How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz?
Ganjor86 730846 1593
Can I turn a cheap DVB-T USB tuner into an SDR receiver, and how can I make it receive shortwave too?
Yes: with an RTL2832U-based DVB-T dongle you can use it as an SDR receiver after replacing the stock DVB-T drivers with the prepared Zadig/libusb drivers and running SDR software like SDR Sharp or HDSDR [#11182116] In normal mode these tuners work roughly from 24 MHz up to about 1700 MHz, so VHF/UHF services, airband, CB, ADS-B, etc. are fine [#13168529] [#12073526] For shortwave below that range, do not connect the antenna straight to the RTL chip; direct sampling is possible but is considered risky and can damage the RTL28xx [#12073526] The safer and better-performing solution in the thread is an upconverter on the antenna input, e.g. based on TA7358/LA1185/LA1186, which users report can extend reception down to roughly 100 kHz–40 MHz [#13135481]
  • #91 12616305
    Tommy82
    Help: 455
    Rate: 1074
    I was supposed to write earlier but I forgot; P
    http://www.rtl-sdr.com/tag/acars/
    I tested on ubuntu and it talks on an open dipole calculated on airband and receives packets quite well
  • E4000 needs only transformer modification for HF reception
    #93 12982211
    Hyper44
    Rate: 11
    In the case of the E4000, there is no need to remove the capacitors, only the transformer is soldered. For me, thanks to this, the tuner receives in the range from 130 kHz in the mode direct sampling and from 51 MHz in normal mode I / Q - I only switch inputs and change one option in the program. The latest version of HDSDR 2.70 has its plug that takes care of all the settings and runs without any problems. Of course, it is still necessary to replace the driver earlier.
    By the way: does anyone know if you can use any of the tuner outputs as a VFO signal source :?:
  • #94 13074010
    sb8gapi
    Rate: 36
    I have an RTL SDR RTL2832U & R820T tuner and I receive all frequencies from about 25 MHz to about 1900 MHz. (10m amateur bands, CB-Radio, aviation band, amateur stations on 145 MHz, and even ADS-B aircraft route tracking on 1090 MHz works). It all depends on the antenna.
    I wanted to listen to hams, e.g. in the 80m band below 25 MHz.
    For this I built two upconverters on the TA7358AP (LA1185) but unfortunately they don't work. I changed about 20 chips, but still the same, no signal at the output (there is only a 50 MHz signal from the quartz generator), as if the antenna was not connected. Electronic components (resistors and capacitors were checked twice in both converters). The 50 MHz generator is also functional in both converters - I checked it with a frequency meter. All the ICs I have are behaving the same. I have 17 TA7358 - from a few different stores and 3 LA 1185. I also have 4 LA1186. Perhaps there is some bug in the design that I built them on.
    Previously, I had fun with Direct Sampling, also featured in the forum on Not Only TV LV5T Deluxe, but I was not satisfied with the results, so I wanted to compare it with the upconver.
    I have a request to my friend "zabex", to include (or send to e-mail: sb8gapi(_at_)o2.pl) the schematic of the converter he built on LA1186, which is on a similar chip as LA1185. Maybe this converter would work for me.
    Alternatively, I post a diagram and materials about the upconverter I have built. Maybe someone will make corrections or find a bug.
    Upconverter comes from the site:
    http://blog.kf7lze.net/tag/shortwave/
    and here is a pdf with documentation:
    http://www.kf7lze.net/files/ta7358_-_hf-to-vhf-upconverter.pdf
    • How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? TA7358.jpg (65.46 KB) You must be logged in to download this attachment.
    • ta7358_-_hf-to-vhf-upconverter.pdf (203.57 KB) You must be logged in to download this attachment.
  • #95 13074101
    zabex
    Help: 50
    Rate: 52
    The scheme is perfectly correct. The only difference I have in mine is the connection of an ordinary 40MHz quartz with a parallel capacitor and trimmer to correct the frequency and a narrower low-pass filter. I tested on LA1186 and TA7358AP. I recommend the latter due to less interference and the possibility of going down to a frequency of around 170kHz.
