Miboxer FUT036w and CB3s Issues: Flashing Firmware, WiFi Connectivity, and Button Control
mplum 7437 61
  • #61 20578995
    What kind of configuration? The OBK CFG does not contain LittleFS autoexec.bat.
  • #62 20579024
    mplum
    i know. the little fs file i have send later.
    I know the problem. is the same with Flag 12. when i read OBK with active Flag 12 and then i transfer it to a new controller. then i can't switch or dimm. the led going not on. When i deactivate flag12 and reboot then is working, when i then activate flag 12 and before the restart i switch the led and dimm up and down then after the restart all is OK.
The discussion revolves around issues faced with the Miboxer FUT036w LED controller after flashing it with the ObenBK firmware. Users report successful WiFi connectivity and MQTT integration but encounter problems with web control and button functionality. The conversation highlights the complexity of the TuyaMCU protocol, the need for proper PWM pin connections to MOSFETs for effective light control, and the challenges of managing internal pull-up resistors affecting button operations. Solutions proposed include using a single PWM to control multiple MOSFETs, modifying button behavior through scripts, and addressing firmware bugs. Users also discuss the potential for connecting 1-wire sensors and the importance of maintaining device state across reboots. The conversation concludes with considerations for device configuration and the implications of using Flag 12 for state saving.
Summary generated by the language model.
