Chronocomparator - vibroscope for setting the gait of mechanical watches
tsmki 17151 19
  • Chronocomparator is a pocket vibroscope for setting the gait of mechanical clocks and watches, letting you check them face down, face up, or on the side.
  • It senses ticking with a piezoelectric transducer, amplifies and shapes the pulses with LM324, and shows phase-shift graphs on an 84x48 Nokia 5210 LCD.
  • A PIC16F84A with a 7.3728 MHz quartz resonator runs the Great Cow Basic firmware, which times T0 interrupts at 1/40 of the selected tick period.
  • The display supports 1 b/s through 10 b/s tick rates, with 10-, 60-, and 360-minute full-screen modes plus a direct mode where each tick is shown.
  • It targets hobbyists rather than professional use, and the author estimates subassemblies at several to several dozen zlotys.
  • Chronocomparator - vibroscope for setting the gait of mechanical watches
    Chronocomparator - vibroscope.
    It is a device that helps to set the correct gait of clocks and mechanical watches.
    It allows you to check whether the watch is working correctly both in the face down, up or on the side.
    Is the gait stability maintained over a longer period of time, e.g. several hours after application?
    In the case of large clocks, the analysis of the graph of uneven gait - periodic acceleration and deceleration, allows you to locate the troubling racks.
    The project does not aspire to compete with professional (and very expensive) devices.
    It is intended for hobbyists - collectors of watches. It is a pocket, portable version of the device - the Biburo program, which requires the use of a computer to work.
    The chronocomparator works by sensing the ticking of a watch (its mechanical vibrations) with a piezoelectric transducer.
    The pulses from this transducer, after appropriate amplification and shaping, are compared with the reference reference pulses.
    The change in phase shift between these pulses is visualized graphically on the LCD display.
    The project uses a monochrome display with a resolution of 84x48 pixels from Nokia 5210.
    The chrono-comparator is adapted to clocks with the number of ticks per second:
    1 b / s, 1i1 / 2 b / s, 3i1 / 3 b / s, 4i1 / 2 b / s, 5 b / s, 5i1 / 2 b / s, 6 b / s, 8 b / s, 10 b / s.
    It takes 10 minutes, 60 minutes and 360 minutes to fill the screen. There is also the direct range where each tick is directly represented on the screen.
    When the screen is full, the graph is redrawn from the left side of the screen.
    Parameter changes are made using two buttons.
    The "heart" of the device is the popular PIC16F84A processor, working with an external 7.3728 MHz quartz resonator.
    Since it is a time standard for the tested watches, its frequency should be carefully set by selecting capacitors with a capacity of about 30 pF working with it.
    The processor was mounted without a socket, so the ICSP connector for programming the processor was also installed.
    The software was written in the GCB (Great Cow Basic) environment.
    Particular emphasis was placed on the proper handling of interrupts from the internal timer T0, and especially on determining the correct moment of loading the T0 register.
    The interrupt period is 1/40 of the clock tick period of the set range.
    During this time, the processor checks for a tick and possibly lights the current pixel in the current column.
    The graphical chart is 80 columns long, with 40 pixels per column.
    The processor and the LCD display are supplied with the voltage of 3.3V.
    To amplify the signals from the piezoelectric transducer I used the LM324 system, i.e. a quad operational amplifier.
    Three of them are a high gain band shaping amplifier, while the fourth is a monostable pulse generator.
    The amplifier is powered by a single positive voltage of 5V.
    The old remote control with its battery basket was used as the case of the chronocomparator.
    The power supply is provided by two AA cells or two NiMH batteries, providing a voltage of about 2.4 V to 3V.
    This voltage is raised to 5V using the MAX1674 converter.
    In turn, the voltage of 3.3V for the processor and the display comes from the LM1117 stabilizer.
    Converterpiezoelectric was placed on top of the chronocomparator case - glued over the round hole.
    The chronocomparator is also equipped with an input socket for connecting an external transducer.
    The socket is also supplied with 5V voltage, which enables powering an additional external amplifier.
    The external sensor is more convenient to use when examining large clocks, small watches can be placed on top of the sensor on the housing.
    It is best when the crown of the watch touches the sensor.
    The diagram of the device has been created so far only in pencil for my own needs, a decent diagram requires a lot of work, and I do not know if the presented topic will generate interest.
