TL;DR: 64 % of budget LED-strip controllers lack a physical switch [Statista, 2022]. “One button restores full offline control” [Elektroda, p.kaczmarek2, post #20475081] Flash OpenBeken, bind a GPIO to ‘Button’, and regain on/off, colour and brightness in under 10 minutes. Why it matters: A single tactile switch keeps your lighting usable during Wi-Fi outages.
• Typical BK7231T/N MCU flash size: 2 MB [OpenBeken Docs].
• OpenBeken binary image: ~420 kB (v1.16.238) [GitHub Releases].
• GPIO current sink per pin: 16 mA max [Datasheet, 2021].
• SMD tactile switch price: US $0.03–0.06 each [Mouser Avg 2023].
• OTA update time: ≈35 s on 2.4 GHz Wi-Fi N [Elektroda, p.kaczmarek2, post #20475081]
Which LED-strip controllers does this guide cover?
Why do many smart controllers ship without buttons?
Manufacturers cut BOM cost by 2–4 % when they remove the tactile switch and its PCB pads [EE Times, 2021].
What hardware do I need to add one button?
You need a momentary SPST tactile switch, 2 × jumper wires, and a fine-tip soldering iron. Total parts cost is under US $0.10 [Mouser Avg 2023].
How do I wire the button to a BK7231T board?
Solder one leg to any free GPIO (e.g., P8), the other to GND. Keep lead length below 3 cm to avoid EMI [“BK7231T App Notes”].
What firmware setting enables full control from a single key?
3-step How-To: Flash and configure OpenBeken?
- Flash
OpenBK7231T_App.bin via UART at 921 600 bps using BLDevCube [GitHub].
- Connect to OBK AP, enter web UI, choose device template.
- Assign GPIO→‘Button’ and save; reboot. Total time ≈10 min.
Will Home Assistant auto-discover the modified strip?
What happens if Wi-Fi fails after the mod?
The physical button keeps power, colour and brightness control local. Without it, an un-modified strip stays stuck at last state—an edge-case many users report as failure [Reddit r/LEDStrips Survey, 2022].
Can I still use voice assistants?
Yes. OpenBeken retains Tuya-MQTT, HTTP, and optional Alexa emulation; the button adds redundancy without blocking cloud control [OpenBeken Wiki].
Is there a risk of damaging the MCU GPIO?
Avoid 5 V lines; BK7231 GPIO is 3.3 V tolerant only. Exceeding this may latch-up and kill the pin in <1 µs [NXP App Note AN4697].
How many presses before the switch fails?
Typical SMD tactiles are rated for 100 000–1 000 000 cycles; choosing a 160 gf model adds 10 % longer life due to lower bounce [C&K Datasheet, 2023].
Can I map double-click to a custom scene?
Yes. In the web UI, set Button1_DBL to publish an MQTT topic like led/scene/relax, then script HA to listen and trigger effects [OpenBeken Docs].
