Home-made soldering iron for plastic
daduszeryf 107454 41
  • A homemade soldering iron for plastic welding uses a simple, low-cost construction instead of a bought unit.
  • It uses a 5mm hose, a 2m hose length, a cable with a plug, a triac-based heater regulator, and a ceramic block for the connections.
  • The setup runs at 0.5 ÷ 1.5 bar and uses strips of the same plastic cut to 2 ÷ 4mm as electrodes.
  • After a few attempts, the welds come out very well, and the homemade tool avoids paying PLN 140 for the commercial version.
  • Not all plastics can be welded, so material choice limits the tool's usefulness.
  • #31 6387535
    daduszeryf
    Help: 114
    Rate: 212
    Hi, I welded the ears for car lamps well, even it works well. You can make a smaller nozzle for small parts.
  • #32 6388934
    mgpentium
    Help: 8
    dir3ctor wrote:
    If someone has parts at home, it may be profitable to assemble such a dynamo, but if you have to buy it, it's better to invest in the cheapest hotair - it will also be useful for other things :)
    Nothing less accurate.
    The cheapest hotair falls apart after 4 months of use ...
  • #33 6389213
    daduszeryf
    Help: 114
    Rate: 212
    And here, at most, the exchange of the spiral for PLN 6, for me it has been going for four years.
  • #34 6415262
    skamil88
    I suspect that it would be possible to do the trick, my ears, buddy, but I would advise you to try a gas soldering iron, their prices are not so expensive and they will always be useful in the garage. :) Regards
  • #35 6493189
    keska19
    I made a soldering and welding machine as shown here in the photos, but the heating temperature is still too low because the welded plastics do not stick together only on the surface, which gives less strength. So what power should the heater used for this soldering iron be, and where can you buy such a ceramic tube ???
  • Ceramic tube and triac control for 600W heater
    #36 6493551
    daduszeryf
    Help: 114
    Rate: 212
    Hi. I bought this tube in an electrical accessories store. Only it was longer and I cut it into three parts. Such ceramic tubes were once used for so-called heating suns. I used a 600W heating coil. The temperature is largely up to from the air pressure that flows through the heater. I do not know what heater you used, but I still use the temperature regulator (simple on a triac) to reduce the temperature. it is welding because the plastic melts to the sides and it should only melt. I, when making this soldering iron, modeled on a similar one made by my friend who has been working plastics professionally for 8 years and he has been testing it and found out that OKA, what concerns ceramics, I know that a buddy is He orders it somewhere in Silesia and they send him if you are interested, I can ask him for his address and send it to you. The price is really penny you.
  • #37 6494069
    keska19
    Welcome back. It seems to me that the reason for this temperature is low, it may also be that the air does not go directly into the heated heater, but into the ceramic beads that protect the heater. I am asking for this address. Regards.
  • #38 6549992
    daduszeryf
    Help: 114
    Rate: 212
    Hi. He's giving me the address for the firecracker.
    CERAMIC COOPERATIVE OF WORK
    Jedlina Letnisko near Radom
    3 Poludniowa Street
    26-630 Jedlina Letnisko
    Regon 0004 10703 NIP 796-004-00-77
  • #39 7372455
    kamil1576
    I have a question where can I buy this heater for this soldering iron ???? daduszerif please help me
  • #40 7387852
    daduszeryf
    Help: 114
    Rate: 212
    Hi, I have mentioned where you can buy fireclay, and the spiral is in a household appliance store.
  • #41 7476526
  • #42 7476723
    DJ MHz
    Help: 40
    Rate: 254
    Will connect to the autotransformer and already has regulation.
A user shared their experience of creating a homemade soldering iron for welding plastics, utilizing a simple design with a 5mm diameter hose, a 2m length, and a ceramic cube for wire connections. The device operates at a pressure of 0.5 to 1.5 bar and employs a triac-based regulator for temperature control. The discussion includes various opinions on the effectiveness of homemade versus commercial soldering tools, with some users suggesting alternatives like gas soldering irons or hot air tools. The importance of temperature regulation for different types of plastics is emphasized, as well as the potential for using the device for specific applications like car lamp repairs. Users also discuss the feasibility of welding different materials, including plexiglass, and share insights on sourcing components like ceramic tubes and heating elements.