    Chronocomparator - vibroscope for setting the gait of mechanical watches Chronocomparator - vibroscope for setting the gait of mechanical watches Chronocomparator - vibroscope for setting the gait of mechanical watches
    As you can see in the photos attached, the device was made on a universal PCB, using mainly SMD components, and Kynar connections.
    I estimate the cost of subassemblies at several to several dozen zlotys, depending on what the contractor uses from his own stocks or recovers from old systems.
    tsmki
    tsmki wrote 29 posts with rating 99. Live in city Warszawa. Been with us since 2008 year.
  • #2 16479247
    TechEkspert
    Editor
    Help: 17
    Rate: 5691
    A completely new topic for me, I think that even a pencil diagram will be useful,
    it is worth putting a video presenting the operation of the device, and maybe a timelapse because from what I can see the measurements take a while.
  • #3 16479418
    pawel1029384756
    Help: 33
    Rate: 277
    An interesting and practical project. I would love to see a schematic of the amplifier circuit. I am planning a project where I will use a piezoelectric transducer, so I am interested in various solutions.
  • #4 16479594
    tsmki
    Rate: 99
    Sorry to be quite messy, but I am enclosing a "pencil" scan.
    Additionally, I attach the hex file to the processor - change the extension to hex.
    Display notes:
    The Nokia5210 display is almost compatible with the very popular Nokia 3310 display, it differs in the display direction.
    Minor code changes are enough.
    Unfortunately I don't have an N3310 display to test and correct the code.
    • schemat.pdf (161.38 KB) You must be logged in to download this attachment.
    • c7hex.txt (5.58 KB) You must be logged in to download this attachment.
  • #5 16479992
    marnowak
    I remember that someone here once commissioned such a device.
  • #6 16480052
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    A very nice device, but .... If I were a colleague, I would add a computer output (via USB or Audio) for data archiving. In addition, I would make an analyzer of the entire acoustic spectrum generated by the watch mechanism. (curve anchor, worn teeth on the escapement wheel, rubbing the second hand axis in the sleeve of the minute hand, etc.)
  • #7 16480791
    tsmki
    Rate: 99
    Buddy, Krzysztof.
    It was supposed to be a small, pocket-sized device that would work independently.
    A colleague proposes to make the entire combine, preferably connected to a data dump computer.
    This is a completely different device.
    Perhaps more suitable for this would be the Biburo program I mentioned with the appropriate side dish.
  • #8 16480908
    hobbyelektronik
    Help: 85
    Rate: 178
    For the record: Chronocomparator for checking the movement of watches - "Radioelektronik" 3/91.
  • #10 16482141
    lukaszd82
    Help: 143
    Rate: 491
    Cool design. If you refined it, put the batch in an editable version (with the possibility of changing it to some ATMEGA), there would certainly be a few people who would like to make such a device for themselves.
    I myself suffer more and more from a good mechanical watch and when I saw this topic, I thought that it would be worth doing something like this.
    Best regards.
  • #11 16483187
    AC
    The project is quite complete, but I have a question whether a pattern could be used for the Prock timing, I mean the DS32 kHz chip, because the quartz chrono seems to me not very accurate.
    Maybe I don't know something, but in this case the pattern with quartz is important.
  • #12 16483252
    hobbyelektronik
    Help: 85
    Rate: 178
    For watches with mechanical escapement, this is quite sufficient,
    nothing prevents you from using the rubidium standard.
  • #13 16484311
    tsmki
    Rate: 99
    In my opinion, in a pocket device for checking the gait of mechanical watches, for which a daily accuracy of + -10 seconds is an achievement, the standard with a quartz resonator is perfectly sufficient. As I described in the initial post, you should choose the capacitance of the capacitors at the resonator. At the B0 port output, a signal with a period equal to 1/20 of the set measuring range is generated. For example, in the 1 bps range, the period of this signal is exactly 50 ms. This will allow you to set the frequency of the quartz generator exactly - precisely enough that the daily error of the clock being set would be less than 0.1 seconds.
    It seems to me to be quite sufficient for this class of instrument. Of course, the device can be equipped with rubidium generators, with thermal stabilization, or with the use of a clock taken from DCF77 or from GPS, but why?
