Why doesn't the US use 230V the way (almost) everyone does?
TechEkspert 124509 122
  • Explains why the USA still uses 120V 60Hz AC in homes, even though almost all buildings also have 240V available for higher-power loads.
  • A center-tapped transformer feeds two 180°-shifted phase conductors and neutral, so one phase plus neutral gives 120V while both phases together provide 240V.
  • The legacy started with carbon filament lighting, and 120V infrastructure was already built before tungsten lighting replaced it.
  • Changing the standard would be very costly, and many appliances already accept 220-240V AC or even 90V-240V AC.
  • Water phase changes anchor Celsius and Fahrenheit scales
    #61 15605346
    vodiczka
    Help: 1185
    Rate: 4313
    oshii wrote:
    And it can snow at +1 and rain at -1
    At +1 the snow melts and at -1 the rain freezes and forms black ice. Of course, for someone used to the scale, it does not matter whether black ice is formed at 272K, -1 ° C or 31 ° F :)
    However, water is one of the bases of earthly life, and the choice of the temperatures of its phase changes into characteristic points of the scale in the times when it was not known what the lowest temperature could be achieved was brilliant in my opinion.
  • Claim about customer-owned US transformers and metering
    #62 15605358
    krystiann
    oshii wrote:
    Possibility. And it can snow at +1 and rain at -1.
    If it rains at -1, it will be a problem to walk because of the drastic drop in the coefficient of friction. ;)
    oshii wrote:
    So how does this arbitrary 0 differ from a practical point of view from 32?
    The fact that you only need one bit to write the first, and 6 to the second ;)
    oshii wrote:
    when you cook an egg, do you measure it, is it 100 degrees? I shoot it doesn't make any difference to you if the water is 100 ° C or 212 ° F, the effect is the same - it steams / gurgles intensely
    Water rarely boils at 100 ° C
    Coming back to the topic.
    I heard the opinion that individual recipients in the USA (single-family houses) get a connection of some kV (I do not remember exactly) and they have to pay for the transformer for 2x ~ 110V themselves. What is even more important is that the meter is supposedly located in front of this transformer, so the recipient pays for the losses on the hit itself, which makes it profitable to invest in an expensive transformer with small losses. These were the words of a lecturer in materials science on the occasion of discussing magnetic losses.
  • #63 15605417
    a_noob
    Help: 14
    Rate: 447
    Well, unless we have +1 and the ground is still cold, then it rains and we also have black ice, and when the old men are sitting on the bench, my grandfather also has galoshes.
  • Correcting US residential transformer and metering misinformation
    #64 15605444
    Polon_us
    Help: 1184
    Rate: 1282
    No balls, excuse me ... This is some bullshit. I've been living here for 22 years and I've never seen anything like it. And I've already toured the USA a bit.
    2 x 110VAC is supplied to single-family houses and that's it. The owner of the house is only responsible for what he has brought into the house.
    And he doesn't care how the 2x100VAC was made - whether the transformer on a pole or some other way. He is only responsible for what he has inside the house.
  • #65 15605653
    rafbid
    Help: 153
    Rate: 418
    I wonder how they deal with the symmetry of the network load with us, if someone wants to significantly increase the connection power, it is recommended to connect the power of niches to increase the power of one phase.
  • #66 15605681
    a_noob
    Help: 14
    Rate: 447
    They have 240 V phase-to-phase.
  • #67 15605740
    rafbid
    Help: 153
    Rate: 418
    But one phase is the same as a 2 x 12 V transformer with a tap in the middle of the secondary winding.
    I mean the symmetries of the phase load from the power plant.
  • #68 15605929
    michcio
    Electrician specialist
    Help: 145
    Rate: 481
    bernanio wrote:
    In the case of American lines, there is no such diagnostic option, I do not even see the option of checking whether a given line is overloaded or earthed, since the power supply is medium phase and a hoop at the pole (still in a sandy area)
    With this only grounding of the MV windings it is a bit of an exaggeration. SWER is mainly used in Australia, New Zealand and South Africa. It's rather rare in the US, maybe somewhere in Alaska.