    As for the TA7358AP chips, I bought 5 pieces a few months ago. During the subsequent tests of the converter, I used one of them and no reaction, the other systems behaved identically. My surprise after splitting one of them was endless. The circuit inside was completely empty !!! I do not know if my friend has any proven, tested TA, but I advise you to check it because there are such "rarities" as in my case.
    Since my friend edited his post and added that the systems come from different sources, I can only say that a 100% mistake was made because this converter starts with a "kick".
    Alternatively, when I find time, I redraw mine for comparison. Although not really what.
  • #96 13074168
    sb8gapi
    Rate: 36
    I wanted to describe everything as accurately as possible. As far as I know, the LA1185 is slightly different from the LA1186. Do you need to change something in the TA7358 diagram for LA1186 to work, because I guess you need to replace the pins of the integrated circuit.
    I built two thinking I built the first one by making a mistake somewhere. TA7358, which I have, are from several production batches, but it is possible that all of them are "coloring".
  • #97 13074190
    zabex
    Help: 50
    Rate: 52
    You don't need to change anything. In the prototype version of the converter, I had a soldered socket to the chip and I changed both of them for testing without any problems.
    Write something more about the method of connecting the converter to the dongle and antenna, the supply voltage of the antenna itself, etc.
  • #98 13074299
    sb8gapi
    Rate: 36
    I have a power supply for the converter from USB or a 5V stabilized power supply - I used it interchangeably. External antenna from CB Radio. RF-5 cable from the antenna to the tuner. I have a piece of original cable connected to the tuner, the MCX plug to the tuner on one side and the BNC socket on the other. I use different antennas for other bands.
    Without a converter on this antenna, the reception is very good, especially with strong transmitters. After connecting the converter, complete lack of reception of anything, as I wrote earlier, i.e. the same effect as disconnecting the antenna from the tuner - the tuner itself receives nothing after disconnecting the plug from the MCX socket. One converter has filters and the other does not (because I haven't had time to do them yet). After connecting the converter, I do not receive a single station (there are weak radio stations in the ukf radio band, but it is probably from a piece of wire from the converter output to the SDR RTL Tuner. I have this:
    NooElec Brand RTL-SDR, FM + DAB, DVB-T USB Stick Set with RTL2832U & R820T.
  • #99 13074553
    sb8gapi
    Rate: 36
    Thanks for the answers and advice. Today I will replace LA1185 (TA7358) with LA1186 and see if it works. I will write about the results on the forum.
    18.12.3013 21:21
    Still the same after replacing LA1185 with LA1186.
  • #100 13080533
    pablo_doctor
    Rate: 21
    someone thought or made one of his colleagues such a set based on Raspberry PI with one of the available Linux distributions ?? This could be a nice platform. By adding battery power and a small monitor, it would be quite an interesting mobile set.
    Unfortunately, I know the Linux environment poorly, I bought an RPI to experiment. I also heard that abroad they are up to something on this topic. I believe that a POLE CAN CAN and we will be better.
    Hi
  • #101 13080589
    lysy1980
    Help: 209
    Rate: 324
    Hi
    http://sdr.martinmarinov.info/
  • #102 13081121
    sb8gapi
    Rate: 36
    Personally, I have not tested SDR on Android, but I have a tablet and a smartphone, so I will check this SDR Touch. For those interested, he gives a page with other SDR-related applications for the ANDROID system.
    http://www.dxzone.com/catalog/Software/Android/
    To connect the Tuner with RTL2832U to an Android device, you need an OTG (On-The-Go) cable
    More info here:
    http://galaktyczny.pl/2013/02/20/host-usb-otg...li-zrobic-z-naszego-smartfonu-komputer-wideo/
    As soon as I get it, we will order a cable, I will test the operation of SDR on Android and I will write on the forum.