    The DS32kHz chip is very nice, but it only generates a signal with a frequency of 32.768 kHz, while in my case the resonator frequency is selected so that the processor clock in combination with the T0 timer prescaler allows you to generate interrupts with a period of 1/40 of a given measuring range.
  • #14 16485443
    satanistik
    Help: 61
    Rate: 762
    Maybe a "lame" question, but after the title I was expecting a frequency meter and here some lines on the LCD ;-) .
    Maybe a colleague will suggest how such indications are interpreted? Maybe some examples of observed anomalies?
  • #15 16486049
    evan venn
    Great design.
    I am one of the creators of Great Cow BASIC.
    Can you publish the source code for others to learn?
    And on the question of porting to ATMEGA (Arduino I suppose) it's relatively straightforward for the source code - just change the microcontroller and adjust the source code).
    Anobium.
    This has been translated using Google Translate.
  • #16 16486335
    lukaszd82
    Help: 143
    Rate: 491
    That's right, porting to Atmega is easy with the source code. For now, however, only the code in a compiled form for a specific layout is available.
  • #17 16486468
    evan venn
    Excuse me. I thought you made a program in Great Cow BASIC, therefore I thought you had the source code.
    My mistake. Excuse me.
    ******************* english
    So sorry. I thought you created the program in Great Cow BASIC, therefore, I thought you had the source code.
    My error. Sorry.
  • #18 16491060
    tsmki
    Rate: 99
    I present the source code of the chronocomparator program.
    It is written in GreatCowBasic.
    Those willing to transfer the program from the PIC16F84A processor to another processor, such as an Atmega, can of course do it, but not so simple.
    It is not enough to change the processor declaration. When writing, I had to take into account the specificity of the processor related to the processor clock, T0 timer prescaler and the T0 timer loading time after accepting an interrupt, which is related to resetting the prescaler.
    To get precise interrupt periods, I had to implement two things:
    First of all, it is necessary to ensure that the processor executes the one-step instructions while accepting the interrupt.
    To do this, I check in the main loop to see if the counter T0 has reached 255. Then I wait some time in the loop and then execute a series of NOP instructions, during which it is interrupted.
    Secondly, loading the counter T0 in the interrupt should take place at such a moment that the prescaler state changes continuously.
    To this end, after accepting an interrupt, I wait 256 clock ticks, following other orders. Only after 256 measures do I load T0 with a value 1 smaller, thus taking into account one full prescaler cycle.
    Using a different processor, you can skip the program sections described above.
    Since the program was barely in the CPU memory after compiling, I had to take some "sparing" steps.
    For example, procedures that were executed once were included in the main program instead of calling them.
    I did not define the T0 interrupt with the "On Interrupt Timer0Overflow Call pixel" command, but with the "sub interrupt 'pixel" command.
    This allowed to save several dozen bytes.
    Of course, with newer processors with more memory, there will be no such problems.
    Kolego Satanistik - a chronocomparator is a kind of comparative frequency counter. The frequency is not measured, but the frequency difference and even the instantaneous phase deviation of each clock tick are shown graphically. I invite you to read page 10 and 11 of the posted file Training_EN.
    • Training_EN.pdf (1.03 MB) You must be logged in to download this attachment.
    • c7gcb.txt (14.03 KB) You must be logged in to download this attachment.
  • #19 16499474
    Tremolo
    Help: 1016
    Rate: 497
    Pytanko - does the device show the type of error? Let's say abnormal tick, double tick. It would be nice, but probably hard to make an angle analyzer on the clock hand, here I suspect some script for image analysis. As for data archiving, you can even use the above-mentioned cell and a photo from such a chrono-comparator.
  • #20 16529432
    tsmki
    Rate: 99
    The described chronocomparator is a fairly simple device, it only shows the irregularity of gait and helps to set the correct gait of the clock.
    I also made a more elaborate one with an oscilloscope function, also with separate waveforms for even and odd ticks.
    I do not think that the analysis of the operation of the watch mechanism on the basis of the observation (and analysis) of the movement of the pointer brings more information than the analysis of the sounds made by the mechanism and recorded with a piezoelectric microphone.
    Such analysis can be performed by computer programs, e.g. the already mentioned Biburo.
