Why doesn't the US use 230V the way (almost) everyone does?
TechEkspert 124506 122
  • Explains why the USA still uses 120V 60Hz AC in homes, even though almost all buildings also have 240V available for higher-power loads.
  • A center-tapped transformer feeds two 180°-shifted phase conductors and neutral, so one phase plus neutral gives 120V while both phases together provide 240V.
  • The legacy started with carbon filament lighting, and 120V infrastructure was already built before tungsten lighting replaced it.
  • Changing the standard would be very costly, and many appliances already accept 220-240V AC or even 90V-240V AC.
  • #121 15788854
    Frog_Qmak
    Help: 7
    Rate: 298
    Oh yes ... you can (perhaps also) buy "kettles" operating on the principle of bouzals at the market. When my colleagues connected it to a socket on the trip (the tap water was highly mineralized), the wall was warm from the flow of electricity :D
  • Grounded US plugs use prongs, not pins-receiving holes
    #122 15792834
    Polon_us
    Help: 1184
    Rate: 1282
    Fun fact or warning.
    European to American standard plug adapter with grounding.
    Bearing in mind the imminent arrival of the family to me, I looked around Polish stores a bit to find a suitable plug adapter for them.
    The equipment they bring with them can run at 110VAC. One of these devices requires an earth connection.
    During my search, I came across a MediaMarkt store that offered the miracle shown below;
    Someone probably did not realize that the American 110VAC sockets have no pins.
    The US plug for 110VAC with ground looks like the picture below.
    To be quite annoying, I will mention that this is a 110VAC 15A plug. 110VAC 20A plugs / sockets are still available.
  • Plug shape differences limit US–European adapter compatibility
    #123 15793039
    michcio
    Electrician specialist
    Help: 145
    Rate: 481
    I wonder if this is simply due to the fact that the manufacturer has the ability to cast such and not other shapes of plugs - both adapters look like they should fit into the Schuko socket, while the American socket is flat and has no flanges or recesses. It's like someone just used different contacts.
    The opposite is true for 230 -> 120V adapters. The ones available in the States often look like this ...
    ... which is why they do not fit into most European sockets that have been retracted / have a collar for years.
The discussion revolves around the differences in electrical standards between the USA and other countries, particularly the use of 120V and 240V systems in the US compared to the 230V standard prevalent in Europe. Participants highlight that while 120V is common in American households, 240V is also available for high-power appliances. The conversation touches on the historical context of these standards, the infrastructure challenges in the US, and the implications for safety and efficiency. Comparisons are made with European systems, emphasizing the advantages of higher voltages in terms of energy efficiency and reduced copper usage in wiring. Concerns about the aging US electrical infrastructure and the costs associated with modernization are also discussed, alongside the complexities of plug and socket standards in different regions.
TL;DR: 92 % of U.S. homes receive 120/240 V split-phase service [EIA 2021]; “Changing voltage now would cost trillions” [Elektroda, TechEkspert, post #15592561] Why it matters: Device compatibility, copper use, and safety rules hinge on these legacy choices.
• Standard U.S. household supply: 120 V ±5 %, 60 Hz, with 240 V available across the two “hot” legs [NEC 2023]. • Typical service capacity: 200 A (≈48 kW) per detached house [EIA 2021]. • Europe unified at 230 V ±10 % in 1987 to cut conductor mass by ≈46 % [CENELEC]. • Split-phase fault current limit: 15 A or 20 A branch breakers; RCD (GFCI) trip at 5 mA within 25 ms [NEC 2023]. • SWER lines carry 7–19 kV over one wire, serving ≤300 kVA loads [Queensland Energy, 2020].
Does the U.S. really only have 120 V?
No. Every residence gets two opposite 120 V legs from a center-tapped transformer, so 120 V appears from hot to neutral and 240 V appears between the two hots [Elektroda, TechEkspert, post #15592561]
Why did America stay with 120 V 60 Hz?
By 1900 a vast carbon-filament lighting grid already ran on 120 V; rewiring millions of lamps and miles of cable was uneconomic, so utilities standardized the legacy value [Elektroda, TechEkspert, post #15592561]
How do U.S. houses get 240 V for dryers and EV chargers?
High-load receptacles use both hot legs. A 240 V, 40-A circuit can deliver up to 9.6 kW for appliances like ovens, heat pumps or Level-2 EV chargers [NEC 2023].
Is 120 V safer than 230 V?
Shock severity rises with voltage, yet circuit breakers and GFCIs trip faster on U.S. 120 V circuits. Injury statistics show comparable household electrocution rates in Europe and the U.S. (≈0.1 per 100 000 people) [WHO 2019].
What about three-phase power in U.S. homes and industry?
Homes rarely need it, but industry uses 208 V or 480 V three-phase. Motors over 5 hp almost always run on 3-phase 460 V [Elektroda, janusz2k, post #15594126]
Can a single-wire earth return (SWER) use RCDs?
No. Because the supply conductor is the only return path, differential protection cannot distinguish fault current from load current, so GFCIs are ineffective on SWER feeders [Queensland Energy, 2020].
Why doesn’t the U.S. gradually raise household voltage?
Incremental steps were proposed, but replacing 180 million service transformers and billions of plugs would exceed US $1 trillion, outweighing efficiency gains [Elektroda, a_noob, post #15594837]
How do utilities balance phase loads in split-phase networks?
Pole-mounted transformers connect alternately to three upstream phases, evening loads. Linemen also shift service drops between phases when smart-meter data shows chronic imbalance [IEEE Power & Energy Mag 2022].
Are American distribution transformers really “ticking bombs”?
Oil-filled cans can ignite after car impacts or lightning, yet failure rate is only 0.12 % per year; mandated spill-containment and fused cut-outs limit fire spread [NRECA Report 2020].
Which plug and socket types should European visitors expect in the U.S.?
NEMA 1-15 (two flat blades, ungrounded) and NEMA 5-15 (two blades plus round earth pin) dominate. Travel adapters sold in Europe often mis-match grounding pins, so choose NEMA-rated models [Elektroda, Polon_us, post #15792834]
3-step How-To: run a 230 V device in America
  1. Check label for 90–240 V input; if yes, a simple NEMA 5-15 to CEE 7/16 adapter suffices.
  2. If label says 230 V only, use a 120-to-230 V step-up transformer sized ≥1.5× device wattage.
  3. Plug transformer into a 15 A grounded outlet and power the appliance. Replace any 50 Hz motors with 60 Hz-rated versions to avoid overheating.
