B1SC-WE21 Tuya Bluetooth Downlight dpIDs for ESP32 S3 Integration
holchansgomes 1236 3
  • #1 21316839
    holchansgomes
    Electronic module with LED components and an integrated circuit on a board marked XQ-17072. Close-up of an electronic module with visible components like an integrated circuit and quartz.
    Bought a cheap aliexpress tuya downlight and for my surprise it was a BLE only, im new to all of this, any help? I have esp32 s3's so being a Bluetooth is not that huge of issue, but i without knowing went for it.
  • #2 21316876
    Rate: 12940
    Which device model is that? What kind of information was on the packaging and seller's site?
    It looks like you either bought or was sent a BT-only version by accident.
  • Identified TY-SL-15W and Tuya dpIDs
    #3 21325484
    holchansgomes
    >>21316876 I dont know. Its a generic one from Aliexpress, in Tuya iot plataform it shown as: 8003 pwmRGBCW 5
    The DPs are:
    "code": "switch_led",
    "dp_id": 1,
    "type": "bool",
    "value": false
    "code": "work_mode",
    "dp_id": 2,
    "type": "enum",
    "value": "white"
    "code": "bright_value",
    "dp_id": 3,
    "type": "value",
    "value": 10
    "code": "temp_value",
    "dp_id": 4,
    "type": "value",
    "value": 0
    "code": "countdown",
    "dp_id": 7,
    "type": "value",
    "value": 0
    "code": "colour_data_raw",
    "dp_id": 11,
    "type": "raw"
    "code": "music_data_raw",
    "dp_id": 13,
    "type": "raw"
    "code": "do_not_disturb",
    "dp_id": 34,
    "type": "bool",
    "value": false
    "code": "strip_scene",
    "dp_id": 73,
    "type": "raw"
    "code": "strip_local_timer",
    "dp_id": 75,
    "type": "raw"
    They constantly shows as offline in iot plataform, i guess because i don't have a tuya gateway, but works fine paired to the smartphone.
    I tried to make it work with ha_tuya_ble repo and using my esp32 as a proxy but no luck.
    Product id is: "heflj0rj" category: "dj"
    Edit: found the maker and the model, website is: https://rgbcct.en.alibaba.com/?spm=a2700.shop_plser.88.12.4ae23b1bEypFuD the product is the TY-SL-15W
    Sent them a message asking info about the microcontroller, lets see.
    edit2: also found this https://fccid.io/2BDTU-TY- but the schematics are confidential.
    What now? I desolder it? I should create a topic? Any topic or section that i should read?
  • #4 21624585
    Rate: 12940
    I didn't play yet with this particular device, but here is some related information.
    This is a guide for Tuya: https://www.elektroda.com/rtvforum/topic4110868.html
    Similar device teardown and analysis: https://www.elektroda.com/rtvforum/topic4105891.html
    Here is related experiment with Sonoff BT device and Tasmota as BT gateway: https://www.elektroda.com/news/news4128017.html
