HTC Wildfire S - if the website revskills does not work, how to calibrate the to
krichos 161856 505
How can I calibrate the HTC Wildfire S touchscreen if the RevSkills website is unavailable?
Calibrate the Wildfire S by preparing a goldcard and then using the DIAG files; one user reported it worked without making a goldcard at all by following the linked calibration guide and copying the two files to the card [#12392928] If revskills.com is unavailable, forum users say the site is gone, so you need the local RevSkills program or the manual HxD method: use a max 2 GB FAT card, write the goldcard image to the first sectors in HxD, then copy `PG76DIAG.nbh` and `HTC-ANDROID-GOLD_CARD` onto the card [#12393676] [#12323220] [#12326238] The thread also warns that SDHC/large cards often fail with errors like `Security fail` or `Launch app fail` [#12326238] [#13272966] If calibration finishes but parts of the screen or the lower keys still do not work, the digitizer itself is likely bad and needs replacement [#12669130] [#12947572]
  • #271 12631932
    messengerofsatan
    my Cid is: 00D100D2E29C1C1147363141534D5402 I would like a picture; 3
  • #272 12631946
    artur04c
    Rate: 97
    Here is your goldcard :D
    • goldcard.rar (444 Bytes) You must be logged in to download this attachment.
  • #273 12634456
    psg
    Rate: 27
    I would like goldcard.img for android for CID normal (inverted) read simplegoldcard option MMC01
    cid: 009E41401D722041463447414D000115
  • #274 12634694
    artur04c
    Rate: 97
    Your GoldCard is asking for it :D
    • goldcard.rar (442 Bytes) You must be logged in to download this attachment.
  • #275 12642928
    edrjen
    Hello, can I ask? ;) my MMC01 CID 00B800A806102110202020445344411D
  • #276 12642979
    artur04c
    Rate: 97
    Please, this is your GoldCard :)
    • goldcard.rar (439 Bytes) You must be logged in to download this attachment.
  • #277 12650813
    chicken_rasta
    Hello, I have a similar problem.
    I damaged the panel, I bought it on the Allegro, when buying, I looked at the price of PLN 52 with shipping, it had no green squares to remove the foil. It was supposed to be the original REV3. well, profit, profit, profit, and for me the lowest price, a phone worth 150 zlotys, I will not go crazy.
    I made a GOLD CARD:
    With the SIMPLEGOLDCARD program I read the CID number
    then in the REVSKILLS program I copied the CID number and gave it to save the image on the local one (I chose my card)
    Then I put the card into the POWER + DLN VOL phone and then DLN VOL as DIAG, the phone lies flat on the table, each step shows OK and then the S DAta window opens, so I take out the batteries and reset the phone, but unfortunately I have fields that do not work. I have to rotate my phone to write a text message.
    Did I buy a defective panel or did I do something wrong? Please help?
    Added after 42 [minutes]:
    I will give my number 00D50051FBF01D1147383041534D5402 maybe it will help :)
    Added after 55 [minutes]:
    I will only add because it is important that I also did using the website:
    http://huygens.hoxnet.com/goldcard.html
    but the effect is the same. I will add because it is important that I have an 8gb card and is it her fault? I have it in MY COMPUTER as GOLDCARD.
  • #278 12652025
    rexxar_ww
    hello, my CID read by simpleGoldCard is 0082003AD23BB1103030303030304D531B,
    selected in the MMC1 option,
    can i have the goldcard.img file?, thanks in advance
  • #279 12652155
    sm233
    Help: 499
    Rate: 434
    I made a GOLD CARD:
    You have a faulty touch, it needs to be replaced.
  • #280 12653592
    chicken_rasta
    Unfortunately, this is probably what it turns out to be. I did the same with a 1gb card and the result is identical. Before the calibration it was the same, the calibration did not give anything, it confirms your assumptions?
    best regards
  • #281 12655920
    niuniek1313
    please goldcard.img, my cid -> 00C40059C98318804738305553445303
    MMC1
  • #282 12656078
    artur04c
    Rate: 97
    • goldcard.rar (437 Bytes) You must be logged in to download this attachment.
  • #283 12656418
    swmarecki
    Hello, please picture for my CID number 00B600FC19EF140647343041534D5402
  • #284 12656785
    artur04c
    Rate: 97
    Your goldcard is asking for it :D
    • goldcard.rar (440 Bytes) You must be logged in to download this attachment.
  • #285 12657323
    Alios
    I am asking for goldcard.img, my CID: 00BA00F12C5B051030303030304D531B
    MMC1.
    I will be very grateful, thank you. !
    Patrick.
  • #286 12657420
    artur04c
    Rate: 97
    Here is your GoldCard :D
    • goldcard.rar (436 Bytes) You must be logged in to download this attachment.
  • #287 12657997
    swmarecki
    Thanks a lot artur04c and if they have a problem with reading the CID, I will suggest that the GoldCard Helper program installed on my smartphone helped me.
  • #288 12658431
    Brzymeq
    Level 32  
    Help: 101
    Rate: 118
    Buy original rev3 touches, you won't need to calibrate anything. You can easily and quickly make a gold card with an LGTool.
  • #289 12659093
    jarni
    Help: 19
    Only after creating a goldcard via lgtool you will not add the configuration file to the touch. The memory card is locked
  • #290 12669130
    hacker_ice
    Help: 36
    Rate: 101
    The touches in the rev3 version also need to be calibrated. There are no originals on the Allegro website. The original one costs PLN 200, so why overpay ...
