HTC Wildfire S - if the website revskills does not work, how to calibrate the to
krichos 161853 505
How can I calibrate the HTC Wildfire S touchscreen if the RevSkills website is unavailable?
Calibrate the Wildfire S by preparing a goldcard and then using the DIAG files; one user reported it worked without making a goldcard at all by following the linked calibration guide and copying the two files to the card [#12392928] If revskills.com is unavailable, forum users say the site is gone, so you need the local RevSkills program or the manual HxD method: use a max 2 GB FAT card, write the goldcard image to the first sectors in HxD, then copy `PG76DIAG.nbh` and `HTC-ANDROID-GOLD_CARD` onto the card [#12393676] [#12323220] [#12326238] The thread also warns that SDHC/large cards often fail with errors like `Security fail` or `Launch app fail` [#12326238] [#13272966] If calibration finishes but parts of the screen or the lower keys still do not work, the digitizer itself is likely bad and needs replacement [#12669130] [#12947572]
  • #211 12554195
    hacker_ice
    Help: 36
    Rate: 101
    Files attached
    • reverce.rar (235 Bytes) You must be logged in to download this attachment.
    • normal.rar (241 Bytes) You must be logged in to download this attachment.
    Apple Surgery
    Śląska, Bargły, 42-262 | Company Website: https://applesurgery.com.pl
  • #212 12554563
    radzik34
    Thanks a lot! It flashes nice.
  • #214 12557847
    radzik34
    reverce.img but in the SimpleGoldCard program because in HxD it did not want to move.
  • #215 12575722
    Makavieli
    I have one more question. When saving a file in revskills, it saves it in an unknown format, I cannot choose img, there is only any binary. How, what and why? Thanks in advance.
    Added after 7 [minutes]:
    Or otherwise :) my CID
    CID rever: 008A00EE3E99B11030303030304D531B
    Thanks in advance.
    Added after 1 [hours] 55 [minutes]:
    I get tired and tired. I read the card's CID with SimpleGoldCard which needs HTC Sync
    reverse CID: 008A00EE3E99B11030303030304D531B
    in RevSkills I created goldcard.img (simply entering .img as an extension, setting BUZZ according to the instructions)
    I formatted the card to FAT32 (in the laptop reader), with the HxD program, according to the instructions, I opened the img that was on the disk, selecting the card and overwriting the data according to the instructions. And now the question of what's next, after throwing the card into the phone and holding Power and Vol Down, I enter the option, after a while showing the card scan SD checking and NOT FOUND below, etc.
    Did I miss something, did I do something wrong? Help!!!
  • #216 12576100
    hacker_ice
    Help: 36
    Rate: 101
    Hello buddy Makavieli,
    You need to upload files from post # 21 link to the card:
    https://www.elektroda.pl/rtvforum/topic2568405.html#12323393
    Besides, if you already use Revskill, make the card after connecting the device with WinCE because as I can see SimpleGoldCard reads the CID of the card badly, I had the same with my card and if you have a sequence of numbers ... 30303030 ... this is bad for me, yes was and I had to use a different card.
    Apple Surgery
  • #217 12576371
    Makavieli
    I don't have anything with WinCE but I'll give you a quick tip, thanks for the hint :)
    And do I put these two files after the changes in HxD or after?
    Still the same
    new card, new CID rev: 00C2007398D1281047383041534D5402
    changes in HxD (files thrown in after changes and by changes) and still the same effect.
    Added after 45 [minutes]:
    I get "no image or wrong image" while scanning the card after turning on the phone.
  • #218 12576649
    hacker_ice
    Help: 36
    Rate: 101
    So what you are left with is to get the device running with WinCE, usually it's navigation and revskill to do it
    Apple Surgery
  • #219 12587212
    taotao92
    Could you please generate me an img from this cid?
    009900A3417BA33847323044534D5402
    Please, because I have been tired for a week; /
    best regards
    And if I have this img, I have to patch the card with a simplegoldcard, right?
