Description of the step down converter based on the XL4005
grala1 20730 54
  • A step-down converter based on the XL4005E1 chip was tested, including two bought copies and a comparison with LM2596-based modules.
  • The module uses a multi-turn potentiometer, runs at 300kHz, accepts up to 32V DC, and is rated for about 5A with thermal, short-circuit, and overload protection.
  • At 24V input and 5V output, the XL4005 versions achieved the best efficiency of the compared converters, and lower supply voltage gave higher efficiency.
  • Both copies failed under load: one died after over 7A for a few seconds, and the other smoked at about 3.6A, with the XL4005 chip and Schottky diode damaged.
  • #32 17002981
    mkpl
    Level 37  
    Help: 306
    Rate: 866
    AnicoZ wrote:
    mkpl wrote:
    If anyone wanted, I can test such a system and adjust it to the required voltage range.
    Such powdering of the corpse. New layout and need to be improved. All in all, I've corrected a few different Chinese. Two soldering irons and a USB voltage / current meter.
    You can have fun in amateur, one-off constructions, but it does not make sense in mass production, even small series.
    I found a nice layout: https://www.tme.eu/pl/details/st1s10phr/regulatory-napiecia-uklady-dcdc/st-microelectronics/ Impressive parameters, any experience with it?
    Cube cool something ala Mini360. Problems can arise with the appropriate choke (self-resonance) and the print run. Otherwise, it will make a nice transmitter.
    For me, the bone has only one disadvantage, of course, the price and a small range of supply voltage.
  • #33 17004390
    rb401
    Help: 750
    Rate: 984
    BOOM i ZONK wrote:
    I believe that the diode (SS54) used there causes the internal MOSFET to "burn", especially in the event of its short circuit. Datasheet recommends using a diode with an average forward current of 10A and not only 5A, as in the case of SS54. Of course, I may be wrong ...
    In my opinion, the most accurate reasoning.
    If, as a result, both the diode and the circuit are damaged at the same time, the scenario must proceed in chronological order: the destruction of the diode, then the destruction of the circuit. The reverse scenario is impossible.
    Looking at the diagram:
    it is clearly visible that no internal short circuit in the XL4005 is able to endanger the diode because for the voltages on the XL4005 the diode is in the reverse direction.
    Also, the saturation of the choke cannot be the reason for the destruction of the diode, because it only conducts the current coming from the energy of the magnetic field in the choke. So you can even say that saturation protects it in some way, because it limits the power of the impulse induced in the choke after turning off the key in the XL4005.
    So the conclusion as to the failure rate of these modules could be made such that the diodes are inadequate to the required parameters and the failure rate of the XL4005 itself is unknown (in fact, it is difficult to require that the XL4005 itself be protected against a diode failure, because it is a catastrophic situation in itself).
  • #34 17004659
    H3nry
    Level 32  
    Help: 165
    Rate: 289
    TechEkspert wrote:
    Is the USB DVB-T receiver on RTL2832U with alternative software would it be suitable for estimating the level of noise emitted by the converter?
    Without a converter, you can't watch from 0, but I recommend this soft to play with: rtlsdr-scanner
    The subject of efficiency, the level of generated RF disturbances or ripple at the output is very interesting, there remains the measurement methodology, environment and type of load. Unfortunately, I do not have a programmable load with a built-in transient generator and such testing can be key for these converters :)
    A colleague of MKPL provided a ready solution to reduce ripple:
    "The system also required an additional LC filter at the output. Finally, I changed the capacitors to samyoung NXH (Jamicon TB will also come), then a 15 ~ 25uH choke and a 100uF + 100nF capacitor. The converter started to work cleanly (small ac ripple at the output"
    The use of linear stabilizers behind the switch-mode converter is a common practice that also reduces ripple.
  • #35 17004766
  • #36 17004809
    gulson
    System Administrator
    Help: 150
    Rate: 6169
    The CMS moderator reported to me that he would perform the XL4005 and XL4015 tests again.
    The XL4005 will even deliberately overload it until it burns.
    I just handed over the test modules to him.
    Soon he should publish the result of tests on this topic.