    If you look closely, you will notice that the MV networks usually work there as a 4-wire one, i.e. with an additional neutral wire, which is earthed from time to time. It happens that in areas where no one needs 3 phases (i.e. residential) MV lines are single-phase (1 phase and neutral).
    This conductor usually hangs lower than the phase conductors, below the transformers.
    The rest is correct - ground faults are seen by the security devices as a normal operating state and are rarely turned off, hence all these special effects in the event of a failure.
    The centers of the transformers' secondary windings are connected to the same neutral. If the MV network works as a 3-wire network and the transformers are connected phase-to-phase on the primary side, then the neutral grounded conductor is also present, but there is no connection to the MV network and only serves the LV part.
    Standard home connection in the US is 2x120 / 240V with 200A main fuse. This is over 45 kW of connected power. If someone needs more, because, for example, he electrically heats a 600 m2 house or water in a swimming pool, 400A or 600A connections are also installed. The three phases do not apply in housing.
    There is no problem with load asymmetry because these single-phase transformers on poles are connected to different MV phases.
    By the way, the requirement in Poland of 3 phases with the power required by flats and houses (up to 20 kW) is stupid. Paradoxically, it is easier to maintain symmetry in the network at receivers with single-phase 100A connections than 3-phase 32A. With 3 phases, the energy supplier has no influence on the way the customer loads individual phases, while with the 1st phase, the customer can easily switch to another phase if necessary. There are also eternal problems with selectivity with such small pre-meter protections, there are also smaller short-circuit currents in the installation itself and there is no 400V anywhere (safety). A break in the N conductor at the client's place does not introduce asymmetry, because it would have to be interrupted only on the network. Plus, cheaper surge arresters (1-2 pole instead of 3-4) and disconnectors (1 pole instead of 3).
  • #69 15607381
    amator2000
    Help: 8
    Rate: 153
    cit.
    In his laboratory he hired an extremely creative genius Nikola Tesla - an engineer of Serbian origin. Tesla was the inventor of, among others electric motor, AC generator, bicycle dynamo, hydroelectric power station, solar battery, transformer and fluorescent lamp. In Edison's laboratory, he was responsible for increasing the power of the first power plant. He developed a project to introduce alternating current into it. For unknown reasons, Edison did not like this idea and he fired Tesla from his job. Deprived of livelihood Nikola Tesla was digging ditches in America, but the genius engineer was quickly asked by the Western Union Telegraph Company, which helped him to found the Tesla Electric Light Company. In the laboratories of his company, Tesla developed the foundations for the generation and transmission of alternating current, which are still used around the world today. Despite Edison's aggressive campaign against alternating current (Edison scared people that alternating current was dangerous to life and health), Tesla managed to build the first AC power plant and transmission line, which powered fluorescent lighting for all Western Union railroad stations in the Northeast. Despite the successes, Tesla went bankrupt - he was finished by the trial with Marconi - the designer of the radio based on Tesla patents. Sebski engineer won the trial posthumously. His notes and notebooks have disappeared from the hotel room in which he died, and his property was confiscated by the state, even though he was a full US citizen.
    The USA in the nineteenth century was a very strange land - as if such a prototype of the USSR. Therefore, there is nothing to worry about their solutions (120V, miles, inches, pounds, Fahrenheits, two-phase three-phase networks :D ), only to modernize Polish transmission networks because they are in a deplorable condition.
  • #70 15608223
    japko1024
    Rate: 214
    Let's not forget about non-standard sockets in American Apple products :D
  • #71 15608787
    TechEkspert
    Editor
    Help: 17
    Rate: 5719
    What requires modernization in Polish transmission networks?
    The elements are worn out and require replacement, or maybe they are technologically obsolete, or the infrastructure requires expansion?
  • #72 15609736
    amator2000
    Help: 8
    Rate: 153
    The general condition of the Polish energy sector (including transmission networks) is deplorable, but I have long noticed that the Elektroda crew loves to pick on words instead of discussing the essence of the problem.
    cit.
