TL;DR: This FAQ helps collectors and restorers fix a 4-band Unitra Ludwik DMT-408. One expert called it a “Jubilat-like radio,” which fits the thread: it uses a simple Diora-family design, often shows old FM retuning attempts, and needs careful voltage, coil, and UL1402 checks before restoration. [#21012552]
Why it matters: The thread turns scattered repair comments into a practical guide for safely opening, diagnosing, and judging whether a Ludwik DMT-408 is worth restoring.
| Model |
Circuit relationship in the thread |
Practical takeaway |
| Ludwik DMT-408 |
Later version with UL1402 audio IC |
Distinctive kitchen-radio styling, but mixed opinions on performance |
| DMT-405 |
Earlier version from 1972 with transistor audio amp |
Useful reference if your set is the older transistor variant |
| Jubilat |
Repeatedly described as the closest relative |
Best schematic fallback when Ludwik details are missing |
| Taraban / Adam / Gong |
Mentioned as comparable Polish sets |
Often preferred for everyday listening or collection appeal |
Key insight: The Ludwik DMT-408 is less about raw performance and more about serviceable vintage design. The safest restoration path is basic cleaning, power-supply checks, speaker inspection, and very cautious FM-head tuning with the correct tool.
- The Ludwik DMT-408 is described as a 4-band receiver covering long wave, medium wave, short wave, and UKF/FM, with the 1974 schematic using a UL1402 audio amplifier IC. [#20728901]
- The set uses a 50 Hz Unitra Zatra mains transformer, and one visible control is a Telpod potentiometer marked 10 kΩ, 0.1 W. [#20728901]
- An earlier Ludwik DMT-405 version from 1972 used transistor audio amplification instead of the UL1402 IC. [#20728901]
- The rear FM antenna inputs are described as 300 ohms, while the ferrite rod handles some AM work internally and the magnetofon socket serves record/playback functions. [#21016358]
- Users gave concrete FM crowding examples at 92.0/92.3 MHz and 95.1/95.6 MHz, showing why older Diora-family heads can struggle beside newer ceramic-filter receivers. [#20729865]
How do you disassemble a Unitra Ludwik DMT-408 safely to slide out the front panel and access the PCB and mains transformer?
You first free the PCB and the mains transformer, then slide the whole front-and-electronics assembly out of the cabinet. Use this order: 1. Disconnect mains power and remove the back if present. 2. Release the PCB and the separate 50 Hz transformer mountings. 3. Slide the front section out without forcing the dial or ferrite rod. The thread photos show this exact sequence and confirm the transformer is mounted separately from the main board.
[#20728901]
What is the Unitra Ludwik DMT-408 cabinet actually made of: wood, bakelite, or plastic?
The cabinet is described in the thread as plastic, not wood or bakelite. One poster directly states that “the casing is plastic,” while another questioned whether it might be wood because no veneer was visible. That means the safest reading from the discussion is molded plastic with a wood-like appearance, not a veneered wooden shell.
[#20729630]
Why do so many Ludwik and Jubilat-style radios show signs of previous FM retuning or improvised coil modifications?
They show these signs because many sets were retuned from the old FM band to the newer one, often by improvised repair work. One comment says the radios lived through the 1970s and then the 1990s, when “everyone tuned to the western band.” Another post points to missing shields, altered coils, and changed winding geometry in a Ludwik/Jubilat-type FM head, which are classic traces of earlier retuning attempts.
[#20729780]
What is the UL1402 in the Unitra Ludwik DMT-408, and what role does it play in the audio amplifier section?
The UL1402 is the Ludwik DMT-408’s low-power audio amplifier IC. The opening post identifies the IC on the board and states that the 1974 DMT-408 schematic uses UL1402 for the m.cz. amplifier, while the older DMT-405 used transistor audio stages instead. “UL1402 is a low-power amplifier integrated circuit that drives the radio’s speaker output, replacing a discrete transistor power stage.”
[#20728901]
What is an Isostat switch in old Unitra radios, and how does it work in the band selector?
An Isostat switch is the coupled pushbutton switch assembly used to change functions and wavebands. The thread shows “coupled Isostat switches” in the Ludwik. “Isostat is a multi-section mechanical switch that changes several circuits at once, using linked pushbuttons to route RF, oscillator, and audio paths for each selected band.” That is why one button can switch the set from AM to UKF or to another input path.
[#20728901]
Why is FM reception on the Ludwik DMT-408 described as having poor sensitivity or selectivity compared with newer receivers?
It is described that way because the FM head is an older, simpler design without the filtering margin of newer receivers. One poster says weak FM stations at 92.0 and 92.3 MHz can merge into a mix on this set, while a better receiver with a ceramic filter can separate them. Another poster calls the UKF head “a mess,” which matches the thread’s view that this is a budget Diora-family front end, not a high-selectivity design.
