  • Two homemade solar tracker builds are shown: two single-axis trackers and a two-axis tracker with truss-based structures.
  • Actuators drive the structures; the single-axis units use reed switches and a 9-channel controller, while the two-axis unit sequences two actuators and a third sun-tracking actuator.
  • The single-axis trackers cover about 150 degrees with a constant 40-degree tilt and 2.4 kW total power.
  • The two-axis tracker reaches up to 200 degrees, but limit switches are set around 170 degrees because of terrain.
  • Costs were around 7,000 zloty in 2020 and about 9,000 plus 5,000 zloty for the inverter in 2021; the wind sensor can require manual reset.
  • Let me present my own constructions of my own performance.
    I have presented them very briefly / roughly in another topic, not in this section, here they will probably be subject to professional evaluation / criticism.
    Maybe they will inspire someone, help someone, building prototypes is really difficult, but users of the DIY Constructions section probably know that.
    Two single axis trackers:
    One- and two-axis solar trackers One- and two-axis solar trackers One- and two-axis solar trackers One- and two-axis solar trackers One- and two-axis solar trackers
    Two-axis tracker, trusses based on uniaxial:
    The structures use actuators as a drive.
    The uniaxials have a tracking range of about 150 degrees, a constant angle of inclination of about 40 degrees and a total power of 2.4kW, at the beginning the 9-channel second controller gives 8 seconds after time intervals. impulses. In addition to the limit switches in the actuators, the system with two reed switches on the first tracker, the second one works synchronously.
    The two-axis can track up to 200 degrees, the limit switches are set at about 170 degrees due to the terrain conditions, its power is 3.0 kW. The second 16-channel driver (for now), gives 6 sec. impulses. A unique system of two actuators rotates the load-bearing structure sequentially: first one works, after the work is finished the other. When polarity is reversed, reverse.
    The second axis is moved by the third actuator via the sun tracking controller. At the top, the wind force sensor, which activates the third actuator, works until the pulses are flattened and the pulses are disconnected, to restore the functions, it must be done manually with the "work" button.
    There is a box on the main pole, it has switches, but they are only for service.
    Costs:
    2020 - around 7,000 zloty.
    2021 - considerable, around 9,000 + 5,000 inverter zloty
    Does it all make sense? only thanks to the contribution of my own work.
    I have orders locally, but there are other ideas in my head.
    zimny8
    zimny8 wrote 3654 posts with rating 504, helped 26 times. Live in city żywiec. Been with us since 2011 year.
  • #2 19585525
    CosteC
    Help: 402
    Rate: 1674
    Impressive structure, or rather structures. What is "second driver" - is this some kind of photovoltaic slang?
    I am worried about cables - they look ordinary, indoor installation, and hang freely, susceptible to wind damage.
    I am interested in the topic of protection against strong winds - did you count it or did you assume that the whole thing will have time to assemble?
  • Jumper cables and 40-second wind flattening
    #3 19585689
    zimny8
    Help: 26
    Rate: 504
    Yes, it's the jumper cables, they'll be different, connected.
    The complete flattening in the case of wind takes as much, depending on the initial position, as max. actuator operation time 24 ", i.e. about 40 sec.
    Second controller, type in google, mainly in aquarium, terrarium, generally timer with programs.
    Ultimately, 30 programs are to be ordered, already ordered.
  • #4 19585860
    ADI-mistrzu
    Level 30  
    Help: 37
    Rate: 308
    PLN 21k (i.e. PLN 7k + PLN 9k + PLN 5k) is the cost of both structures + an inverter that supports both masts?
  • #5 19586313
    krzbor
    Help: 43
    Rate: 1073
    I wonder if it pays off. I mean, isn't it cheaper to install more panels on the roof?
  • #6 19586391
    KamiJas
    Rate: 20
    Aren't you afraid of higher winds that it might act like a sail and fly?
  • #7 19586714
    marik_te
    Help: 29
    Rate: 57
    Allow me to insert a photo of the construction that I had the pleasure to create some time ago.
    Two tables on separate trackers, 15 340W panels each.
    Photovoltaic panel system mounted on a rotating mechanism, illuminated at night.
  • Wind load makes fixed solar structures impractical
    #8 19586862
    zimny8
    Help: 26
    Rate: 504
    To this "power plant" you have to add two previously placed, such as those from 2020, with a total capacity of 2KW for 5k PLN.
    The roofs are different, I have a gable but unfavorably oriented, the neighbor I helped has panels near the house of 20m? in 4 rows. After adding the services, he did not get much cheaper, and they are standing still. You do not need to explain what it means? I will just say that the manufacturers of panels provide the power of their products with lighting perpendicular to the surface.
