/toolchain/../bk7231n_os/tools/generate/OpenBK7231N_*.rbl || /bin/true
    rm sdk/OpenBK7231N/platforms/bk7231n/toolchain/../bk7231n_os/tools/generate/OpenBK7231N_*.bin || /bin/true
    make[1]: Leaving directory '/app/build'
    Build task finished in 14.55 seconds.
    The only downside of this speed up is a large disk space required (more than 32Gb) to cache all the files on first build but after that build in 23 seconds or 14.5.... no contest.
    It can probably be optimized more but I am very satisfied with the result. Will add a PR for this in the coming days once I clean up all the mess I made because I didn't know about berry prebuild.... thanks @p.kaczmarek2 for the tip to fix that 😉
    Windows File Explorer list showing mostly OpenBK7231N .bin files plus .asm, .axf, .map, and .rbl
    Windows cmd/PowerShell window showing OpenBK7231N firmware build log with “COMPILE SUCCESS”.
    I wasn't timing the initial build but subsequent ECR6600 with 1 random driver took less than a minute. Timer result is 0s though
    Windows console screenshot showing OpenBeken firmware build logs and generated binary files
    I think you should integrate PROTA mechanism directly - rewrite it in Python:
    https://github.com/openshwprojects/OBKotaTool
    This way your tool can auto update target devices.
  • #6 21834411
    DeDaMrAz
    Console screenshot with test summary: 33 total, 17 success, 16 failed, plus lists of successful and failed platforms.
    First run of the test all builds, not bad I would say, most of the failed ones are my mistake some of which I fixed already like RTL8720 and 8721, adding IDF v5.5.2 to the cached SDK's o fix ESP32C5 and ESP32C61 now and will tackle BK7231U, 38, 52 next and rerun all the tests again.
    Once I get all the platforms to build 100% with all available drivers I'll post a PR update and consider it ready to merge ( I would hope so )
    Then I will think about creating local PROTA tool, that is a good idea.
    Status updates will go here, getting closer one platform at a time ;)
    Terminal screenshot with test summary: 33 total, 21 successes, 12 failures, plus lists of successful and failed platforms.
    Enough for tonight... success rate climbed to 84.8% + I'll fix the BL602 before I call it a night and continue tomorrow
    Terminal screenshot showing test summary: 33 total, 28 success (84.8%), 5 failed, 17.5 minutes
    No it is not enough, my brain would not let me sleep so I've wrestled with problematic builds and my own stupidity... came out clean on the other side (points for everyone who gets the reference)
    Full test --clean build with all drivers available on all 33 platforms is about 18 minutes (I can already see how I can speed it up even more - by not downloading certain thing for example but have them ready) each platform is building now with 2Mb default flash size ( yes I know and will do a full-nuclear test with everything form the start and flash sizes corrected at some point but I needed this win NOW!!!) After all the tests are done and completed I'll post a finished commit in the PR and I would call it done. When I find time I'll improve on the build speeds on certain platforms and maybe even create a ready made docker container from docker hub but it can wait... for now and our OBK community this is rather significant improvement (in my eyes at least), you can use python script as is or if you prefer GUI, that is available as well.
    MAJOR WARNING!!! I have tested builds on certain platforms only - not all of them!!! I tried to replicate the CI build as much as possible but be warned again - prepare for bricked modules!!!
    Console screenshot showing test summary: 33/33 success, platform list, and 18.4 minutes runtime
    TXW build is now "fixed" and it is fast!!!
    Terminal screenshot showing build logs, copying .bin and .img files, and a build finished message.
    Next big thing is correct caching of all the big tar files that influence ESP and RTL builds the most so I can shave more time for those build as well... right now RTL8721DA takes about 50 seconds, I am going to test and see if my idea is correct....
    My idea is correct and RTL build went down from 54 to under 19 seconds, continuing.... as long as there is coffee...
  • #7 21834566
    @DeDaMrAz maybe do Visual Code extension next?
  • #9 21834717
    Maybe restrict flash sizes to only ones that really exist? Per platform.
