How to Send RAW IR Codes With OpenBeken 1.18.31 for MAXA AC Remote Control
MuriFlavo 2124 16
How can I send the raw IR codes from a MAXA AC remote using OpenBeken 1.18.31 on a Neo IR Remote Control device?
To send the raw MAXA AC codes in OpenBeken, start the IR2 driver, configure it with the correct TX pin 7 using `SetupIR2 50 0.33 0 7 24`, and bind each long raw frame to an alias with `SendIR2` [#21584048][#21583364] Your original `SetupIR2 ... 8 ...` used the wrong pin; after changing the TX pin from 8 to 7, the LEDs started flashing and the command worked [#21584048][#21584260] Then create aliases such as `alias ac_on SendIR2 ...` and `alias ac_off SendIR2 ...`, and expose them on the web UI with `setButtonEnabled`, `setButtonLabel`, and `setButtonCommand` [#21584263][#21584266] For MQTT/Home Assistant control, map those aliases with `addMQTTAlias ac_on ac_on` and `addMQTTAlias ac_off ac_off` [#21584266] The author also noted that IR2 raw sending may not reproduce pulse widths perfectly, so verify the AC still behaves as intended [#21584263]
  • Need help decoding MAXA AC raw IR codes
    #1 21583229
    MuriFlavo
    I have a remote flashed with Version: 1.18.31 My post of flashing : https://www.elektroda.com/rtvforum/topic4103748.html
    I have a chinese brand of ac called MAXA and i want to turn on and of my ac, when looking into the logs of ir remote and blasting the ac remote i get some data but i have no idea what to do with it and the stuff i tried doesn't seem to work (mostly says not like NEC-01-0).
    turns on:
    type: raw
    frequency: 38000
    duty_cycle: 0.330000
    data: 9114 4420 716 1591 716 490 715 490 741 1567 740 1569 740 1569 738 469 736 469 736 1571 736 1572 736 1572 736 469 737 470 736 470 735 470 736 470 736 470 736 470 736 470 736 470 736 470 736 1571 736 1571 737 470 736 471 735 471 736 470 735 470 736 1571 736 471 736 1572 735 470 735 470 736 1572 735 470 736 19904 736 470 736 469 737 470 736 470 736 469 737 470 736 470 736 469 736 470 736 468 736 470 737 470 735 471 736 470 736 470 736 470 737 470 736 470 735 470 736 470 736 470 736 471 735 472 735 470 735 470 735 470 736 470 736 470 735 470 736 1572 735 471 735 1572 735 39914 9084 4398 737 1571 737 469 737 470 736 1572 736 1572 736 1571 736 470 736 470 737 1573 735 1572 736 1572 736 471 735 470 736 470 735 470 738 469 736 470 736 470 736 470 735 470 735 470 736 1573 735 1572 736 470 736 470 736 470 734 471 735 470 735 1572 736 1572 735 1571 736 471 735 470 735 1573 736 471 734 19907 736 469 737 470 736 469 736 471 736 469 736 470 737 470 736 469 736 470 737 470 736 470 736 470 735 470 735 470 736 471 735 471 735 470 735 470 735 470 735 470 736 1573 734 470 736 1571 736 471 735 471 735 470 735 471 736 471 735 1572 735 1573 735 1575 734 1572 735
    turns off:
    type: raw
    frequency: 38000
    data: 9106 4398 731 499 706 500 705 502 702 504 701 505 701 505 701 1606 701 505 701 1607 701 505 701 506 700 1607 700 506 700 506 700 505 700 505 701 506 700 506 700 506 699 506 700 506 700 1607 700 506 700 506 700 506 700 505 701 506 700 506 700 1608 699 506 700 1608 699 506 700 506 700 1608 700 506 700 19941 701 1606 700 505 701 505 701 506 700 505 700 506 700 506 700 506 700 506 700 506 700 506 700 506 700 506 701 506 700 506 700 506 700 506 700 506 700 506 700 506 700 506 700 506 700 506 700 506 700 506 700 506 699 506 700 506 700 1608 700 1607 700 506 700 506 700
    The raw values are from the flipper, the off i got from universal remotes and is apparently from Daichi DA25AVQS1-W
    with IR and RAW features on log level INFO i get:
    Info:IR:IR IR_PulseDistance 0xD21 0xD0B 0 (35 bits)
    Info:IR:IR IR_PulseDistance 0xD21 0xD0B 0 (31 bits)
    with IR and RAW features on log level ALL i get:
    Debug:IR:IR decode returned true, protocol 1
    Debug:IR: Raw-Data=0x2
    Debug:IR: 35 bits
    Debug:IR: LSB first
    Debug:IR:IR decode returned true, protocol PulseDistance (1)
    Debug:IR:IR fire event took 0ms
    Debug:IR: Raw-Data=0x58000100
    Debug:IR: 31 bits
    Debug:IR: LSB first
    Debug:IR: 35 bits
    Debug:IR: LSB first
    Can someone help me make this work, on openbeken, otherwise ill have to buy something with an esp and use tasmota-ir.