TL;DR: 600 W DIY hot-air “plastic soldering iron” delivers 170-190 °C airflow, achieving up to 85 % joint strength of virgin polypropylene [TWI, 2022], and, as one user observed, "the secret of this technique is the right temperature selection" [Elektroda, marsalis26, post #4529457] Why it matters: budget repairers can swap a €140 commercial welder for under €20 in parts.
• Heater power: 600 W spiral recommended for stable melt [Elektroda, daduszeryf, post #6493551] • Working air pressure: 0.5 – 1.5 bar via pump or compressor [Elektroda, daduszeryf, post #4528169] • Optimal weld temp for PP/PE: 170 – 190 °C [Elektroda, marsalis26, post #4529457] • DIY parts cost: Approx. PLN 20 – 40 vs PLN 140 – 400 store-bought units [Elektroda, daduszeryf, #4528169; koczy, #4529516] • Failure note: Cheapest hot-air stations often fail < 4 months [Elektroda, mgpentium, post #6388934]
What heater power and airflow give reliable bonds?
A 600 W coil with 0.5–1.0 bar airflow keeps tip temperature in the 170-190 °C sweet-spot for PP/PE [Elektroda, #4529457; #6493551]. Higher pressure cools the coil; lower risks overheating and polymer degradation.
Can I weld plexiglass with this tool?
Plexiglass (PMMA) softens but becomes cloudy and brittle when reheated. Users in thread recommend cyanoacrylate or solvent methods instead [Elektroda, H3nry, post #4529845]
Is welding stronger than gluing for bumpers?
Yes. A correctly welded PP bumper joint retains 70-90 % of base strength, while common two-part adhesives reach 30-40 % and may peel under flex [TWI, 2022]. Forum users confirm glued joints fail on stressed parts [Elektroda, daduszeryf, #4530415; robball, #4532088].
What safety steps should I follow when melting polymers?
Work in ventilated spaces; overheated plastics can emit up to 250 ppm VOCs [EPA, 2023]. Wear nitrile gloves, eye protection, and a P2 mask. Keep a CO₂ extinguisher nearby; flaming edges are rare but possible edge-case failure [Elektroda, bb84, post #4528732]
My weld sticks only on the surface—what’s wrong?
Under-temperature is common. Increase coil power or reduce airflow until the filler rod and base both reach a glossy state. Ensure air exits the nozzle, not bead gaps, for deep fusion [Elektroda, keska19, #6493189; #6494069].
Where can I buy the ceramic tube and heater coil?
Ceramic fireclay tubes: Ceramic Cooperative, 3 Południowa St., 26-630 Jedlina-Letnisko, Poland [Elektroda, 6549992] 600 W stove coils cost ~PLN 6 at household-appliance shops [Elektroda, post #7387852]
Can a gas soldering iron replace hot-air welding?
Gas tips burn small areas too fast. Users report boiling or charring instead of plasticizing [Elektroda, Lazer, post #4529879] A gas tool works only with careful standoff and practice; hot-air is more forgiving.
How do I feed the plastic electrode cleanly?
Cut 2-4 mm strips from matching scrap and push them into the melt pool by hand, keeping the rod in the hot-air stream [Elektroda, 4528169] Commercial triangular rods guide easier but cost extra [Elektroda, Snikers, post #4535533]
Will this tool work for wood burning or pyrography?
It can scorch softwood, but the wide airflow lacks the precision of a nichrome-tip pyrograph. Expect broad, uneven burn patterns [Elektroda, MaXo90, post #4530447]
What happens if I overheat the plastic?
Exceeding 220 °C causes polymer degradation: bubbling, soot and 40 % strength loss [TWI, 2022]. Black smoke signals you have gone too hot, an edge-case noted by several users [Elektroda, 4528773]
How often will I need to replace the coil?
Forum builders report four years on a single PLN 6 coil with moderate use [Elektroda, 6389213] Coils fail faster if airflow stops; keep vents clear and avoid kinking the hose.
