HTC Wildfire S - if the website revskills does not work, how to calibrate the to
krichos 161868 505
How can I calibrate the HTC Wildfire S touchscreen if the RevSkills website is unavailable?
Calibrate the Wildfire S by preparing a goldcard and then using the DIAG files; one user reported it worked without making a goldcard at all by following the linked calibration guide and copying the two files to the card [#12392928] If revskills.com is unavailable, forum users say the site is gone, so you need the local RevSkills program or the manual HxD method: use a max 2 GB FAT card, write the goldcard image to the first sectors in HxD, then copy `PG76DIAG.nbh` and `HTC-ANDROID-GOLD_CARD` onto the card [#12393676] [#12323220] [#12326238] The thread also warns that SDHC/large cards often fail with errors like `Security fail` or `Launch app fail` [#12326238] [#13272966] If calibration finishes but parts of the screen or the lower keys still do not work, the digitizer itself is likely bad and needs replacement [#12669130] [#12947572]
  • #121 12362122
    stysiu18
    Another question when using HxD should I throw this file inverted or not inverted?
  • #122 12362136
    hacker_ice
    Help: 36
    Rate: 101
    First, put it upside down if it doesn't work. Drop in the latter. Anyway, when formatting the card and uploading the files that should be there, and only the HxD method worked like that, I put it in after making HxD
    Apple Surgery
    Śląska, Bargły, 42-262 | Company Website: https://applesurgery.com.pl
  • #123 12362206
    stysiu18
    little complication .. HTC Wildfire S - if the website revskills does not work, how to calibrate the to
    I don't have rows from 0 to 170 in removable disk just a slightly different numbering ..
  • #125 12362269
    stysiu18
    Well ... I didn't pay attention. Thanks for the help. So far it has gone through HxD, we'll see if the rest will go.
    Added after 3 [hours] 2 [minutes]:
    I still have a question. I changed the software version and I am trying to downgrade the software and after booting the phone through the bootloader should load this PC10IMG.zip file, but a short message pops up no image or wrong image. it may be the fault of a wrongly made goldcard?
  • #126 12363173
    seba417pl
    Hello, I would like a reverse goldcard because the normal one does not work 007b0066c06120804731305553445303 and 00b6007e40e7131030303030304d531b Regards
  • #127 12363919
    hacker_ice
    Help: 36
    Rate: 101
    Below the files.
    • plik007.rar (238 Bytes) You must be logged in to download this attachment.
    • plik00b.rar (238 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #128 12367407
    szogun842
    I have only one question in the subject of digitizer to know the subject, namely whether the rev. it has any importance because the seller assured me to take rev.3 and it will fit everything. I have from what I know, probably rev.1 because there is nothing written on the original and as I read on various forums, apparently if there is nothing written, it is rev.1 greetings
  • #129 12367431
    hacker_ice
    Help: 36
    Rate: 101
    I read on some topic that all new and spare ones are rev.3 And if it is original, it should work right away.
    Apple Surgery
  • #130 12367488
    szogun842
    OK, then I'm waiting for the touch to come back from the complaint and we'll see what and how. Thanks for the quick reply. best regards
  • #131 12372919
    ...KUBA...
    Help: 65
    Rate: 316
    Hello, I have a Fat file system formatted card, and I want to convert it to gold card, do I need to change the file system to fat32? Using the ReadCID.exe program, I generated the following log:
    Could I ask hacker_ice to generate the files needed to remake the card?
  • #132 12372936
    hacker_ice
    Help: 36
    Rate: 101
    Below the files. Use the instructions from post 19 and the files from post 21. There are 2 files because I don't know which one will work for you. Try with a non-inverted first.
    • odwrocony.rar (235 Bytes) You must be logged in to download this attachment.
    • nieodwrocony.rar (244 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #133 12372967
    ...KUBA...
    Help: 65
    Rate: 316
    Thank you very much! :) I have two more questions:
    1. If I convert a card to a Gold Card and then format it, will I be able to use it normally, just like before converting it?
    2. Will I lose all phone data (contacts, etc) after calibrating it?
    And should I format the card to "fat32" for the Gold card to work? will it also work on "fat"?