    AI: Can you specify the exact hardware or board you're running OpenBeken on (e.g., model of the remote or IR blaster device)?
    (Tuya) Shenzhen Neo IR Remote Control - 5V USB-C (NAS-IR02W6)
    AI: What exact method or commands have you tried in OpenBeken to send the raw IR data—are you using the web interface, MQTT, scripting, or something else? If possible, can you share an example of what you tried?
    using mqtt and log console i tried things like "RAW 9114,4420,..." and some other stuff i didn't note down.
  • OpenBeken autoexec setup for raw IR AC codes
    #2 21583364
    DeDaMrAz
    Help: 34
    Rate: 130
    Use OTA and upload this attached file build for test (!!!)
    Next in create autoexec.bat in LFS and add these lines
    startDriver httpButtons
    StartDriver IR2
    SetupIR2 50 0.33 0 8 24
    alias ac_on SendIR2 9114 4420 716 1591 716 490 715 490 741 1567 740 1569 740 1569 738 469 736 469 736 1571 736 1572 736 1572 736 469 737 470 736 470 735 470 736 470 736 470 736 470 736 470 736 470 736 470 736 1571 736 1571 737 470 736 471 735 471 736 470 735 470 736 1571 736 471 736 1572 735 470 735 470 736 1572 735 470 736 19904 736 470 736 469 737 470 736 470 736 469 737 470 736 470 736 469 736 470 736 468 736 470 737 470 735 471 736 470 736 470 736 470 737 470 736 470 735 470 736 470 736 470 736 471 735 472 735 470 735 470 735 470 736 470 736 470 735 470 736 1572 735 471 735 1572 735 39914 9084 4398 737 1571 737 469 737 470 736 1572 736 1572 736 1571 736 470 736 470 737 1573 735 1572 736 1572 736 471 735 470 736 470 735 470 738 469 736 470 736 470 736 470 735 470 735 470 736 1573 735 1572 736 470 736 470 736 470 734 471 735 470 735 1572 736 1572 735 1571 736 471 735 470 735 1573 736 471 734 19907 736 469 737 470 736 469 736 471 736 469 736 470 737 470 736 469 736 470 737 470 736 470 736 470 735 470 735 470 736 471 735 471 735 470 735 470 735 470 735 470 736 1573 734 470 736 1571 736 471 735 471 735 470 735 471 736 471 735 1572 735 1573 735 1575 734 1572 735
    setButtonEnabled 0 1
    setButtonLabel 0 "Send On"
    setButtonCommand 0 "ac_on"
    on the OBK home page you should get an AC_ON button, press it and confirm with your flipper that it works, or even on your device and report back please.
    • OpenBK7231N_main_d96a66e33a9e.rar (472.04 KB) You must be logged in to download this attachment.
  • No visible IR output despite send logs
    #3 21583983
    MuriFlavo
    >>21583364 So the logs show that it sends stuff, but neither the flipper nor the ac detect anything. Also a thing i noticed is, there doesn't seem to be any light coming from the leds (checking with my phone camera), nor does the console print received ir.