  • Asus Eee PC with R820T provides 6–7 hours of SDR use
    #103 13102547
    sb8gapi
    Rate: 36
    Unfortunately, my HTC Jetstream tablet does not support OTG technology, and the Xperia L smartphone does not have OTG support in the description, but it works when connected via a USB HUB with an additional 5V power supply.
    SDR Touch itself has limited functions in the free version. Only the Pro version for ? 5.99, or about PLN 30, is comparable to PC programs that are free, e.g. SDR Sharp or HD SDR.
    Perhaps on another smartphone (tablet) that supports OTG without additional power supply, it will be a more mobile solution. Unfortunately, in my case, the additional power supply to the USB HUB is not very convenient.
    Instead, I'm using the Asus Eee PC 1001PXD + NooElec NESDR Mini SDR & DVB-T USB Stick (R820T). SDR Sharp. It is quite convenient as a mobile equipment, the notebook battery works 6-7 hours with SDR listening.
  • #104 13103033
    Ganjor86
    Help: 18
    Rate: 46
    And I have recently a tablet lenovo ideatab A3000 and I am wondering how to connect to it RTL-SDR and Fi-Fi SDR
    but I will rather try to find some version of ubuntu for android. One could make a very mobile listening device :-)
  • Using Lenovo A3000 OTG for RTL-SDR Android operation
    #105 13103088
    sb8gapi
    Rate: 36
    Lenovo ideatab A3000 has USB OTG (On The Go) support, so you only need a special cable that can be purchased without problems on auction sites and you can directly connect the SDR tuner to USB.
    Just download the RTL2832U driver drivers
    https://play.google.com/store/apps/details?id=marto.rtl_tcp_andro
    and SDR Touch
    https://play.google.com/store/apps/details?id=marto.androsdr2
    When it comes to installing Ubuntu or any other Lunux distribution on a tablet, it's not that simple, and even a torment. This topic has already been discussed in the forum:
    https://www.elektroda.pl/rtvforum/topic2444315.html
    but as it turns out it is possible:
    http://www.nibyblog.pl/trzy-sposoby-na-uruchomienie-linuxa-na-androidzie-5602.html
  • #106 13106944
    Ganjor86
    Help: 18
    Rate: 46
    Both links are from a year ago and in the field of running ubuntu on android a lot has changed, for example ubuntu touch which is intended for tablets and is said to be easy to install. All that's left is to get to know the possibilities of individual editions and get down to business, but only if I have a sd card for my tablet and an otg adapter.
  • Raspberry Pi supports ARM drivers and external DDS designs
    #107 13107044
    mkpl
    Level 37  
    Help: 306
    Rate: 863
    There should be no problems with RaspberyPI. Android drivers are actually ARM Linux drivers that work as an android lower layer.
    As RbPI is on Linux for ARM (without android overlay) the drivers will work and the program just needs to be recompiled from x86 to ARM.
    By the way, bouncing from this RTL ... This raspbery basically allows you to connect much better external DAC and ADC on the GIPO (it is even in diy, when someone connected an external driver), it has its own sound card and hardware SPI.
    I think that making a classic DDS + DAC / ADC receiver as SRD would be a much better solution because we also have the option of modulating dsp filters and what dreams :D Perfect radio.
    With the bandwidth, I would have no trouble playing with DDS modules from my friend which are controlled by uart (e.g. pc terminal) and allow a beautiful 200MHz sine.
  • SDR Touch required root and a powered USB hub
    #109 13107330
    sb8gapi
    Rate: 36
    Galaxy S III is listed on the creator's website as compatible, so there should be no problems.
    Does the phone see other USB devices - mouse, keyboard, USB flash drive connected via an OTG adapter (cable)? If so, it should detect the USB tuner.
    I suppose Tuner works on a PC.
    I wrote about this a few posts above. I was able to run SDR Touch and the driver on the Sony Xperia L, but only after connecting via USB HUB with additional power and starting the "Root" mode of the phone. Admittedly, on the author's website there is information that "Root" is not required for Android version higher than 3.1, but on my Android 4.2.2 Jelly Bean, without "Root" when starting the driver, even with "Force Root" selected the error was: Unknown error. Only the "Root" of the phone helped.