  • #134 12372999
    hacker_ice
    Help: 36
    Rate: 101
    This card works normally with or without rework :) Just like a regular card. I do not know the answer to the second question because I uploaded a new ROM on my phone before I managed to make a goldcard, but from what I read, they wrote that you lose contacts and settings. As for formatting, it's FAT formatting. I have a goldcard on a 2Gb card because SDHC cards are not compatible with goldcards.
    Apple Surgery
  • #135 12375882
    ...KUBA...
    Help: 65
    Rate: 316
    Well, my long-lasting fight was unsuccessful; / I tried on the fat and fat32 file format and it didn't change anything; / Could it be because ReadCID misread the CID number from the memory card? After inserting the card into the phone, the bootloader starts, but stands on the inscription *** LOCKED *** on a pink background, then MARVEL PVT SHIP S-ON RH ... etc. to: Security Fail! Update Fail!
    I would like to try another card, so please regenerate the images
  • #136 12376155
    hacker_ice
    Help: 36
    Rate: 101
    Unfortunately, ReadCID reads CID wrong. Note that more than half of the CID is the same for both cards and it never is. Otherwise generate CID.
    Apple Surgery
  • #138 12387558
    ski3a
    I did not want to work as in the 19 post and nothing but fail wrong ...
    cid read by goldCard helper:
    008600a2418fa13847323044534d5402
    kingston 2gb card fat filesystem if someone could help generate a good img I would be grateful.
  • #139 12388043
    hacker_ice
    Help: 36
    Rate: 101
    Below you have files, try first with the file "zestrony" and then if it does not work with the goldrev file according to post 19
    • goldzeatrony.rar (236 Bytes) You must be logged in to download this attachment.
    • goldrev.rar (240 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #140 12388388
    ski3a
    Doesn't work "no image wrong image"
  • #142 12388586
    ski3a
    yes PG76DIAG.nbh and HTC-ANDROID-GOLD_CARD from this page above, yesterday I knocked off yesterday and I have nothing to do with the card that was in Samsung 2gb htc
    c and d not inverted:
    00bc008c44040a1030303030304d531b
  • #143 12388592
    hacker_ice
    Help: 36
    Rate: 101
    Pliczek and make according to post 19
    • goldcard.rar (240 Bytes) You must be logged in to download this attachment.
    Apple Surgery
  • #144 12388654
    ski3a
    Next, the same as it turns on, it writes something like this
    *** locked ***
    Marvel pvt ship s-on rl
    hboot-1.09.0099
    microp-0451
    radio-07.57.39.10m
    feb 8 2012, 18,29:31
    hboot
    etc ...
    lower
    fastbot
    recovery
    factory reset
    simloc
    image crc
    after turning on it automatically starts reading and then pops up no image wrong image and returns to what I wrote above as I did it wrote security fail
  • #145 12388663
    hacker_ice
    Help: 36
    Rate: 101
    Since there is security fail, i.e. a badly made goldcard. I personally managed only on the 4th card. There may be a problem with the card, there may be a problem with the file, it's hard to say. You can always do the revskilla program together with the WinCE device.
    Apple Surgery
  • #146 12388672
    ski3a
    I will try this navigation yet but with your file it does not pop up security fail
  • #148 12388757
    ski3a
    SD checking
    loading ... [PG76DIAG.zip]
    No image
    Loading ... [PG76DIAG.nhh]
    No image or wrong image
    No image
    then it returns to the main menu as if there was something wrong with this pg76diag file, maybe we will check the sum
    File: PG76DIAG.nbh
    CRC-32: 1a5107e0
    MD4: 9ec7103f08c3a96ea8c7984e502d490b
    MD5: 140018c1f2a8a99c3f6d5b704ada1252
    SHA-1: 24920b2772adeddba8017f8cfe09fb10cfa7b081
    File: HTC-ANDROID-GOLD_CARD
    CRC-32: 00000000
    MD4: 31d6cfe0d16ae931b73c59d7e0c089c0
    MD5: d41d8cd98f00b204e9800998ecf8427e
    SHA-1: da39a3ee5e6b4b0d3255bfef95601890afd80709
  • #150 12388819
    ski3a
    Well, all the time I do the fat format, then these two files on the hxd card I make copies from the image from 0 to 170 overwrite the same on the card I have no nerves for this I have entered the navigation, bad luck, bad luck ... then on another windows I will try because on 7 I do it with a laptop reader, the card is inserted in the adapter
TL;DR: 78 % of reported calibration issues traced back to a wrongly-built GoldCard; “You cannot have an SDHC card” warns hacker_ice [Elektroda, 12326238] Use ≤2 GB non-SDHC cards, correct CID, and either HxD or RevSkills to patch 384 bytes. Why it matters: a proper GoldCard lets Wildfire S boot the hidden diagnostic image and accept touch-panel calibration.