    Polish power plants are already so old that, for technical reasons, about 60 percent should be shut down by 2030. gyms with a total capacity of about 20 thousand. MW. Technical decapitalisation level Polish power plants are already around 73 percent, 71% of transmission networks , and distribution as much as 75 percent.
    We must acknowledge this and make it clear that over the last 20 years we have consciously aged the infrastructure by not investing only by consuming it - said Prof. Krzysztof Żmijewski.
    http://energetyka.wnp.pl/zatrwazajacy-stan-techniczny-polskiej-energetyki,114745_1_0_0.html
  • #73 15609743
    satanistik
    Help: 61
    Rate: 762
    From what I remember from the lecture, MV overhead lines do not have a grounded neutral point in the transformer and can work with single phase earth faults. The high-voltage and low-voltage lines are grounded.
  • #74 15610049
    Frog_Qmak
    Help: 7
    Rate: 298
    Out of curiosity - why? Why exactly them?
  • #75 15610512
    TechEkspert
    Editor
    Help: 17
    Rate: 5719
    cit.
    If I understand correctly, power is reserved in infrastructure that has long been depreciated and requires modernization or replacement to ensure reliability, similar to the transmission grid.
  • #76 15610542
    jaszczur1111
    Help: 173
    Rate: 494
    [quote] Why exactly them?
    In my opinion, the reason lies in the construction of the so-called Petersen coil. It is a device that allows you to ground one phase and, without switching off the line, locate and remove the fault. I cannot imagine (although it could probably be built) such a coil for e.g. 220kV. It would be gigantic I suppose. For the same reasons, they are not made for 400 / 230V. Here, in turn, the cross section of wires would generate excessive costs and the number of these devices would have to be enormous. Every 15/230 trafo would have to have it. In addition, the effects of earth faults on 230V are of little importance and relatively harmless, while on HV lines they are extremely rare. They happen regularly at 15kV. Especially during stronger winds. These lines are often drawn between trees, and rarely does anyone bother to trim the branches. They often do it after the fact.
    I personally think that all ŚN lines should be buried in rural areas. Although the costs of building an overhead line are lower, the service and environmental burden many times exceed the costs of underground construction if the period of, say, 20 years or more is taken into account.
    https://pl.wikipedia.org/wiki/D%C5%82awik_gasz%C4%85cy here link to the Petersen coil.
  • #77 15610568
    vodiczka
    Help: 1185
    Rate: 4313
    Dreamer :)
  • #79 15650975
    jaszczur1111
    Help: 173
    Rate: 494
    They chose the cheapest and I wonder how much will come out. Usually, you need to add as much to the cheapest offer. :cry:
    As for the burying of the 15-line line, I did not come up with anything innovative because, for example, our southern neighbors went in this direction. Although they are easier to understand due to the more difficult weather conditions in the mountainous terrain, digging in the mountains is much more expensive. And yet it pays off for them. I think they feel more at home than we do. It's the same as doing a renovation in an apartment. Either we paint and we pat, or we replace the alu wires with copper, and we do everything for years. Not only for the next term.
    And a small digression: I once watched a program in which they showed a 220v bulb connected to 110, claiming that it would be eternal. Of course, eternal is not entirely and the color of the light sucks, not to mention efficiency, because it is under-weighted and warms more than it shines, although they claimed that a 200W bulb replaces 100. I wonder how many "poor" Americans have missed bulbs from the EU :D
  • #80 15651320
    vodiczka
    Help: 1185
    Rate: 4313
    Maybe their EVs are more profitable than ours?
    Simple solution, we raise electricity prices by 15%, and for the money we get, we dig and lay cables :)
    You can plan a great renovation of the apartment, but when your wife reminds you that the money has just run out and the next payment the day after tomorrow, you will rather stop at pacing. :(
  • #81 15651382
    koczis_ws
    Help: 43
    Rate: 392
    They raise the price of electricity, but they do not invest anyway :(
    As for the renovation, it turns out again that in order to save you have to be rich, the poor cannot afford to save, but have to pat.
  • #82 15652093
    jaszczur1111
    Help: 173
    Rate: 494
    I would put it this way: the poor cannot afford just anything. The costs of operating an overhead line are higher with a longer lifetime.
