  • DIY-A586 v1.6 by piotr_go Green circuit board with various ports and electronic components. A processor is visible in the center.
    I present a next plate for Retrocomputing.
    The emulator has:
    - FPGA Spartan6 XC6SLX9
    - 8MB 16bit SDRAM memory
    - 16MB flash for core and ROMs
    - HDMI output
    - analog audio output + tape recorder input
    - SD slot
    - RS232
    - 2 * joystick port
    - 2 * PS / 2
    - A500 keyboard connector
    - floppy disk drive connectors
    - 2 buttons (menu and reset)
    - 2 LEDs
    - 5V USB-C power socket
    - dimensions 100x100mm
    Up to 30 configurations in flash can be loaded into an FPGA.
    Floppy Disk Drive:
    Amiga and PC:
    A500 keyboard:
    NES:
    Spectrum:
    Gamepad:
    Boot Amiga from SD:
    Diagram and gerberas in the attachment.
    Commercial use prohibited.
    I do not help to order tiles, complete elements, I do not give soldering lessons.
    • piotr_go DIY-A586 v1.6.tar.gz (991.08 KB) You must be logged in to download this attachment.
    piotr_go
    DIY electronics designer
    piotr_go wrote 2910 posts with rating 3351, helped 94 times. Been with us since 2003 year.
  • #2 18067339
    Troberto
    Nice job!!
    Where is the code?
    Regards.
  • #3 18067387
    piotr_go
    Help: 94
    Rate: 3351
    Soon.
    I need to update main menu first.
    • spectrum.a586.tar.gz (56.77 KB) You must be logged in to download this attachment.
    • spectrum_v0.01.tar.gz (137.23 KB) You must be logged in to download this attachment.
  • #4 18067404
    Troberto
    Thanks so much Piotr, keep up the good work!!
  • #5 18067792
    LA72
    Help: 648
    Rate: 1661
    Come on. Another beautiful emulator came out of your hand.
    Which floppy disk drive did you use for loading, Amiga?
    What else can this connector be connected to?
  • #6 18067819
    piotr_go
    Help: 94
    Rate: 3351
    At the moment it is programmed for Amiga, but the PC should also work after reprogramming.
    LEDs, buttons, ...
    ================ update ===============
    I added a BIN file from the main menu.
    Flash at 0x000000.
    • main (v0.4 beta6.1).tar.gz (258.47 KB) You must be logged in to download this attachment.
    • nes.a586.tar.gz (93.09 KB) You must be logged in to download this attachment.
    • nes_v0.01.tar.gz (153.96 KB) You must be logged in to download this attachment.
  • #7 18076248
    Krzysiek007
    Help: 13
    Rate: 53
    Shouldn't the length of SDRAM paths be kept?
    For SD cards and Flash memory the rule has been respected.
  • #8 18076257
    piotr_go
    Help: 94
    Rate: 3351
    Because it looks cool :)
    At these frequencies, such length differences are irrelevant.
  • #9 18078167
    pawelcb33
    Help: 11
    Rate: 124
    You've turned out to be quite a treat, congratulations.
    What is the approximate cost of implementation because maybe I would do for myself?
    Out of curiosity, hand or machine soldered?
    You could throw in the parts list even from the program because probably not everything is on the diagram.
  • #10 18078433
    Darek0026
    Help: 224
    Rate: 385
    A masterpiece, as usual WOOOOOOW !.
  • #11 18078501
    piotr_go
    Help: 94
    Rate: 3351
    pawelcb33 wrote:
    What is the indicative cost of execution
    I have no idea, I do not buy individual items.
    There are many boxes lying around and I take out what I need.
    pawelcb33 wrote:
    Hand soldered out of curiosity
    Manually.
    I tried the second core C64 approach yesterday.
    So far I haven't been able to match it with the SDRAM controller.
    Certainly it is possible, but without knowing the timings, it's hard to do it.
    It will take some time to analyze this.
    Core running on the internal GRAM works, but it's only 40kB.
    • bom.txt (23.88 KB) You must be logged in to download this attachment.
  • #12 18088889
    Hetii
    Rate: 420
    Design, as always noble ;)
    But I will ask, where did you get a working floppy disk from in 2019?
  • #13 18088957
    piotr_go
    Help: 94
    Rate: 3351
    It took care of it :)
    You can still buy clean, probably still being produced.
  • #14 18088977
    bigrom
    Help: 7
    Rate: 8
    And you don't need 8 "floppy disks :)
  • #15 18088999
    piotr_go
    Help: 94
    Rate: 3351
    If you have it, you can give it to me because I've never seen it :) ... and 5.25 with a working station would come in handy.
    I will also gladly take the Amiga 500 (but not qwertz) if someone has it, because I don't have a keyboard for testing.
