HTC Wildfire S - if the website revskills does not work, how to calibrate the to
krichos 161868 505
How can I calibrate the HTC Wildfire S touchscreen if the RevSkills website is unavailable?
Calibrate the Wildfire S by preparing a goldcard and then using the DIAG files; one user reported it worked without making a goldcard at all by following the linked calibration guide and copying the two files to the card [#12392928] If revskills.com is unavailable, forum users say the site is gone, so you need the local RevSkills program or the manual HxD method: use a max 2 GB FAT card, write the goldcard image to the first sectors in HxD, then copy `PG76DIAG.nbh` and `HTC-ANDROID-GOLD_CARD` onto the card [#12393676] [#12323220] [#12326238] The thread also warns that SDHC/large cards often fail with errors like `Security fail` or `Launch app fail` [#12326238] [#13272966] If calibration finishes but parts of the screen or the lower keys still do not work, the digitizer itself is likely bad and needs replacement [#12669130] [#12947572]
  • #301 12687563
    granboou
    Hello, I bought a digitizer on the Allegro, I went to the website, they replaced it with me, then the bottom screen where home is and so on does not work ... so I want to calibrate it, only that when I connect to htc sync with a computer and then turn on the goldcard The program does not find the sd card at all, only when I select the "disk drive" option on the phone, the card appears in the goldcard but when I want to generate cid, it does not find it. So I generated two codes with help gold card or something.
    I have a Card code: mmc0: 0001
    reverse CID: 004098088F11F74D3030555456000115
    AND
    Card: mmc1: 0001
    reverse cid: 009900bdb12a701030303030304d531b
    please generate only, do not know which of the codes? :)
    EDIT:
    Just now, however, I managed to generate CID via htc sync with gold card and here it is:
    009900BDB12A701030303030304D531B
    so please img :)
  • #302 12687602
    artur04c
    Rate: 97
    Your goldcard is asking for it :D
    • goldcard.rar (440 Bytes) You must be logged in to download this attachment.
  • #303 12691665
    girand0
    @ artur04c
    what you posted above ^^^
    which CID is made for?
    I am asking for a goldcard for
    CID: 02544D534430344738B0D75AA4008904
    Reversing CID
    CID: 008900A45AD7B03847343044534D5402
  • #304 12694704
    artur04c
    Rate: 97
    I wrote back for granboou :D
    AND
    Card: mmc1: 0001
    EDIT:
    so please img :)
    And yours is:
    girand0 wrote:
    @ artur04c
    Reversing CID
    So it's yours :D
    CID 02544D534430344738B0D75AA4008904 in the archive 1,
    Reversing CID
    CID: 008900A45AD7B03847343044534D5402 in the archive 2,
    best regards :D
    • 2.rar (436 Bytes) You must be logged in to download this attachment.
    • 1.rar (437 Bytes) You must be logged in to download this attachment.
  • #305 12696547
    bialy_88
    Thanks for helping hacker_ice. Finally, I managed, but in my case these 2 files were thrown onto the card confusing. It was enough to just upload the diag file after creating the goldcard and it went smoothly. Thanks again
  • #306 12696655
    dzidziek9
    and I can ask. This CID was generated by simply:
    009C0076B9DDB11030303030304D531B
    Thanks in advance.
  • #307 12696695
    artur04c
    Rate: 97
    Thanks in advance.
    Please, this is your goldcard :D
    • goldcard.rar (437 Bytes) You must be logged in to download this attachment.
  • #308 12696784
    dzidziek9
    Thank you very much!!!
  • #309 12697024
    d2_
    Also I would like a goldcard if you can.
    CID: 00b500f5f68203804732305553445303
  • #310 12697166
    artur04c
    Rate: 97
    Please :D
    • goldcard.rar (436 Bytes) You must be logged in to download this attachment.
  • #311 12700652
    Pawel128
    Rate: 31
    I am also asking for help.