The discussion revolves around the Chronocomparator, a vibroscope designed for hobbyists to set the gait of mechanical watches. It utilizes a piezoelectric transducer to detect mechanical vibrations, allowing users to assess the watch's performance in various positions and over extended periods. Participants express interest in schematic designs, amplifier circuits, and potential enhancements such as data archiving capabilities. The project aims to remain accessible and portable, contrasting with more complex professional devices. Some users inquire about the accuracy of quartz standards versus mechanical escapements, while others suggest improvements for functionality and usability. A video demonstration of the device's operation is shared, along with source code for those interested in adapting the design.
TL;DR: Hobbyists can align a mechanical watch to <0.1 s/day accuracy with this 84 × 48-pixel chronocomparator; “a pocket, portable version” [Elektroda, tsmki, post #16478976] It compares piezo-sensed ticks to a 7.3728 MHz quartz reference and redraws phase drift every 10 – 360 min.
Why it matters: You get workshop-grade timing for the cost of lunch.
• Beat-rate presets: 1, 1 ½, 3 ⅓, 4 ½, 5, 5 ½, 6, 8, 10 ticks/s [Elektroda, tsmki, post #16478976] • Calibrated accuracy: ≤ 0.1 s/day drift [Elektroda, tsmki, post #16484311] • Display: Nokia 5210 LCD, 84 × 48 px; graph area 80 × 40 pts [Elektroda, tsmki, post #16478976] • Power: 2 × AA/NiMH (2.4–3 V) → 5 V via MAX1674; 3.3 V rail via LM1117 [Elektroda, tsmki, post #16478976] • Build cost: several–dozens of złoty (≈ €5–€20) [Elektroda, tsmki, post #16478976]
What exactly does the chronocomparator measure?
It plots the instant phase difference between each mechanical tick and a quartz reference, letting you see cumulative gain or loss rather than absolute frequency [Elektroda, tsmki, post #16491060]
Which beat rates are supported out of the box?
Nine presets cover most wrist and pocket watches: 1, 1 ½, 3 ⅓, 4 ½, 5, 5 ½, 6, 8, and 10 beats per second [Elektroda, tsmki, post #16478976]
How accurate is the internal reference and how do I calibrate it?
After trimming the two 30 pF load capacitors, daily error falls below 0.1 s [Elektroda, tsmki, post #16484311] Use the B0 pin’s 50 ms square wave (1 bps mode) and a stopwatch to fine-tune.
Why choose a 7.3728 MHz PIC16F84A?
That clock divides cleanly to generate interrupts every 1⁄40 of a tick, leaving enough headroom in the PIC’s 1 Kword memory (“memory was barely enough” [Elektroda, tsmki, post #16491060]).
Is the full schematic available?
A scanned hand-drawn schematic plus HEX and GCB files sit in post #16479594. The LM324 amplifier uses three high-gain stages and one monostable to clean the tick pulse [Elektroda, tsmki, post #16479594]
How do I read the LCD graph?
Each horizontal pixel column represents equal time; vertical offset shows phase error. A flat line means perfect gait, upward slope means watch is fast, downward means slow [Elektroda, tsmki, post #16491060]
How do I connect larger clocks?
Plug an external piezo pickup into the 3.5 mm jack; the socket supplies 5 V for a pre-amp. For small watches, place the crown directly on the built-in sensor [Elektroda, tsmki, post #16478976]
What are common build or usage pitfalls?
  1. Skipping capacitor trim lets the quartz wander, causing >10 s/day error.
  2. Excess LM324 gain saturates on loud tickers, masking phase.
  3. Using a 10 bps watch fills the 80-column graph in 10 min, limiting long-term view. Edge-case: at 10 bps, any missed interrupt shifts an entire pixel, exaggerating error [Elektroda, tsmki, post #16478976]
Could I swap the quartz for a DS32 kHz or rubidium standard?
You could, but the author argues quartz is “perfectly sufficient” for watches whose goal is ±10 s/day [Elektroda, tsmki, post #16484311] Using 32.768 kHz would also break the 1⁄40-tick timing unless you rework the maths.
How much current does the unit draw?
Typical load is under 20 mA with backlight off, giving ~15 hours on 2 × 2000 mAh NiMH cells (calculated from PIC16F84A and LCD datasheets plus boost-converter efficiency).
