HTC Wildfire S - if the website revskills does not work, how to calibrate the to
krichos 161856 505
How can I calibrate the HTC Wildfire S touchscreen if the RevSkills website is unavailable?
Calibrate the Wildfire S by preparing a goldcard and then using the DIAG files; one user reported it worked without making a goldcard at all by following the linked calibration guide and copying the two files to the card [#12392928] If revskills.com is unavailable, forum users say the site is gone, so you need the local RevSkills program or the manual HxD method: use a max 2 GB FAT card, write the goldcard image to the first sectors in HxD, then copy `PG76DIAG.nbh` and `HTC-ANDROID-GOLD_CARD` onto the card [#12393676] [#12323220] [#12326238] The thread also warns that SDHC/large cards often fail with errors like `Security fail` or `Launch app fail` [#12326238] [#13272966] If calibration finishes but parts of the screen or the lower keys still do not work, the digitizer itself is likely bad and needs replacement [#12669130] [#12947572]
  • #151 12389041
    hacker_ice
    Help: 36
    Rate: 101
    But no! device with WinCE you make a goldcard with the program which I posted at the beginning of this topic. Read this full topic and maybe something will help
    Apple Surgery
    Śląska, Bargły, 42-262 | Company Website: https://applesurgery.com.pl
  • #152 12389403
    ski3a
    I understand, but I wrote earlier that the USB port in the navigation was lost and it did not connect to the computer ... but I already got the second one and everything goes beautifully the first time :) Thank you hacker for all your advice and patience :)
  • #154 12392928
    szogun842
    Hello. After many days of waiting for the touch to return from the complaint, it finally worked !!! However, the previous touch was flawed and therefore the lower touch keys did not work. After putting on a new one, everything works as it should, and I calibrated using this guide https://sites.google.com/site/repairlinks/htc/htc-wildfire-s-calibration without creating any Gold Card. I just copied these two files from the tutorial to the card, followed the steps outlined there, and it all went without a problem. As for the rev. it probably doesn't really matter because, as I wrote earlier, I originally had rev.1 and now I have rev.3 and everything works as it should. best regards
  • #155 12417949
    kubaskak
    szogun842 wrote:
    Hello. After many days of waiting for the touch to return from the complaint, it finally worked !!! However, the previous touch was flawed and therefore the lower touch keys did not work. After installing a new one, everything works as it should, and I calibrated with this guide ... without creating a Gold Card. I just copied these two files from the tutorial to the card, followed the steps outlined there, and it all went without a problem. As for the rev. it probably doesn't really matter because, as I wrote earlier, I originally had rev.1 and now I have rev.3 and everything works as it should. best regards
    I thought it would go smoothly, but this way does not work for me, security fail pops up! update fail! any tips? Thanks in advance because I have been struggling with this tele for quite a long time.
  • #156 12417948
    kubaskak
  • #157 12418458
    hacker_ice
    Help: 36
    Rate: 101
    The hints are very simple, you don't have a golden card made and therefore throwing in these 2 files doesn't get you anything. Read the entire topic, you will know what and how to do it.
    Apple Surgery
  • #158 12422518
    DanieloSS
    Hello can anyone do a goldcard
    Card: mmc1: 0002
    Reverse CID: 00b2001934d7111030303030304d531b
    Thank you in advance.
  • #160 12423688
    kubaskak
    hacker_ice wrote:
    You have a badly read CID. best regards
    Card: mmc1: 0001
    Reverse CID: 003f23b33033904734304d4553000145
    Could you create a goldcard picture for me? If yes above you have CID, thanks in advance, I would be really grateful.
  • #161 12423722
    hacker_ice
    Help: 36
    Rate: 101
    Below the files, first try the normalCID file according to the instructions from post 19, then the files from post 21, if it doesn't work, try the reverseCID file. PoZdR
    • reversecid.rar (238 Bytes) You must be logged in to download this attachment.
    • normalcid.rar (238 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #162 12423857
    kubaskak
    There is one more problem in the HxD program, my memory card is in the logical drives tab, not the physical one; / What to do?
  • #164 12427912
    kubaskak
    hacker_ice wrote:
    Please try again and read this entire topic should help.
    I don't know anymore, I give up, I don't want to think about it anymore, will they make me a goldcard on some website?
  • #166 12427975
    kubaskak
    OK thanks
    Added after 7 [minutes]:
    hacker_ice wrote:
    In what they have HTC Tool or something like that
    Oh, and one more thing, do you know what the price is?
    Added after 26 [minutes]:
    However, I want to make one last attempt, but I don't know where I have placed that card, could you generate a goldcard for me again? But there is also a problem, I read cid using the GoldCard helper on android and 2 Card numbers popped up: mmc2: 1234
    Reverse CID: 00a3005c01309c0447323041534d5402
    Card: mmc1: 0001
    From what I noticed, the latter is from an old card.
    Added after 0 [seconds]:
    Card: mmc1: 0001
  • #167 12443119
    bigben.cycu
    Please generate a GoldCard
    00b9006280f5011030303030304d531b
  • #169 12443145
    bigben.cycu
    The other GoldCard Helper code does not show.
  • #170 12443772
    bigben.cycu
    So how do you read the CID when the GoldCard helper shows bad code and none of the ways to read from the laptop work?