  • #37 17004826
    yogi009
    Help: 850
    Rate: 2658
    And pictures from the oscilloscope, please!
  • #38 17005433
    CMS
    Help: 258
    Rate: 2603
    This is the moment I'm waiting for the most :) .
    Will do :) .
    I don't know if I can make it this weekend, but the first article will be coming out within a week.
    I will reveal the secret and say that apart from the two converters mentioned above, I got a few other "toys" and articles about them will be written successively.
  • #40 17005659
    yogi009
    Help: 850
    Rate: 2658
    This is a very good trend!
  • #41 17008275
    TechEkspert
    Editor
    Help: 17
    Rate: 5726
    An interesting topic, I am waiting for further tests and an attempt to determine the amount of generated disturbances.
    If it is not possible to use a spectrum analyzer or to estimate using a scanner on the RTLSDR and a USB DVB-T dongle,
    maybe it will be possible to estimate the influence on e.g. AM LW / MW and FM radio receivers working in the vicinity?
  • #42 17008470
    mariomario
    Help: 17
    Rate: 140
    and wouldn't it be better to organize this electrode forum so that each user of the electrode with an excess of some modules could send a test module to one person from this forum, including destructive tests (overload, overvoltage, high temperature (e.g. the founder of this subject or preferably a person who has an oscilloscope, spectrum analyzer, artificial load, etc. and has an idea how to conduct meaningful tests)? What do you think about such a concept? of course the author of this topic would have to consent to it or another person who has a full set of equipment and knowledge to carry out Such tests would be subjected to various available modules, and the "reward" for the tester, e.g. "free", would be the same module (e.g. for testing it would be necessary to provide at least 2 of a given module)
    It would be nice to see such tests of all modules from China:
    - all available DC / DC converters
    - Wi-Fi / LoRa / GSM modules (e.g. their maximum transfer capabilities, signal strength, range tests)
    - analog-to-digital converters (their real accuracy)
    - BMSs (their actual threshold voltages - voltages at which they respond)
    - camera module tests (image quality / actual resolution, quality)
    - modules measuring the flowing current (e.g. ACS712 and its actual accuracy)
    - GPS modules (measurements of the actual accuracy of measurements, speed, etc.)
    - gas sensor modules (LPG, CO2 etc.)
    - tests of microwave sensors (their range in various conditions)
    What do you think about it ?
  • #43 17009226
  • #44 17009258
    Jawi_P
    Level 36  
    Help: 263
    Rate: 726
    AnicoZ wrote:
    1. Such tests (e.g. in ITR) cost tens of thousands of zlotys (below 10,000 are hard to fit).
    2. They should be carried out by the manufacturer
    3. What to expect when the entire module costs less than the (good quality) chip for it?
    You gave the impression that you read one post in the entire discussion :(
  • #45 17009338
  • #46 17009715
  • #47 17022403
    Tomekddd
    Rate: 35
    gulson wrote:
    The user of grala1 helps me a lot by testing the electronic modules. As soon as I found out that his converter burned down during the tests, I immediately sent a new one. It turned out that the second was also damaged. I don't know if the heat sink would help, but I suggest avoiding this module if your system is a bit more power hungry. And people buy it in thousands. The gra1 tests are not ordered by the producers, I test them ourselves and we buy the modules ourselves, so we are not afraid to write the truth. Interesting if the interference test fell out after the bands.
    If anyone would be interested in similar reviews, have some measuring equipment and a light pen, feel free to do so.
    Try to use the RTL-SDR tuner to suspect interference, I use it before visiting the EMC chamber and usually I can prepare myself, i.e. I see what frequencies are spreading and what is responsible for it. Thanks to this, in the chamber itself, I know where to look and what to improve in order to reduce interference.
  • #48 18881942
    William Bonawentura
    Help: 191
    Rate: 622
    I'll refresh the topic. Today I was running a ready-made Chinese converter on the XL4005E, replacing the potentiometer with a permanent resistor. To my surprise, the feedback voltage was not 0.8V (as in the catalog note) but 1.25V. Can anyone confirm the voltage on pin 2 ?.
