  • A vacuum tube Tesla coil uses a GU-81M lamp as the main active element.
  • The build follows a linked schematic, although it is only loosely based on that scheme.
  • A film shows the coil operating, indicating the project was demonstrated in practice.
  • VTTC- Vacuum Tube Tesla Coil I warmly welcome all fans of high voltage.
    I would like to introduce my tube tesla coil on the GU-81M lamp.
    The coil was created according to the diagram on page Link
    And what to write here, I wish you good luck in building the tlock and meter coil 1998
    I used this scheme (not really)
    Film with coil operation
    VTTC- Vacuum Tube Tesla Coil VTTC- Vacuum Tube Tesla Coil VTTC- Vacuum Tube Tesla Coil VTTC- Vacuum Tube Tesla Coil
    trzaska456
    trzaska456 wrote 326 posts with rating 133, helped 4 times. Live in city Złoczew. Been with us since 2008 year.
  • #2 7465657
  • #3 7465672
    trzaska456
    Rate: 133
    Where it is written that it must be at the bottom. And the pattern is the opposite because it was easier to paint, if I'm sorry I'm sorry
  • #4 7465698
  • #5 7466106
    KJ
    Help: 68
    Rate: 945
    Very nice :) I support all activities related to TC ;) Tlock is again confused by concepts. The primary winding is to be below the secondary one in DRSSTC in other coils, but this is not important, but you can experiment. I am planning to make an attempt to change the feedback to lower in my SSTC and in DRSSTC I have already convinced that the secondary MUST be above the original because otherwise too large coupling results in punctures on the original one. Generally, the principle sounds - if there are no secondary breakthroughs - the original one has no reason to lower the feedback. If we are reducing the feedback by extending the secondary from the original. There is an unspoken rule that says it is better not to drill holes in the secondary pipe wall. With this coil, it does not matter. With a bigger one, this is the first place where a ;) breakdown will occur ;) So if you planned something bigger remember about it.
  • #6 7466672
  • #7 7468224
    hvelektronik
    Help: 54
    Rate: 211
    Welcome At the beginning, congratulations for the author, the design is decently made. I have one question where did you buy a GU-81 lamp? I have been hunting for her for some time and at what price can I buy it?
  • #8 7468317
    Nick2
    Rate: 94
    The link is not working, could you update it?
  • #9 7468540
    Dragas
    Help: 76
    Rate: 197
    Very nice design, congratulations!
    hvelektronik wrote:
    Hi At the beginning, congratulations for the author, the design is decently made. I have one question where did you buy a GU-81 lamp? I have been hunting for her for some time and at what price can I buy it?
    About 3-4 months ago I saw GU-81 on the Allegro for PLN 50. You need to check there a few times a week, and maybe someone will add.
    Nick2 wrote:
    link does not work you could update it?
    Well, I think so too, but I made my work on the opera and it works correctly already.
  • #10 7469863
  • #11 7469930
    miernik998
    Help: 6
    Rate: 54
    Welcome back!!
    I have a question, how to make two lamps work to achieve more power? I would like to use two to increase the power.
  • #12 7469943
    KJ
    Help: 68
    Rate: 945
    I just want to point out that the above-mentioned coil uses this driver: Staccato Controller . In short, it allows you to squeeze more out of the lamp by shortening the cycle.
  • #13 7470687
    Artur k.
    Help: 1279
    Rate: 1701
    I am asking the author of the topic to include the correct link to the project's sources and to improve the photos - it was hard to turn the right side before loading?
  • #14 7470753
    diamonxxx
    Very nice construction :)
    I have to do something like this :)
    And how many coils did you give to the coil ?? :)
  • #15 7470842
    trzaska456
    Rate: 133
    Tlock this picture is a different lamp and another power, and the images from lukasb9 are nicer because they did it with a long exposure time (eg night mode with the flash off).
    And when it comes to the link, this is ok, the site is not open at all, so it gives a link to the post https://www.elektroda.pl/rtvforum/topic971433.html
    The film, however, will be at school ... But it gives you a link to another http://www.youtube.com/watch?v=wNFLibUZOTY where the effects are similar, I am interested in connecting this foot next to the anode S1. It hunts for one more GU 81 to combine them for more power. The lamp in my heater is in the new housing I gave the microwave fan, I'm still waiting for the heel switches.
    And tlock probably was right, see here how it is done http://www.teslacoil.it/
  • #16 7471560
  • #17 7472648
    rafixs
    Help: 46
    Rate: 149
    Nice Tesla :spoko: transformers
    Buddy tlock
    I have a question - what kind of capacitor and where did you buy it?
  • #18 7473029
  • #19 7473503
    DaKKi
    Rate: 665
    Great design, I like this ;) lamp
    I have a question - where did you get the power supply from?
    From what I know for the very glow you need 12V / 10A.
    Greetings.
  • #20 7474009
  • #21 7474386
    lukasb9
    Help: 56
    Rate: 70
    trzaska456 - it looks like your tesla is not tuned to resonance, just like a colleague wrote above, make taps on the top 10 windings of the primary winding and connect one by one looking for the maximum. If you get a definite maximum (one and the other side of the discharge will be reduced), take care of the feedback. Try to increase the number of windings of the coupling winding, reduce the value of the grid resistor. On the GU81, when powering from a transformer from a microwave and using a multiplier, you can get 30cm long discharges.
    As for the explanation of not working links to my site - everything will work at the beginning of the week.