  • #16 18089739
    bigrom
    Help: 7
    Rate: 8
    Maybe I still have 5.25 "ignition switches, as I did not open it. Because they have cool stepper motors (such for PC as you are interested in) 8" floppy disks (as someone still remembers the name) but no ignition (they were used in Polish PSPD devices (https : //www.youtube.com/watch? v = Svxmq08Ow_I) produced by MERA-KFAP in Krakow They were produced in two pockets so that it was 2x 256kB :) . After the introduction of CPM v1.0, the computer had up to 64kB in dynamic memories.
    Added after 4 [minutes]:
    I found it on OLX https://www.olx.pl/oferta/matsushita-zbytkowa...etek-5-1-4-cala-CID99-IDybDiM.html#6f9e9b5470
    But the price of space is probably not so big a fan of antiques.
  • #17 18089775
    blue_17
    Level 32  
    Help: 172
    Rate: 472
    great job, I'm finished and delighted with the relatively small amount of components.
    I have four questions.
    1. Some resistor values are not on the list of elements, ie are they jumpers or aren't they mounted?
    2. As I understand correctly, to have a different platform, FPGA should be reprogrammed or maybe in the menu it is possible to choose the platform that will be loaded - it would be great but I understand that there are some limitations.
    3. Will there be an implementation of C64 and the ability to load files into it from an SD card
    4. What configuration was the Wolfenstein fired on, was it Amiga or something else?
    If you would like the housing, I can design and print it on a 3D printer, you can then share it - if you wish
    Best wishes
  • #18 18089869
    piotr_go
    Help: 94
    Rate: 3351
    Those on the underside at the station connector are not mounted.
    F1 and F2 - ferrite at SD, 0.5A polymer fuse at JOY1
    blue_17 wrote:
    2. How well I understand to have a different platform
    There is a menu (penultimate video in the first post).
    In preparation, 100% can be done, but I don't know if it won't take too long.
    blue_17 wrote:
    4. On what configuration the wolfenstein was launched
    PC, ~ 80186
  • #19 18090235
    blue_17
    Level 32  
    Help: 172
    Rate: 472
    Thank you for your answer
    I am waiting with diligence if there is still an option from C64, I immediately start building.
    Thank you, great project!
  • #20 18097803
    androot
    Help: 54
    Rate: 635
    A few programming related questions.
    1. Configuration is programmed by JTAG and is it used for "main (v0.4 beta2) .bin"?
    2. Can it be done with the FT2232 converter?
    3. The remaining files are loaded from the SD card? I see there are NES and Spectrum files, and Amiga?
  • #21 18097825
    piotr_go
    Help: 94
    Rate: 3351
    No, the luxury version ... :) , MAIN allows you to load FPGA configuration from SD card to FLASH.
    ROMs and other files can be loaded from FLASH or SD.
    JTAG for developers.
  • #22 18098051
    androot
    Help: 54
    Rate: 635
    Is this AS4C4M16 memory replaceable? It is quite difficult to access.
    I found one in Farnell: MT48LC4M16A2
  • #23 18098086
    piotr_go
    Help: 94
    Rate: 3351
    ~ 10 PLN at TME.
  • #24 18098102
    androot
    Help: 54
    Rate: 635
    I looked in Farnell and it wasn't there. Google, however, did not suggest TME. Thanks.
  • #25 18108832
    pawelcb33
    Help: 11
    Rate: 124
    Com sockets are to be male or female?
  • #26 18108837
    piotr_go
    Help: 94
    Rate: 3351
    All DB9 male.
  • #27 18113362
    pawelcb33
    Help: 11
    Rate: 124
    Thanks, I've just ordered. Pcb will also come to me soon.
    Tell me what are these mini din sockets, where do you get it?
    Or if you could take a picture of the front of the sockets and the bottom of the pcb, I will know what to look for.
    Thanks
  • #29 18128609
    androot
    Help: 54
    Rate: 635
    Board assembled, consumes approx. 20 mA of current. How to prepare an SD card to boot FPGA from it?
  • #30 18128871
    piotr_go
    Help: 94
    Rate: 3351
    The first time you have to load MAIN to flash with some programmer.
    Alternatively, upload main_xxxx.a586 to fat32 card (main partition), run fpga via jtag, and F2 update (it will be uploaded to flash).
    I include the card image (DOS_ClassicWB.raw.zip).
    The first dos partition (it's just command.com) of the core PC.
    Second Amiga, don't change.
    Make the third fat32 (as the main one). You will throw roms or other files on it.
    • DOS_ClassicWB.raw.zip (22.11 MB) You must be logged in to download this attachment.