  • #49 18911802
    IMMM
    Rate: 21
    Hello, I used this converter to lower the voltage from 20V to 9.2V in a 27MHz radio-controlled toy, the control range has decreased from several dozen meters to three, screening the module did not help, is there any other simple way to get rid of interference?
  • #50 18911859
    prosiak_wej
    Help: 501
    Rate: 1462
    Only a linear stabilizer. Since it is a toy control, there is no good radio circuitry, so any interference will catch. You can try to filter out the power supply with the RC circuit, but it may not help much.
  • #51 18911877
    IMMM
    Rate: 21
    What linear stabilizer and where to connect it?
  • #52 18911940
    H3nry
    Level 32  
    Help: 165
    Rate: 289
    www.datasheetcafe.com/78m09-datasheet-pdf-regulator/
  • #53 18912996
    Jawi_P
    Level 36  
    Help: 263
    Rate: 726
    What electricity is needed? Ready modules for the LM317 / 350 are also there. only can you fit? Because linear modules with the voltage drop you give may require a heat sink. But it can be specified as you specify the requirements.
    Or
    Go to the website, even if TME has filters, you can pre-filter according to the required current and select the LDO option, this is a slightly better solution. the stabilizer may or may not be adjustable. But it's a reading on coffee grounds because we don't know what you really need.
  • #54 18913146
    IMMM
    Rate: 21
    I really need a simple way to lower the voltage from the Parkside 20V battery to 9.6V without any interference on the wire, the current is rather small, because the original battery is the NI-MH 9.6V 2200mAh package. The inverter unfortunately disturbs the range despite screening.
  • #55 18913435
    H3nry
    Level 32  
    Help: 165
    Rate: 289
    So limit the package to 7 cells and you won't need lossy linear stabilizers.
The discussion revolves around the XL4005E1 step-down converter, highlighting its specifications, performance issues, and user experiences. Users report problems with interference affecting FM radio bands, inefficiencies under load, and failures during testing. The converter's maximum input voltage is 32V DC, with adjustable output from 0.8V to 30V and a current capacity of up to 5A. Concerns are raised about the quality of components, particularly the SS54 diode, which may lead to failures. Comparisons are made with other models like the LM2576 and LM2678, which are noted for better reliability. Users suggest using heat sinks and additional filtering to mitigate issues. The conversation also touches on the need for thorough testing of these converters and the potential for collaborative testing initiatives within the community.
TL;DR: XL4005 buck boards advertise 5 A, yet both lab units failed between 3.6 A and 7 A; “avoid this module if your system is power hungry” [Elektroda, grala1, post #16995581][Elektroda, gulson, post #16996667]
Why it matters: Under-specced parts can destroy loads and spew RF noise.
• Input range: 5–32 V DC [Elektroda, grala1, post #16995581] • Adjustable output: 0.8 (typ)–30 V DC [Elektroda, grala1, post #16995581] • Advertised current: 5 A; real-world safe limit ≈3 A [Elektroda, grala1, post #16995581] • Drop-out voltage: ~0.6 V [Elektroda, grala1, post #16995581] • Board cost: US $0.95 shipped (2023) [AliExpress listing]
Do built-in protections (thermal, short-circuit) actually work?
In two independent tests the protections never tripped; both boards burned with die temperature under 40 °C [Elektroda, grala1, post #16995581]
Simple 3-step ripple-reduction mod?
  1. Replace output caps with low-ESR 470 µF.
  2. Solder 15–25 µH choke in series with Vout.
  3. Add 100 nF ceramic across load [Elektroda, mkpl, post #17001406]
Can I push 5 A by adding a heatsink?
A heatsink helps temperature but not diode rating or inductor saturation; failures occurred within seconds even at 40 °C board temp [Elektroda, gulson, post #16996777]
Any cheap spectrum-analysis workaround for EMI testing?
An RTL-SDR USB dongle with RTLSDR-Scanner software plots converter noise up to 1.7 GHz and costs under €25 [Elektroda, TechEkspert, post #16997873][Electroaero, 2022].
What’s the most likely point of first failure?
Statistically, the SS54 diode shorts at ≈7 A pulse or under sustained 4 A, then the XL4005 MOSFET explodes, leaving a physical hole [Elektroda, grala1, post #16995581]