    Info:IR:SendIR2 args len: 569
    Info:IR:Value: 9106
    Info:IR:Value: 4398
    Info:IR:Value: 731
    Info:IR:Value: 499
    Info:IR:Value: 706
    Info:IR:Value: 500
    Info:IR:Value: 705
    Info:IR:Value: 502
    Info:IR:Value: 702
    Info:IR:Value: 504
    Info:IR:Value: 701
    Info:IR:Value: 505
    Info:IR:Value: 701
    Info:IR:Value: 505
    Info:IR:Value: 701
    Info:IR:Value: 1606
    Info:IR:Value: 701
    Info:IR:Value: 505
    Info:IR:Value: 701
    Info:IR:Value: 1607
    Info:IR:Value: 701
    Info:IR:Value: 505
    Info:IR:Value: 701
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 1607
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 505
    Info:IR:Value: 700
    Info:IR:Value: 505
    Info:IR:Value: 701
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 699
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 1607
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 505
    Info:IR:Value: 701
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 1608
    Info:IR:Value: 699
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 1608
    Info:IR:Value: 699
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 1608
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 19941
    Info:IR:Value: 701
    Info:IR:Value: 1606
    Info:IR:Value: 700
    Info:IR:Value: 505
    Info:IR:Value: 701
    Info:IR:Value: 505
    Info:IR:Value: 701
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 505
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 701
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 699
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 1608
    Info:IR:Value: 700
    Info:IR:Value: 1607
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Value: 506
    Info:IR:Value: 700
    Info:IR:Queue size 140
  • #4 21583985
    DeDaMrAz
    Help: 34
    Rate: 130
    Is your OBK pin configuration correct then if no LED's are showing on camera??
    As I can replicate your code and my flipper picks up the unknown code.
    Share more details about the device, pictures maybe?
  • #5 21583996
    MuriFlavo
    >>21583985 Thing is before I flashed your file / yesterday my flipper did detect ir sent from the remote so pinout should be right, and if you want picture they are available in the post which I linked at the start. Ota is the update right? so I can upload the old firmware if I still have it and try if the leds still work?
  • #6 21584006
    DeDaMrAz
    Help: 34
    Rate: 130
    Ok, my bad that I didn't check the original teardown, looks like you have M chip flavor, which should work with the OTA file I gave you....hmmm, let me check.
    OTA (Over The Air) update is the firmware with .rbl extension you can use to change firmware back - yes.
    I'll ping @divadiow as I have no BK7231M (somehow) devices to test maybe he can provide more info?
  • #7 21584013
    MuriFlavo
    this is the file i flashed originally i think
    • OpenBK7231N_QIO_1.18.31.bin (1.16 MB) You must be logged in to download this attachment.
  • #8 21584016
    DeDaMrAz
    Help: 34
    Rate: 130
    That is the UART flash file, via cable, OTA is done from a webapp mostly so no soldering or anything if you already have that flashed.
  • #9 21584022
    Help: 449
    Rate: 918
    DeDaMrAz wrote:
    BK7231M
    Pretty sure it's a misprinted N rather than an actual M. Seemed to be standard Tuya BK7231N affair
  • #10 21584031
    MuriFlavo
    So I flashed back the 1.18.31.rbl and the LEDs flash again...
  • #11 21584039
    DeDaMrAz
    Help: 34
    Rate: 130
    This is the flipper capture I got from my device running that OTA .rbl file.
    • Remote36.rar (566 Bytes) You must be logged in to download this attachment.
  • #12 21584048
    DeDaMrAz
    Help: 34
    Rate: 130
    Ok, takes a while to catch up on it all after being away for 7 months.
    This means Setup IR2 driver <period_in_ms> <duty_cycle_ON> <duty_cycle_OFF> <TXPIN> so you are obviously not on pin 8 but pin 7 as per the teardown @divadiow did with you 😁
    Change the above line to
    And report back.
    Sorry
  • #13 21584260
    MuriFlavo
    >>21584048 OMG IT WORKS!!! Thank you so much, I had no idea what those numbers represented.
    Added after 4 [minutes]:
    So now I can send using these buttons, how do I form the mqtt payload and topic so I can send from homeassistant?
  • OpenBeken button setup for sending RAW IR codes
    #14 21584263
    DeDaMrAz
    Help: 34
    Rate: 130
    So now you have a basic template you can work with;
    alias something <your RAW code>
    setButtonEnabled 1 1 - set button 2 to enable (1, 0 to dissable) (button 2 as first button is enumerated zero)
    setButtonLabel 1 "Send OFF" - this is a button label
    setButtonCommand 1 "something"
    and so on....
