How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz?
Ganjor86 730846 1593
Can I turn a cheap DVB-T USB tuner into an SDR receiver, and how can I make it receive shortwave too?
Yes: with an RTL2832U-based DVB-T dongle you can use it as an SDR receiver after replacing the stock DVB-T drivers with the prepared Zadig/libusb drivers and running SDR software like SDR Sharp or HDSDR [#11182116] In normal mode these tuners work roughly from 24 MHz up to about 1700 MHz, so VHF/UHF services, airband, CB, ADS-B, etc. are fine [#13168529] [#12073526] For shortwave below that range, do not connect the antenna straight to the RTL chip; direct sampling is possible but is considered risky and can damage the RTL28xx [#12073526] The safer and better-performing solution in the thread is an upconverter on the antenna input, e.g. based on TA7358/LA1185/LA1186, which users report can extend reception down to roughly 100 kHz–40 MHz [#13135481]
  • #121 13176281
    sb8gapi
    Rate: 36
    If it is an antenna from the set, it is usually of very poor quality. And how many stations are received on an ordinary radio receiver?
    A suitable antenna is the basis for reception.
    I propose to build an external antenna for the roof or balcony. There are many descriptions of antennas for different bands on the electrode.
    For the most interesting bands of 144 MHz and 430 MHz, there is an antenna in this topic:
    https://www.elektroda.pl/rtvforum/topic252399.html
    construction
    Rob SP3WBX
  • #122 13176707
    Tommy82
    Help: 455
    Rate: 1074
    On VHF, he even picks it up on his finger.
    I would check the antenna cable first, especially if you have a Chinese cable, a grommet or an original antenna. Some antennae have a hair-thick hot vein concentrate, and it's not hard to break it
  • #123 13179892
    Ganjor86
    Help: 18
    Rate: 46
    If you have an antenna added to the tuner, it is definitely the antenna's fault :-)
  • #124 13180888
    woitek77
    Hello!
    Where is this PPM function from correcting the shift?
  • #125 13182125
    lysy1980
    Help: 209
    Rate: 324
    What program?
  • Configuring SDR# and HDSDR for matching VHF reception
    #126 13183651
    woitek77
    Hello!
    I installed both HDSDR and SDR #. The case is as follows:
    SDR # very few stations, 137 MHz aviation complete necrosis, 173 MHz I receive something there, but quiet, VHF radio is ok ... for me this program is poor
    HDSDR many more stations, 137 aviation warszawa-radar very good, cb band very good, except that 173 MHz data transmissions only, as if encoded at the same frequencies as in SDR # speech was received, and on HDSDR no VHF ... spectrum I can see the station, but the voice is very modulated ...
    What to do to make SDR # receive the same as HDSDR, and what to do to make sure there are ukf's in HDSDR
  • #127 13185973
    lysy1980
    Help: 209
    Rate: 324
    Change the gain in the settings.
  • #128 13206155
    Serwis1
    Help: 36
    Rate: 128
    Here is a plugin for SDR # which already has something like a scanner http://www.sdrsharpplugins.com/
    I recommend version V1.4 as it works as fast as possible
    As for the most important SDR settings # because this program is the best
    1. In the "Cofigure" tab set the correct frequency "Frequency correction"
    First, tune to a well-known VHF radio station, then listen and "catch", for example, the 134.225 Warsaw radar and fine-tune it (the half-zoom is best visible if it is inside).
    2. For listening, in my opinion, it is best to set everything unchecked in the "Configure" tab and the RF Gain to the maximum
    3. The computer must have a minimum USB 2.0 processor with at least 1.2GHz
    And this is the most important thing for further action
    As for which receiver to choose, the best one is RTL2832U (it is no problem at auctions), secured input, covers the entire range and is sensitive, I compared it with several "normal" scanners and it won or was identical with each one.