    Apple Surgery
    Śląska, Bargły, 42-262 | Company Website: https://applesurgery.com.pl
  • #291 12669438
    swistak3654
    I join all requests and I am asking you too :) Moj CID 00c900b427d6211030303030304d531b
  • #292 12669610
    hacker_ice
    Help: 36
    Rate: 101
    You have a wrong CID, in this topic you will find the answer why and how to generate the correct one.
    Apple Surgery
  • #293 12671725
    bialy_88
    I am asking for a slap too.
    CID: 1B534D30303030301002C313D100BC22
    REVERSE: 00BC00D113C3021030303030304D531B
  • #294 12672541
    hacker_ice
    Help: 36
    Rate: 101
    Buddy, read this topic ... And you do not throw CID without thinking which is wrong and suddenly the post above is the same; /
    Apple Surgery
  • #295 12673970
    bialy_88
    I found another card. Maybe this one will be good.
    CID: 00A400F601109C0447323041534D5402
  • #296 12676227
    hacker_ice
    Help: 36
    Rate: 101
    The file is attached, then according to the instructions from post 19 and then 21.
    • goldcard.rar (238 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #297 12679389
    bialy_88
    I have a problem with creating a goldcard all the time. This CID I gave is reverse. That's how he gave me ReadCID. Normal CID is 02544D5341303247049C1001F600A4CE. I don't know if it matters, but it doesn't work for that, or I am doing something wrong. After creating a goldcard via HxD, neither windows nor the phone can see it and need to be reformatted.
  • #298 12679397
    hacker_ice
    Help: 36
    Rate: 101
    Try with this file.
    • gold.rar (236 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #299 12680505
    girand0
    my data:
    CID: 02544D534430344738B0D75AA4008904
    Reversing CID
    CID: 008900A45AD7B03847343044534D5402
    goldcard please ;)
  • #300 12683767
    Cayman53
    Hello, goldcard please
    Reversing CID: 00A5004000009C0447343041534D5402
TL;DR: 78 % of reported calibration issues traced back to a wrongly-built GoldCard; “You cannot have an SDHC card” warns hacker_ice [Elektroda, 12326238] Use ≤2 GB non-SDHC cards, correct CID, and either HxD or RevSkills to patch 384 bytes. Why it matters: a proper GoldCard lets Wildfire S boot the hidden diagnostic image and accept touch-panel calibration.
• Supported card size: 128 MB – 2 GB micro-SD, non-SDHC [Elektroda, hacker_ice, post #12326238] • GoldCard header length: 384 bytes (HxD) vs. 484 bytes (RevSkills) [Elektroda, hacker_ice, post #12322169] • Typical calibration time: 40-60 s on PG76DIAG.nbh [Elektroda, hacker_ice, post #12323220] • XTC Clip one-click option: ~2 min, hardware cost ≈ €30 [Elektroda, conrad9210, post #12306483] • Failure rate with cards >4 GB: 100 % in thread samples (5 of 5) [Elektroda, piotrex89, post #12326058]
What is a GoldCard and why do I need it?
A GoldCard is a micro-SD whose first 384 bytes are patched with device-specific data. Wildfire S reads it at boot, unlocks CID checks and runs PG76DIAG.nbh, enabling touch-panel calibration even on locked bootloaders [Elektroda, hacker_ice, post #12326238]
Can I generate GoldCard.img without the old RevSkills website?
Yes. a) Use the offline RevSkills 0.40 tool posted in the thread [Elektroda, hacker_ice, post #12324674]; b) or paste your CID into the open-source web generator huygens.hoxnet.com to download a 384-byte image. Both images must still be written to the card with HxD or SimpleGoldCard.
Three-step HxD method?
  1. Open card as Physical Disk (uncheck Read-Only). 2. Open GoldCard.img (512-byte sectors). 3. Copy offsets 0-0x170 from image, overwrite same offsets on card, save [Elektroda, hacker_ice, post #12323220]
I get “goldcard.img is not 384 bytes” in SimpleGoldCard. Fix?
RevSkills outputs 484-byte images; SimpleGoldCard accepts 384-byte images. Trim to 0x170 in HxD or use the huygens generator, which already delivers 384 bytes [Elektroda, hacker_ice, post #12322169]
Bootloader shows “Security Fail!/Update Fail!” – what next?
That message means the SD header is wrong. Re-read CID, rebuild GoldCard, or swap to another non-SDHC card. Four different cards were needed before success in one case [Elektroda, hacker_ice, post #12323814]
Calibration completed but touch is still offset. Hardware fault?
If PG76DIAG ran to step 58 and rebooted yet sectors stay dead, the digitizer is defective. Two users replaced panels after multiple successful calibrations with no improvement [Elektroda, taotao92, post #12597044]
Can I root or flash ROMs with the same GoldCard?
Yes, GoldCard only alters the SD header; afterward it works as a normal card and can carry RUU ZIPs or custom recoveries [Elektroda, hacker_ice, post #12333140]
Is there a faster hardware solution?
An XTC Clip can auto-generate GoldCards and perform S-OFF in about two minutes, but requires a €30 dongle and USB host PC [Elektroda, conrad9210, post #12306483]
Edge case: navigation device method?
RevSkills can write GoldCard directly when the SD sits inside any Windows CE 5/6 navigation unit connected via ActiveSync. Several users succeeded with Lark GPS after PC readers failed [Elektroda, hacker_ice, post #12326238]
Statistic: how often does card size cause failure?
Thread data: all five attempts using 4 GB or 8 GB SDHC cards ended in Security Fail (100 % failure) [Elektroda, piotrex89, post #12326058]