    Word of caution, since the AC commands are large and somewhat problematic, be careful and pay attention that they actually do what you want them to. IR2 is not 100% perfect and sending RAW will not replicate your code pulse width for pulse width or 1 for 1 ( as you may se on my flipper IR capture). So just use with caution and pay attention to the device.
  • Raw IR command aliases for MAXA AC remote
    #15 21584266
    MuriFlavo
    >>21584263 this should work, right?
    StartDriver IR2
    alias ac_off SendIR2 9106 4398 731 499 706 500 705 502 702 504 701 505 701 505 701 1606 701 505 701 1607 701 505 701 506 700 1607 700 506 700 506 700 505 700 505 701 506 700 506 700 506 699 506 700 506 700 1607 700 506 700 506 700 506 700 505 701 506 700 506 700 1608 699 506 700 1608 699 506 700 506 700 1608 700 506 700 19941 701 1606 700 505 701 505 701 506 700 505 700 506 700 506 700 506 700 506 700 506 700 506 700 506 700 506 701 506 700 506 700 506 700 506 700 506 700 506 700 506 700 506 700 506 700 506 700 506 700 506 700 506 699 506 700 506 700 1608 700 1607 700 506 700 506 700
    setButtonLabel 1 "Send off"
    setButtonCommand 1 "ac_off"
    Also as far as I can see the ac does what I want it to without doing weird things so for my case it's perfect. thank you.
  • Toshiba AC remote produces only unknown IR codes
    #17 21698705
    cijoml
    Hello I might continue in this tread. I try to catch codes from my Toshiba AC remote however still get nothink:
    Info:IR:IR MQTT publish IR_UNKNOWN 0x0 0 took 0ms
    Info:IR:IR MQTT publish IR_RC5 0x0 0x40 1 (0 bits) took 0ms
    Info:IR:IR MQTT publish IR_UNKNOWN 0x6254649E 0 took 0ms
    Info:IR:IR MQTT publish IR_UNKNOWN 0x399E4D64 0 took 0ms
    Info:IR:IR MQTT publish IR_UNKNOWN 0x30D44A12 0 took 0ms
    Info:IR:IR MQTT publish IR_UNKNOWN 0xFC67298D 0 took 0ms
    Info:IR:IR MQTT publish IR_UNKNOWN 0x4AB0F7B6 0 took 0ms
    Info:IR:IR MQTT publish IR_UNKNOWN 0x6FB84EC5 0 took 0ms
    This is my autoexec:
    startDriver IR2
    startDriver ntp
    ntp_setServer 195.113.144.201
    ntp_timeZoneOfs +1:00
    My IR TX is at pin 7, RX at pin 8
    what do I wrong?
Discussion about sending RAW IR codes with OpenBeken 1.18.31 for a MAXA air conditioner remote. The main issue was that the IR transmitter appeared to send data in logs, but no IR light was visible and the AC did not respond. The solution was to correct the IR2 pin configuration in `SetupIR2`: the device used TX pin 7, not pin 8. After changing `SetupIR2 50 0.33 0 8 24` to `SetupIR2 50 0.33 0 7 24`, the IR LED worked again and the RAW AC command could be sent successfully. The discussion also covered using OTA `.rbl` firmware, creating `autoexec.bat`, defining aliases for RAW IR commands, and configuring `httpButtons` for button-based control. Later, the same thread included a separate question about capturing Toshiba AC remote codes, where IR MQTT logs mostly showed `IR_UNKNOWN` and occasional `IR_RC5`.
TL;DR: Configure OpenBeken IR2 with a 0.33 duty cycle and TX pin 7, then send RAW via aliases/MQTT — "SetupIR2 50 0.33 0 7 24". This resolves no-blink/no-send issues on the NAS-IR02W6. [Elektroda, DeDaMrAz, post #21584048]
Why it matters: It fixes "nothing is transmitted" problems and enables reliable MAXA AC control without extra hardware.
Who this is for: DIYers using OpenBeken 1.18.31 on Tuya NAS-IR02W6 who need to send RAW IR codes (e.g., MAXA/Daichi) and integrate with Home Assistant.
What’s the exact IR2 setup for NAS-IR02W6 to send RAW codes?