    As for connecting a normal antenna, because you will not hear anything on this set, it is enough to cut off the original antenna and mount a socket on the cable, even an ordinary TV
    At the beginning of the fun you can use the popular mesh TV antenna, but without any amplifiers !!! and preferably without this mesh in the back it will be more omnidirectional On such an antenna you will receive virtually all planes over Poland, trains, ambulances, guards and other services at least 20 km and even 60 km
    The 400MHz band, there are smaller ranges, but something is going to catch
    And then just think and it's best to make an appropriate antenna for the band that interests us the most (for a few zlotys).
    Serwis RTV
    50-lecia Kopalni Konin 11, Kleczew, 62-540 | Company Website: http://rtvlg.pl
  • #129 13206400
    lysy1980
    Help: 209
    Rate: 324
    Whether SDR # is the best for your taste, but I recommend SDR CONSOLE v2
  • #130 13214891
    maser777
    Two heads are better than one, so maybe colleagues will tell you why HDSDR does not work for me. I have Not Only TV RTL2832u / FC0013, the system is Windows MX which is a truncated professional version of 2002 SP2. I did everything step by step according to the instructions (http://www.hmmb.nl/downloads/RTL2832U-installing.pdf), I replaced the drivers, pasted the new librtl2832 ++. Dll to the installation folder, in device hint I entered RTL and the flap. I run and even don't catch radio stations. My device manager looks like this:
  • #132 13215002
    maser777
    I did step 5 during the installation. To be sure, I did it again and it looks like Zadig is not replacing my drivers. Device manager remains unchanged as mentioned above. And in the next step after replacing drivers, something like this appears to me:
  • #133 13215230
    lysy1980
    Help: 209
    Rate: 324
    It seems to me that you are installing drivers for some other device.
    What appears in the ZADIG list when you select Options> List All Devices?
  • #134 13215462
    maser777
    I have: USB 2.0 Video, USB audio device, Bulk-In Interface 1 and Bulk-In Interface 0.
  • #135 13215525
    lysy1980
    Help: 209
    Rate: 324
    What is in the VID and PID fields of Bulk-In devices in Zadig?
  • #136 13215569
    maser777
    Bulk-In Interface 1 mam VID: 1F4D PID: C803 MI:01
    Bulk-In Interface 0 VID:1F4D PID: C803 MI:00
  • #137 13215597
    lysy1980
    Help: 209
    Rate: 324
    In my eye you have something mixed up in the system, remove both devices in the device manager and after this procedure, remove the tuner from the USB port, wait a moment and insert it again and then show what has appeared in the device manager.
    I do not know if it is not the fault of your truncated Windows.
    For any of the Bulk-In, Interface should be 0BDA VID and PID 2832 or 2838
    EDIT:
    What do you have in VID and PID at USB 2.0 Video because I buried in my tuners and I think that NotOnly is like that?
  • #138 13215681
    maser777
    Lysy thanks for your help. I do not want to clutter the forum, so I will try to install it on another laptop with a different system on Sunday because I also think that something is not working in my system. As soon as I check, I will contact you at PW.
  • #139 13218954
    maser777
    problem solved. The culprit turned out to be a truncated version of the system and its drivers. On normal XP, it flies. Unfortunately, the tenderness is terrible. Gain to the max and you can hardly hear radio stations, let alone receive weaker signals. I do not have a "normal" antenna at the moment, so I use the thumbnail included in the set.
  • #140 13224810
    M. S.
    Help: 259
    Rate: 680
    I have short and frequent breaks in my pickup. The sound is hoarse. Has anyone encountered such a problem?
  • #141 13225138
    hosiek
    Help: 5
    Rate: 21
    Yes, reduce the receiver bandwidth, you probably have 2MHz and the computer is not working.
  • Weak reception caused by the bundled antenna
    #142 13226010
    DjExit
    Help: 10
    Rate: 81
    You answered yourself :P Use a "normal" antenna and you will see that the circuit has a really good sensitivity.
  • #143 13226136
    M. S.
    Help: 259
    Rate: 680
    hosiek
    Could you please guide me on how to do it in HDSDR program? I changed the settings, but I guess I missed the right one.
  • #145 13283401
    TM85
    Help: 52
    Rate: 150
    Is there a program that can scan the full band - spectrum analyzer 50-860MHz? The point is for me to see the whole band, not just a few MHz.