    Buddy, after flattening, they put up almost no resistance to the wind, it was already windy and nothing.
    Do you think idiots build this way blindly?
    marik_te - cool, but I prefer smaller ones, because I can do everything myself. A friend had a windmill, but it was not windy, he turned it into a photo. There was an excavator at the construction site, 12 cubic meters of concrete went into the hole, a larger excavator, actually a crane, was to be assembled. He strengthens this structure from time to time, it weighs tons.
  • #9 19586885
    bambus94
    Help: 245
    Rate: 717
    And I am curious what this wind strength sensor looks like. Because it would be useful for my project.
  • Solar trackers no longer pay back economically
    #10 19586897
  • Reed switch tilt sensor for solar tracker
    #11 19586899
    zimny8
    Help: 26
    Rate: 504
    This sensor is not extremely precise, but it works fine. Tiltable, i.e. a plate with a selected surface with an integrated magnet, a reed switch on the side boom.
    cefaloid wrote:
    Today, for these 21,000 PLN, you can order a team that will install the 5kW installation without moving your butt. Or you can buy so many panels yourself that the power obtained will spread the one you get using the tracker.
    I see these teams of pullers, in my area not a single roof has been prepared for screwing, they even lay it on a rusty metal sheet. Everything on a hooray, one house with several roofs, the so-called Roof panels, two panels on each roof, even on the northern one.
    Moderated By tmf:
    I removed some off-topic content.
  • #12 19587108
    Slawek K.
    Help: 259
    Rate: 1303
    It is not always possible to add an infinite number of panels, because there is no space on the roof, no space on the plot, etc. etc. - then the tracker makes sense, because it is basically the only solution that allows you to increase the efficiency of the installation - not always only the economy decides.
  • Cost analysis of a homemade two-axis tracker
    #13 19587306
    zimny8
    Help: 26
    Rate: 504
    As for the economy, let's take a two-axis tracker made with our own work - PLN 9k. - 4k PLN for the inverter panels also, because it is always needed, so we are talking about 5k PLN. For 8 hours work on a sunny day is able to generate max. about 20 kWh, monthly in summer 300 to 350 kWh. 2000 kWh all summer, in winter 1000 kWh annually about 3000 kWh. How much money is it? How many years will it take to depreciate?
    Someone writes that it will not return, its strange mathematics, and the roof also needs a not cheap construction alu. Well, I saw it tied with wire to the chimney, the proud owner even posted a video on yt.
    Certainly, it will not pay off to outsource the construction of the tracker to someone, although I have 2 people for + PLN 10k for me, I do not undertake it, I have other goals.
  • Two-axis tracker can boost output by 35% in Poland
    #14 19587332
  • #15 19587361
    Slawek K.
    Help: 259
    Rate: 1303
    Nobody attacks, I just referred to the fact that the hobby is not always about money and economic sense. If you do everything just to make it profitable and beneficial, then I feel a little sorry ;) I did a lot of things there that did not necessarily pay off, but the fun and satisfaction of building them was / is priceless :)
  • #16 19587372
  • Trackers reduce storage needs under grid constraints
    #17 19587382
    trojan 12
    Level 40  
    Help: 518
    Rate: 1125
    Colleagues, you are a bit detached from reality.
    The power industry will force the storage of electricity and with the tracker, the production will be spread more evenly, you need a smaller warehouse.
    You can be sure of this, because the modernization of the network costs money, they want to transfer the costs to the producer instead of modernizing the network.
    Recognition for the constructor for his ability to predict, because he was building the installation at the time the previous Prosumer Act was in force.
  • Installer criticism and roof suitability argument
    #18 19587662
    zimny8
    Help: 26
    Rate: 504
    cefaloid wrote:
    Oh, and you assume that every installer is a liar, bastard and thief? Because I don't understand - could you specify what exactly you wanted to say?
    Why the belief that everyone else is definitely spartolone and you are not the only one? And why do you call this man (instead of feeling sorry for him because he was deceived) an envious man?
    I will only refer to this, on other points I fully or partially agree (not the 35% difference).
    I did not write that they are all bunglers and liars, but there are probably a lot of them, because in a small radius I can see their botched works.
    The aforementioned envy is my matchmaker, and I will add that I am a disbeliever, I will not feel sorry for him, because if I advised him something, he would not listen. He came as it was, for help, he cannot be helped now. And he has a piece of a garden, and he could give it there, instead of a roof that was not suitable for it. A good installer would tell him the same.