  • #22 7477641
  • #23 7482070
    trzaska456
    Rate: 133
    After reducing the resistor from 1k? to 2?, the effect improves (longer sparks), and what you think about it to connect two motifs with each other. Normally, the MOT takes me 4A and with a 0? resistor takes me 7A
    PS: I added a movie with my :D coil
  • #24 7483215
  • #25 7485596
    trzaska456
    Rate: 133
    Ok I changed the primary winding to the resonant winding by removing some coils and increased the distance between them to 2cm and the effects improved, the sparks are about 24cm max. And as for the toroid, I read somewhere that no lamps are needed
  • #26 7485713
    KJ
    Help: 68
    Rate: 945
    It is not needed in the same way as in SSTC ;) Read tesla will work without it, but combining with the right one can improve the effects. It can also aggravate :) but in the end the fun with TC is based on experimenting with ;) so it's worth ;) with the torus.
  • #27 7485813
  • #28 7487272
    trzaska456
    Rate: 133
    I removed 7 scrolls from the secondary one and it is even better, and tell me why this 1k Ohm resistor may be worth it, as on the website http://www.teslacoil.it/
  • #29 7489016
    lukasb9
    Help: 56
    Rate: 70
    rolled back 7 rolls from secondary
    for what? not much will change this secondary inductance. And what follows and the resonant frequency.
    Everyone says that you will tune the resonant frequencies by changing the number of windings of the primary winding (you must find a clear maximum), then only combine with the wire resistor (it sets the working point of the lamp).
    Another thing you can try to move the secondary winding relative to the original one, then you change the coupling factor (here also look for the maximum), only after such an operation you will probably need to re-tune the primary part.
  • #30 7509566
    a_rtur7
    How does it work? are these sparks harmless?
    For how much can you buy something (already done?)
The discussion revolves around the construction and optimization of a Vacuum Tube Tesla Coil (VTTC) using the GU-81M lamp. Participants share insights on coil design, tuning, and performance enhancements. Key points include the placement of the resonant winding, which is typically below the secondary winding, and the importance of tuning for achieving optimal discharge lengths. Users discuss various components, including capacitors and power supplies, and share experiences with sourcing the GU-81 lamp. There are also inquiries about using multiple lamps for increased power and the effects of different resistors on performance. Links to resources and videos demonstrating coil operation are provided, along with troubleshooting advice for common issues encountered during assembly and operation.
TL;DR: A well-tuned GU-81M vacuum-tube Tesla coil can throw 24 cm sparks on 4 A input current; “The torus can slightly improve the discharges.” [Elektroda, Anonymous, post #7485813][Elektroda, trzaska456, post #7485596] Why it matters: This FAQ helps hobbyists squeeze maximum, safe performance from VTTC builds.
• GU-81M filament: 12.6 V ± 0.6 V, 10–20 A supply recommended [Elektroda, DaKKi, post #7473503][Elektroda, Anonymous, post #7474009] • Single GU-81M spark length: 20–30 cm when correctly tuned [Elektroda, Anonymous, post #7465698] • Staccato-controlled coil: up to ~1 m discharges with cycle shortening [Elektroda, Anonymous, post #7483215] • Typical build cost: PLN 300–350 (≈ €70) including tube, iron, and passives [Elektroda, Anonymous, post #7511231] • Safe pre-heat: 60 s filament-only before anode power [Tube Data Sheet]
What coupling distance between primary and secondary is safe?
Leave at least 2 cm air gap. Increasing spacing from 0.5 cm to 2 cm eliminated arc-over and lengthened sparks in tests [Elektroda, trzaska456, post #7485596]
Can I run two GU-81M tubes in parallel for more power?
Yes. Wire filaments separately, share a common cathode, and duplicate grid stoppers. Keep the anodes on separate primary halves or a bifilar coil. Expect near-double current draw; upgrade capacitors and transformer accordingly [Elektroda, miernik998, post #7469930]
How does a Staccato Controller improve performance?
The CMOS-555 Staccato driver fires the tube at the AC peaks, cutting duty cycle to 10–20 %. Peak anode voltage rises, giving longer sparks without overheating; the Steve Ward design boosted output by ~3× in practice [Elektroda, KJ, post #7469943][Ward, Staccato Controller].
Why does a blue glow appear on the glass envelope?
It’s electron back-scatter hitting the envelope when anode voltage is present without full resonance. This is normal but indicates inefficient operation; retune or add a series resistor [Elektroda, Anonymous, post #7473029]
How long should I heat the filament before applying high voltage?
Wait 60 seconds so the cathode reaches emission temperature; hot-switching shortens tube life [Tube Data Sheet][Elektroda, lodzik1990, post #7863988]
Are VTTC sparks safe to touch?
They are lower-current RF discharges; brief contact usually causes mild heating, but continuous arcs can burn skin or ignite flammables [Elektroda, Anonymous, post #7511231] Keep ground connections solid and use insulated tools.
What does reversing a winding lead actually do?
It swaps phase: if the feedback drives the grid 180° out of phase, gain is negative and the coil stalls. Reversing restores positive feedback and oscillation [Elektroda, slu_1982, post #7790795]
How much does a GU-81M VTTC cost to build?
Forum builders spent about PLN 100 on the secondary, PLN 150 on the tube plus heatsink, and another PLN 50 on parts—roughly €70 total [Elektroda, Anonymous, post #7511231]
Edge case: what causes secondary-to-primary punctures?
Too-tight coupling or sharp edges concentrate voltage, leading to flash-over during warm-up [Elektroda, d3211, post #7788619] Increase spacing, round corners, and limit peak current to <8 A.