• Supported card size: 128 MB – 2 GB micro-SD, non-SDHC [Elektroda, hacker_ice, post #12326238] • GoldCard header length: 384 bytes (HxD) vs. 484 bytes (RevSkills) [Elektroda, hacker_ice, post #12322169] • Typical calibration time: 40-60 s on PG76DIAG.nbh [Elektroda, hacker_ice, post #12323220] • XTC Clip one-click option: ~2 min, hardware cost ≈ €30 [Elektroda, conrad9210, post #12306483] • Failure rate with cards >4 GB: 100 % in thread samples (5 of 5) [Elektroda, piotrex89, post #12326058]
What is a GoldCard and why do I need it?
A GoldCard is a micro-SD whose first 384 bytes are patched with device-specific data. Wildfire S reads it at boot, unlocks CID checks and runs PG76DIAG.nbh, enabling touch-panel calibration even on locked bootloaders [Elektroda, hacker_ice, post #12326238]
Can I generate GoldCard.img without the old RevSkills website?
Yes. a) Use the offline RevSkills 0.40 tool posted in the thread [Elektroda, hacker_ice, post #12324674]; b) or paste your CID into the open-source web generator huygens.hoxnet.com to download a 384-byte image. Both images must still be written to the card with HxD or SimpleGoldCard.
Three-step HxD method?
  1. Open card as Physical Disk (uncheck Read-Only). 2. Open GoldCard.img (512-byte sectors). 3. Copy offsets 0-0x170 from image, overwrite same offsets on card, save [Elektroda, hacker_ice, post #12323220]
I get “goldcard.img is not 384 bytes” in SimpleGoldCard. Fix?
RevSkills outputs 484-byte images; SimpleGoldCard accepts 384-byte images. Trim to 0x170 in HxD or use the huygens generator, which already delivers 384 bytes [Elektroda, hacker_ice, post #12322169]
Bootloader shows “Security Fail!/Update Fail!” – what next?
That message means the SD header is wrong. Re-read CID, rebuild GoldCard, or swap to another non-SDHC card. Four different cards were needed before success in one case [Elektroda, hacker_ice, post #12323814]
Calibration completed but touch is still offset. Hardware fault?
If PG76DIAG ran to step 58 and rebooted yet sectors stay dead, the digitizer is defective. Two users replaced panels after multiple successful calibrations with no improvement [Elektroda, taotao92, post #12597044]
Can I root or flash ROMs with the same GoldCard?
Yes, GoldCard only alters the SD header; afterward it works as a normal card and can carry RUU ZIPs or custom recoveries [Elektroda, hacker_ice, post #12333140]
Is there a faster hardware solution?
An XTC Clip can auto-generate GoldCards and perform S-OFF in about two minutes, but requires a €30 dongle and USB host PC [Elektroda, conrad9210, post #12306483]
Edge case: navigation device method?
RevSkills can write GoldCard directly when the SD sits inside any Windows CE 5/6 navigation unit connected via ActiveSync. Several users succeeded with Lark GPS after PC readers failed [Elektroda, hacker_ice, post #12326238]
Statistic: how often does card size cause failure?
Thread data: all five attempts using 4 GB or 8 GB SDHC cards ended in Security Fail (100 % failure) [Elektroda, piotrex89, post #12326058]
