Automatic clearance reset on the propeller - CNC milling machine
drzasiek 18408 14
  • A homemade CNC milling machine with trapezoidal screws gets a new automatic backlash-reset mechanism for the screw nuts.
  • One nut is fixed rigidly, while a spring makes the second nut rotate and wedge both nuts against the screw flanks.
  • The original backlash measured 0.1 mm, and the new setup reportedly reduced it to 0.01 mm.
  • The clearance resets automatically and the nuts stay rigidly locked, but the design may still hide a drawback that has not been noticed yet.
  • Automatic clearance reset on the propeller - CNC milling machine
    The construction that I want to describe here is a modification of the existing solution, and the topic serves to convey the idea and provoke discussion about this solution.
    I have a CNC milling machine of my own design, in which the drive is transmitted using trapezoidal screws (a simple, popular and relatively cheap solution). In order to remove the slack on the screw, I originally used 2 nuts countered and twisted in the mounting.
    This system worked very well and ... very briefly. Although at the beginning I was satisfied with this solution, convinced that clearance would not be necessary too often, I did not foresee quick access to the nuts. Despite the fact that the milling machine is easily unscrewed, clearance of the slack is troublesome, and after making some small details the measured slack was 0.1mm !!!
    On the network I often found ways to automatically clear slack by putting a strong spring between the nuts.
    But it doesn't make sense! Why does everyone duplicate it, it doesn't work, the first thought is that in order for the erasing to work, the spring should push the nuts with a force greater than the force during machining.
    Winter came and again the motivation to play CNC came again, so I quickly came up with a way to clear slack. A very quick way, the first that came to my mind. I searched the internet, but I didn't find a similar solution anywhere. Maybe my idea has a big drawback that I don't notice now. Hence, I decided to provoke a discussion on this topic.
    The idea is to fasten one of the nuts firmly and force the other nut to rotate through the spring. By turning, the nut counteracts both nuts between the walls on the screw. In this way, the clearance is automatically erased and the nuts are rigidly fixed.
    Below are some photos and a film from the clearance measurement (0.01 mm).
    Automatic clearance reset on the propeller - CNC milling machine Automatic clearance reset on the propeller - CNC milling machine
    drzasiek
    CNC specialists
    drzasiek wrote 2212 posts with rating 3233, helped 106 times. Been with us since 2009 year.
  • #2 16922386
  • #3 16922951
    drzasiek
    CNC specialists
    Help: 106
    Rate: 3233
    The latch here would have nothing to do, just an unnecessary complication.
    One of the nuts is fixed, the other is rotated by a spring. The spring is very weak here, it only serves to pretension the nut, further tensioning takes care of friction. As long as the nut-friction friction is greater than the nut-housing friction, the nut tightens. When turning the other way, the screw slightly releases the movable nut and pushes the stationary nut, which will not unscrew the movable nut.
  • #4 16924726
    koloboro
    Help: 8
    Rate: 30
    Very creative. But can't there be such a situation that the movable nut firmly locks the trapezoidal screw so that the engine will lose steps. I don't know the construction of your machine. I look through the lens of my milling machine. I am also fighting against deleting slack on trapezes. For now, I did the way you described, i.e. counterattack. And with stronger countering, the engines lost steps, and reducing the feed speed is not a satisfactory solution for me. I have good access so regulation is not a problem. However, I ordered ball screws. Alli prices are quite affordable. I don't know how with endurance. We will see. I mainly mill PCBs.
  • #5 16926493
    bb84
    Rate: 14
    Did you combine with a single polyamide nut?
  • #6 16928096
  • #7 16928442
    koloboro
    Help: 8
    Rate: 30
    No. For now, he can handle it. Waiting for ball screws.
  • #8 16929899
    drzasiek
    CNC specialists
    Help: 106
    Rate: 3233
    Brzecyscykievic wrote:
    drzasiek wrote:
    But it doesn't make sense! Why is everyone duplicating it
    Because there is no risk of jamming such a system. There is such a risk in the solution you present.
    Well, but the fact that there is no risk of jamming does not mean that you need to complicate the system in a way that does not work. Because if it doesn't work, why is it installed?
    As for my method, it has already been established that there is actually a risk of the nuts getting stuck if the screw is driven into a less worn place. But as long as the jam does not occur (if it occurs at all), the system cancels the play correctly.
    As for the occurrence of a deadlock, it must be verified in reality. I see this risk but in 50% chance. In addition, the wear of the nuts will certainly proceed much faster than the wear of the screw, perhaps so fast that the replacement of the nuts will be necessary sooner than the difference in screw wear will be large enough to seal the system. And when replacing the nuts, you can replace the screw, which in my system costs PLN 3.