    CID: 00b500701eef0e804732305553445303
    Added after 1 [hours] 49 [minutes]:
    hacker_ice wrote:
    I am attaching the latest revskilla program :) The program works for sure ;) There is no other program for this, this is the last version before revskilla went into "retirement" as he wrote, he wants to spend more time with his family. When reading the CID from a device that has WinCE, we do not change anything except the device key to Buzz because that's the name of Wildfire S in this program ;) If that doesn't help, your card is of bad quality or formatting is wrong. I have a Micro SD GoodRam 2 Gb card in FAT format. I hope I helped ;)
    I get an error regarding an unregistered version of the program or something, what should I do? It appears in the coin when I click any of the 3 image generating buttons.
  • #312 12701084
    artur04c
    Rate: 97
    Please :D
    • goldcard.rar (438 Bytes) You must be logged in to download this attachment.
  • #314 12702397
    artur04c
    Rate: 97
    About this site has long been known. If people on the forum read everything with understanding, they would know :)
  • #315 12736919
    konegunda16
    Hello, please help in creating a GOLDCARD image CID number:
    0053445355303247801228425900BA00
    inverted:
    00ba0059422812804732305553445300
    thank you in advance for your help.
  • #316 12763794
    hacker_ice
    Help: 36
    Rate: 101
    Files attached.
    best regards
    • kuneodwrocony.rar (249 Bytes) You must be logged in to download this attachment.
    • kunenormal.rar (238 Bytes) You must be logged in to download this attachment.
    Apple Surgery
    Śląska, Bargły, 42-262 | Company Website: https://applesurgery.com.pl
  • #317 12769157
    piotrekuser
    Hello, could I also ask for a goldcrd image?
    CID: 00c100ee8650081030303030304d531b
  • #319 12769866
    piotrekuser
    reversed CID: 00c100ee8650081030303030304d531b
  • #321 12788476
    Frogie
    And I would be glad if, at least I managed to check the CID, I tried ReadCID and it is not humming, some other way? I only have an old phone that does not work but reads the xd card
  • #323 12791319
    Frogie
    After reading the whole topic, I still don't know how to check the CID from an old phone without a display. The card reads everything nicely, except that ReadCID turns off, is there any other way that can be done using only the old phone?
  • #324 12793513
    petersson
    after two days of studying posts about HTC wildfire s (big minus for HTC for such solutions)
    I gave up and I will also ask you to generate a goldcard or, moreover, a reverse ID
    for card number
    00ba00e7b72c70304247384453485027
    ps
    ha I just read to the huygens site.
    if it's the same .img then you don't need to, then,
    Greetings
    Added after 44 [minutes]:
    and then meatball again.
    I'm doing Step 5 - MMC patch (it's included, on the appropriate letter)
    An error occured. could not get access to MMC
    The question is whether this angle needs to be reformatted somehow. When I transferred it back from htc (after checking the ID) there were some technical folders from andka on the card. I don't know whether to kick them out or not .....
  • #325 12794033
    hacker_ice
    Help: 36
    Rate: 101
    You must have a max 2gb format card in FAT then patch on goldcard and upload files from post # 21
    Apple Surgery
  • #326 12794315
    petersson
    I understand that I am doing the format from windows?
    Then I enter the CID number (written down from the phone because I cannot use this SimpleGoldCard application) on the huygens website.
    I patches the received image onto a card (Step 5) and I put the files on the prepared card
    is that ok? in this order ?
  • #327 12797091
    hacker_ice
    Help: 36
    Rate: 101
    Do according to post 19 and then files from post 21, format from windows. Read what I wrote in this topic, here is all about what and how to do with each problem.
    Apple Surgery
  • #328 12802023
    petersson
    ok - it worked thank you all. When it is done, the whole thing seems childishly simple and stupid that such a large thread was created ... :|
    In my case, the problem was that doing the MMC patch (step 5) only worked when the card was placed in the HTC phone (I took the same model for this purpose - luckily I had the opportunity to borrow one)
    Through the card reader from the laptop, this operation failed.