  • #146 13283494
    sb8gapi
    Rate: 36
    I don't know Linux programs, so I don't comment on that.
    SDR Sharp and HDSDR are very popular for Windows.
    I suggest checking one more program:
    SDR RADIO Pro
    Has RTL SDR support - Realtek RTL2832U
    The program is noteworthy, and it has already been mentioned on the forum:
    Version 2.1 Release - license until January 8, 2015.
    https://www.dropbox.com/s/b1kqas6o5ofpdy0/SDR-RADIO-Pro_v2.1b1640.exe
    RTLsdr.dll libraries required for the program:
    http://sdr.osmocom.org/trac/attachment/wiki/rtl-sdr/RelWithDebInfo.zip
    and
    64bit SDRSourceRTL2832U.dll
    http://www.aa5sh.com/files/SDR-RADIO.com.RTLUSB.zip
    or
    http://www.aa5sh.com/files/SDR-Radio.com.RTLUSB-20130209.zip
    Source: http://www.aa5sh.com/?page_id=65
    Description of installation and configuration for RTL SDR:
    http://www.hamradioscience.com/sdr-radio-com-v2-0-now-supports-rtl2832u-sdr/
    and SDR RADIO Pro home page:
    http://v2.sdr-radio.com/Home.aspx
    http://v2.sdr-radio.com/Download.aspx
    http://v2.sdr-radio.com/Support/QuickStart.aspx
    For this program you need more powerful hardware, as it has much greater requirements than SDR Sharp or HD SDR.
    The recommended minimum system configuration is:
    Windows XP or later, 32-bit or 64-bit
    Core 2 Duo @ 2GHz or more or i3 or better.
    Monitor resolution of 1368 x 768 or higher.
  • #147 13286870
    TM85
    Help: 52
    Rate: 150
    Thanks. I used to play with a cable TV analyzer. In a second or two, it scanned and traced the entire spectrum on the screen. I am looking for a program with this functionality. Non-vibrating spectrum but rather signal strength graph.
    I was looking for but there is probably nothing like that.
  • #148 13287209
    zabex
    Help: 50
    Rate: 52
    sb8gapi wrote:
    As far as I know, such a program does not exist, and watching the 800MHz band is rather pointless, because you will not see anything anyway.
    For Windows:
    In SDR Sharp, you can set the highest Sample Rate in Configure to 3.2 MPPS. Then the widest band is viewed. It is a few MHz. In HDSDR you can see a much wider band, more than a dozen MHZ ...
    Such a program of course exists and it is not about displaying the SR which for the R820T is up to 3.2MSPS (i.e. about 3.2MHz). In HDSDR you will not see anything else because the hardware does not allow it!
    What the TM85 asks about is the analysis of the entire bandwidth received by the dongle, not the number of samples received in a given bandwidth!
    Please search rtl-sdr.com for frequency scanners (incl. Plugins for SDR #). Some time ago, there was also a link to a separate software that "scanned" all available frequencies and a graph was made on this basis. Thanks to this, I know at what frequency "something" works and what I can expect in my area.
  • #150 13296983
    Zloty60
    Help: 14
    Rate: 69
    What are the hardware requirements for SDR Sharp?
    Is USB 1.1 enough?
The discussion centers on using inexpensive DVB-T USB tuners, particularly those based on the RTL2832U chipset combined with various tuner modules like the R820T and E4000, as software-defined radio (SDR) receivers. These devices, originally intended for digital TV reception, can be repurposed for wideband SDR reception from approximately 25 MHz up to 1.7 GHz, covering amateur radio bands, FM broadcast, airband, ADS-B, and more. Modifications such as direct antenna connection to the RTL2832U chip pins enable reception of lower frequency bands (below 30 MHz), including shortwave, though precautions against electrostatic discharge and signal surges are necessary. Upconverter circuits based on chips like LA1186, LA1185, and TA7358AP are commonly used to extend reception down to HF and VLF bands by frequency shifting signals into the tuner's range. Various software solutions including SDR# (SDR Sharp), HDSDR, and dump1090 are recommended for Windows and Linux platforms, with driver installation often requiring tools like Zadig to replace default DVB-T drivers with RTL-SDR compatible ones. Users report challenges with driver installation, device recognition, and antenna selection, especially for frequencies outside the FM broadcast band. Amplifiers such as the FP6L and antennas like Discone or long wire are suggested to improve reception quality. Mobile and embedded platforms like Raspberry Pi and Android devices with USB OTG support are explored for portable SDR setups. The community shares detailed schematics, installation guides, and troubleshooting tips, emphasizing the cost-effectiveness and versatility of RTL-SDR dongles for radio experimentation and monitoring.