  • #19 19588634
  • Topography and shading explain tracker yield differences
    #20 19588693
    zimny8
    Help: 26
    Rate: 504
    From my observations and comparisons to my neighbors, I have over 40% of them, but this difference will not be everywhere. The photos show the topography and vegetation. Those who have panels low to the ground (1 neighbor behind the fence), some to noon and others in the afternoon, have almost no yield. At this time of the year, the first rays of the sun fall on my trackers, e.g. today 0 8:30 (at my neighbor's house at noon, because it's almost near the forest and on a slope), and in winter (December), only around 10:00.
    Therefore, the roof would be the best, unfortunately not mine.
  • Suggesting smaller panel groups on raised frames as trackers
    #21 19590259
    kotbury
    Gantry automation specialist
    Help: 2102
    Rate: 3636
    My answer is: 10 to 12 panels 375 W or 400 W. I have 10 panels on the roof (375 W PERC Longi), an angle of approx. 26 degrees (classic Gierek post with an envelope roof). The paneled slope faces almost exactly south (with a slight deviation to the east). On a good day (May to end of July) an average of 20 kWh per day. But the yield measured with the inverter right after the panels. After the inverter and balancing, of course, less.
    In winter there will be a misery, but I plan to add another 8 on the western slope, but the CIGS (apparently they better collect non-perpendicular and diffused light - it will turn out) on pseudo trackers, i.e. whole frames (panels in 3 separate groups due to obstacles on the roof) lifted by gate actuators.
    I do not sit deeply in the subject of trackers, but would it not look neater if instead of a gigantic sail mounted on a turntable of several hundred kilograms and a ton of foundation, panels should be made (even in several sets) on the raised frames, and the east-west positioning should be done by "spinning" individual panels (or " risers ") if more of them - about the vertical axis?
    If I already have the abovementioned CIGS, I will just try to come up with something like that and maybe I will also add a vertical axis. It's just that I have a special situation, additional panels will work only in the afternoon, so the ranges of movement will be smaller (and the design is simpler) than in the case of an all-day tracker.
  • 10 to 12 roof panels needed for comparison
    #22 19590292
    zimny8
    Help: 26
    Rate: 504
    Quote :
    "How many years will it take to depreciate? How many roof panels do you need to have this result?"
    kotbury wrote:
    My answer: 10 to 12 panels of 375W or 400W
    And that is the true answer to someone who has.
    As you can see, almost twice as many.
    As for my 2-axle axle, it is not that gigantic or heavy, the profiles in Centrostal cost PLN 2,500, knowing the average price per ton is easy to count. For the hole, 1 cubic meter of concrete + 0.5 knots of tritin.
    As for the idea, how do you get your place? The single swivels will take up a lot of space so that they do not shade each other.
  • Roof-mounted tracker feasibility and wind-load concerns
    #23 19590366
    kotbury
    Help: 2102
    Rate: 3636
    At the ground it's just an idea - I will do them on the roof, but the target CIGSs are small (70 cm wide), so even if I place them wider, they will climb onto the roof. How it comes out and if I can do it - we'll see.
    On the ground you actually need a lot of unshaded space, but if someone has a live field ... I noticed that some large farms have this tracking solution.
    PS.
    The previous speaker has 2.5 tons of concrete in the ground.
    However, in the last 4 years, I had one storm with the wind and rain speed of 212 km / h measured by the local weather station. Hundred-year-old linden trees (barely), and such a tracker? will not turn into a glider?
    Profitability, as the previous speakers noted, is debatable. And no one counts the work put into the design of the controller - but after all, it's a DIY department.
  • #24 19590502
    zimny8
    Help: 26
    Rate: 504
    I already wrote, a parked, flattened tracker, the surface of which is so minimized, practically offers no resistance, not like a leafy tree.
    Of course, not for a whirlwind, so there is also insurance, quite large, higher than the above-mentioned costs.
  • Roller-guide tracker design with freeze risk
    #25 19593781
    alt11
    Help: 5
    Rate: 32
    A year ago, we were to carry out an order in an unusual company with very unusual trackers - very interesting.
    Quite a different approach to construction and very logical. Placing the supporting structure on roller guides with four support places. Cheaper and more effective. There is only one downside to this design - sensitivity to freezing snow.
    Unconventional solar tracker construction in a field with vegetation and houses in the background.
    https://youtu.be/D7Dy4avnzWo
  • Measured 35.6% gain from tracker installation
    #26 19596096
    czarodziej1968
    Rate: 28
    Congratulations on the project. It is a pity that you did not provide more details, because the project is interesting.
    zimny8 wrote:
    Costs:
    It would make sense if you could break down the cost of the PV and the cost of the trackers. Perhaps then you would avoid "weak" entries "it is not profitable".