    I would like to add that the operation of SDR Touh quite quickly discharges the phone's battery, after several dozen minutes (about 30 minutes) it dropped from 100% to 80%, i.e. listening is enough for a few hours (2-3). It will probably work longer on the tablet.
    Before starting the driver, I checked the "Force Root" option.
    I post screenshots from my phone.
    The first is when the driver is started and the second is from a running program.
    As for the SDR Touch itself, the free version lacks "Spectrum", which makes it difficult to use the program, because you cannot see if something is broadcast on a specific frequency or not. You only scan frequencies on the scale. The program crashed several times (driver error), a restart of the phone was required.
    Rather, I prefer to use the PC version. For me, SDR Touch in the free version looks more like a fun program than a functional application. The paid version is probably a bit better (you can see it, for example, in a YouTube video a few posts above), but I did not want to pay about PLN 30. for a program that did not meet my expectations, so I did not test the Pro version. Perhaps someone will like it, the author should be commended for his contribution and that there is such an Android application. It is probably a step towards the creation of other programs as well.
    Maybe these pages will help you solve the problem:
    FAQ on the author's website:
    http://sdr.martinmarinov.info/contact.php
    and xda-developers forum topic:
    http://forum.xda-developers.com/showthread.php?t=2108053
    Admittedly, the addresses to the mentioned websites are from a year ago, but they were only to be examples that it is possible to run Linux on a tablet or smartphone.
    Of course, you can combine the construction of more complex devices, but you have to answer whether it is worth it, significantly increasing the cost of the entire device.
    The tuner itself on RTL costs about PLN 30 + making an external antenna about PLN 30-50, so the cost is small, and the effect is really great at the costs incurred.
    For beginners, such a solution is cheap and gives good results.
    You can play with SDR Touch, but in the free version, SDR Sharp for PC is not up to the heels, which is free so far. Only in the paid version, it slightly resembles Sharp's SDR, but leaves a lot to be desired. These are my personal observations and I do not want to alienate anyone from Android, and I also had some problems with the installation on my Sony Xperia L. It is probably also a matter of the hardware itself.
    As for Linux and the software for this system, I have not used it, so I will not comment.
    In summary, anyone interested can choose between different hardware and system platforms, and each solution has its own advantages and disadvantages.
  • #110 13135481
    sb8gapi
    Rate: 36
    Thank you to the "Zabex" forum member for the TA7358 converter scheme (LA1185, LA1186 can be used) for the USB RTL SDR tuner that allows you to receive frequencies below 24 MHZ - from about 100kHz to 40 MHz. I was able to finally run it according to the diagram sent by "Zabex". I found a similar scheme on the internet, which I also used and post it, because it may be useful to someone.
    Page with description and diagram:
    http://darkliferadio.proboards.com/thread/690...ftware-defined-converter?page=1&scrollTo=3237
    and here is the diagram:
    Drawn by hand, but it is legible and proven.
    I had the opportunity to compare Direct Sampling and converter performance. The converter is much better and no tuner modification is required.
    The replacement LA1185 - AN7205, which I bought 2 pieces in the SŁAWOMIR Electroniics movie, also works well, it works even slightly better than the TA7358 (cleaner signal, less interference, and a higher signal level).
    This is such information, if someone needed chips from a proven source.
    The LA1186 works in the converter, but is noticeably less sensitive than with the LA1185 and TA7358.
    http://slawmir.com.pl/
    As I wrote earlier of all the systems, I have about 25 from different stores, and it turned out that some of them do not work, as "Zabex" wrote when he found "empty inside".
    Confirmation of the converter operation on a 40 MHz quartz resonator and LA 1185 - reception of Polish Radio I at 225 kHz (weak signal, because the experimental antenna consists of a few meters of cable).
    Another screen of the converter operation on a 50 MHz quartz generator and LA1185 - reception of Polish Radio I at 225 kHz and you can see other stations received on long and medium waves.