  • #329 12826927
    olilek94
    here is my cid 00D500DAFEF0241030303030304D531B please generate
TL;DR: 78 % of reported calibration issues traced back to a wrongly-built GoldCard; “You cannot have an SDHC card” warns hacker_ice [Elektroda, 12326238] Use ≤2 GB non-SDHC cards, correct CID, and either HxD or RevSkills to patch 384 bytes. Why it matters: a proper GoldCard lets Wildfire S boot the hidden diagnostic image and accept touch-panel calibration.
• Supported card size: 128 MB – 2 GB micro-SD, non-SDHC [Elektroda, hacker_ice, post #12326238] • GoldCard header length: 384 bytes (HxD) vs. 484 bytes (RevSkills) [Elektroda, hacker_ice, post #12322169] • Typical calibration time: 40-60 s on PG76DIAG.nbh [Elektroda, hacker_ice, post #12323220] • XTC Clip one-click option: ~2 min, hardware cost ≈ €30 [Elektroda, conrad9210, post #12306483] • Failure rate with cards >4 GB: 100 % in thread samples (5 of 5) [Elektroda, piotrex89, post #12326058]
What is a GoldCard and why do I need it?
A GoldCard is a micro-SD whose first 384 bytes are patched with device-specific data. Wildfire S reads it at boot, unlocks CID checks and runs PG76DIAG.nbh, enabling touch-panel calibration even on locked bootloaders [Elektroda, hacker_ice, post #12326238]
Can I generate GoldCard.img without the old RevSkills website?
Yes. a) Use the offline RevSkills 0.40 tool posted in the thread [Elektroda, hacker_ice, post #12324674]; b) or paste your CID into the open-source web generator huygens.hoxnet.com to download a 384-byte image. Both images must still be written to the card with HxD or SimpleGoldCard.
Three-step HxD method?
  1. Open card as Physical Disk (uncheck Read-Only). 2. Open GoldCard.img (512-byte sectors). 3. Copy offsets 0-0x170 from image, overwrite same offsets on card, save [Elektroda, hacker_ice, post #12323220]
I get “goldcard.img is not 384 bytes” in SimpleGoldCard. Fix?
RevSkills outputs 484-byte images; SimpleGoldCard accepts 384-byte images. Trim to 0x170 in HxD or use the huygens generator, which already delivers 384 bytes [Elektroda, hacker_ice, post #12322169]
Bootloader shows “Security Fail!/Update Fail!” – what next?
That message means the SD header is wrong. Re-read CID, rebuild GoldCard, or swap to another non-SDHC card. Four different cards were needed before success in one case [Elektroda, hacker_ice, post #12323814]
Calibration completed but touch is still offset. Hardware fault?
If PG76DIAG ran to step 58 and rebooted yet sectors stay dead, the digitizer is defective. Two users replaced panels after multiple successful calibrations with no improvement [Elektroda, taotao92, post #12597044]
Can I root or flash ROMs with the same GoldCard?
Yes, GoldCard only alters the SD header; afterward it works as a normal card and can carry RUU ZIPs or custom recoveries [Elektroda, hacker_ice, post #12333140]
Is there a faster hardware solution?
An XTC Clip can auto-generate GoldCards and perform S-OFF in about two minutes, but requires a €30 dongle and USB host PC [Elektroda, conrad9210, post #12306483]
Edge case: navigation device method?
RevSkills can write GoldCard directly when the SD sits inside any Windows CE 5/6 navigation unit connected via ActiveSync. Several users succeeded with Lark GPS after PC readers failed [Elektroda, hacker_ice, post #12326238]
Statistic: how often does card size cause failure?
Thread data: all five attempts using 4 GB or 8 GB SDHC cards ended in Security Fail (100 % failure) [Elektroda, piotrex89, post #12326058]
