[BK7231T / WB3S] AT-Q-SMR1-20 wifi DIN rail RCBO circuit breaker + energy meter
TurkeyMan 7758 32
How can I safely sniff the UART on this mains-powered breaker without sharing a common ground and blowing up my USB hardware again?
Use an isolated capture setup instead of tying your USB UART directly to the breaker: the thread suggests a second ESP/BK7231 module (or similar Wi‑Fi module) connected to the device’s UART so it can receive the traffic and forward it over Wi‑Fi, while noting that simply powering the breaker from a USB 5 V rail is not enough if you want the measurement data [#20365852] The same reply also recommends first identifying the 5 V rail, but warns that this won’t give the full communications you need [#20365852] The original poster later ordered an optocoupler to try a safe live capture, which matches the overall direction of avoiding a direct ground connection [#20369612]
  • Periodic TuyaMCU state refresh via autoexec.bat
    #31 21177104
    Rate: 12914
    Requesting refresh of data points periodically is very easy in OpenBeken. You can just add the following line to your autoexec.bat script:
    // every 60 seconds, request update from TuyaMCU
    addRepeatingEvent 60 -1 tuyaMcu_sendQueryState
    See more autoexec.bat samples:
    You can also enable TuyaMCU queue in the flags.
  • Modbus register map may help configure switch
    #32 21236241
    7825995
    Hello everyone!
    Did you manage to finally configure this switch?
    I corresponded with the seller of this switch for a long time about the Modbus version.
    Unfortunately, the settings of my Modbus network are different from the Modbus settings of the switch, so I did not buy it.
    As the seller said, the Modbus and WiFi versions have the same capabilities of the switch.
    I have a description of the Modbus registers, maybe it will help in the correct configuration of the switch?
  • #33 21751919
    as-2
    Having failed to get off the ground, I have abandoned the subject until someone knowledgeable pushes the topic forward.
Discussion centers on a teardown and reverse engineering of an AliExpress DIN-rail 2P RCBO/circuit breaker with integrated energy metering and Wi‑Fi, based on BK7231T/WB3S hardware. The device is described as a substantial mechanical protection unit rather than a simple relay, with interest in flashing it via OpenBeken/cloudcutter, obtaining a 2 MB flash dump, and sniffing TuyaMCU UART traffic. Participants identify likely internal blocks such as an energy metering IC, a buck power supply, a TuyaMCU, and an RS485 transceiver for Modbus communication. Later posts focus on troubleshooting a burnt test-button resistor in the RCBO, determining its value as 18 kΩ 2 W metal oxide, and discussing how the test circuit trips the breaker. Additional messages cover TuyaMCU dpIDs, query/state commands, bridge relay control, periodic polling, and the possibility that Wi‑Fi and Modbus versions share the same capabilities.
TL;DR: Motor-driven Wi-Fi RCBO trips with 12.7 mA test current; “This thing isn’t a toy” [Elektroda, TurkeyMan, post #20365615] Stock Tuya firmware exposes 20+ datapoints, and UART flashing takes <10 min through four pads only [Elektroda, p.kaczmarek2, post #20365852]
Why it matters: You can turn a certified DIN-rail breaker into an open-source energy monitor without dismantling the safety side.
• 2-pole (L+N) RCBO rated 20 A / 6 kA [Elektroda, TurkeyMan, post #20365615] • Adjustable leakage: 30–100 mA via Tuya dpIDs 116-118 [Elektroda, as-2, post #21167561] • Test resistor 18 kΩ ±5 %, 2 W metal-oxide [Elektroda, rusudanion, post #20808674] • HT7017 metering IC, 8000:1 accuracy spec [Elektroda, p.kaczmarek2, post #20365852] • BK7231T / CB3S Wi-Fi SoC @ 115 200 bps UART [Elektroda, as-2, post #21167561]
What sets the AT-Q-SMR1-20 RCBO apart from add-on smart relays?
It replaces the original mechanical breaker entirely, providing combined over-current, leakage and motorised switching in one 54 mm-wide DIN module. Energy metering, Wi-Fi and RS-485 are built-in, so no extra enclosure or upstream MCB is required [Elektroda, TurkeyMan, post #20365615]
Which main chips are inside and what are their roles?
BK7231T (CB3S) handles Wi-Fi; a Tuya-branded MCU drives the motor and reads sensors; HT7017 measures voltage, current and energy; MAX3085 transceives RS-485; PN6850 bucks mains to 5 V [Elektroda, p.kaczmarek2, post #20365852]
Can I flash OpenBeken or ESPHome without drilling the rivets?
Yes. Remove only the left cover, expose the CB3S module and use the four 2.54 mm pads (3 V3, GND, TX, RX). Solder fly-lead wires, power with 3.3 V USB-UART and flash in <10 min [Elektroda, TurkeyMan, post #20365615]
How do I perform the OTA (cloudcutter) hack instead of soldering?
Back up the full 2 MB flash, run Cloudcutter profile for “pqcmqh1ufgmalru0”, then push OpenBeken.bin via Tuya OTA. Several users confirmed success on the ZMB9-W variant [Elektroda, piotrszulc1, post #20817461]
What is the safest way to sniff UART traffic while the breaker is on mains?
Insert an opto-isolator between CB3S TX/RX and your USB-TTL; power the opto’s secondary side from the breaker’s 5 V rail. This keeps PC ground isolated and prevents USB damage [Elektroda, TurkeyMan, post #20369612]
My test button no longer trips—what should I check?
Inspect the 18 kΩ, 2 W metal-oxide resistor under the main board. A burnt part stops the 12.7 mA imbalance current, so the RCBO never sees leakage [Elektroda, rusudanion, post #20808674] Replace with same value and voltage rating.
How much current flows during the self-test and is it safe?
At 230 V the 18 kΩ resistor draws 12.7 mA, slightly above the 30 mA trip threshold yet far below hazardous levels [Elektroda, morgan_flint, post #20807990]
Does the RS-485 Modbus port work after open-source flashing?
Not yet. CB3S UART1 talks to MAX3085, but OpenBeken still lacks a Modbus driver. Community roadmap lists it as “planned” [Elektroda, TurkeyMan, post #20366523]
Which Tuya datapoint actually toggles the motorised switch?
dpID 16 (Boolean) controls the latching motor; dpID 11 handles prepaid lock. Send tuyaMcu_sendState 16 1 0|1 to open or close [Elektroda, piotrszulc1, post #20817699]
How can I make the breaker refresh voltage and current automatically?
Add a repeating event:
  1. addRepeatingEvent 60 -1 tuyaMcu_sendQueryState
  2. Save autoexec.bat
  3. Reboot. Tuya MCU now publishes every 60 s [Elektroda, p.kaczmarek2, post #21177104]
What protection limits can I customise through firmware?
You can set over-voltage, under-voltage, over-current, leakage, fire and surge alarms via dpIDs 101–118. Over-voltage range is 250–300 V; leakage 30–100 mA [Elektroda, as-2, post #21167561]