  • #10 21834723
    DeDaMrAz
    Well that may be a problem as you and I had a conversation some time ago to add SPI to BK platform and use it for testing so 2Mb will not apply there :)
    Also I don't actually know all the specifications for each platform, for example I know BL has 1 and 2Mb versions, BK is 2Mb default but not all (??), but the rest is somewhat hard to find exactly so I'd rather leave the option to choose the flash size than to go into that rabbit hole now :) I'll test again the BMP280 driver now to see what the problem was on some of my previous runs.
  • #11 21835246
    SPI? You mean in Easy Flasher? That's a separate thing.
    max4elektroda
    I'f I didn't do something wrong there's some todo for all platforms with "variants" @DeDaMrAz.
    Simple example: I build a BK7238 firmware with drivers
    DS1820_FULL
    I2C
    SHT3x
    Trying to start SHT3x results in:
    Info:MAIN:Driver sht3x is not known in this build.
    Info:MAIN:Available drivers:
    Info:MAIN:I2C
    Info:MAIN:, PWMToggler
    Info:MAIN:, DoorSensor
    Info:CMD:[WebApp Cmd 'startdriver sht3x' Result] OK
    The driver code seems not present, only the "IOroles":
    strings test_OUT/OpenBK7238_QIO_test.bin  | grep SHT
    SHT3X
    "SHT3X":
    SHT3X_SDA
    SHT3X_S
    but it seems reasonable, looking into the temporary obk_config.h:
    #elif PLATFORM_BEKEN
    //#define ENABLE_LFS_SPI                  1
    // #define ENABLE_DRIVER_TESTSPIFLASH   0 // Disabled by build_tool
    [...snipp...]
    // #define ENABLE_DRIVER_HT16K33   0 // Disabled by build_tool
    // #define ENABLE_DRIVER_MAX72XX   0 // Disabled by build_tool
    // #define ENABLE_DRIVER_ADCBUTTON   0 // Disabled by build_tool
    #define ENABLE_I2C   1
    // #define ENABLE_TEST_COMMANDS               1
    #define ENABLE_CALENDAR_EVENTS               1
    // #define ENABLE_DRIVER_BRIDGE   0 // Disabled by build_tool
    [...snipp...]
    #if (OBK_VARIANT == OBK_VARIANT_SENSORS || OBK_VARIANT == OBK_VARIANT_BATTERY)
    // #define ENABLE_DRIVER_BMP280   0 // Disabled by build_tool
    // #define ENABLE_DRIVER_BMPI2C   0 // Disabled by build_tool
    #define ENABLE_DRIVER_SHT3X   1
    #define ENABLE_DRIVER_DS1820_FULL   1
    #endif
    #if (OBK_VARIANT == OBK_VARIANT_HLW8112)
    [...snipp...]
    #endif
    #elif PLATFORM_LN882H
    Since we define our own config, the variants don't make sense in my eyes.
    Here's my idea to solve this:
    diff --git a/docker/GUI_build_tool.py b/docker/GUI_build_tool.py
    index d6af62b2..95ea79eb 100644
    --- a/docker/GUI_build_tool.py
    +++ b/docker/GUI_build_tool.py
    @@ -1115,7 +1115,8 @@ class OBKBuildToolGUI(tk.Tk):
                 # Cleanup temp config
                 try:
                     if os.path.exists(temp_config_path):
    -                    os.remove(temp_config_path)
    +                    pass
    +                    #os.remove(temp_config_path)
                 except Exception:
                     pass
    diff --git a/docker/build_tool.py b/docker/build_tool.py
    index 52700b71..efff66df 100644
    --- a/docker/build_tool.py
    +++ b/docker/build_tool.py
    @@ -457,7 +457,7 @@ def get_available_drivers(platform_name):
         driver_regex = re.compile(r'^\s*#\s*define\s+(ENABLE_\w+)\s+1')
         # Special non-driver names we want to capture
    -    special_names = ["ENABLE_NTP", "ENABLE_I2C", "ENABLE_TASMOTADEVICEGROUPS"]
    +    special_names = ["ENABLE_NTP", "ENABLE_I2C", "ENABLE_TASMOTADEVICEGROUPS", "ENABLE_OBK_BERRY"]
         for line in lines:
             line = line.strip()
    @@ -567,8 +567,21 @@ def create_custom_config(selected_drivers):
         new_lines = []
         # Match any #define ENABLE_... or #define ENABLE_DRIVER_... followed by a number
         driver_regex = re.compile(r'#\s*define\s+(ENABLE_\w+)\s+(\d+)')
    +    VARIANT_regex = re.compile(r'^#if \(OBK_VARIANT ==')
    +    undef_regex = re.compile(r'^#undef ')
    +    endif_regex = re.compile(r'^#endif')
    +    VAR_found = 0
         for line in lines:
    +        if VARIANT_regex.search(line):
    +            VAR_found = 1
    +            continue
    +        if VAR_found == 1 and undef_regex.search(line):
    +            continue
    +        if VAR_found == 1 and endif_regex.search(line):
    +            VAR_found = 0
    +            continue
             match = driver_regex.search(line)
             if match:
                 driver_name = match.group(1)
    @@ -576,7 +589,7 @@ def create_custom_config(selected_drivers):
