Nie, dziękuję Przekieruj mnie tammax-bit wrote:A tunable filter would be too "coarse", of course it would be gratuitous, but it would be an excess of form over substance.
Unless someone wants to do DX on DAB+, in which case a general amplifier filter is made first, then a narrow-band tunable filter and once again amp, then we have approximately +40 dB of gain with narrow-band filtering.
If we combined it with a directional DAB antenna, things would get bigger.
Then all that remains is to set up a DAB DX club
max-bit wrote:
Although there is a small problem how to synchronize it with the receiver... (scan function).
TL;DR: With ~20 dB gain and the claim that "the parameters are quite good," this Mini-Circuits DAB+ preamp/filter targets hobbyists who need cleaner Band III reception than a bare single-chip receiver front end can deliver, especially where hills, weak front ends, and local interference cause dropouts. [#20980128]
Why it matters: DAB+ often fails because antenna, receiver front end, propagation, and local interference all interact, so a filtered preamplifier helps only when it fits the real bottleneck.
| Option | What the thread says | Concrete figures |
| Bare DAB receiver | Often uses a very simple single-chip front end with little or no input filtering | "zero input filters" was the design complaint [#20980128] |
| This CMA-5043 + RBP-204 design | Adds gain plus out-of-band filtering without tuning | ~20 dB gain, min. 30 dB filtering outside band [#20980128] |
| Better antenna only | Often the first improvement to try, especially at home | Example suggestion: dedicated DAB antenna instead of X-300 compromise [#20985186] |
| DX-oriented tuned setup | Can outperform a general Band III preamp for chasing distant muxes | Approx. +40 dB with amp + narrow filter + amp chain [#20988426] |
Key insight: This design improves DAB+ most when the receiver front end is weak or overloaded. It cannot defeat terrain blocking, poor indoor signal levels, or noisy LED power supplies by itself. [#20990904]