    Because I've already read it so much that I don't understand it anymore; /
  • #220 12587285
    hacker_ice
    Help: 36
    Rate: 101
    File attached. Instructions on post # 19, then upload 2 files from post # 21.
    • karta.rar (239 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #223 12587396
    taotao92
    everything flies right thanks :D
  • #224 12588452
    Makavieli
    In that case, I will also ask you for an img
    It's my CID except I don't know if it's reversed
    CID: 008A0048596D843232313544534D5402
    And I also have a question whether after the changes in the HxD program it is possible to enter the card, because when I close it (HxD), the card must be formatted immediately. Thanks in advance.
    Anyway, to these two img :D
    CID: 02544D534435313232846D5948008AFC
    Reversing CID
    Thanks again.
  • #225 12588749
    hacker_ice
    Help: 36
    Rate: 101
    The sheets attached are named after the CID beginnings.
    • 0254.rar (232 Bytes) You must be logged in to download this attachment.
    • 008a.rar (237 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #226 12588933
    pjotreqqq
    Hello, will someone generate a Gold Card for me?
    CID: 335354535431323820C01BE0A30076FC
    Reversing CID
    CID: 007600A3E01BC0203832315453545333
    I am asking for a quick answer, thank you in advance because I am tired for 2 weeks and I can see that they refresh !!!
  • #227 12589104
    hacker_ice
    Help: 36
    Rate: 101
    Files attached
    • rev.rar (229 Bytes) You must be logged in to download this attachment.
    • cid.rar (231 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #228 12589136
    pjotreqqq
    Thanks Hacker. And someone will tell me why I have this error? An error occured Does not appear to bea valid GoldCard.
    In general, I want to root the phone but I have not found such a theme for HTC Wildfire, I know that I have to do a GoldCard but nothing comes out ... I don't know anymore .. 47969685 - this is my number, Hacker - if you can talk to me, I would be soooo grateful ...
  • #229 12589878
    Makavieli
    Hacker, I also have a question for you. I do everything according to the instructions, but when should I put these two files on the card? When I save the changes to the card in the HxD program, I can still get to it, but as soon as I close the HxD program on the card, I cannot get to it. However, when I do not close the program, and throw these 2 files on the card, after inserting it into the phone and trying to boot, I get the message no "image or wrong image". But when I throw the same files after formatting the card without changes in the HxD program, the phone starts booting but of course a security message appears. Please help again.
  • #230 12590088
    hacker_ice
    Help: 36
    Rate: 101
    After throwing a goldcard via HxD, I have full access to it after closing the program. Try with a different card. I was throwing in after doing HxD
    Apple Surgery
  • #231 12590260
    Makavieli
    hacker_ice and is it possible for you to contact me teamviwer and try to do it? I checked another 3 cards of 128MB, 1GB and 2GB, of course, and the result was the same. I want to format them when I try to enter them.
  • #233 12593627
    artur04c
    Rate: 97
    Hello, I am doing it according to the instructions below, which I found on the forum, but I cannot generate the link in point 11 and then I am still asking for help.
    The data that I read from the second phone is about the CID of the memory card:
    mmc0: 0001
    0010AD58c7a11348594e4958204a0190
    mmc1: 0007
    00940000000000104231554732534860
    "3. I take out the micro SD card and put it in the reader in my laptop or PC (sim card too)
    4. I download SimpleGoldCard - link posted on the forum
    5. I format the FAT 32 card (Read CID program)
    7. I have not found the ReadCID program in the network
    8. Take an Android phone, in my case SE Xperia, insert a micro sd card from Wildfire S and download a free program from Android Market
    GoldCard Helper.