Discussion of the DIY-A586 v1.6 retrocomputing board by piotr_go, an FPGA-based emulator platform built around a Spartan-6 XC6SLX9, 8 MB SDRAM, 16 MB flash, HDMI, audio, SD, RS232, joystick, PS/2, A500 keyboard, and floppy connectors. The thread covers availability of the main firmware, flash programming via JTAG or a 25Q128 programmer, SD card image preparation, core loading from flash/SD, and supported systems such as Amiga, PC, NES, Spectrum, and Gamepad modes. Users ask about BOM details, component substitutions, regulator and oscillator selection, ESD protection, ferrite beads, and connector orientation. Several build/debug topics are discussed, including power rail faults, 1.2 V and 3.3 V regulators, 16 MHz clock generator replacement, flash QuadEnable setup, SD card compatibility, Amiga booting from SD, floppy drive wiring, Gotek support, and limitations such as ECS-only Amiga support and no built-in ADF floppy emulation. The author also mentions future release of Amiga sources and provides guidance for dual floppy drive wiring and modified cores.
TL;DR: DIY-A586 packs a 100 × 100 mm Spartan-6 board that stores 30 FPGA cores in its 16 MB flash—“Up to 30 configurations in flash can be loaded” [Elektroda, piotr_go, post #18067213] Why it matters: one card swaps instantly between Amiga, PC-XT, C64 and more.
• FPGA: Xilinx Spartan-6 XC6SLX9-2TQG144 [Elektroda, piotr_go, post #18067213] • RAM: 8 MB SDR SDRAM @ ~56 MHz (Amiga) or 133 MHz CL2 (PC) [Elektroda, piotr_go, post #20583795] • Flash: 16 MB SPI (Winbond 25Q128) — first flash needs external programmer [Elektroda, piotr_go, post #19143673] • Power: 5 V via USB-C; legacy floppy drives need extra 12 V rail [Elektroda, EKBubba, post #19358582] • SD: SDHC (≥4 GB) FAT32 + Amiga RDB, multi-disk driver v0.10 [Elektroda, piotr_go, post #20677771]
What components are mandatory for a working v1.6 board?
Essential parts: XC6SLX9 FPGA, AS4C4M16 SDRAM, Winbond 25Q128 flash, 16 MHz CMOS oscillator, SD socket, USB-C power jack, two SOT-223 LDOs (3.3 V & 1.2 V) and the HDMI level shifters [Elektroda, piotr_go, #18067213 #19178403].
Which SDRAM speed grade should I order?
Any 166 MHz (6 ns) IS42S16400J will run; Amiga core clocks the RAM at ~56 MHz and the PC core at up to 133 MHz CL2 [Elektroda, piotr_go, post #20583795]
My SD card isn’t recognised—what’s wrong?
The driver needs SDHC cards; old 2 GB SDSC cards fail detection [Elektroda, piotr_go, post #19186591] Format the primary partition FAT32 (MBR) and place *.A586 files in the root.
Can I use PFS3 or multiple virtual hard disks?
Yes. SD.ROM v0.10 adds multi-disk and PFS3 support. Each MBR primary partition type F0 becomes an Amiga unit; FAT volumes stay readable via fat95 [Elektroda, piotr_go, post #20677771]
How fast is the new Mikan 0.1.7 Amiga core?
It delivers ~143 % of real A500 CPU speed and triples SD throughput versus Minimig; audio, bitplane and copper bugs fixed [Elektroda, piotr_go, post #20783590]
Does Gotek or dual-drive work?
With Mikan v0.1.5+ the auto-switch logic makes DF1 the boot drive when it asserts _RDY during reset. Both drives must output _RDY and DF1 should be an emulator that ignores _MTR [Elektroda, piotr_go, post #20677771]
Edge-case: Amiga mouse and PS/2 mouse together?
From Mikan 0.1.9 you may connect either two Amiga mice (joy ports) or one PS/2 mouse; mixing beyond these combos is unsupported [Elektroda, piotr_go, post #21362045]
Why does my vintage Chinon floppy spin but not read?
Early 720 kB drives and A500 units draw 12 V for the spindle, which the DIY-A586 5 V rail can’t supply. Feed 12 V externally or use a modern 5 V-only mechanism [Elektroda, EKBubba, post #19358582]
How do I patch Kickstart 3.2.1 for SD boot?
Run the supplied xdelta script in mikan/kick3.x patch v0.8 then rename the output to KICK32SD.ROM and list it with -fb in bin2a586; checksum must match 75c85b… [Elektroda, piotr_go, post #19898942]
What’s the licence situation—why ‘DEMO LIMIT, 4 CORES MAX’?
Unregistered MAIN limits the flash menu to four cores; request a free personal key from the author via forum PM to unlock [Elektroda, tchernychov query #21048193 and piotr_go reply context].
Where can I source the 16 MHz oscillator?
Use any 3.3 V CMOS clock module, e.g., Microchip DSC6111 16 MHz; crystals won’t work—one caused a Vcc-GND short during assembly [Elektroda, piotr_go, post #19178936]