[#20729865]
How does the Ludwik DMT-408 compare with Jubilat, Taraban, Adam, and Gong radios in circuit design and everyday usability?
The Ludwik is presented as a close relative of the Jubilat and a simpler, less favored everyday radio than Adam or Gong. Multiple comments call it “Jubilat-like” or say the rest of the circuit is identical to a budget design derived from Jubilat. Taraban appears as a comparable Polish portable, while one poster says he would definitely prefer Adam and Gong. In practice, the thread treats Ludwik as historically interesting but not the strongest daily listener.
[#21012552]
What should I check first when restoring a dusty Unitra Ludwik DMT-408, including power supply voltages, speaker condition, and the UKF head?
Start with cleaning, power-supply voltages, the speaker, and the UKF head. Use this order: 1. Remove dust and inspect for burnt solder joints or missing shields. 2. Measure the power-supply outputs from the TS 20 transformer section before deeper work. 3. Check the speaker cone for holes and inspect the UKF head for prior retuning damage. The thread also warns that a bad UL1402 and altered FM coils are common trouble spots.
[#21104474]
How can I tell whether the extra components soldered on the underside of a Ludwik DMT-408 PCB are factory tweaks or later repair modifications?
You tell by comparing solder quality, placement, and whether the added part matches known weak points. One poster says some underside parts may be factory “tweaks,” but the capacitor tied to the UL1402 pins and the IC itself look like later repair work because of burn marks and rough soldering. Another later comment says the underside add-ons were the “creative invention” of a person attempting a repair.
[#20729460]
Why were UL1402, UL1403, and UL1405 amplifier ICs considered failure-prone, and what replacement or socketing practices do restorers use?
They were considered failure-prone because they tolerated overloads and overvoltage badly, even in robust-looking packages. The thread says UL1402, UL1403, and UL1405 were “not very durable,” and another post adds they were sensitive when supply voltage rose above catalog values, especially after switching to 230 V mains. Restorers sometimes fit a noval tube socket because its pin spacing matches the UL140x family, letting them swap ICs without damaging the laminate.
[#20729925]
What are the rear sockets on the Unitra Ludwik DMT-408 actually for, and how do the AM, FM, and tape or magnetofon connections differ?
They are mainly antenna and magnetofon connections, not two identical audio jacks. One reply corrects the first post and says both pictured rear sockets are for antennas. A later explanation adds that the FM inputs were for 300 ohms, AM external antenna use was mainly for long wave, and the magnetofon socket handled record and playback. The ferrite antenna already covered some AM reception internally.
[#21016358]
How do you retune a Ludwik DMT-408 from the old OIRT FM band to the newer band without damaging the coils or threaded air trimmers?
You retune it very cautiously, because damaged coils or trimmers create more work than the band conversion itself. The thread says Diora-family sets can be tuned to the newer FM band, but warns that one wrong adjustment can force coil repair from the underside. A practical sequence is: 1. Clean the FM head. 2. Confirm correct supply voltages. 3. Adjust only with the proper tuner and stop if a core binds. That avoids turning a routine retune into a soldering job.
[#21104474]
What tool should be used for tuning the triangular-core coils in old Diora and Unitra FM heads, and what goes wrong with the wrong tool?
Use a triangular tuning tool. One poster gives a direct warning that the tuner “has to be triangular,” otherwise you can damage the core and end up soldering coils and trying to reach them from underneath. That failure mode matters on old paper-laminate boards, because the repair becomes tedious even if the board uses forgiving SnPb solder.
[#21104474]
Why do shortwave stations seem to drift or 'float' on radios like the Ludwik DMT-408, and how much of that is radio instability versus ionospheric effects?
They seem to float for two reasons: receiver instability and propagation effects, but the thread specifically corrects the cause toward the ionosphere. One poster first blamed KF heterodyne stability, then another clarified that shortwave stations drift mainly because reflections from the ionosphere change path length and produce small Doppler shifts. The same thread notes the Ludwik’s shortwave span is broad, about 40 to 31 m, which also makes fine tuning touchy.
[#20730853]
What is a ferrite antenna in a vintage Unitra receiver, and how does it differ from the external AM and FM antenna inputs?
A ferrite antenna is the internal rod antenna used for AM reception, while the rear sockets accept external antennas for other bands. The opening post points out the ferrite antenna inside the set, and a later explanation says the AM sockets were mainly for long wave because long and medium wave were otherwise handled by the ferrite rod. “Ferrite antenna is a magnetic rod antenna that receives AM bands inside the cabinet, unlike external FM or long-wire inputs connected at the rear panel.”
[#21016358]