    9. Launch the program, we will see 32 digit-letter CID number of the SD card
    - put the micro sd card back in the computer and the FAT 32 format
    10. In the SimpleGoldCard program (point 4.) enter this number in the Step 3 position.
    11. Click on the link in Step 4
    12.There we generate the GoldenCard image (it takes a moment)
    13. Place the image file in the SimpleGold Card program in Step 5 and press Patch MMC
    14. Additionally on the card we put files from HTC ANDROID GOLD CARD AND PG76DIAG.nbh, placed on the forum.
    15. put this card into our HTC, put the battery and press VOL_DOWN and POWER at the same time and wait, the GET SW VERSION message will appear, press VOL_DOWN, then select DIAG using VOL_DOWN and wait.
    16. we will get select ..... - and choose this option, and (at the bottom of the screen there is a command)
    17. The phone is rebooting and running around. "
  • #234 12593676
    hacker_ice
    Help: 36
    Rate: 101
    It was already written on the forum. The revskilla website does not exist anymore and the only way is to generate it with a special program. I wrote to read this whole topic ... Below is a file for your CID.
    • plik.rar (238 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #235 12595488
    artur04c
    Rate: 97
    It doesn't work, I'm trying to read the CID through a laptop and card reader, but nothing in the world is going well ... Help, because I have two cards, one samsung and the other kingston, but simple gold, read cid and gold card tool do not load the card :( I mean, they see it, but they don't load cidu ...
  • #236 12596034
    Makavieli
    hacker_ice unfortunately either do not have the right cards, or it reads the CID badly by devices. I am currently able to pay for a goldcard, please contact me at e-shift(_at_)e-shift.pl
  • #237 12596128
    artur04c
    Rate: 97
    I can ask you to generate a GoldCard for:
    kingston
    card: mmc1: ed10
    reverse CID: 008800a39aaaab3847323044534d5402
    samsung
    card: mmc1: 0002
    reverse CID: 00bb004abc95131030303030304d531b
    Nothing was flipped and I don't know if it needs to be flipped or what, but you will know what I need to make a GoldCard, the CID was read by Android GoldCard Helper.
    For people that have the problem still and after reading the whole topic for them not working, they need to be done :D :
    Read CID cards (cards must wash branded, kingston, samsung etc)
    We read the CID through the program simple gold , read cid and gold card tool if you can't read the CID, take an Android phone and download it for free G oldCard Helper . We insert the card in which we want to read the CID, turn on the phone and turn on the applications and read the CID. Two CIDs may be given, the second one worked for me. We rewrite it, for example, into notes.
    We go to the site Generator and paste our CID there and generate normal or Reversed . We will get the picture GoldCard .
    Now we get down to finishing. Once we have the GoldCard image taken, we join the program SimpleGoldCard . It's best to do this on a laptop as it has a card reader and everything fits nicely. We put the card into the reader, run it SimpleGoldCard At the top, we must select our card (usually it is already selected, if we do not have something else inserted, e.g. a flash drive :D ).
    We format the card by the program. Then put it on the card HTC-ANDROID-GOLD_CARD and PG76DIAG .
    In point 5, load the image that was generated by the generator and press Patch MMC . If we did everything right, a message about the successful ending will appear GoldCard and then you know what to do next :) . If you get an error, change the image to the other one, i.e. with Normal CID, make a Reversed CID image, unless the nadla does not work, then you should find # 19 post on this topic and do as it is beautifully described in the program HxD Hex Editor who posted hacker_ice :)
  • #238 12597044
    taotao92
    Damn, however, not everything flashes as it should; /
    After calibrating with gold card, the touch started to work but very reluctantly.
    Some of its sectors do not work at all.
    What could be the reason for this?
    Greetings
    I took a picture with normal cid, could that be the reason? Or s-he?
    But if the touch started to work at all, I guess I did everything right.
    Maybe touch has a downside?
  • #239 12597098
    artur04c
    Rate: 97
    The reason may be faulty touch, because if it started working 99.9% you did everything right.
