  • Dreame V9 cordless hoover battery regeneration replaces ageing 18650 cells in the original pack after runtime dropped sharply.
  • Samsung 18650 25S cells were fitted, with a spare battery temporarily connected in parallel to fool the BMS during the swap.
  • The new Samsung 18650 25S cells are rated 2500 mah 25A, versus the original 18650 25R at 2500 mah 20A.
  • Matching cells should sit at 4.10-4.15V and differ by no more than 0.05V; the rebuilt battery works, but disconnecting cells can lock the BMS and light the red LED.
  • #31 21301943
    krzbor
    Help: 42
    Rate: 1072
    speedy9 wrote:
    I assure you it saves such events for itself.
    How does it supposedly save if there is no power? For me, either the processor responds to a reboot (you wrote that it doesn't), or it saves something in flash/eeprom. However, in order to save something it has to work. Without power it won't save anything.
  • BMS capacity learning may still limit runtime
    #32 21302040
    elektryku5
    Help: 460
    Rate: 1055
    What difference does it make whether the processor registers a reboot event or a power outage, if the effect will be the same?
    krzbor wrote:
    It could find that processor and cut power to it, replace the batteries and connect the power supply?
    You'll cut off a leg of let's say VCC to it, and it can still parasitically power up from some IO pin.
    I've also encountered such a behaviour of the BMS (this time from a laptop), that although unplugging it from the cells didn't block it completely, but despite replacing them the laptop died after the same time as on the old worn-out ones, because it already had the learned capacity of the cells, the number of cycles and a lot of other parameters (I recommend datasheets of BQ series chips).
  • #33 21302682
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2424
    Exactly. @krzbor read more about the subject. There is a lot of material and the topic is a river.
  • Battery controller can be replaced independently
    #34 21367595
    rafalekrav40
    Rate: 12
    I have been through the subject of this hoover and confirm everything written above. When even one cell is disconnected, the controller locks up, the red LED lights up and you can throw the battery in the bin. I have searched all over the internet and have not found a solution for this. A new battery costs so much that a replacement is unlikely to be worthwhile. I would just like to add, because no one mentioned it: the battery controller does not communicate with the hoover in any way, so if the battery is stuck, you can buy another controller, another battery and by applying the same power, the hoover will start normally.
  • #35 21397278
    MariuCh
    Rate: 24
    >>21246622 .
    Hello and many thanks for the description.
    I have a follow up question though - how (directions) do you take apart the housing of these batteries? I'm trying and I'm not sure if there are latches somewhere or if it's glued together? I would be grateful for a hint.
    Added after 4 [minutes]:
    >>21251708 Hi, has anyone practiced such a proposal instead of using an extra set of batteries? Any comments from such experiences?
  • #36 21397884
    Willy Coyote
    Rate: 37
    I don't know, I'm old ... but is it possible to plug this hoover into a power supply and vacuum with it? It's cordless, but on a thin wire. It used to be possible to play around with battery-powered screwdrivers, but has anyone here given it any thought?
The discussion centers on the battery regeneration and replacement challenges of the Dreame V9 cordless vacuum cleaner. After years of use, the original battery's capacity significantly decreased, prompting attempts to replace the cells with Samsung 18650 25S (2500mAh 25A) cells instead of the original 18650 25R (2500mAh 20A). A key issue identified is the Battery Management System (BMS), which can lock or block the vacuum if it detects irregularities such as cell disconnection or power outages. The BMS contains a processor with non-volatile memory (EEPROM/Flash) that stores charge/discharge cycles and fault events, preventing reuse of the battery without resetting or replacing the BMS. Some users suggest bypassing or resetting the BMS by supplying voltage to individual cells or replacing the BMS module itself, with new BMS units available online (e.g., from AliExpress). However, the original BMS is generally preferred due to communication with the vacuum's electronics. Attempts to power the vacuum directly from a lab power supply or to fool the BMS with voltage dividers have been discussed but with uncertain success. The battery housing is difficult to open, often glued or latched, complicating cell replacement. Overall, the manufacturer’s design discourages user repair by locking the BMS after faults, making battery replacement costly and complex. Some users report partial success by equalizing voltages and reconnecting batteries carefully, but no definitive method to reset the BMS without replacement is confirmed.