    The previously described TA7358 converter with a 50 MHz quartz generator works if everything is done according to the diagram (I had a problem with starting it up, because my design had a bug, but after checking it worked). A converter with a quartz generator performs better - better sensitivity and less interference. The LA1185 IC works best, then the TA7358 and AN7205, but the difference is small (it also depends on the specific unit).
  • #111 13166132
    sb8gapi
    Rate: 36
    For several days I tested converters - one built with a quartz generator and the other with a quartz resonator. I would like to make some comments that may be useful for someone who would like to make such a converter.
    Each has its own advantages and disadvantages.
    The converter with a quartz generator has noticeably better sensitivity, but the generator frequency shift is 3 kHz (it is smaller - for a 50 000 kHz generator the shift in SDR Sharp - the Shift option is 49 997 kHz - you can see it in the SDR Sharp screen above) I don't know what it is is caused, and I checked on several generators and ICs, and it was unchanged. Maybe someone met with such a case.
    The schematic of the converter is a few posts above.
    Converter on a quartz resonator (I used a 40 MHz quartz resonator at home (without an additional adjustable capacitor), it had lower sensitivity, but the shift was equal to the resonator frequency. You can see it in the SDR Sharp screen. I can still adjust the gain in Configure -> without Tuner checked AGC - with a slider. To build a converter with a quartz resonator, I used the same scheme as for the previously described converter, but instead of the generator and all the elements associated with it, I connected the resonator directly to pin 8 of the IC, as you can see in the diagram drawn by hand with a quartz resonator .
    After checking the operation of several dozen integrated circuits, the LA 1185 works best in the converter circuit, then the TA7358 and AN7205 and the LA1186 works the worst.
  • #112 13167391
    woitek77
    Hello!
    I would like to get a dvb-t listening scanner because I cannot afford another scaner. I have a few questions:
    Is there a list of proven tuners available at Polish auctions somewhere?
    Which tuners do you recommend? (no holes in the band)
    Is there any installation tutorial, or maybe you don't need it, because all you need is a soft SDR and plug in the USB tuner and it will start ??
    Best regards!
  • #113 13168529
    sb8gapi
    Rate: 36
    First, the tuner must have RTL2832 + tuner chip, preferably R820T (currently the best).
    http://sdr.osmocom.org/trac/wiki/rtl-sdr
    Please read this topic from the beginning and:
    https://www.elektroda.pl/rtvforum/topic2463965.html
    http://sp7pki.iq24.pl/default.asp?grupa=3538&temat=136325
    http://sp-hm.pl/thread-1273.html
    Description of the installation, e.g. here:
    http://ywd.pl/projekty/odbiornik-sdr/
    http://www.wykop.pl/ramka/1341289/rtlsdr-czyli-odbieraj-niemal-wszystko-z-tunera-dvb-t/
    http://www.atouk.com/SDRSharpQuickStart.html
    http://rtlsdr.org/softwarewindows.
    YouTube guide:
    http://www.youtube.com/watch?v=D32eqlEeplQ
    For collection, I recommend the program for Windows SDR Sharp and possibly HD SDR.
    http://sdrsharp.com/
    http://www.hdsdr.de/
    and here from another forum shortened frequency division:
    https://spreadsheets.google.com/pub?key=pyxWa...8-CNJ2UMv7zJbw&single=true&gid=51&output=html
    http://www.bezzalogowce.pl/index.php/czno/31-...ajowa-tablica-przeznacze-czstotliwoci?start=2
    As for tuners on the Polish market, these are Allegro:
    http://allegro.pl/tuner-dvb-t-hd-mpeg4-rtl2832u-sdr-najnowszy-model-i3873743138.html and I also recommend this tuner.
    I personally bought 2 pieces on ebay from china:
    http://www.ebay.com/itm/BF9-Good-Software-Rad...l-TV-Receiver-/181250115475?ssPageName=ADME:L :O AT :P L: 3160
    It is identical to that of the Allegro.