    Oh, I would think twice about it. If you are doing something that is not fully proven at home, then you will hurt yourself at best. Although there is a big option that the storm will tear the panels out and fly somewhere to the neighbor. The factory trackers are numbered and the manufacturer informs you what winds he can withstand. It is a big puzzle in your construction.
    A 40 percent increase in efficiency compared to a fixed installation is quite real. Well, it just depends what you compare to.
    Some of my installations work on trackers, some panels are mounted on the roof. The roof panels face south, almost perfectly, a few steps to the east. The tilt angle is 45 degrees, this is the roof.
    The installation has been in operation for 1.5 years and I have the opportunity to calculate exactly what is the difference between the panels working in exactly the same light conditions. In my case it is 35.6%. The 40% mentioned would be realistic, but on the eastern side, the neighbor has a high hedge that covers some of the lower panels on the tracker in the morning. In the evening, from the west side, I have tall trees that block the sun. On the longest sunny days, my production ends around 20:00, and it could pump for an hour more.
    The installation is on microinverters, I have a preview of each panel and I can calculate exactly how much electricity it gives.
    I would seriously consider some extra security. I see trackers placed on hills. The platform can lie flat, but the wind can bounce off the slope and lift everything up. Today the weather is less and less predictable. I check the weather and if there is any information that there will be strong winds, I put it flat and secure it with solid tapes. The operation takes a few minutes, and I have peace of mind. Besides, I like my neighbors and I wouldn't want my trackers to hurt them. It is also an amateur construction ;)
  • #27 19596202
    zimny8
    Help: 26
    Rate: 504
    Very constructive, helpful, thanks.
    Belts are a great idea, I have where to attach in the 3 points you use, where can I buy?
    It's a pity that I haven't heard of microinverters before.
    How many and what panels do you have, on the tracker and the roof, total power?
  • Profitability question for tilt-only solar tracking
    #28 19597524
    Karol966
    Help: 83
    Rate: 650
    And I have a question, how to calculate the profitability of a tracker that only controls the inclination of the installation? Any single or double axis trackers behave differently (they track the sun), even a single axis tracker follows it. I am considering installing only with the tilt angle adjustment. I have 10 kW (I just poured concrete on the poles), on the front / lower poles I have bearings in housings and PV rails are cross-bolted to them. So you can easily adjust the height (enough on the rear / upper legs) mount the actuators. But does it make economic sense? I have 7 legs, so 7 actuators would be needed, which is PLN 1300 for the drives only. I estimate modestly that as a percentage it could be a greater relative profit in winter than in summer. Initially, I did 30 '(so that this installation was not too "gigantic", but in winter you do not sit on the terrace anyway and it is worth catching every ray of the sun).
    Table showing solar panel efficiency based on tilt and direction.
  • Transport belt recommendation for solar tracker drive
    #29 19597619
    czarodziej1968
    Rate: 28
    I bought a transport belt, something like this https://allegro.pl/oferta/pas-transportowy-2t-2000-kg-100m-25mm-hit-8941168574. I can see that even the price has not changed in over a year :D Can be found in shorter lengths. Other sizes. I recommend :)
    I have 12 305 Wp panels on the trackers, 4 the same panels on the roof, plus the old 4 235 Wp panels, which I installed a few years ago for testing and learning purposes. I wrote about them here: https://www.elektroda.pl/rtvforum/topic2850862.html
    Now it looks like this:
    Solar panels on a green roof of a house.
    Two sets of solar panels on trackers in a garden.
    Two sets of solar panels on tracking mounts in a garden plot.
    Microinverters were a good solution for me, the panels were separated by a good 50m, additionally there is a mixture. I wouldn't get it on the inverter. Another advantage is that I can expand the installation at any time. You just need to buy more panels and another microinverter. I used APSystems YC-1000-3. Three-phase microinverters.
    Watch this video, it might be helpful.
    https://youtu.be/ySJ0VxuKhBs?t=1
    Man has a lot of knowledge when it comes to all calculations. Check out his feed. When it comes to the winter months, I wouldn't be killing myself in any particular way. See the production of my installation per year. November, December and January, a disaster. These are dead months, short days, enough sunshine as medicine.
    Monthly energy production chart in kWh from a photovoltaic installation.
  • Questioning the geometry behind solar tracker efficiency
    #30 19615991
    zimny8
    Help: 26
    Rate: 504
    Kolego czarodziej1968, well, you have grown up pretty among carrots and others ;) .
    Coming back to the already famous picture:
    Can someone describe how it is possible, when the simple geometry shows that the plane on which the sun's rays fall at an angle of 90 degrees is 100%, and for example at 45 degrees it is 50% of its visibility.