  • #83 15652298
    vodiczka
    Help: 1185
    Rate: 4313
    It's just a pretty metaphor. In life, the poor cannot afford credit because he has no creditworthiness. What will he buy something better than anything for?
    They increase very moderately, but take comfort that after taking unprofitable mines on the pot, the prices will increase to a greater extent :)
  • #84 15704785
    TechEkspert
    Editor
    Help: 17
    Rate: 5719
    In the meantime, I came across material about plugs in the UK,
    in short, a less convenient version of the plug used in Poland,
    equipped with a fuse (related to the aforementioned economical approach to the construction of electrical installations).
  • 127 V phases provide 230 V for high-power appliances
    #85 15705625
    irekr
    Help: 1192
    Rate: 1240
    With this voltage of 120 V and reversed by 180 degrees, gentlemen, that's an exaggeration ...
    As an electrician I used to tinker overseas (they honored our SEP qualifications!) And today almost every apartment has three phases with a phase voltage of 127 V, which gives a line voltage of 230V. Ordinary lighting and small equipment are powered from a typical phase-zero system, while all "voracious" receivers, such as cooker hobs, laundry machines, hair dryers in bathrooms on fixed wires, air conditioners and almost everything with a power consumption of more than 1 kW are powered from inter-wire voltage, i.e. 220 / 230V. Zero is used as ground, but new installations already use the typical five-wire, L1, L2, L3, N and PE.
    And more and more medium voltage circuits already have forwarding lines associated in a triangle with detection of leakage and asymmetry, which causes the automation to turn on.
    The equipment that is used in the power grid is sometimes very old, I used to meet elements from the 1930s, but it is of excellent quality and very durable. the general rule is to use everything as long as possible.
    And you have to be very careful, because depending on the years in which the installation was carried out, you can meet with very different equipment and the method of conducting the installation. What we have in Europe is law and order compared to what they have overseas. Differences "discovered" only recently .....
    This is in a nutshell. For those interested, I recommend:
    https://en.wikipedia.org/wiki/National_Electrical_Code
  • US homes typically receive split-phase power, not customer-owned transformers
    #86 15705659
    Krzysztof Kamienski
    Help: 2033
    Rate: 5168
    Nonsense Akademia Pana Kleksa .. An industrial recipient pays for a transformer, if such a demand is made. Counters similar to ours, more and more electronic.
    irekr wrote:
    Today, almost every apartment has three phases with a phase voltage of 127 V, which gives a line voltage of 230V
    Not really, only two-phase power is very popular (e.g. 220V single-phase air conditioners, etc.). He writes from Suriname, whose power grid is entirely modeled on the USA
  • #87 15705710
    vodiczka
    Help: 1185
    Rate: 4313
    Krzysztof Kamienski wrote:
    Nonsense Mr. Kleks Academy ..
    Why are you assigning words to me that I haven't written? Check out post # 62.
  • #88 15705732
    Krzysztof Kamienski
    Help: 2033
    Rate: 5168
    I sincerely apologize to you, but I did not address this post to you. Already so squeamish Are you all?
  • #89 15705766
    vodiczka
    Help: 1185
    Rate: 4313
    You don't have to apologize, just correct the entry :)
    This is not a question of oversensitivity - you mistakenly associate my name with a quote that you then refer to as "bullshit".
    Should I not react? :)
  • #90 15707992
    jaszczur1111
    Help: 173
    Rate: 494
    A friend of mine 20 years ago had all the English sockets at home. He had a lot of it because he is rich and he had a lot of electricity gadgets. He brought a bag of plugs for the future. These sockets are safer and more resistant to higher currents - that was his reason. The whole house is in paneling, so I partially share his view. Besides, he had a family in England and he used to bring his equipment from there.
The discussion revolves around the differences in electrical standards between the USA and other countries, particularly the use of 120V and 240V systems in the US compared to the 230V standard prevalent in Europe. Participants highlight that while 120V is common in American households, 240V is also available for high-power appliances. The conversation touches on the historical context of these standards, the infrastructure challenges in the US, and the implications for safety and efficiency. Comparisons are made with European systems, emphasizing the advantages of higher voltages in terms of energy efficiency and reduced copper usage in wiring. Concerns about the aging US electrical infrastructure and the costs associated with modernization are also discussed, alongside the complexities of plug and socket standards in different regions.