Start IR2 and configure: SetupIR2 50 0.33 0 7 24. This sets period, duty, and the correct TX pin. Using pin 7 fixes the no-blink/no-send symptom on NAS-IR02W6. After this, aliases or buttons will transmit reliably. [Elektroda, DeDaMrAz, post #21584048]
What do the SetupIR2 parameters mean?
They are: period_in_ms, duty_cycle_ON, duty_cycle_OFF, TX pin, and RX pin. In the working example, 50 is the period, 0.33 the ON duty, 0 the OFF duty, 7 the TX pin, and 24 the RX pin. Pin 7 is critical for output on NAS-IR02W6. [Elektroda, DeDaMrAz, post #21584048]
How do I send the MAXA AC ON/OFF RAW codes from this thread?
Define aliases that call SendIR2 with your RAW timings, then bind them to buttons or MQTT aliases. Example shows alias ac_on/ac_off and addMQTTAlias lines. Trigger the alias to transmit the full RAW burst. [Elektroda, MuriFlavo, post #21584266]
My IR LEDs don’t blink and Flipper sees nothing, but logs say it sent. How do I fix it?
Set the correct TX pin. On NAS-IR02W6, change SetupIR2 to use TX pin 7. Wrong pin prevents the LED from driving, causing no visible blink or capture. Reconfigure and retry transmission. [Elektroda, DeDaMrAz, post #21584048]
How can I test quickly from the web UI before using MQTT?
Enable httpButtons, create labels, and bind each to an alias calling SendIR2. You’ll see clickable buttons on the OBK homepage. Press a button, and confirm with a Flipper or your AC. [Elektroda, DeDaMrAz, post #21583364]
How do I trigger these aliases from Home Assistant over MQTT?
Expose each alias with addMQTTAlias, then publish that alias name to your OpenBeken MQTT command topic as configured. The example maps ac_on and ac_off directly for simple HA automations. [Elektroda, MuriFlavo, post #21584266]
Do I need to set the 38 kHz carrier shown in Flipper dumps?
You don’t specify carrier in SendIR2. Provide the RAW pulse timings and use the working IR2 setup. The example configuration drives the carrier and transmits correctly without adding a frequency field. [Elektroda, DeDaMrAz, post #21583364]
My logs show IR_PulseDistance frames with 31 or 35 bits. Is that normal?
Yes. AC remotes often send multiple frames or variants per command. The log showed PulseDistance with 31 and 35 bits for the same session. You can still transmit using RAW timings. [Elektroda, MuriFlavo, post #21583229]
Why doesn’t the transmitted RAW exactly match the captured pulses?
IR2 approximates pulse widths when sending RAW. “IR2 is not 100% perfect,” so monitor device behavior and validate with your AC. Use caution and verify outcomes. [Elektroda, DeDaMrAz, post #21584263]
The console shows “Queue size 140.” What should I do?
That indicates a transmission backlog. Avoid spamming commands. Send once, wait for completion, and reduce repeats. If stuck, restart the device to clear the queue. [Elektroda, MuriFlavo, post #21583983]
Does BK7231M vs BK7231N matter for this IR blaster?
Treat this unit as BK7231N. It’s typically a misprinted N, not a true M variant. Use the N-based guidance and configuration. [Elektroda, divadiow, post #21584022]
Can I revert firmware if a test build breaks IR output?
Yes. Use an OTA .rbl to move back to a known-good build through the web app. No soldering is required after initial flashing. [Elektroda, DeDaMrAz, post #21584006]
Can I mix brand codes, like using a Daichi OFF for a MAXA AC?
You can transmit any captured RAW burst. The OFF example came from a Daichi DA25AVQS1-W universal profile and was used as a RAW SendIR2 sequence. [Elektroda, MuriFlavo, post #21583229]
What’s the fastest way to reproduce the working setup?
  1. Start drivers and configure: startDriver httpButtons; StartDriver IR2; SetupIR2 50 0.33 0 7 24.
  2. Create aliases: alias ac_on/ac_off with SendIR2 and your RAW timings.
  3. Add addMQTTAlias or bind buttons, then trigger and verify with Flipper/AC. [Elektroda, MuriFlavo, post #21584266]