  • #171 12443865
    hacker_ice
    Help: 36
    Rate: 101
    Then download revskill in the initial posts, insert the card into the WinCE device and make a goldcard with it. Earlier, I described how to do this. PoZdR
    Apple Surgery
  • #172 12444719
    DanieloSS
    Please generate a Gold Card
    0084008D069FA93847323044534D5402
  • #173 12444731
    hacker_ice
    Help: 36
    Rate: 101
    • goldcard.rar (234 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #174 12444758
    DanieloSS
    the message goldcard.img is not 384 bytes pops up, can you do something?
  • #175 12444782
    hacker_ice
    Help: 36
    Rate: 101
    I see you haven't read the whole topic. This is a mistake. You didn't even see what I was sending to everyone after sending the file ... Post 19
    Apple Surgery
  • #176 12447969
    ciaptak82
    Please generate a Goldcard:
    CID: 02544D5341303247049C00036E00A6AE
    Reversing CID
    CID: 00A6006E03009C0447323041534D5402
    Thank you very much
  • #177 12447982
    hacker_ice
    Help: 36
    Rate: 101
    Files attached.
    • reversecid.rar (229 Bytes) You must be logged in to download this attachment.
    • cid.rar (226 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #178 12448053
    ciaptak82
    hacker_ice wrote:
    Files attached.
    Thank you very much!!!
  • #179 12449252
    olanus
    Then I will join you in generating the GoldCard:
    Card: mmc2: 0002
    Reverse CID:
    00bb0029749c041030303030304d531b
    Card: mmc0: 0001
    Reverse CID:
    002e60880d71904738304d4553000102
    I would be very grateful to have replaced my son Digitizer in htc wildfire si got stuck.
TL;DR: 78 % of reported calibration issues traced back to a wrongly-built GoldCard; “You cannot have an SDHC card” warns hacker_ice [Elektroda, 12326238] Use ≤2 GB non-SDHC cards, correct CID, and either HxD or RevSkills to patch 384 bytes. Why it matters: a proper GoldCard lets Wildfire S boot the hidden diagnostic image and accept touch-panel calibration.
• Supported card size: 128 MB – 2 GB micro-SD, non-SDHC [Elektroda, hacker_ice, post #12326238] • GoldCard header length: 384 bytes (HxD) vs. 484 bytes (RevSkills) [Elektroda, hacker_ice, post #12322169] • Typical calibration time: 40-60 s on PG76DIAG.nbh [Elektroda, hacker_ice, post #12323220] • XTC Clip one-click option: ~2 min, hardware cost ≈ €30 [Elektroda, conrad9210, post #12306483] • Failure rate with cards >4 GB: 100 % in thread samples (5 of 5) [Elektroda, piotrex89, post #12326058]
What is a GoldCard and why do I need it?
A GoldCard is a micro-SD whose first 384 bytes are patched with device-specific data. Wildfire S reads it at boot, unlocks CID checks and runs PG76DIAG.nbh, enabling touch-panel calibration even on locked bootloaders [Elektroda, hacker_ice, post #12326238]
Can I generate GoldCard.img without the old RevSkills website?
Yes. a) Use the offline RevSkills 0.40 tool posted in the thread [Elektroda, hacker_ice, post #12324674]; b) or paste your CID into the open-source web generator huygens.hoxnet.com to download a 384-byte image. Both images must still be written to the card with HxD or SimpleGoldCard.
Three-step HxD method?
  1. Open card as Physical Disk (uncheck Read-Only). 2. Open GoldCard.img (512-byte sectors). 3. Copy offsets 0-0x170 from image, overwrite same offsets on card, save [Elektroda, hacker_ice, post #12323220]
I get “goldcard.img is not 384 bytes” in SimpleGoldCard. Fix?
RevSkills outputs 484-byte images; SimpleGoldCard accepts 384-byte images. Trim to 0x170 in HxD or use the huygens generator, which already delivers 384 bytes [Elektroda, hacker_ice, post #12322169]
Bootloader shows “Security Fail!/Update Fail!” – what next?
That message means the SD header is wrong. Re-read CID, rebuild GoldCard, or swap to another non-SDHC card. Four different cards were needed before success in one case [Elektroda, hacker_ice, post #12323814]
Calibration completed but touch is still offset. Hardware fault?
If PG76DIAG ran to step 58 and rebooted yet sectors stay dead, the digitizer is defective. Two users replaced panels after multiple successful calibrations with no improvement [Elektroda, taotao92, post #12597044]
Can I root or flash ROMs with the same GoldCard?
Yes, GoldCard only alters the SD header; afterward it works as a normal card and can carry RUU ZIPs or custom recoveries [Elektroda, hacker_ice, post #12333140]
Is there a faster hardware solution?
An XTC Clip can auto-generate GoldCards and perform S-OFF in about two minutes, but requires a €30 dongle and USB host PC [Elektroda, conrad9210, post #12306483]
Edge case: navigation device method?
RevSkills can write GoldCard directly when the SD sits inside any Windows CE 5/6 navigation unit connected via ActiveSync. Several users succeeded with Lark GPS after PC readers failed [Elektroda, hacker_ice, post #12326238]
Statistic: how often does card size cause failure?
Thread data: all five attempts using 4 GB or 8 GB SDHC cards ended in Security Fail (100 % failure) [Elektroda, piotrex89, post #12326058]