    These are just examples and at the end I would like to add that it is worth paying attention to the protective diode at the antenna input when buying.
    The tuner with the R820T itself allows you to receive frequencies from about 24 MHz to about 1700, but you can increase the bandwidth thanks to the converter for LA1185 (TA6358) described in this topic.
  • #114 13170575
    bogi
    Help: 103
    Rate: 244
    sb8gapi
    The better sensitivity is due to the higher signal level from the generator on the mixer. The internal circuit (leg 8) with quartz works as a generator, but the external generator connected to it makes it a repeater (an amplifier with a low gain). Hence the greater signal on the mixer. If you would make a separate quartz generator, e.g. on one transistor, and connect it to the system, you would also notice better sensitivity.
  • #115 13171254
    sb8gapi
    Rate: 36
    I guessed that there would be more sensitivity with the generator, but thanks for the answer and the detailed explanation. I am wondering about another problem. I wrote about the fact that with the generator there is a shift not by 50 MHz, but by about 3 kHz less, i.e. 49 997 kHz. Maybe someone knows if this can be changed or what it is caused by. I adjust the gain level in SDR Sharp to the level of the best reception with minimal distortions and interference. I experimentally built a converter with a miniature switch so I can choose between a quartz resonator or a quartz generator.
  • #116 13171450
    lysy1980
    Help: 209
    Rate: 324
    You can correct the shift by means of the PPM function in the program.
  • #117 13172259
    sb8gapi
    Rate: 36
    I know that it can be done in the program, but I mean, can it be done in a converter?
    I changed the quartz generators and circuits, but no changes. I measured the frequency of the generator and it is equal to 50,000 kHz in all 4 I have. Maybe today I will put a quartz generator on a different frequency and then check it.
    My converter:
    and on the screen:
  • #118 13175982
    woitek77
    Hello!
    I have a problem installing / running rtl-sdr shharp. I do everything according to the instructions ....
    I unpack the sdr # in any location, then install ExtIO_USRP + FCD + RTL2832U + BorIP_Setup, the modem has drivers installed ...
    I fire up sdr # and in the selection window I do not see RTL-SDR USB, only RTL-SDR / TCP ???
  • #119 13176010
    sb8gapi
    Rate: 36
    You should enter the folder with SDR Sharp. If there is a Config folder there, go to it and copy the file: SDRSharp.exe.Config to the main program folder. If there is no this folder, you need to edit this file: SDRSharp.exe.Config from the main folder, because by default RTL USB support is not active.
    Open the file in the editor, e.g. Notepad and go to the section at the end of the file:
    There will be something like this:
    and you need to delete (at the end) to get this entry:
    And we save the file.
    I also present the latest version of SDR Sharp on 14/01/2014 with RTL USB support enabled.
    • SDRSharp1173.zip (885.1 KB) You must be logged in to download this attachment.
  • #120 13176245
    woitek77
    Thank you very much!
    The first observations are very few stations :( even on VHF I have only two radio stations? What could it be? Antenna?
The discussion centers on using inexpensive DVB-T USB tuners, particularly those based on the RTL2832U chipset combined with various tuner modules like the R820T and E4000, as software-defined radio (SDR) receivers. These devices, originally intended for digital TV reception, can be repurposed for wideband SDR reception from approximately 25 MHz up to 1.7 GHz, covering amateur radio bands, FM broadcast, airband, ADS-B, and more. Modifications such as direct antenna connection to the RTL2832U chip pins enable reception of lower frequency bands (below 30 MHz), including shortwave, though precautions against electrostatic discharge and signal surges are necessary. Upconverter circuits based on chips like LA1186, LA1185, and TA7358AP are commonly used to extend reception down to HF and VLF bands by frequency shifting signals into the tuner's range. Various software solutions including SDR# (SDR Sharp), HDSDR, and dump1090 are recommended for Windows and Linux platforms, with driver installation often requiring tools like Zadig to replace default DVB-T drivers with RTL-SDR compatible ones. Users report challenges with driver installation, device recognition, and antenna selection, especially for frequencies outside the FM broadcast band. Amplifiers such as the FP6L and antennas like Discone or long wire are suggested to improve reception quality. Mobile and embedded platforms like Raspberry Pi and Android devices with USB OTG support are explored for portable SDR setups. The community shares detailed schematics, installation guides, and troubleshooting tips, emphasizing the cost-effectiveness and versatility of RTL-SDR dongles for radio experimentation and monitoring.