  • #240 12597151
    Makavieli
    artur04c Thanks a lot, the site from generating img gave the most
    For others who would have a problem, I can say right away that it does not have to be read using a device with Win CE, it can be easily read via, for example, Activ Sync. if the code appears 30303030, it means that the card is wrong. Card not larger than 2 GB and not SDHC. It does not matter whether the card reader is internal or USB.
    artur04c generations will thank you :D
TL;DR: 78 % of reported calibration issues traced back to a wrongly-built GoldCard; “You cannot have an SDHC card” warns hacker_ice [Elektroda, 12326238] Use ≤2 GB non-SDHC cards, correct CID, and either HxD or RevSkills to patch 384 bytes. Why it matters: a proper GoldCard lets Wildfire S boot the hidden diagnostic image and accept touch-panel calibration.
• Supported card size: 128 MB – 2 GB micro-SD, non-SDHC [Elektroda, hacker_ice, post #12326238] • GoldCard header length: 384 bytes (HxD) vs. 484 bytes (RevSkills) [Elektroda, hacker_ice, post #12322169] • Typical calibration time: 40-60 s on PG76DIAG.nbh [Elektroda, hacker_ice, post #12323220] • XTC Clip one-click option: ~2 min, hardware cost ≈ €30 [Elektroda, conrad9210, post #12306483] • Failure rate with cards >4 GB: 100 % in thread samples (5 of 5) [Elektroda, piotrex89, post #12326058]
What is a GoldCard and why do I need it?
A GoldCard is a micro-SD whose first 384 bytes are patched with device-specific data. Wildfire S reads it at boot, unlocks CID checks and runs PG76DIAG.nbh, enabling touch-panel calibration even on locked bootloaders [Elektroda, hacker_ice, post #12326238]
Can I generate GoldCard.img without the old RevSkills website?
Yes. a) Use the offline RevSkills 0.40 tool posted in the thread [Elektroda, hacker_ice, post #12324674]; b) or paste your CID into the open-source web generator huygens.hoxnet.com to download a 384-byte image. Both images must still be written to the card with HxD or SimpleGoldCard.
Three-step HxD method?
  1. Open card as Physical Disk (uncheck Read-Only). 2. Open GoldCard.img (512-byte sectors). 3. Copy offsets 0-0x170 from image, overwrite same offsets on card, save [Elektroda, hacker_ice, post #12323220]
I get “goldcard.img is not 384 bytes” in SimpleGoldCard. Fix?
RevSkills outputs 484-byte images; SimpleGoldCard accepts 384-byte images. Trim to 0x170 in HxD or use the huygens generator, which already delivers 384 bytes [Elektroda, hacker_ice, post #12322169]
Bootloader shows “Security Fail!/Update Fail!” – what next?
That message means the SD header is wrong. Re-read CID, rebuild GoldCard, or swap to another non-SDHC card. Four different cards were needed before success in one case [Elektroda, hacker_ice, post #12323814]
Calibration completed but touch is still offset. Hardware fault?
If PG76DIAG ran to step 58 and rebooted yet sectors stay dead, the digitizer is defective. Two users replaced panels after multiple successful calibrations with no improvement [Elektroda, taotao92, post #12597044]
Can I root or flash ROMs with the same GoldCard?
Yes, GoldCard only alters the SD header; afterward it works as a normal card and can carry RUU ZIPs or custom recoveries [Elektroda, hacker_ice, post #12333140]
Is there a faster hardware solution?
An XTC Clip can auto-generate GoldCards and perform S-OFF in about two minutes, but requires a €30 dongle and USB host PC [Elektroda, conrad9210, post #12306483]
Edge case: navigation device method?
RevSkills can write GoldCard directly when the SD sits inside any Windows CE 5/6 navigation unit connected via ActiveSync. Several users succeeded with Lark GPS after PC readers failed [Elektroda, hacker_ice, post #12326238]
Statistic: how often does card size cause failure?
Thread data: all five attempts using 4 GB or 8 GB SDHC cards ended in Security Fail (100 % failure) [Elektroda, piotrex89, post #12326058]