                 # IS this a driver we are managing?
                 # We manage anything starting with ENABLE_DRIVER_ or our special list
                 is_managed = driver_name.startswith("ENABLE_DRIVER_") or \
    -                         driver_name in ["ENABLE_NTP", "ENABLE_I2C", "ENABLE_TASMOTADEVICEGROUPS"]
    +                         driver_name in ["ENABLE_NTP", "ENABLE_I2C", "ENABLE_TASMOTADEVICEGROUPS", "ENABLE_OBK_BERRY"]
                 if is_managed:
                     if driver_name in all_drivers:
    @@ -915,7 +928,8 @@ def main():
         finally:
             # Cleanup
    +            pass
             elapsed = time.time() - start_time
             print(f"\nScript execution time: {elapsed:.2f} seconds")
    Remove all "OBK_VARIANT" lines and the matching "#endif" lines plus all "#undef" inside the block.
    Also added "berry" as an additional choice.
    Screenshot of firmware build tool: BK7238 platform, driver checklist, and log showing “Build completed”
    At least for BK7238 it works now ...
    Info:SENSOR:SHT : Status : FF FF
    Info:MAIN:Started sht3x.
    Info:MAIN:Time 77, idle 372242/s, free 108032, MQTT 0(5), bWifi 1, secondsWithNoPing 11, socks 2/24
    Info:MAIN:Time 78, idle 738719/s, free 116336, MQTT 0(5), bWifi 1, secondsWithNoPing 12, socks 2/24
    Info:MAIN:Time 79, idle 361863/s, free 108032, MQTT 0(5), bWifi 1, secondsWithNoPing 13, socks 2/24
    Info:MAIN:Driver UNKNOWN is not known in this build.
    Info:MAIN:I2C
    Info:MAIN:, CHT83XX
    Info:MAIN:, SHT3X
    Info:MAIN:, DS1820_FULL
    Info:CMD:[WebApp Cmd 'startdriver UNKNOWN' Result] OK
    Keeping temporary config is meant just for testing
  • #13 21840000
    DeDaMrAz
    @max4elektroda
    Thanks for the test and report and I 100% agree on the suggestion. I was focused on getting the build local out not so much on obk_config.h, I'll look into that next and add drivers that were also disabled by default and add them to selection for testing.
  • #14 21840005
    max4elektroda
    That's nothing, I just did one step ahead for I needed this actually. I really like the new possibility to get a fully customized image without editing obk_config.h.
    And it just came in time for me. So, thanks again, this new possibility is really a big help.
  • #15 21840108
    DeDaMrAz
    PR updated and core drivers revised (MQTT, HA and scripting for example) - incorporate @max4elektroda suggestions, no need to rebuild anything in docker just run and test the script.
✨ The discussion focuses on optimizing OBK platform builds using Docker to reduce SDK copy time and overall build duration. The initial issue identified was that SDK files were copied into the Docker container on every build without caching, causing build times of approximately 20 minutes. A new local build script was developed to address this, achieving a clean build time of around 105 seconds for the first SDK copy, with subsequent builds completing in about 15 seconds by leveraging caching and parallel processing with up to 16 CPU cores. The script supports multiple platforms and drivers, requires Docker Desktop, Python 3.x, Git, and sufficient disk space (~25GB) for cached volumes and containers. Initial volume and container setup takes 30-45 minutes, but subsequent builds are significantly faster, with clean builds under 30 seconds and driver updates below 15 seconds, depending on PC specifications. Further testing by other users is requested to validate these improvements.
