LN8825B Flashdump Resources, UART Pinout, and OTA Web App for Lightning Semi LN8825
divadiow 255 5
  • #1 21809651
    A new thread for Lightning Semiconductor (上海亮牛半导体科技有限公司 (Shanghai Liangniu Semiconductor / “亮牛半导体”)) LN8825 development.
    @insmod first revealed evidence of development here https://www.elektroda.com/rtvforum/topic4147664-150.html#21804979 then later OpenLN8825 PR appeared https://github.com/openshwprojects/OpenBK7231T_App/pull/1946
    LN8825B previously seen :
    https://www.elektroda.com/rtvforum/topic4023264.html
    https://www.elektroda.com/rtvforum/topic4089301.html
    Current Flashdumps :
    https://github.com/openshwprojects/FlashDumps/tree/main/IoT/LN8825B
    OpenLN8825 web interface with system details and control buttons
    Quick ref:
    A10 grounded at power-on - download mode
    Flash program B8 - U0RXD, B9 - U0TXD
    B6 - U1RX, B7 - U1TX
    Pinout diagram of the LN8825B IC with labeled pins and central GND marking
    LN8825 programmable I/O table showing GPIO, logic levels, and default directions
    Added after 7 [minutes]:
    for LN8825 ota in web app https://github.com/OpenBekenIOT/webapp/pull/256
  • #2 21810219
    OpenLN8825 boot log
    Added after 2 [hours] 4 [minutes]:
    omg. one of the 3 LN8825B Tuya RGB controllers I've owned over the last 2 years IS still viable. I thought I'd killed them all
    Terminal showing LN8825 OpenBeken boot logs and Easy Flasher interface with flash status
    LN8825 electronic module with connected wires on blue mat
    Added after 9 [hours] 29 [minutes]:
    soldered and cleaned back up ready for PWM test. need to go out for a bit. coloured cables didn't match PCB marking from factory, so kept that.
    OTA 1946_merge_8775a20909f8 -> 1946_merge_07e9bff1fbb6 ✅
    OpenLN8825 device web panel with system status and control buttons Two PCB boards with Wi-Fi modules and wires soldered to labeled pins
    looks like IR has resistors and capacitor too so could try that out. could bridge resistors on CW and WW too I guess for other IO use
    Added after 3 [hours] 10 [minutes]:
    well, LLM was correct with these IOs being in use on this device (not from KV extraction). With my 3-pin strip I immediately get R, G and B to match:
    R=A11, G=A8, B=A7
    but only if I use GPIO dr to pull each high. As PWM the colours don't change much, even with LED tools. Power on/off button is not effective - the colours change a little instead.
    Added after 11 [hours] 1 [minutes]:
    1946_merge_07e9bff1fbb6 -> 1946_merge_4e2cdfd460bc ✅
    PWM looks good now! dimmer too
    Added after 5 [minutes]:
    getting something - A9
    Level 30  
    I think LN pr can be merged.
    IR recv works fine.
    IR send seems to work fine (esphome IR receives what i sent), but i doubt that anyone would be using it.
    There's also LN882H SDK update (the only important thing is wifi lib, 1.5.0->1.6.0).
    Plus i added sockets count and idle hook.
    https://github.com/openshwprojects/OpenLN882H/pull/22
    Shall i merge it into LN8825 pr, or do it in separate one?
    I tested it, and nothing is broken.
  • #4 21812120
    very nice
    of course it does. it shipped with IR 🤓
    Level 30  
    Just a notice for the future - cloudcutter won't be supported, because partition layout is different (and .ld subsequently)
  • #6 21819507
    LN8825B OTA listing
    OTA to release worked