TL;DR: A US$13 RTL-SDR dongle with an R820T tuner covers 24-1762 MHz “Band 24-1762 MHz (no holes)” [Elektroda, zabex, post #12073526] and can be pushed to ≈100 kHz with a 50 MHz up-converter [Elektroda, sb8gapi, post #13074101]
Why it matters: One stick lets hobbyists scan HF, VHF, UHF and ADS-B without big radios.
• R820T native span: 24–1762 MHz [Elektroda, zabex, post #12073526] • Direct-Sampling mod: ≈0.1–28 MHz [Elektroda, methyl, post #13657048] • Typical dongle cost: US$13–15 incl. whip [Elektroda, Ganjor86, post #12076142] • PC spec: USB 2.0 + ≥1.2 GHz CPU [Elektroda, Serwis1, post #13206155] • TA7358 up-converter parts ≈ PLN 15 [Elektroda, sb8gapi, post #13074101]
What frequencies can an un-modified RTL-SDR with R820T cover?
About 24 MHz to 1.76 GHz without gaps [Elektroda, zabex, post #12073526] That spans airband, AIS, ACARS, ADS-B, VHF FM, UHF trunked, LTE and more.
How do I install drivers on Windows XP?
  1. Plug dongle, let Windows load Realtek driver.
  2. Run Zadig v2.1 XP, Menu → Options → List All Devices, choose "Bulk-In Interface 0".
  3. Click Install WINUSB driver. After 5 s SDR# sees “RTL-SDR/USB”. [Elektroda, lysy1980, post #13511327]
I get no DVB-T after installing SDR drivers—normal?
Yes. WINUSB replaces Realtek’s TV driver. Switch USB port or reinstall OEM driver when you need DVB-T reception [Elektroda, lysy1980, post #13511327]
What’s the simplest way to receive 0–30 MHz?
Add a 50 MHz HF up-converter using TA7358 or LA1185. It mixes HF to 50–80 MHz, cost under PLN 15 and sensitivity beats direct sampling [Elektroda, sb8gapi, #13074101; Elektroda, zabex, #12073526].
Can overheating freeze the dongle?
Yes. R820T can reach >60 °C and USB disconnects appear. Resoldering the USB plug and adding small heatsinks stopped lock-ups [Elektroda, mkpl, post #13635115]
Which antenna works best for wideband scans?
An outdoor TV log-periodic or discone on 50 Ω feed covers 50–1300 MHz. For HF add Mini-Whip or 20 m long-wire plus the up-converter [Elektroda, methyl, post #13657048]
Edge case: why does FM broadcast appear at 30 MHz?
Strong local FM images alias into 26–40 MHz when the front-end overloads. Use 88–108 MHz notch or reduce RF gain [Elektroda, mkpl, post #13583266]
Can I scan automatically like a hardware scanner?
Yes. Install the ‘Frequency Manager Scanner’ plug-in for SDR#; it hops user lists at 20 channels /s and logs activity [SDRSharpPlugins].
Is spectrum-analysis possible?
RTL-SDR plus ‘RTL-Power’ or ‘Spektrum’ sweeps 24 MHz–1.7 GHz, 2 MHz steps, ~30 dB dynamic range—handy for EMC checks [majek, 2013].
How do I add HF direct sampling without removing the tuner?
On R820T boards, wire a 1:10 transformer to RTL pins 4-5, select “Direct Sampling Q” in SDR#. This keeps VHF/UHF intact [Elektroda, BOOM i ZONK, post #13914702]