TL;DR: Local OBK Docker builds drop from ~20 min to 14.55–23.20 s; “Build task finished in 23.20 seconds.” Cache SDKs once, then rebuild in seconds via a Python/Docker script and optional GUI. [Elektroda, DeDaMrAz, post #21830930]
Why it matters: Faster, reproducible local firmware builds help you iterate drivers and platforms without waiting on CI, saving hours per day.
What is this OBK Docker local build tool?
It’s a Python-driven Docker workflow for OpenBeken (OBK). It caches SDKs and orchestrates platform builds locally. After the first cache, incremental builds run in seconds. A GUI front end is also available for easier selection and testing. [Elektroda, DeDaMrAz, post #21830930]
How much faster are local builds compared to the old flow?
After caching, reported builds complete in 14.55–23.20 seconds per target. That’s a major drop from multi‑minute runs. One log shows, “Build task finished in 23.20 seconds.” Expect variance by PC specs and selected drivers. [Elektroda, DeDaMrAz, post #21830930]
What do I need installed before I start?
Install Docker Desktop, Python 3.x, and Git. Reserve about 25 GB for volumes and the container, and plan 30–45 minutes for the initial setup. Keep Docker running during builds. [Elektroda, DeDaMrAz, post #21830930]
Why does my selected driver (e.g., SHT3x) say it’s unknown at runtime?
Variant guards can exclude drivers from the final image. A tester fixed this by stripping OBK_VARIANT blocks during temporary config generation and adding ENABLE_OBK_BERRY to managed options. After that, SHT3x loaded correctly. [Elektroda, max4elektroda, post #21838691]
How do I run my first build quickly?
  1. Install Docker, Python 3.x, and Git; start Docker.
  2. Run the Python build script to create caches and the container (first time takes 30–45 minutes).
  3. Select a platform and drivers, then build; subsequent runs take seconds. [Elektroda, DeDaMrAz, post #21830930]
Is there a GUI, or do I have to use the CLI?
There is a GUI with tested workflows and screenshots showing successful runs. Use it to choose platforms, flash sizes, and drivers without editing headers manually. [Elektroda, DeDaMrAz, post #21834715]
Which platforms are supported today?
A clean test covered 33 platforms, including ESP32C6, BK7231 series, BL602, RTL8720/8721, and TXW. One update reduced RTL8721DA build time from ~54 s to under 19 s. “Full test — clean build … is about 18 minutes.” [Elektroda, DeDaMrAz, post #21834411]
How much disk space should I plan for cached SDKs?
Plan for more than 32 GB if you cache everything. The speedup is substantial once caches exist, but storage is the trade‑off. [Elektroda, DeDaMrAz, post #21830930]
Is it safe to flash these images to devices?
Use caution. The author warns that not all platforms were hardware‑tested, so failed flashes can brick modules. Back up and test on sacrificial hardware first. [Elektroda, DeDaMrAz, post #21834411]
Will this integrate device auto‑updates (PROTA/OBKotaTool)?
A maintainer suggested integrating the PROTA mechanism by rewriting it in Python. That would enable automated device updates from the build tool. [Elektroda, p.kaczmarek2, post #21834395]
Should flash sizes be restricted per platform?
One proposal suggested per‑platform limits, but the current approach keeps selectable flash sizes. The author defaults many tests to 2 MB and prioritizes flexibility. [Elektroda, DeDaMrAz, post #21834723]
Can I work with this inside Visual Studio Code?
A VS Code extension was proposed to improve developer experience. For now, use the existing Python script and GUI while that idea is explored. [Elektroda, p.kaczmarek2, post #21834566]
Do I need to rebuild the Docker image after PR updates?
No. The latest update revised core drivers such as MQTT, Home Assistant, and scripting. You can run and test the script without rebuilding the container. [Elektroda, DeDaMrAz, post #21840108]
My timer shows 0 seconds, but the build ran; what’s up?
A tester reported a subsequent build under a minute while the timer displayed 0 s. Treat it as a display quirk; verify with logs and artifacts. [Elektroda, divadiow, post #21831694]