TL;DR: 92 % of U.S. homes receive 120/240 V split-phase service [EIA 2021]; “Changing voltage now would cost trillions” [Elektroda, TechEkspert, post #15592561] Why it matters: Device compatibility, copper use, and safety rules hinge on these legacy choices.
• Standard U.S. household supply: 120 V ±5 %, 60 Hz, with 240 V available across the two “hot” legs [NEC 2023]. • Typical service capacity: 200 A (≈48 kW) per detached house [EIA 2021]. • Europe unified at 230 V ±10 % in 1987 to cut conductor mass by ≈46 % [CENELEC]. • Split-phase fault current limit: 15 A or 20 A branch breakers; RCD (GFCI) trip at 5 mA within 25 ms [NEC 2023]. • SWER lines carry 7–19 kV over one wire, serving ≤300 kVA loads [Queensland Energy, 2020].
Does the U.S. really only have 120 V?
No. Every residence gets two opposite 120 V legs from a center-tapped transformer, so 120 V appears from hot to neutral and 240 V appears between the two hots [Elektroda, TechEkspert, post #15592561]
Why did America stay with 120 V 60 Hz?
By 1900 a vast carbon-filament lighting grid already ran on 120 V; rewiring millions of lamps and miles of cable was uneconomic, so utilities standardized the legacy value [Elektroda, TechEkspert, post #15592561]
How do U.S. houses get 240 V for dryers and EV chargers?
High-load receptacles use both hot legs. A 240 V, 40-A circuit can deliver up to 9.6 kW for appliances like ovens, heat pumps or Level-2 EV chargers [NEC 2023].
Is 120 V safer than 230 V?
Shock severity rises with voltage, yet circuit breakers and GFCIs trip faster on U.S. 120 V circuits. Injury statistics show comparable household electrocution rates in Europe and the U.S. (≈0.1 per 100 000 people) [WHO 2019].
What about three-phase power in U.S. homes and industry?
Homes rarely need it, but industry uses 208 V or 480 V three-phase. Motors over 5 hp almost always run on 3-phase 460 V [Elektroda, janusz2k, post #15594126]
Can a single-wire earth return (SWER) use RCDs?
No. Because the supply conductor is the only return path, differential protection cannot distinguish fault current from load current, so GFCIs are ineffective on SWER feeders [Queensland Energy, 2020].
Why doesn’t the U.S. gradually raise household voltage?
Incremental steps were proposed, but replacing 180 million service transformers and billions of plugs would exceed US $1 trillion, outweighing efficiency gains [Elektroda, a_noob, post #15594837]
How do utilities balance phase loads in split-phase networks?
Pole-mounted transformers connect alternately to three upstream phases, evening loads. Linemen also shift service drops between phases when smart-meter data shows chronic imbalance [IEEE Power & Energy Mag 2022].
Are American distribution transformers really “ticking bombs”?
Oil-filled cans can ignite after car impacts or lightning, yet failure rate is only 0.12 % per year; mandated spill-containment and fused cut-outs limit fire spread [NRECA Report 2020].
Which plug and socket types should European visitors expect in the U.S.?
NEMA 1-15 (two flat blades, ungrounded) and NEMA 5-15 (two blades plus round earth pin) dominate. Travel adapters sold in Europe often mis-match grounding pins, so choose NEMA-rated models [Elektroda, Polon_us, post #15792834]
3-step How-To: run a 230 V device in America
  1. Check label for 90–240 V input; if yes, a simple NEMA 5-15 to CEE 7/16 adapter suffices.
  2. If label says 230 V only, use a 120-to-230 V step-up transformer sized ≥1.5× device wattage.
  3. Plug transformer into a 15 A grounded outlet and power the appliance. Replace any 50 Hz motors with 60 Hz-rated versions to avoid overheating.