    After all, this is what it is about, how large a surface is illuminated.
    Take a piece of paper, twist it and experience what if the piece of paper seems to be illuminated all the time, when the amount of incident solar "rays" at e.g. 45 degrees will be half as much.
    So how does this relate to this graphic?
The discussion revolves around the construction and evaluation of one- and two-axis solar trackers. The original poster shares their DIY designs and seeks feedback on their performance and structural integrity, particularly concerning wind resistance and cable management. Participants express concerns about the practicality and cost-effectiveness of trackers compared to fixed solar panel installations, with some arguing that trackers may not yield sufficient returns on investment. Others highlight the benefits of trackers in maximizing solar energy capture, especially in constrained spaces where additional panels cannot be installed. Various technical aspects are discussed, including the use of specific components like actuators, inverters, and wind sensors, as well as the importance of proper construction to withstand environmental challenges. The conversation also touches on the hobbyist aspect of building trackers for personal satisfaction rather than purely economic reasons.
TL;DR: DIY single-axis trackers raise yield by 35-45 % and a 3 kWp two-axis rig can output about 3 000 kWh a year [Elektroda, zimny8, post #19587306] “Not everything has to pay off; the fun and satisfaction are priceless” [Elektroda, Slawek K., post #19587361] Why it matters: Understanding real-world numbers helps decide when a moving mount beats extra fixed panels.
• Typical single-axis range: 150 °-180 ° sweep, 40 ° fixed tilt [Elektroda, zimny8, post #19585358] • Two-axis tracker yield gain: +35 % to +45 % vs. fixed south-facing array [Elektroda, zimny8, post #19588693] • DIY material cost: PLN 7 000–9 000 for structure + PLN 5 000 inverter (≈€2 600–3 100) [Elektroda, zimny8, post #19585358] • Emergency stow time: ≤40 s for 24" actuators at full travel [Elektroda, zimny8, post #19585689] • Edge case: rail-guided trackers can seize after freezing snow accumulation [Elektroda, alt11, post #19593781]
What power increase can I expect from a tracker in Central Europe?
Forum measurements show about 3 000 kWh per 3 kWp (≈+40 % vs. fixed 2 100 kWh) on a two-axis design [Elektroda, zimny8, post #19587306] Independent studies quote +35 % as typical for Poland [“PVGIS EU”, 2023].
How much does a DIY tracker cost?
Materials for a two-axis steel frame and three actuators ran PLN 9 000 in 2021; adding panels and inverter lifted the full system to ~PLN 21 000 [Elektroda, zimny8, post #19585358]
Is a tracker still economical when panels are cheap?
Payback emerges in ~10 years if the extra structure costs ≤PLN 5 000 and electricity credit is PLN 0.65 /kWh [Elektroda, cefaloid, post #19587332] Higher steel prices or paid labour can erase gains.
What happens if sensors or power fail during a storm?
Edge-case reports show that frozen reed switches or snow-jammed rails can stop stow; manual override buttons and insurance are recommended [Elektroda, alt11, post #19593781]
Which drives and controllers are used?
Builders reuse 24" linear actuators and small 50-100 W gear-motors connected to low-cost multi-channel aquarium timers or Reivision sun trackers [Elektroda, zimny8, #19585358; marik_te, #20810405].
Can I monitor each panel on a moving array?
Yes. Micro-inverters such as APSystems YC-1000-3 mount directly under the table and report per-module data over power-line comms [Elektroda, czarodziej1968, post #19597619]
How tall should the mast be?
A 5 m truss mast built from four 60 × 3 mm tubes provides clearance over nearby roofs while weighing less than a single 320 × 8 mm pipe [Elektroda, bachin, post #20809219]
Do single-axis tilt-only systems pay off?
Tilting for seasons adds ~10 % annual yield; adding east-west tracking boosts to ~35 % [“NREL Best Practices”, 2022]. With seven actuators at PLN 1 300, seasonal tilt often breaks even sooner than full tracking.
How do I compute light loss when panels are off-angle?
Irradiance scales by cos θ; at 45 ° incidence the usable power drops to 71 %, not 50 %, because cos 45 ° = 0.71 [“Solar Engineering”, Duffie & Beckman].
What routine keeps the tracker safe during a gale?
  1. Issue park command to flatten table.
  2. Attach three transport belts to ground anchors.
  3. Verify actuator power off. The whole process takes under five minutes [Elektroda, zimny8, post #19590502]
Will future grid rules favour trackers?
Evening-skewed output smooths feed-in; smaller batteries suffice when production is more evenly spread, lowering storage costs [Elektroda, trojan 12, post #19587382]