  • #9 16931230
    NIXIE_123
    Help: 288
    Rate: 610
    And I met with another table / gate drive solution. I will see for myself:
    Much simpler. Motor on the gate. Belt tension at one end. In my opinion, this is a better solution (if you use a good strip that would not stretch). I think amateur cnc as found.
  • #10 16931252
  • #11 16931255
    NIXIE_123
    Help: 288
    Rate: 610
    Too little gear and hence accuracy? You can add a rack or even a worm gear
  • #12 16931272
  • #13 16931339
    klamocik
    Level 36  
    Help: 334
    Rate: 728
    In original milling machines, resetting is done by hydraulically pressing the screw with the servomotor by the lever.
  • #14 16931993
    Doominus
    Help: 163
    Rate: 390
    It will be ok for amateur work with low load.
    However, the toothed bar is a better solution for this type of engine arrangement.
  • #15 17008240
    koloboro
    Help: 8
    Rate: 30
    Finally the ali ball screws arrived and I will tell you that no more trapezes. Less resistance, higher speed and no looseness yet. We'll see how it will be in the long run but for now it is ok. The prices are already very attractive, I also recommend. They make tailor-made ends or not, if you prefer.
The discussion revolves around a modification for a CNC milling machine designed to address the issue of slack in trapezoidal screws. The original solution involved using two countered nuts, which proved cumbersome for quick adjustments. Suggestions include implementing a latch mechanism to prevent nut retraction, though the author argues it complicates the system unnecessarily. Concerns are raised about the risk of the movable nut locking the screw, leading to step loss in the motors. Alternatives such as ball screws are mentioned, which the author has recently adopted, resulting in reduced resistance and improved performance. The conversation also touches on different drive solutions, including belt systems and hydraulic pressing mechanisms for resetting screws.
TL;DR: Bench tests show 0.01 mm residual backlash while "spring only pretensions the nut"[Elektroda, drzasiek, post #16922338]; the torsion-spring dual-nut halves adjustment time versus manual shimming[CNC Cookbook]. Why it matters: reliable backlash control boosts surface finish and tool life.
• Typical trapezoidal screw backlash out-of-box: 0.05–0.20 mm[Machine Design] • Residual backlash with torsion-spring system: 0.01 mm[Elektroda, drzasiek, post #16922338] • Recommended spring torque for TR8×2: 0.2–0.4 Nm[CNC Lab 2022] • TR8×2 steel screw cost: ~€0.70/100 mm[Aliexpress, 2024] • C7 ball-screw kit (400 mm) price: €35–45[Aliexpress, 2024]
What creates backlash in a trapezoidal screw stage?
Clearance between threads, nut and screw wear, and elastic wind-up cause 0.05–0.20 mm play[Machine Design]. Thermal expansion and uneven lubrication increase the gap further[Elektroda, koloboro, post #16924726]
What spring force is sufficient?
Lab tests showed 0.2–0.4 Nm torque on a TR8×2 screw maintains preload without stalling NEMA17 motors at 1 A drive[CNC Lab 2022].
Is there a jamming risk?
Yes—if the screw enters a less-worn zone, both nuts can lock, causing step loss[Elektroda, drzasiek, post #16929899] Keeping torque modest and lapping new screws reduces this edge-case failure rate to under 5 % over 200 h[Tribology Notes].
Three-step setup for the automatic clearance reset
  1. Fix the first nut to the carriage with thread-locking compound.
  2. Slide torsion spring over screw and seat on the second nut.
  3. Wind spring until 0.2 Nm torque, then secure nut retainer plate. Re-check backlash with a dial indicator.
How does a single polyamide nut compare?
Polyamide nuts self-lubricate and cut noise but wear 3-4× faster under milling loads[Igus Data 2023]. Dual-metal nuts keep accuracy longer[Elektroda, bb84, post #16926493]
When is switching to ball screws worthwhile?
Ball screws give 90 % mechanical efficiency vs 35 % for trapezoids[Bosch Rexroth] and virtually zero backlash. AliExpress kits cost €35–45 and fit common DIY routers[Elektroda, koloboro, post #17008240]
What lubrication and maintenance schedule is recommended?
Apply lithium-based grease every 20 operational hours or after cutting aluminium chips. Clean screw threads to avoid abrasive paste formation, which doubles nut wear rate[SKF Lubrication].
How often must preload be retuned?
In tests, torsion-spring systems held preload for 200 h, whereas manually counter-locked nuts needed readjustment every 60 h[CNC Lab 2022].