TL;DR: A US$13 RTL-SDR dongle with an R820T tuner covers 24-1762 MHz “Band 24-1762 MHz (no holes)” [Elektroda, zabex, post #12073526] and can be pushed to ≈100 kHz with a 50 MHz up-converter [Elektroda, sb8gapi, post #13074101]
Why it matters: One stick lets hobbyists scan HF, VHF, UHF and ADS-B without big radios.
• R820T native span: 24–1762 MHz [Elektroda, zabex, post #12073526] • Direct-Sampling mod: ≈0.1–28 MHz [Elektroda, methyl, post #13657048] • Typical dongle cost: US$13–15 incl. whip [Elektroda, Ganjor86, post #12076142] • PC spec: USB 2.0 + ≥1.2 GHz CPU [Elektroda, Serwis1, post #13206155] • TA7358 up-converter parts ≈ PLN 15 [Elektroda, sb8gapi, post #13074101]
What frequencies can an un-modified RTL-SDR with R820T cover?
About 24 MHz to 1.76 GHz without gaps [Elektroda, zabex, post #12073526] That spans airband, AIS, ACARS, ADS-B, VHF FM, UHF trunked, LTE and more.
How do I install drivers on Windows XP?
  1. Plug dongle, let Windows load Realtek driver.
  2. Run Zadig v2.1 XP, Menu → Options → List All Devices, choose "Bulk-In Interface 0".
  3. Click Install WINUSB driver. After 5 s SDR# sees “RTL-SDR/USB”. [Elektroda, lysy1980, post #13511327]
I get no DVB-T after installing SDR drivers—normal?
Yes. WINUSB replaces Realtek’s TV driver. Switch USB port or reinstall OEM driver when you need DVB-T reception [Elektroda, lysy1980, post #13511327]
What’s the simplest way to receive 0–30 MHz?
Add a 50 MHz HF up-converter using TA7358 or LA1185. It mixes HF to 50–80 MHz, cost under PLN 15 and sensitivity beats direct sampling [Elektroda, sb8gapi, #13074101; Elektroda, zabex, #12073526].
Can overheating freeze the dongle?
Yes. R820T can reach >60 °C and USB disconnects appear. Resoldering the USB plug and adding small heatsinks stopped lock-ups [Elektroda, mkpl, post #13635115]
Which antenna works best for wideband scans?
An outdoor TV log-periodic or discone on 50 Ω feed covers 50–1300 MHz. For HF add Mini-Whip or 20 m long-wire plus the up-converter [Elektroda, methyl, post #13657048]
Edge case: why does FM broadcast appear at 30 MHz?
Strong local FM images alias into 26–40 MHz when the front-end overloads. Use 88–108 MHz notch or reduce RF gain [Elektroda, mkpl, post #13583266]
Can I scan automatically like a hardware scanner?
Yes. Install the ‘Frequency Manager Scanner’ plug-in for SDR#; it hops user lists at 20 channels /s and logs activity [SDRSharpPlugins].
Is spectrum-analysis possible?
RTL-SDR plus ‘RTL-Power’ or ‘Spektrum’ sweeps 24 MHz–1.7 GHz, 2 MHz steps, ~30 dB dynamic range—handy for EMC checks [majek, 2013].
How do I add HF direct sampling without removing the tuner?
On R820T boards, wire a 1:10 transformer to RTL pins 4-5, select “Direct Sampling Q” in SDR#. This keeps VHF/UHF intact [Elektroda, BOOM i ZONK, post #13914702]
